jwalds Posted March 19 Posted March 19 (edited) Hello! I am trying to get the cedar_ve device working for OPIZ2W. I am currently running this image: Orangepizero2w_1.0.4_ubuntu_noble_server_linux6.1.31 My uname -a: Linux orangepizero2w 6.1.31-sun50iw9 #1.0.4 SMP Wed Oct 9 13:39:53 CST 2024 aarch64 aarch64 aarch64 GNU/Linux To do this I am trying to follow these steps: 1. Modify a dts for OPIZ2W to include cedar_ve. 2. Donwloan cedrus driver and build it. 3. Compile modified ffmpeg with x264cedrus support Have anyone tried this? I have only found builds for recent kernel for the H3 CPU, none for the H618. I am looking for a DTS that supports cedar_ve for Orange Pi Zero 2W or any other things that can point me in the right direction. Edited March 19 by jwalds 0 Quote
robertoj Posted March 20 Posted March 20 (edited) Have you ever seen the OPIZ2w (or OPIZ3) doing HW video encoding in another Linux? Where did you find this cedrus driver? What does the website claim it can do? Where did your OS image come from? What DTS modifications did you mean? Why not just a DTS overlay? Edited March 20 by robertoj 0 Quote
jwalds Posted March 20 Author Posted March 20 I have not seen any one of them do it, but I assume they possess that capability since it is mentioned in the datasheet for H616 here: https://linux-sunxi.org/images/b/b9/H616_Datasheet_V1.0_cleaned.pdf I am looking for a DTS that has the correct parameters for the cedar driver (correct registers, memory etc) for the H618. I am absolutely open to doing a DTS overlay if that would make work easier. 0 Quote
robertoj Posted March 20 Posted March 20 This is the closest I can find https://forum.armbian.com/topic/26551-video-encoder-using-mainline-kernel/ https://gregdavill.com/posts/allwinner-s3-videoencoders/ https://linux-sunxi.org/Cedrus 0 Quote
Ryzer Posted March 20 Posted March 20 Hi Jwalds, It's definitely possible as there is Hardware support for it however the software support does not currently exist within the current Cedrus driver. To the best of my knowledge there is currently no mainline video encoding support for any Allwinner SOC. There are problem some efforts to get it working though, one such is: https://bootlin.com/blog/open-source-linux-kernel-support-for-the-allwinner-v3-v3s-s3-h-264-video-encoder/ while target at the V3 it should set the groundwork for getting encoding supported on other Allwinner SOCs. If there is already some form of decoding support then there should already be the video engine / video codec engine node within the main H616 dts. While I prefer overlays there are certain limits meaning it has to been integrated into the main dts rather than via an overlay. Found this out recently myself when exploring G2D hardware block present in some Allwinner SOCs. Best of luck Ryzer 0 Quote
going Posted March 21 Posted March 21 Greetings to all participants. Before configuring the software, we need to properly configure the hardware nodes on the chip that are responsible for video/audio processes. Turn on the power, make a reset, adjust the clock, etc. This should be done by the kernel driver. Currently, in the sunxi(64) family for h616-h618 chips, I see a mess in the drivers. There are several of them for the same thing. They were added by different people at different times. Today, these drivers do not want to work correctly. On at least one BPI-m4-berry (h618) board. I'm trying to fix this situation right now. Please write here whatever you think is necessary to speed up the process. After applying all the sunxi-6.12 patches, the core looks like sunxi-6.12-rebase sunxi-6.13-rebase 0 Quote
