darkdrgn2k Posted September 1, 2017 Posted September 1, 2017 How often do nightly builds get added. I had a kernel support committed for meshpoint to the Orange Pi H5 repo but there is still no new download and its been over a month.
Igor Posted September 1, 2017 Posted September 1, 2017 Images manually, while deb packages are done daily. https://beta.armbian.com/
darkdrgn2k Posted September 1, 2017 Author Posted September 1, 2017 Any chance i could ask you guys to do a nightly build for orangepizeroplus2-h5 We are using it for testing on our mesh project (i know its WIP as i said for TESTING ) and would love to have the instructions to be in line with the other boards we are testing. 1
Bubba Posted September 1, 2017 Posted September 1, 2017 To get what you want you should build it yourself. It is really easy now that These folks here have done all the heavy lifting for us. https://docs.armbian.com/Developer-Guide_Build-Preparation/ And you should donate some funds to the project if you are going to use the work.
darkdrgn2k Posted September 1, 2017 Author Posted September 1, 2017 Yes i tried doing the build and it worked the first time sadly the second time i tried it it wont boot although it MAY be because im running 16.04.3 so i have to VM ware it and try again. It would just be nice for everything to be in "one spot" but yeh. As for donation, the project has no money, (its completely volunteer) and in its infancy, but maybe ill throw something you guyzes way, its a solid project Thanks for the work!
Igor Posted September 1, 2017 Posted September 1, 2017 If you want to test latest builds, it's also fairly ok to download just any available image for this board, switch to beta repository and update. It will work in most cases.
darkdrgn2k Posted September 1, 2017 Author Posted September 1, 2017 Good to know, but will it update the KERNEL or do i have to copy the /boot and /usr/lib/modules ? The missing flag was in the kenrel:/
Igor Posted September 1, 2017 Posted September 1, 2017 option one: edit /etc/apt/sources.list.d/armbian.list and change apt to beta, save, apt update, apt upgrade, reboot option two: armbian-config, switch to beta (nighlty or daily build), reboot Nothing else. If kernel flag is changed in this file: https://github.com/armbian/build/blob/master/config/kernel/linux-sun50i-dev.config then you should notice changes. (this config is responsible for the kernel you are using).
darkdrgn2k Posted September 2, 2017 Author Posted September 2, 2017 apt upgrade worked but then it would not boot seems to have lost things like the driver tree
darkdrgn2k Posted September 2, 2017 Author Posted September 2, 2017 It was looking for /boot/dtb/allwinner/allwinner..... where all the files where in boot/dtb/allwinner/.. so i moved them and now it get the same thing i got when i compiled it myself Spoiler 0 38518 bytes read in 130 ms (289.1 KiB/s) Unknown command 'bmp' - try 'help' switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3362 bytes read in 191 ms (16.6 KiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 116 bytes read in 159 ms (0 Bytes/s) 23204 bytes read in 522 ms (43 KiB/s) ** File not found /boot/dtb/allwinner/overlay/sun50i-h5-fixup.scr ** 4992073 bytes read in 455 ms (10.5 MiB/s) 12288008 bytes read in 890 ms (13.2 MiB/s) ## Loading init Ramdisk from Legacy Image at 4fe00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 4992009 Bytes = 4.8 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Loading Ramdisk to 49b3d000, end 49fffc09 ... OK reserving fdt memory region: addr=4fa00000 size=6c000 Loading Device Tree to 0000000049ace000, end 0000000049b3cfff ... OK Starting kernel ... Loading, please wait... starting version 229 Begin: Loading essential drivers ... done. Begin: Running /scripts/init-premount ... done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Waiting for root file system ... Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done.
Igor Posted September 2, 2017 Posted September 2, 2017 Well, my recipe should work on stable builds, but in beta areas, there is no warranty - it might or not ... things are WIP. Try altering boot device in /boot/armbianEnv.txt or simply pay attention to build log changes https://github.com/armbian/build/commits/master
darkdrgn2k Posted September 12, 2017 Author Posted September 12, 2017 On 2017/09/02 at 1:20 AM, Igor said: Well, my recipe should work on stable builds, but in beta areas, there is no warranty - it might or not ... things are WIP. Try altering boot device in /boot/armbianEnv.txt or simply pay attention to build log changes https://github.com/armbian/build/commits/master Latest git pull fixed the boot problem but now i list usb im guesrsint DTB issue so digging i go thanks for all the help (i know its DIY and even if it wasnt you would be under no obligation to give it so i appreciate it!)
datsuns Posted September 14, 2018 Posted September 14, 2018 On 9/1/2017 at 8:20 AM, Igor said: If you want to test latest builds, it's also fairly ok to download just any available image for this board, switch to beta repository and update. It will work in most cases. Sorry if this is too noobish but how do I switch to the beta repository?
