OttawaHacker Posted April 13, 2025 Posted April 13, 2025 With the vendor kernel, my logs are getting flooded with drm error messages Apr 13 17:04:05 kitchen-opi kernel: [drm:rockchip_vop2_mod_supported] *ERROR* Cluster0-win0 unsupported format modifier 0x800000000000062 Apr 13 17:04:05 kitchen-opi kernel: [drm:rockchip_vop2_mod_supported] *ERROR* Cluster0-win0 unsupported format modifier 0x800000000000062 Apr 13 17:04:05 kitchen-opi kernel: [drm:rockchip_vop2_mod_supported] *ERROR* Cluster0-win0 unsupported format modifier 0x800000000000062 Apr 13 17:04:05 kitchen-opi kernel: [drm:rockchip_vop2_mod_supported] *ERROR* Cluster0-win0 unsupported format modifier 0x800000000000062 Apr 13 17:04:05 kitchen-opi kernel: [drm:rockchip_vop2_mod_supported] *ERROR* Cluster0-win0 unsupported format modifier 0x800000000000062 this seems an old issue (Kernel messages flooding logs · Issue #86 · Joshua-Riek/ubuntu-rockchip) - it doesn't seem complicated to fix, I am familiar with the build system but I cannot figure out how I can create a patch for the kernel source. Which repo should I patch? Can I just put my patch into build/patch/kernel/rk35xx-vendor-6.1? Thanks 0 Quote
Werner Posted April 14, 2025 Posted April 14, 2025 Since we host these sources ourselves, you can directly pr against them:https://github.com/armbian/linux-rockchip 0 Quote
OttawaHacker Posted April 18, 2025 Author Posted April 18, 2025 I sent a PR on the build with a patch - not sure about removing that log entry directly from kernel but on most common armbian builds, this log entry is a pain 0 Quote
