Posted (edited)
Hi,
it seem that Armbian_community_25.5.0-trunk.185_Orangepi5-max build break the HDMI output, in gnome and bookworm.
I try to boot the two with SD card.
existing sytem that make an apt upgrade, the 185 also seem to broke all the system.
regards,
Edited by philippe perquin
  • philippe perquin changed the title to 25.5.0-trunk.185_Orangepi5-max build break the HDMI output from Mar 6, 2025
Could you please share your dmesg log? Which kernel version are you using? Please provide some information to help us understand the issue.
Quick update
New builds dated 17th March don't work either. Exactly the same problem - no boot. All I get is a flashing blue light. The February build works fine - no wifi - but at least it boots
Posted (edited)
I can confirm that 25.5.0-trunk.256 and following work but all trunks after 256 (301 and 334) break WiFi and BT.
Edited by Glibbr
47 minutes ago, mando said:
How do I get a log if the OS won't evenstart to boot?
As long as the board isn't dead it is starting to boot.  That is why Werner directed you to how to capture the uboot booting messages via a uart connection to the board.
