On 5/25/2025 at 1:16 AM, Crossplatform Vlad said:
But Debian and Armbian use previous CPU usage precision settings?
Did you compare those things on the same hardware (architecture)?
Good question. I did compared predefined default kernels from canonical (6.8) and debian (6.10) on the same hardware twice:
1) qemu arm64 emulator on x86_64 host with the same parameters. lines 6 and 7 on the screenshot
2) qemu x86_64 emulator on x86_64 host with the same parameters. lines 4 and 5  on the screenshot
Posted (edited)
On 5/26/2025 at 10:38 PM, hexdump said:
maybe its related to the kernel config parameter CONFIG_HZ_xyz - depending on which of them is set for the different kernels?
Seems it is an option for timer resolution in the measurement of duration. But the topic is about CPU usage precision returned by getrusage function. it is hardcoded interval of time when kernel updates CPU usage of particular thread/process.
Edited by Crossplatform Vlad
