alarik Posted May 17 Posted May 17 (edited) Hi. I've got a strange issue. When Orange Pi 5 Max was unavailable I installed version for Orange Pi 5 Pro from SD card to NVME SSD. It worked fine Now I decided for fresh install of Armbian dedicated to Max board but I can't boot from SD card. I used exactly the same card and the same power supply as when I installed armbian originally, but when I insert SD card, led goes blue and system is not booting. I don't have any signal on HDMI - monitor goes sleep. When I remove SD card - system boots from SSD and all is working. I removed SSD but system still can't boot from SD card. Do you know any method to boot from SD card or install armbian image in other way? For now I'm considering buying nvme usb case and clonning img directly to ssd but I'd like to avoid that as I don't know if that will work. Edited May 17 by alarik making subject more specific 0 Quote
Werner Posted May 18 Posted May 18 5 hours ago, alarik said: I don't have any signal on HDMI - monitor goes sleep This is not uncommon. Very few boards have hdmi support at boot level since developing this feature is expensive and simply not worth since the console output is also available via debug serial console where adapters for those are dirt cheap. To get an idea what happens inside you have to grab these logs and provide them. https://debug.armbian.de 0 Quote
alarik Posted May 18 Author Posted May 18 Thank you for replying me back and the hint. I ordered USB to TTL module Today. I'll debug and get back to you. Best regards alarik. 0 Quote
nnq1612 Posted May 24 Posted May 24 (edited) I also encountered the same situation. I wrote the Ubuntu Orange Pi 5 Max image from the Orange Pi homepage (http://www.orangepi.org/) and it ran normally, but when I wrote the Armbian Ubuntu version from https://www.armbian.com/orangepi-5-max/, the indicator light was only green and nothing appeared on the screen. I also tried writing the Armbian version for the regular Orange Pi 5 or Orange Pi 5 Pro and it could run (although wifi and usb were lost, but I could boot to the desktop), but when I wrote the Armbian version for the Orange Pi 5 Max, it did not run. Is it a bootloader problem? Edited May 24 by nnq1612 0 Quote
Werner Posted May 24 Posted May 24 2 hours ago, nnq1612 said: Is it a bootloader problem? Same answer as above. Without serial logs impossible to debug. It leaves to mention that this board is not officially supported but configuration has been provided by a community effort. Board status is unknown to the core Armbian team. 1 Quote
nnq1612 Posted May 27 Posted May 27 I got uart data from GPIO pin, when I press start button it returns as follows: Quote .DDR 9fffbe1e78 cym 24/02/04-10:09:20,fwver: v1.16 LPDDR5, 2400MHz channel[0] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB channel[1] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB channel[2] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB channel[3] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB Manufacturer ID:0xff CH0 RX Vref:26.2%, TX Vref:20.0%,20.0% CH1 RX Vref:26.7%, TX Vref:21.0%,21.0% CH2 RX Vref:27.1%, TX Vref:20.0%,20.0% CH3 RX Vref:27.5%, TX Vref:19.0%,20.0% change to F1: 534MHz change to F2: 1320MHz change to F3: 1968MHz change to F0: 2400MHz out U-Boot SPL board init U-Boot SPL 2017.09-orangepi (Jul 05 2024 - 20:18:28) Trying to boot from MMC1 Trying fit image at 0x4000 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(7612223b82...) + OK ## Checking uboot 0x00200000 ... sha256(939bc88f65...) + OK ## Checking fdt 0x00354c30 ... sha256(e3b0c44298...) + OK fdt_record_loadable: FDT_ERR_BADMAGIC ## Checking atf-2 0xff100000 ... sha256(70505bb764...) + OK