This solution work correctly:
sudo apt-get -y install git
dd ~
git clone https://github.com/armbian/config
cd config
bash debian-config
But now this is problem for me.
/etc/network/interfaces
# This file intentionally left blank
# All interfaces are handled by network-manager, use nmtui or nmcli on
# server/headless images or the "Network Manager" GUI on desktop images
I need two IP, DHCP and static IP:
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet dhcp
auto wlan0
iface wlan0 inet static
    address 192.168.8.1
    netmask 255.255.255.0
How should I do it now ?
5 minutes ago, Giorgio Climb said:
help
Have you changed kernel perhaps? If you don't write an essay of what you were doing and supply logs you are wasting time.
Start with: armbianmonitor -u
Download desktop image for Orangepi One and relink /boot/script.bin to /boot/bin/orangepizero.bin ... desktop images have enabled USB automount.
or search for generic Debian or Ubuntu tutorials, there is nothing Armbian specific here, especially for CLI images.
Also
Package: usbmount
Priority: extra
Section: universe/admin
Installed-Size: 81
Maintainer: Ubuntu Developers <ubuntu-devel-discuss@lists.ubuntu.com>
Original-Maintainer: Rogério Brito <rbrito@ime.usp.br>
Architecture: all
Version: 0.0.22
Depends: lockfile-progs, udev, util-linux (>> 2.16)
Recommends: pmount
Filename: pool/universe/u/usbmount/usbmount_0.0.22_all.deb
MD5sum: 9aca7abdd1029916c854e3731f28eb8a
SHA1: f2038321fda724e78a5bfbca5af0ebd25071a3b7
SHA256: d911dd20bb2801248206e353c9c6aa79b5874fc9e594354bbfecbf34b5de589e
Description-en: automatically mount and unmount USB mass storage devices
 This package automatically mounts USB mass storage devices (typically
 USB pens) when they are plugged in, and unmounts them when they are
 removed. The mountpoints (/media/usb[0-7] by default), filesystem types
 to consider, and mount options are configurable. When multiple devices
 are plugged in, the first available mountpoint is automatically
 selected. If the device provides a model name, a symbolic link
 /var/run/usbmount/MODELNAME pointing to the mountpoint is automatically
 created.
 The script that does the mounting is called by the udev daemon.
 Therefore, USBmount requires a 2.6 (or newer) Linux kernel.
 Firewire devices are also supported by USBmount.
 USBmount is intended as a lightweight solution which is independent of
 a desktop environment. Users which would like an icon to appear when an
 USB device is plugged in should use the pmount and hal packages
 instead.
Description-md5: 665bf065788bff1ada4b796e26321438
Homepage: http://usbmount.alioth.debian.org/
Bugs: https://bugs.launchpad.net/ubuntu/+filebug
Origin: Ubuntu
Made this, but no automount is there, the folder / mnt remains empty.
On armbian-config found nothing about automount
On 30/9/2017 at 2:00 PM, zador.blood.stained said:
Package: usbmount
Installed this, but all folders in / media / remain empty.
/dev/sda and /dev/sda1 appear when I put the memory stick.