jwalds Posted March 21 Author Posted March 21 Thanks everyone for the answers! Upon looking at the many patches you posted there going, this one sticks out for me https://github.com/armbian/build/blob/main/patch/kernel/archive/sunxi-6.13/patches.armbian/arm64-dts-allwinner-sun50i-h616-Add-VPU-node.patch Maybe that one would work for H618 also to enable the VPU? Would that patch in itself be sufficient to compile and enable the cedrus-driver? 0 Quote
Ryzer Posted March 21 Posted March 21 Hi Jwalds, From what I can tell looking at the sun50i-h618-orangepi-zero2w.dts it gets it's definitions from the sun50i-h616.dtsi so it's a start but support would also need to be added to the cedrus driver to appropriately support the H616 SOC. Now I did notice this patch: https://github.com/armbian/build/blob/main/patch/kernel/archive/sunxi-6.13/patches.armbian/drv-staging-media-sunxi-cedrus-add-H616-variant.patch however I do not know if this will actually work. If you look at the kernel configuration file you need to ensure that the cedrus module is set. Best of luck Ryzer 0 Quote
going Posted March 22 Posted March 22 8 часов назад, Ryzer сказал: you need to ensure that the cedrus module is set boot> grep -n CEDRUS config-* 7001:CONFIG_VIDEO_SUNXI_CEDRUS=m leo@bananapim4berry:~$ dmesg | grep cedrus [ 11.499288] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned. [ 11.522089] cedrus 1c0e000.video-codec: Device registered as /dev/video0 leo@bananapim4berry:~$ ls -al /dev/video0 crw-rw----+ 1 root video 81, 0 �м�а�р 18 11:53 /dev/video0 leo@bananapim4berry:~$ uname -r 6.13.7-edge-sunxi64 leo@bananapim4berry:~$ lsmod | grep cedrus sunxi_cedrus 49152 0 v4l2_mem2mem 28672 1 sunxi_cedrus videobuf2_dma_contig 20480 1 sunxi_cedrus videobuf2_v4l2 20480 2 sunxi_cedrus,v4l2_mem2mem videodev 249856 3 sunxi_cedrus,videobuf2_v4l2,v4l2_mem2mem videobuf2_common 53248 5 sunxi_cedrus,videobuf2_dma_contig,videobuf2_v4l2,v4l2_mem2mem,videobuf2_memops mc 53248 5 sunxi_cedrus,videodev,videobuf2_v4l2,videobuf2_common,v4l2_mem2mem P.S. add more 0 Quote
going Posted March 22 Posted March 22 sunxi-6.12: leo@bananapim4berry:~$ uname -r 6.12.19-current-sunxi64 leo@bananapim4berry:~$ dmesg | grep -iE 'audio|ahub|video|codec|hdmi|drm' [ 0.099396] /soc/hdmi@6000000: Fixed dependency cycle(s) with /soc/tcon-top@6510000 [ 0.099455] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/hdmi@6000000 [ 0.104244] /soc/hdmi@6000000: Fixed dependency cycle(s) with /soc/tcon-top@6510000 [ 0.104620] /soc/hdmi@6000000: Fixed dependency cycle(s) with /soc/tcon-top@6510000 [ 0.104780] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/hdmi@6000000 [ 0.107433] /soc/hdmi@6000000: Fixed dependency cycle(s) with /connector [ 0.107516] /connector: Fixed dependency cycle(s) with /soc/hdmi@6000000 [ 1.946257] sun4i-drm display-engine: bound 1100000.mixer (ops 0xffff80008119ae90) [ 1.946454] sun4i-drm display-engine: bound 6510000.tcon-top (ops 0xffff80008119fc60) [ 1.946768] sun4i-drm display-engine: bound 6515000.lcd-controller (ops 0xffff800081197ab0) [ 1.947062] sun8i-dw-hdmi 6000000.hdmi: Detected HDMI TX controller v2.12a with HDCP (DWC HDMI 2.0 TX PHY) [ 1.949760] sun8i-dw-hdmi 6000000.hdmi: registered DesignWare HDMI I2C bus driver [ 1.950030] sun4i-drm display-engine: bound 6000000.hdmi (ops 0xffff800081199f58) [ 1.950535] [drm] Initialized sun4i-drm 1.0.0 for display-engine on minor 0 [ 1.950566] sun8i-dw-hdmi 6000000.hdmi: read_hpd result: 1 [ 2.438265] sun8i-dw-hdmi 6000000.hdmi: EVENT=plugin [ 4.012109] sun4i-drm display-engine: [drm] fb0: sun4i-drmdrmfb frame buffer device [ 9.311566] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm... [ 9.583263] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 9.590683] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm. [ 11.222612] [drm] Initialized panfrost 1.2.0 for 1800000.gpu on minor 1 [ 11.336128] videodev: Linux video capture interface: v2.00 [ 11.672804] cedrus 1c0e000.video-codec: Device registered as /dev/video0 [ 36.607644] sun8i-dw-hdmi 6000000.hdmi: EVENT=plugin [ 37.501202] sun8i-dw-hdmi 6000000.hdmi: EVENT=plugin [ 39.278755] hdmi-audio-codec hdmi-audio-codec.5.auto: Only one simultaneous stream supported! [ 39.278791] hdmi-audio-codec hdmi-audio-codec.5.