RogerHardiman Posted April 27, 2025 Posted April 27, 2025 Hardware H264 encoding on the F3 is failing with a firmware binary error. ffmpeg command ffmpeg -y -v 99 -f lavfi -i testsrc -pix_fmt nv12 -g 15 -c:v h264_v4l2m2m out.264 dmesg error [ 4834.438234] MVX if: Failed to load firmware binary. filename=linlon-v52_v76-80-2/h264enc.fwb. [ 4834.450002] MVX if: Firmware binary was loaded with error. [ 4834.450020] MVX session: ffffffd905a1a0f8 send event error. error=-22 ffmpeg Gets some way into initialising. It detects the Linlon H264 encoder, checks images are NV12 format, but then fail with this error [h264_v4l2m2m @ 0x2abf834870] Failed to set gop size: Invalid argument Where do I find this .fwb file, and should it be shipping with Armbian? System Banana Pi F3 Uname Linux bananapif3 6.1.15-legacy-spacemit #1 SMP Sat Sep 7 13:08:45 UTC 2024 riscv64 riscv64 riscv64 GNU/Linux /etc/os-release PRETTY_NAME="Armbian 25.5.0-trunk.451 noble" NAME="Ubuntu" VERSION_ID="24.04" VERSION="24.04 LTS (Noble Numbat)" VERSION_CODENAME=noble ID=ubuntu ID_LIKE=debian HOME_URL="https://www.armbian.com/" SUPPORT_URL="https://forum.armbian.com" BUG_REPORT_URL="https://www.armbian.com/bugs" PRIVACY_POLICY_URL="https://www.armbian.com" UBUNTU_CODENAME=noble LOGO="armbian-logo" ARMBIAN_PRETTY_NAME="Armbian 25.5.0-trunk.451 noble" apt-update/apt-upgrade did this first 0 Quote
Werner Posted April 27, 2025 Posted April 27, 2025 Hi Providing logs with PASTE_SERVER_HOST=paste.armbian.de armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