fdt_record_loadable: FDT_ERR_BADMAGIC ## Checking atf-3 0x000f0000 ... sha256(b2af21b504...) + OK fdt_record_loadable: FDT_ERR_BADMAGIC Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000) Total: 762.337 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-868-g040d2de11:derrick.huang, fwver: v1.48 NOTICE: BL31: Built : 15:02:44, Dec 19 2024 INFO: spec: 0x1 INFO: code: 0x88 INFO: ext 32k is valid INFO: ddr: stride-en 4CH INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0 INFO: l3 cache partition cfg-0 INFO: system boots from cpu-hwid-0 INFO: bypass memory repair INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001 INFO: dfs DDR fsp_params[0].freq_mhz= 2400MHz INFO: dfs DDR fsp_params[1].freq_mhz= 534MHz INFO: dfs DDR fsp_params[2].freq_mhz= 1320MHz INFO: dfs DDR fsp_params[3].freq_mhz= 1968MHz INFO: BL31: Initialising Exception Handling Framework INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 No valid device tree binary found - please append one to U-Boot binary, use u-boot-dtb.bin or define CONFIG_OF_EMBED. For sandbox, use -d <file.dtb> initcall sequence 00000000002d2af8 failed at call 00000000002c5028 (err=-1) ### ERROR ### Please RESET the board ### It seems to be an error from the device tree file or the uboot version 0 Quote
nnq1612 Posted June 3 Posted June 3 Can anyone help to fix this bug.... How to install new u boot for Orange Pi 5 Max in a simple way? 0 Quote
SteeMan Posted June 3 Posted June 3 On 5/26/2025 at 11:14 PM, nnq1612 said: U-Boot SPL board init U-Boot SPL 2017.09-orangepi (Jul 05 2024 - 20:18:28) Trying to boot from MMC1 From your log, this is the uboot that is booting and it is trying and failing to boot from your mmc1. I would expect your SD to be mmc0, so it doesn't look like it is even trying to boot from your SD card. So you probably need to replace/update the onboard uboot or perhaps wipe the mmc1. But I don't have this board and really am just guessing. But these are directions you could look into. 0 Quote
Werner Posted June 4 Posted June 4 12 hours ago, nnq1612 said: How to install new u boot for Orange Pi 5 Max in a simple way? armbian-install should be able to do that. Though since there is no option to select WHICH version, if there are multiple installed, to write, I suggest to first check with dpkg -l which uboot package/s is/are installed and make sure there is only the one that you want to write. 0 Quote
alarik Posted June 5 Author Posted June 5 I finally got my debugger, but I was not able to get any data from it. I successfully tested it on ESP32, but when I connected it to my Orange Pi 5 Max, there was no otuput. I tried with both baudrates: 150000 and 115200. 0 Quote
SteeMan Posted June 5 Posted June 5 1 hour ago, alarik said: 150000 that should be 1500000 (one more zero). Note a lot of uart connectors can't handle this high of a speed. There are many threads in the forums discussing specific ones that are able to reach that speed. 1 Quote
alarik Posted June 6 Author Posted June 6 (edited) Thank you @SteeMan for pointing invalid value. Maybe this will help someone: For my configuration serial works only on UART2_TX_M0 and UART2_RX_M0. This is the log from my device: 9fffbe1e78 cym 24/02/04-10:09:20,fwver: v1.16 LPDDR5, 2400MHz channel[0] BW=16 Col=10 Bk=16 CS0 Row=16 CS=1 Die BW=16 Size=2048MB channel[1] BW=16 Col=10 Bk=16 CS0 Row=16 CS=1 Die BW=16 Size=2048MB channel[2] BW=16 Col=10 Bk=16 CS0 Row=16 CS=1 Die BW=16 Size=2048MB channel[3] BW=16 Col=10 Bk=16 CS0 Row=16 CS=1 Die BW=16 Size=2048MB Manufacturer ID:0xff CH0 RX Vref:27.9%, TX Vref:18.0%,0.0% CH1 RX Vref:27.1%, TX Vref:20.0%,0.0% CH2 RX Vref:26.7%, TX Vref:18.0%,0.0% CH3 RX Vref:25.4%, TX Vref:20.0%,0.0% change to F1: 534MHz change