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -22 [ 39.278816] ahub_plat-i2s-hifi: ASoC: error at __soc_pcm_open on ahub_plat-i2s-hifi: -22 [ 57.559744] hdmi-audio-codec hdmi-audio-codec.5.auto: Only one simultaneous stream supported! [ 57.559772] hdmi-audio-codec hdmi-audio-codec.5.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -22 [ 57.559789] ahub_plat-i2s-hifi: ASoC: error at __soc_pcm_open on ahub_plat-i2s-hifi: -22 pkg for test: sunxi64-6.12.19 0 Quote
going Posted March 22 Posted March 22 15 часов назад, jwalds сказал: Would that patch in itself be sufficient to compile and enable the cedrus-driver? The driver is present. You can test this by downloading the packages from the link above. 0 Quote
jwalds Posted March 22 Author Posted March 22 Okay, I have the driver loaded: root@orangepizero2w:/boot# dmesg | grep cedrus [ 8.578154] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned. [ 8.580382] cedrus 1c0e000.video-codec: Device registered as /dev/video2 I also did this: root@orangepizero2w:/boot# v4l2-ctl --all --device /dev/video2 Driver Info: Driver name : cedrus Card type : cedrus Bus info : platform:cedrus Driver version : 6.1.31 Capabilities : 0x84208000 Video Memory-to-Memory Streaming Extended Pix Format Device Capabilities Device Caps : 0x04208000 Video Memory-to-Memory Streaming Extended Pix Format Media Driver Info: Driver name : cedrus Model : cedrus Serial : Bus info : platform:cedrus Media version : 6.1.31 Hardware revision: 0x00000000 (0) Driver version : 6.1.31 Interface Info: ID : 0x0300000c Type : V4L Video Entity Info: ID : 0x00000001 (1) Name : cedrus-source Function : V4L2 I/O Pad 0x01000002 : 0: Source Link 0x02000008: to remote pad 0x1000004 of entity 'cedrus-proc' (Video Decoder): Data, Enabled, Immutable Priority: 2 Format Video Capture: Width/Height : 16/32 Pixel Format : 'ST12' (Y/UV 4:2:0 (32x32 Linear)) Field : None Bytes per Line : 32 Size Image : 2048 Colorspace : Default Transfer Function : Default (maps to Rec. 709) YCbCr/HSV Encoding: Default (maps to ITU-R 601) Quantization : Default (maps to Full Range) Flags : Format Video Output: Width/Height : 16/32 Pixel Format : 'MG2S' (MPEG-2 Parsed Slice Data) Field : None Bytes per Line : 0 Size Image : 1024 Colorspace : Default Transfer Function : Default (maps to Rec. 709) YCbCr/HSV Encoding: Default (maps to ITU-R 601) Quantization : Default (maps to Full Range) Flags : Codec Controls h264_profile 0x00990a6b (menu) : min=0 max=4 default=2 value=2 (Main) 0: Baseline 1: Constrained Baseline 2: Main 4: High Stateless Codec Controls h264_decode_mode 0x00a40900 (menu) : min=0 max=0 default=0 value=0 (Slice-Based) 0: Slice-Based h264_start_code 0x00a40901 (menu) : min=0 max=0 default=0 value=0 (No Start Code) 0: No Start Code h264_sequence_parameter_set 0x00a40902 (h264-sps): value=unsupported payload type flags=has-payload h264_picture_parameter_set 0x00a40903 (h264-pps): value=unsupported payload type flags=has-payload h264_scaling_matrix 0x00a40904 (h264-scaling-matrix): value=unsupported payload type flags=has-payload h264_prediction_weight_table 0x00a40905 (h264-pred-weights): value=unsupported