linda Posted September 6, 2017 Share Posted September 6, 2017 Hello, today I made an upgrade of my pine64-mainline and failed miserably - my new armbian image won't boot any more. So I did some more tests with a new more different sd-cards, power supply and the mailine kernel form the download site (https://dl.armbian.com/pine64/Ubuntu_xenial_dev_nightly.7z): Again, the same behaviour, the image doesn't bott any more after "apt update" and "apt upgrade". Please, could someone help me with this problem? I hope these lockup logs help in troubleshooting. Thanks a lot! boot-fail-2017-09-06-A.log boot-fail-2017-09-06-B.log Link to comment Share on other sites More sharing options...
belfastraven Posted September 8, 2017 Share Posted September 8, 2017 Sorry--I didn't see this before I posted. I believe there is a bad definition somewhere of ftdfile (see my post on this same subject see this line File not found /boot/dtb/allwinner/allwinner/sun50i-a64-pine64-plus.dtb * with duplicate of Allwinner? look at the load line from the boot.cmd. I could not find where ftdfile was defined I got the system to boot by copying the allwinner directory into itself-- that way load will find the files (and overlays if they are being used) Link to comment Share on other sites More sharing options...
belfastraven Posted September 9, 2017 Share Posted September 9, 2017 OK--I found a post in another thread from zador.blood.stained. which explains that the ftdname will now have allwinner/prepended to it .. So probably the best fix is to edit the boot.cmd file to remove the allwinner/ from the load command, and then recompile boot.cmd. This works for me. It seems that boot.cmd hasn't been getting updated since that change was made. Link to comment Share on other sites More sharing options...
martinayotte Posted September 10, 2017 Share Posted September 10, 2017 Yes, this is a discrepancy between u-boot version and only occurs when doing an update instead of using fresh build. Link to comment Share on other sites More sharing options...
linda Posted September 10, 2017 Author Share Posted September 10, 2017 Thanks a lot for your answers and especially for the suggestion to change the boot.cmd. As proposed, I changed two lines concerning the fdtname in the the boot.cmd: "load ${devtype} 0 ${fdt_addr_r} ${prefix}dtb/${fdtfile}" but leave these line concerning the overlay-setting unchanged "if load ${devtype} 0 ${load_addr} ${prefix}dtb/allwinner/overlay/${overlay_prefix}-${overlay_file}.dtbo; then" "if load ${devtype} 0 ${load_addr} ${prefix}dtb/allwinner/overlay/${overlay_prefix}-fixup.scr; then" and recompile boot.cmd. This works for me, also with the allwinner overlay dtbo-file. 1 Link to comment Share on other sites More sharing options...
Menion Posted September 11, 2017 Share Posted September 11, 2017 So, to avoid boot fail after upgrading to latest kernel, we should modify this line in boot.cmd: from: load ${devtype} 0 ${fdt_addr_r} ${prefix}dtb/allwinner/${fdtfile} to load ${devtype} 0 ${fdt_addr_r} ${prefix}dtb/${fdtfile} Because apparently the dtb package stores in /boot/dtb/allwinner and my boot.cmd already points to it Link to comment Share on other sites More sharing options...