to F2: 1320MHz change to F3: 1968MHz change to F0: 2400MHz out U-Boot SPL board init U-Boot SPL 2017.09-armbian-2017.09-Sf73b-Pc965-H8c72-V6123-Bda0a-R448a (Aug 13 2 024 - 07:45:36) Trying to boot from MMC2 spl: partition error Trying fit image at 0x4000 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(7612223b82...) + OK ## Checking uboot 0x00200000 ... sha256(939bc88f65...) + OK ## Checking fdt 0x00354c30 ... sha256(e3b0c44298...) + OK fdt_record_loadable: FDT_ERR_BADMAGIC ## Checking atf-2 0xff100000 ... sha256(70505bb764...) + OK fdt_record_loadable: FDT_ERR_BADMAGIC ## Checking atf-3 0x000f0000 ... sha256(b2af21b504...) + OK fdt_record_loadable: FDT_ERR_BADMAGIC Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000) Total: 623.792/875.455 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-868-g040d2de11:derrick.huang, fwver: v1.48 NOTICE: BL31: Built : 15:02:44, Dec 19 2024 INFO: spec: 0x1 INFO: code: 0x88 INFO: ext 32k is valid INFO: ddr: stride-en 4CH INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0 INFO: l3 cache partition cfg-0 INFO: system boots from cpu-hwid-0 INFO: disable memory repair INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001 INFO: dfs DDR fsp_params[0].freq_mhz= 2400MHz INFO: dfs DDR fsp_params[1].freq_mhz= 534MHz INFO: dfs DDR fsp_params[2].freq_mhz= 1320MHz INFO: dfs DDR fsp_params[3].freq_mhz= 1968MHz INFO: BL31: Initialising Exception Handling Framework INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE init ialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 No valid device tree binary found - please append one to U-Boot binary, use u-bo ot-dtb.bin or define CONFIG_OF_EMBED. For sandbox, use -d <file.dtb> initcall sequence 00000000002d2af8 failed at call 00000000002c5028 (err=-1) ### ERROR ### Please RESET the board ### Currently installed uboot packges: I'm newbie here so if additional configuration is required I'd appreciate any suggestion. Edited June 7 by alarik 0 Quote
alarik Posted June 13 Author Posted June 13 @Werner You suggested using armbian-install. You meant to update boot loader in current installation? If I'll do this will it break currently working booting from nvme? 0 Quote
Werner Posted June 14 Posted June 14 I don't know. I don't have this board nor is the Armbian team aware of its state since it is community supported. On 6/6/2025 at 2:51 PM, alarik said: Currently installed uboot packges: This looks like some upstream (Debian to say) uboot package which certainly does not support this board. IIRC u-boot versions for rk3588, depending on family are something like 2017.09 or 2024.01 (both vendor cases) and 2025.01 or .04 for current/edge. 0 Quote
Solution alarik Posted November 30 Author Solution Posted November 30 (edited) Probably more experienced users will not have similar issues, but I'll provide my solution just for for the record: Power off devide. Insert SD card into the slot. Hold 'boot' button on the mainboard. Plug in device. Release 'boot' after 5 seconds. Power off and power on. in my case it took up to 60 seconds before my device boot from SD card. I checked the same with USB and it also work (*it ust be plugged into one of USB2.0 ports). Thank you for your suggestion. I'll close the thread. Edited November 30 by alarik 0 Quote