payload type flags=has-payload h264_slice_parameters 0x00a40906 (h264-slice-params): value=unsupported payload type flags=has-payload h264_decode_parameters 0x00a40907 (h264-decode-params): value=unsupported payload type flags=has-payload vp8_frame_parameters 0x00a409c8 (vp8-frame): value=unsupported payload type flags=has-payload mpeg_2_sequence_header 0x00a409dc (mpeg2-sequence): value=unsupported payload type flags=has-payload mpeg_2_picture_header 0x00a409dd (mpeg2-picture): value=unsupported payload type flags=has-payload mpeg_2_quantisation_matrices 0x00a409de (mpeg2-quantisation): value=unsupported payload type flags=has-payload hevc_sequence_parameter_set 0x00a40a90 (hevc-sps): value=unsupported payload type flags=has-payload hevc_picture_parameter_set 0x00a40a91 (hevc-sps): value=unsupported payload type flags=has-payload hevc_slice_parameters 0x00a40a92 (hevc-slice-params): elems=1 dims=[1] flags=has-payload, dynamic-array hevc_scaling_matrix 0x00a40a93 (hevc-scaling-matrix): value=unsupported payload type flags=has-payload hevc_decode_parameters 0x00a40a94 (hevc-decode-params): value=unsupported payload type flags=has-payload hevc_decode_mode 0x00a40a95 (menu) : min=0 max=0 default=0 value=0 (Slice-Based) 0: Slice-Based hevc_start_code 0x00a40a96 (menu) : min=0 max=0 default=0 value=0 (No Start Code) 0: No Start Code hevc_entry_point_offsets 0x00a40a97 (u32) : min=0 max=4294967295 step=1 default=0 elems=1 dims=[256] flags= has-payload, dynamic-array I take that the driver is loaded successfully then, so the next step would be to build ffmpeg with cedrus support? 0 Quote
going Posted March 22 Posted March 22 33 минуты назад, jwalds сказал: I take that the driver is loaded successfully then, so the next step would be to build ffmpeg with cedrus support? But will the system installed from the package work? I can't verify it. The internet is not working on my board. In other words. If you just install the necessary packages. 0 Quote
Ryzer Posted March 22 Posted March 22 Hi All, Good to hear that the cedrus driver appears to be initialized correctly. It has been a while since I last tried hardware accelerated playback and unfortunately did not have much success. From what I remember from another topic is that in order to utilize the cedrus, ffmpeg has to be compiled with v4l2m2m (--enable-v4l2-m2m) support in place. From what I can tell this is not set in the system packaged version of ffmpeg. Hope this helps Ryzer 1 Quote
jwalds Posted March 23 Author Posted March 23 I am not sure where I can find a version of ffmepg that supports the cedrus driver and that works with the some form of modern version of ffmpeg source tree. Anyone who knows? 0 Quote
Ryzer Posted March 23 Posted March 23 Hi Jwalds, Looking back I just realised that you are still using kernel-6.1, which is now considered "legacy" and no longer as actively supported. You are likely to have better chance of success with an image built around at least kernel 6.6 which has a more developed version of the cedrus driver. To clarify a further more the cedrus driver is exposed via the v4l framework so this is what ffmpeg has to be built with support for. Now I managed to successful build ffmpeg on my own board, a Pcduino2 (A10) which admittedly is much older than H616 but shares the same cedrus driver and some of the same codecs. In my case I found that ffmpeg failed when attempting hardware decoding. Looking into the debug output, ffmpeg was detecting the cedrus driver but apparently running into somekind of formatting issue. I don't know of it is caused by the demo clip I was using or an underlying issue in the driver. best of luck Ryzer 0 Quote
