Posted (edited)
I recently bought an orange pi plus and am using the armbian 6.12 server (https://dl.armbian.com/orangepi5-plus/Noble_current_server)
I'm wanting to setup hardware acceleration for jellyfin but having trouble with the right steps. I'm using jellyfin inside docker on the orange pi inside armbian. I've found various tutorials but it seems like some of them reference things that no longer exist (like panfork seems to no longer be needed for latest mesa if I'm understanding correctly?), so wanting to see what I need to do to set this up.
So it seems like I need to disable panthor and use mali instead, but I can't find in the armbian config menu the option to do that, and not sure if I know how to get the right mali. Any help would be greatly appreciated.
armbianmonitor is at https://paste.armbian.com/nurazajipu
I've seen these tutorials/posts for reference:
https://akashrajpurohit.com/blog/setup-jellyfin-with-hardware-acceleration-on-orange-pi-5-rockchip-rk3558/
* https://github.com/andyshrk/mesa/blob/panthor-v4/Panfrost-build-howto.md
https://forum.jellyfin.org/t-solved-hw-transcoding-rk3588-arch-not-working?pid=54084
* `https://forum.armbian.com/topic/49115-how-to-install-opencl-on-orangepi-5-plus/`
https://forum.jellyfin.org/t-rockchip-transcode-missing-dev-mali0
Edited by David N
moved
You are using the wrong kernel branch. You need vendor 6.1.y kernel. This is also mentioned in the official documentation of Jellyfin.
Posted (edited)
Thanks for the response!
For the kernel switch, is it using armbian-config to pick under my current installation?
linux-image-vendor-rk35xx=25.2.3             v6.1.99
Is there anything else I need to do as well? Thanks!
Edited by David N
  • Solution
I don't think so. You can check in /boot/armbianEnv.txt if there is panthor overlay enabled. If so, disable it so you can use the proprietary mali blobs.
Thanks for the help! Switching to that kernel was enough to allow me to turn on transcoding after I mounted the proper /dev stuff to the docker container. Before I did this, transcoding just immediately crashed. Now I can see it working and it also looks to be using alot mess CPU as well, showing it's using the hardware.
Hi. My question is the same: how to set up mali hardware acceleration. I just disabled the panthor-gpu devicetree overlay via armbian-config, but the dmesg kernel messages don't contain strings like mail. I also looked for panthor string (after the proper enable procedure via armbian-config) but with no success. Do I need a specific kernel ? The running version is 6.1.115-vendor-rk35xx
I installed the .deb package you suggested, however I don't think everything went as it should have: the device /dev/mali0 is still missing. I understood that this device must be present in order to be sure the device is used correctly. Is it right ? The kernel of Armbian Ubuntu Noble also has been updates: the version is 6.1.115-vendor-rk35xx now. The output of lsmod command is:
 Module                  Size  Used by
rk805_pwrkey           16384  0
nvmem_rockchip_otp     20480  0
r8169                  77824  0
rockchip_cpuinfo       16384  1 nvmem_rockchip_otp
adc_keys               16384  0
Posted (edited)
@Gian Luca Please try
libMali route:
+ Flash Armbian 25.8.1 Noble Gnome (Vendor Kernel: 6.1.115)
+ Disable the Panthor overlay
+ Install libMali https://github.com/ginkage/libmali-rockchip/releases/download/v1.9-1-04f8711/libmali-valhall-g610-g24p0-wayland-gbm_1.9-1_arm64.deb
+ Install the WSI https://github.com/ginkage/vulkan-wsi-layer/releases/tag/v1.3.276-1-d48decd
(for Wayland, XWayland only)
mesa (Panfrost/PanVk) route:
+ Flash Armbian 25.8.1 Noble Gnome/XFCE (Vendor Kernel: 6.1.115)
+ Enable the Panthor overlay
+ Install the "mesa-vulkan-drivers" https://launchpad.net/~ernstp/+archive/ubuntu/mesarc
(for both Wayland and X11)
Edited by KhanhDTP