not_a_duck Posted December 9 Posted December 9 I've recently started seeing similar issues on my orange pi 5 plus and have narrowed it down to uboot spl not detecting the sd cards on initial cold boot. The reason I started noticing this is because I have long overlay path names that are fine with the version of uboot proper that I have on my sd card but does not work with the uboot proper that is on the onboard eeprom. I only started noticing this when getting a new batch of sd cards. this is a "good boot" uboot spl detects the sd card and boots from it: DDR 9fffbe1e78 cym 24/02/04-10:09:20,fwver: v1.16 LPDDR4X, 2112MHz channel[0] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB channel[1] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB channel[2] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB channel[3] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB Manufacturer ID:0xff CH0 RX Vref:29.3%, TX Vref:21.8%,21.8% CH1 RX Vref:28.9%, TX Vref:23.8%,22.8% CH2 RX Vref:30.1%, TX Vref:21.8%,20.8% CH3 RX Vref:30.5%, TX Vref:21.8%,21.8% change to F1: 528MHz change to F2: 1068MHz change to F3: 1560MHz change to F0: 2112MHz out U-Boot SPL board init U-Boot SPL 2017.09-orangepi (Aug 30 2024 - 22:09:16) Trying to boot from MMC1 Trying fit image at 0x4000 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(d37470e935...) + OK ## Checking u-boot 0x00a00000 ... sha256(249bd3a5c2...) + OK ## Checking fdt-1 0x00acd498 ... sha256(537243530a...) + OK ## Checking atf-2 0xff100000 ... sha256(394f39cea2...) + OK Jumping to U-Boot(0x00a00000) via ARM Trusted Firmware(0x00040000) Total: 840.114 ms NOTICE: BL31: v2.12.1(release): NOTICE: BL31: Built : 00:00:00, Jan 1 1980 At this point uboot proper which lives on my sd card and remaps the debug uart to one of the 40 pin header runs. in a bad boot I am seeing this: DDR 9fffbe1e78 cym 24/02/04-10:09:20,fwver: v1.16 LPDDR4X, 2112MHz channel[0] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB channel[1] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB channel[2] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB channel[3] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB Manufacturer ID:0xff CH0 RX Vref:29.3%, TX Vref:21.8%,21.8% CH1 RX Vref:29.3%, TX Vref:23.8%,22.8% CH2 RX Vref:30.5%, TX Vref:21.8%,20.8% CH3 RX Vref:30.5%, TX Vref:21.8%,21.8% change to F1: 528MHz change to F2: 1068MHz change to F3: 1560MHz change to F0: 2112MHz out U-Boot SPL board init U-Boot SPL 2017.09-orangepi (Aug 30 2024 - 22:09:16) Trying to boot from MMC1 spl: mmc init failed with error: -95 Trying to boot from MMC2 Card did not respond to voltage select! spl: mmc init failed with error: -95 Trying to boot from MTD2 Trying fit image at 0x400 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(6dbe36e3e6...) + OK ## Checking uboot 0x00200000 ... sha256(152eb1bd26...) + OK ## Checking fdt 0x00325f70 ... sha256(16188a5876...) + OK ## Checking atf-2 0xff100000 ... sha256(40e9180d15...) + OK ## Checking atf-3 0x000f0000 ... sha256(d189664c33...) + OK Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000) Total: 2706.733 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-754-g371ede2b2:cym, fwver: NOTICE: BL31: Built : 19:36:27, Apr 22 2024 INFO: spec: 0x1 INFO: code: 0x88 INFO: ext 32k is valid INFO: ddr: stride-en 4CH INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0 INFO: l3 cache partition cfg-0 INFO: system boots from cpu-hwid-0 INFO: bypass memory repair INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001 INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz INFO: BL31: Initialising Exception Handling Framework INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 here uboot spl does not detect my sd card and continues to boot from uboot proper that lives on the eeprom. it then at that point detects the sd card and boots linux from there. but as I mentioned above other things fail because my device tree overlay file name lengths. I was able to get around this by sym linking and shortening the dtbs. either way I suspect that there is an issue with newer versions of sd cards or older versions of uboot spl that