Nick A Posted March 23 Posted March 23 Maybe this patch will make ffmpeg-v4l2 work https://github.com/NickAlilovic/build/blob/v20241125/patch/kernel/archive/sunxi-6.10/patches.armbian/0551-media-cedrus-Implement-AFBC-YUV420-formats-for-H265.patch 0 Quote
going Posted March 24 Posted March 24 9 часов назад, Ryzer сказал: Looking back I just realised that you are still using kernel-6.1, which is now considered "legacy" and no longer as actively supported. You are likely to have better chance of success with an image built around at least kernel 6.6 which has a more developed version of the cedrus driver. patch/kernel/archive/sunxi-6.1 It will be deleted tomorrow. patch/kernel/archive/sunxi-6.6 This is frozen on version v6.6.75 as stable. It will be moved to LEGACY tomorrow and will no longer be supported. 1 Quote
going Posted March 24 Posted March 24 7 часов назад, Nick A сказал: Maybe this patch will make ffmpeg-v4l2 work https://github.com/NickAlilovic/build/blob/v20241125/patch/kernel/archive/sunxi-6.10/patches.armbian/0551-media-cedrus-Implement-AFBC-YUV420-formats-for-H265.patch There are no changes in the driver between kernel versions 6.10 and 6.12. I think this patch can be added to the current (6.12) kernel. In your opinion, what else can be added or which parts should I pay special attention to? 0 Quote
Nick A Posted March 25 Posted March 25 (edited) Here's some of the media patches not included in the official armbian build. I tested ffmpeg-v4l2 on my unofficial build and works with only a few frame drops. I'm compiling an image for my TV Box using the official build and these patches. I'll let you know if it works. https://github.com/NickAlilovic/build/tree/v20250306/patch/kernel/archive/warpme-6.12 0553-media-cedrus-Don-t-CPU-map-source-buffers.patch 0554-media-Add-NV12-and-P010-AFBC-compressed-formats.patch 0555-media-cedrus-add-format-filtering-based-on-depth-and.patch 0556-media-cedrus-Implement-AFBC-YUV420-formats-for-H265.patch Edited March 25 by Nick A 0 Quote
Nick A Posted March 25 Posted March 25 (edited) The patches posted above and @jock ffmpeg-v4l2request. H264 hardware decoding now works. I'm using debian bookwarm, X11, xfce. Just follow jocks install instructions in the link below. Getting errors with 1080p mp4 video's. I fixed this before by changing the cma to a higher value (cma=512M) in the boot.cmd file. Quote DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource Quote setenv bootargs "root=${rootdev} rootwait rootfstype=${rootfstype} ${consoleargs} consoleblank=0 loglevel=${verbosity} ubootpart=${partuuid} usb-storage.quirks=${usbstoragequirks} ${extraargs} ${extraboardargs} cma=512M" 720p works ok. Quote nick@transpeed-8k618-t:~/Downloads$ mpv SampleVideo_1280x720_1mb.mp4 (+) Video --vid=1 (*) (h264 1280x720 25.000fps) (+) Audio --aid=1 (*) (aac 6ch 48000Hz) Using hardware decoding (drm). [W][00188.323572] pw.conf | [ conf.c: 939 try_load_conf()] can't load config client.conf: No such file or directory [E][00188.323871] pw.conf | [ conf.c: 963 pw_conf_load_conf_for_context()] can't load default config client.conf: No such file or directory AO: [pulse] 48000Hz 5.1 6ch float VO: [gpu] 1280x720 drm_prime[nv12] AV: 00:00:05 / 00:00:05 (98%) A-V: 0.000 Dropped: 1 Exiting... (End of file) Edited March 25 by Nick A 1 Quote
Nick A Posted March 25 Posted March 25 (edited) I haven't tested encoding. You probably need something like this. https://github.com/bootlin/v4l2-cedrus-enc-test I'm still having issues playing 1080p videos shuttering and dropped frames with the official build. Trying to find more patches that might be missing. Works fine on my build. I'm using warpme-6.12 patches. https://github.com/NickAlilovic/build/tree/v20250329 Edited March 29 by Nick A 0 Quote
