paulted Posted April 18, 2025 Posted April 18, 2025 Windows wont let me edit/access the SD card once the iso has been written to it. Any help? 0 Quote
Werner Posted April 18, 2025 Posted April 18, 2025 Windows doesn't support proper file systems like btrfs or ext4 by default. You need a driver for such in order to read those or use anything but Windows. moved, title replaced 0 Quote
NickD Posted August 10, 2025 Posted August 10, 2025 You can try SharpExt4Explorer to read/write armbian image or SD card directly. https://github.com/nickdu088/SharpExt4Explorer 0 Quote
MaxT Posted August 10, 2025 Posted August 10, 2025 If I remember correctly, it is possible to mount such partition flashed to usb or sd within WSL (just ensure that proper support is installed into WSL) and make any changes. It is possible even to script changes to be run under windows, though I can't remember how exactly this is done. Probably AI can hint. 0 Quote