these orange pis are being shipped with preventing it from detecting the sd cards. this is an sd card that works fine: Card Reader: Built in SD Card Reader: Vendor ID: 0x17a0 Device ID: 0x9755 Subsystem Vendor ID: 0x17a0 Subsystem ID: 0x9755 Revision: 0x0002 Link Width: x1 Link Speed: 5.0 GT/s SDXC Card (Class 10): Product Name: SDSN128 Manufacturer ID: 0x03 Revision: 8.6 Serial Number: 0x22b7de5b Manufacturing Date: 2025-04 Specification Version: 3.0 Capacity: 127.87 GB (127,865,454,592 bytes) Removable Media: Yes BSD Name: disk4 Partition Map Type: MBR (Master Boot Record) S.M.A.R.T. status: Verified Volumes: FIRMWARE: Free: 7.3 MB (7,288,832 bytes) Capacity: 31.5 MB (31,457,280 bytes) Writable: Yes File System: MS-DOS FAT16 BSD Name: disk4s1 Mount Point: /Volumes/FIRMWARE Content: DOS_FAT_32 Volume UUID: 7CB50D4B-9DF9-3646-8316-CB3C06C369BB disk4s2: Capacity: 127.82 GB (127,817,220,096 bytes) BSD Name: disk4s2 Content: Linux this is an sd card that does not work: Card Reader: Built in SD Card Reader: Vendor ID: 0x17a0 Device ID: 0x9755 Subsystem Vendor ID: 0x17a0 Subsystem ID: 0x9755 Revision: 0x0002 Link Width: x1 Link Speed: 5.0 GT/s SDXC Card (Class 10): Product Name: SDSM128 Manufacturer ID: 0x03 Revision: 8.7 Serial Number: 0xb26e2098 Manufacturing Date: 2025-10 Specification Version: 3.0 Capacity: 128 GB (127,999,672,320 bytes) Removable Media: Yes BSD Name: disk4 Partition Map Type: MBR (Master Boot Record) S.M.A.R.T. status: Verified Volumes: FIRMWARE: Free: 7.3 MB (7,288,832 bytes) Capacity: 31.5 MB (31,457,280 bytes) Writable: Yes File System: MS-DOS FAT16 BSD Name: disk4s1 Mount Point: /Volumes/FIRMWARE Content: DOS_FAT_32 Volume UUID: 7CB50D4B-9DF9-3646-8316-CB3C06C369BB disk4s2: Capacity: 127.95 GB (127,951,437,824 bytes) BSD Name: disk4s2 Content: Linux take note here of the difference in product name and revision. 0 Quote
Werner Posted December 9 Posted December 9 3 hours ago, not_a_duck said: 2017.09-orangepi Not an Armbian uboot binary. Also we started to drop vendor uboot in favor of mainline. 0 Quote
not_a_duck Posted December 11 Posted December 11 Quote Not an Armbian uboot binary. Also we started to drop vendor uboot in favor of mainline. as far as i am understanding this is running off of the onboard spi-flash/eeprom on the orange pi board unless you're reflashing that on first boot U-Boot SPL board init U-Boot SPL 2017.09-orangepi (Aug 30 2024 - 22:09:16) i've also switched to using mainline uboot v2025.10 for my emmc and sd cards that i'm creating but previously had not been in a situation where i needed to update the spi-flash/eeprom for sd cards or emmc uboot proper to be able to be loaded. I was able to resolve my issue by building mainline uboot spl with a timeout in the mmc probing 0 Quote
not_a_duck Posted December 11 Posted December 11 actually did some more digging and i think this describes the same issue that i am seeing with these newer sd cards in uboot spl. https://lore.kernel.org/u-boot/20251031145951.535376-1-c.stoidner@phytec.de/ Quote mmc/sd specification requires a 1 ms delay (stable supply voltage) after vdd was enabled and before issuing first command. For most sdcard/soc combinations, the missing delay seems to be not a problem because the processing time between enabling vdd and the first command is often hundreds of microseconds or more. However, in our specific case, some sdcards were not detected by u-boot: * soc: NXP i.MX 93 * sdcards: SanDisk Ultra, 64GB micro SDXC 1, MediaRange, 8GB, SDHC * measured time between vdd and first command: approx. 784us * symptom: both sdcards did not respond at all to first commands, u-boot mmc subsystem ran into timeout and stops to initialize the cards 0 Quote