Ryzer Posted March 25 Posted March 25 (edited) Hi Nick, Thanks for the suggestion, after doing a bit more research it does seem like v4l2-request is better suited. I did attempt following jocks instructions but I could not add the apt repo as it yielded a network unreachable error. AS a work around I will try with Kwiboo's instead: https://github.com/Kwiboo/FFmpeg as this also has v4l2-request support. Thanks for providing the patches, I am interested to see how they will preform on the A10, I will be sure to implement them next time I get round to a system build. Once I get a positive indication that hardware acceleration is working I will trying increasing the CMA size but I may need to change screens. My current system only has a cma of 96MB, in the past I found if I set it too high it will stop displaying at all on my 4K monitor. @jwalds I dont believe so, I have yet to find a patch that adds encoding to the cedrus driver. A possible start point would be here: https://github.com/bootlin/linux/tree/cedrus/h264-encoding as it looks like some work has at least started. just to add testing with MPV did not exactly yield great results, the image seems to bounce up and down for a few seconds then freezes as the system appears to crash Quote [vo/gpu] VT_GETMODE failed: Inappropriate ioctl for device [vo/gpu/opengl] Failed to set up VT switcher. Terminal switching will be unavailable. [vo/gpu/opengl] Initializing KMS [vo/gpu/opengl] Picked DRM card 0, primary node /dev/dri/card0 as the default. [vo/gpu/opengl] Driver: sun4i-drm 1.0.0 (0) [vo/gpu/opengl/kms] Connector 67 currently connected to encoder 66 [vo/gpu/opengl/kms] Selected Encoder 66 with CRTC 48 [vo/gpu/opengl/kms] Could not find any preferred mode. Picking the first mode. [vo/gpu/opengl/kms] Selected mode: 1920x1080 (1920x1080@60.00Hz) [vo/gpu/opengl] DRM Atomic support found [vo/gpu/opengl/kms] Using overlay plane 36 as draw plane [vo/gpu/opengl/kms] Using primary plane 32 as drmprime plane [vo/gpu] GBM_FORMAT_ARGB8888 supported by draw plane. [vo/gpu] Supported modifier: 0x0 [vo/gpu] Creating GBM device [vo/gpu] Initializing GBM surface (1920 x 1080) [vo/gpu/opengl] Initializing EGL [vo/gpu/opengl] EGL_VERSION=1.4 [vo/gpu/opengl] EGL_VENDOR=Mesa Project [vo/gpu/opengl] EGL_CLIENT_APIS=OpenGL OpenGL_ES [vo/gpu/opengl] Trying to create Desktop OpenGL context. [vo/gpu/opengl] Attempting to find EGLConfig matching GBM_FORMAT_ARGB8888 [vo/gpu/opengl] Found matching EGLConfig for GBM_FORMAT_ARGB8888 [vo/gpu/opengl] Initializing EGL surface [vo/gpu] GL_VERSION='2.1 Mesa 22.3.6' [vo/gpu] Detected desktop OpenGL 2.1. [vo/gpu] GL_VENDOR='lima' [vo/gpu] GL_RENDERER='Mali400' [vo/gpu] GL_SHADING_LANGUAGE_VERSION='1.20' [vo/gpu] Loaded extension GL_ARB_map_buffer_range. [vo/gpu] Loaded extension GL_ARB_vertex_array_object. [vo/gpu] Loaded extension GL_ARB_texture_rg. [vo/gpu] Loaded extension GL_ARB_sync. [vo/gpu] Loaded extension GL_ARB_invalidate_subdata. [vo/gpu] Loaded extension GL_ARB_get_program_binary. [vo/gpu] Loaded extension GL_ARB_buffer_storage. [vo/gpu] Loaded extension GL_ARB_debug_output. [vo/gpu] Loaded extension GL_KHR_debug. [vo/gpu/opengl] Preparing framebuffer [vo/gpu/opengl] GBM surface using modifier 0x0 [vo/gpu] crtc is not VRR capable [vo/gpu/opengl] Could not find path to render node. VAAPI hwdec will be disabled [vo/gpu] Monitor pixel aspect: 1 [vo/gpu] Disabling HDR peak computation (one or more of the following is not supported: compute shaders=0, SSBO=0). [vo/gpu] No advanced processing required. Enabling dumb mode. [vo/gpu] Assuming 60.000000 FPS for display sync. [vd] Container reported FPS: 24.000000 [vd] Codec list: [vd] h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [vd] h264_v4l2m2m (h264) - V4L2 mem2mem H.264 decoder wrapper [vd] Opening decoder h264 [vd] Unsupported hwdec: drm [vd] No hardware decoding available for this codec. [vd] Using software decoding. [vd] Detected 1 logical cores. [vd] Requesting 1 threads for decoding. [vd] Selected codec: h264 (H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10) [vf] User filter list: [vf] (empty) [cplayer] Starting playback... [cplayer] Set property: shared-script-properties -> 1 [vd] DR failed - disabling. [vd] Using software decoding. [vd] Decoder format: 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/auto CL=mpeg2/4/h264 [vd] Using container aspect ratio. [vf] [in] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [userdeint] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [userdeint] (disabled) [vf] [autorotate] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [autorotate] (disabled) [vf] [convert] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [convert] (disabled) [vf] [out] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [cplayer] VO: [gpu] 1920x1080 yuv420p Thanks Ryzer Edited March 25 by Ryzer 0 Quote
Nick A Posted March 25 Posted March 25 (edited) Hi @Ryzer I had the same issue with network unreachable error. looks like they updated the repository (25-Mar-2025 16:19). I guess it's still updating? Everything you need is here. http://apt.undo.it:7241/debian/pool/main/f/ffmpeg-v4l2request/ Edit: ffmpeg-v4l2request repository works now. They reverted back to the original files. I don't see the (25-Mar-2025 16:19) updates anymore. I tried all these patches and they all applied cleanly. I haven't noticed any "DRM_IOCTL_MODE_CREATE_DUMB" errors. I don't need the cma changes anymore. 1080p videos still shuttering using the official build and these patches. https://github.com/NickAlilovic/build/tree/v20250306/patch/kernel/archive/warpme-6.12 patches.armbian/0126-drm-panfrost-dvfs-switch-gov-to-performance.patch patches.armbian/0553-media-cedrus-Don-t-CPU-map-source-buffers.patch patches.armbian/0554-media-Add-NV12-and-P010-AFBC-compressed-formats.patch patches.armbian/0555-media-cedrus-add-format-filtering-based-on-depth-and.patch patches.armbian/0556-media-cedrus-Implement-AFBC-YUV420-formats-for-H265.patch patches.armbian/0557-media-cedrus-Increase-H6-clock-rate.patch patches.armbian/0558-media-verisilicon-g2-fix-chroma-offset-calculation.patch patches.armbian/0563-hantro-Add-quirk-for-NV12-NV12_4L4-capture-format.patch Edited March 26 by Nick A 0 Quote
robertoj Posted March 26 Posted March 26 (edited) Thank you for sharing an image for opiz3 I also downloaded and built the code from your github (branch 202503060) as zip file, so I can start with a minimal image, and work the way up... since I always want a fast booting GUI with openbox... and eventually labwc Edited March 26 by robertoj 0 Quote
robertoj Posted March 27 Posted March 27 (edited) Can somebody with an orangepi zero 3 try my dts? It seems that either the patches in NickA's codebase make it incompatible, or linux 6.12 changed the DTS. https://forum.armbian.com/topic/47971-driving-the-ili9488-lcd-40-inch-cheap-chinese-clone/#findComment-208446 ili9488-ads7846.dts: Spoiler /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h616"; fragment@0 { target = <&spi1>; __overlay__ { status = "okay"; cs-gpios = <&pio 7 9 0>,<&pio 2 15 0>; // PH9=CS0 for lcd, PC15=CS1 for touch panel: panel@0 { compatible = "panel-mipi-dbi-spi"; reg = <0>; spi-max-frequency = <40000000>; width-mm=<84>; height-mm=<56>; reset-gpios = <&pio 2 14 0>; // PC14 dc-gpios = <&pio 2 7 0>; // PHC7 write-only; format = "b6x2g6x2r6x2"; panel-timing { hactive = <480>; vactive = <320>; hback-porch = <0>; vback-porch = <0>; clock-frequency = <0>; hfront-porch = <0>; hsync-len = <0>; vfront-porch = <0>; vsync-len = <0>; }; }; ads7846: ads7846@1 { compatible = "ti,ads7846"; reg = <1>; pinctrl-names = "default"; spi-max-frequency = <1000000>; interrupt-parent = <&pio>; interrupts = <2 10 2>; /* PC10 - IRQ */ pendown-gpio = <&pio 2 10 1>; /* PC10 */ /* OPTIONS */ ti,x-min = /bits/ 16 <0>; ti,y-min = /bits/ 16 <0>; ti,x-max = /bits/ 16 <0xFFF>; ti,y-max = /bits/ 16 <0xFFF>; ti,pressure-min = /bits/ 16 <0>; ti,pressure-max = /bits/ 16 <0xFFF>; ti,x-plate-ohms = /bits/ 16 <400>; ti,swap-xy = <1>; }; }; }; }; I am able to do #armbian-add-overlay ili9488-ads7846.dts normally with armbian official and linux 6.11 But with this github's armbian build, I get in uboot: Applying user provided DT overlay ili9488-ads7846.dtbo failed on fdt_overlay_apply(): FDT_ERR_NOTFOUND base fdt does not have a /__symbols__ node make sure you've compiled with -@ Error applying DT overlays, restoring original DT Hmm, I found that my armbian build didn't create a /boot/dtb/allwinner/overlay/ folder I copied the "overlay" folder, from my working armbian microsd, with linux 6.11, to this linux 6.12 microsd... I still get the same error: can't use my dtbo (I needed to make my own build, because I need to activate panel-drm-dbi.ko) Edited March 27 by robertoj 0 Quote
Ryzer Posted March 28 Posted March 28 (edited) Hi @Nick A The problem appears to be at my end, anyway managed to download the ffmpeg-vl42-request debs in the end and will be testing shortly. Thanks for the patches, I only had a slight hiccup when trying to integrate 2 of them. I found that patch 556 no longer appears to be necessary as those changes already appear to be implemented within my current Armbian build fork. The A10 and A20 use the Mali 400 so I have also borrowed patch 125. Good to here the CMA no longer need to be adjusted. Latest build has completed successfully. MPV is using ffmpeg-request. Now it seems to use hardware decoding. Quote [ffmpeg/video] h264: v4l2_request_try_format: pixelformat 842094158 not supported for type 1 [vd] Using hardware decoding (drm). [vd] Decoder format: 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/auto CL=mpeg2/4/h264 [vd] Using container aspect ratio. [vf] [in] 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [userdeint] 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [userdeint] (disabled) [vf] [autorotate] 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [autorotate] (disabled) [vf] [convert] 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [convert] (disabled) [vf] [out] 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [cplayer] VO: [gpu] 1280x720 drm_prime[nv12] [cplayer] VO: Description: Shader-based GPU Renderer [vo/gpu] reconfig to 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vo/gpu] Resize: 1920x1080 [vo/gpu] Window size: 1920x1080 (Borders: l=0 t=0 r=0 b=0) [vo/gpu] Video source: 1280x720 (1:1) [vo/gpu] Video display: (0, 0) 1280x720 -> (0, 0) 1920x1080 [vo/gpu] Video scale: 1.500000/1.500000 [vo/gpu] OSD borders: l=0 t=0 r=0 b=0 [vo/gpu] Video borders: l=0 t=0 r=0 b=0 [vo/gpu] Using HW-overlay mode. No GL filtering is performed on the video! That is the good news at least. The bad news is that it is an incomprehensive grid of sqaures. At the beginning I still get this line: [vo/gpu] VT_GETMODE failed: Inappropriate ioctl for device. Thanks Ryzer Edited March 29 by Ryzer Additional information 0 Quote
