kope Posted September 20, 2017 Share Posted September 20, 2017 Hi, https://www.armbian.com/orange-pi-pc2/ states: "Following features should work:" ... "SPI+USB boot" . I was trying to load u-boot from the SPI (but without success). I followed the instructions in u-boot/board/sunxi/README.sunxi64 : $ ./sunxi-fel spiflash-write 0 spl/sunxi-spl.bin $ ./sunxi-fel spiflash-write 32768 u-boot.itb Booting from SPI ends with an exception: U-Boot SPL 2017.09-armbian (Sep 13 2017 - 12:23:18) DRAM: 1024 MiB Trying to boot from sunxi SPI "Synchronous Abort" handler, esr 0x02000000 ELR: 4a000000 LR: 125cc x 0: 000000004a000000 x 1: 0000000000000000 x 2: 0000000000007000 x 3: 0000000077777777 As if SPL could find/execute u-boot or SPI at all. Does anybody have any success with booting from SPI on OPI PC2? Link to comment Share on other sites More sharing options...
0 martinayotte Posted September 20, 2017 Share Posted September 20, 2017 It been a while since I've checked/tested SPI-NOR ... Effectively, it seems broken now, probably since several u-boot versions. Fortunately, I still had a old u-boot working build in last March, and I've put back this one into SPI_NOR. EDIT : since I'm keeping a lost of previous images, I found out that another image build back in May was also working, we were still using Apriztel u-boot tree at that time. So the issue come most probably when we switched to Mainline u-boot recently ... Link to comment Share on other sites More sharing options...
0 zador.blood.stained Posted September 24, 2017 Share Posted September 24, 2017 Just found this on the u-boot mailing list: https://lists.denx.de/pipermail/u-boot/2017-September/307246.html Link to comment Share on other sites More sharing options...
0 kope Posted September 25, 2017 Author Share Posted September 25, 2017 yes. I reported it to Apriztel. Patch is included in the link above and is working. It should be included in mainline u-boot starting with v2017.11 Link to comment Share on other sites More sharing options...
0 zador.blood.stained Posted September 25, 2017 Share Posted September 25, 2017 2 hours ago, kope said: Patch is included in the link above and is working. It should be included in mainline u-boot starting with v2017.11 Now it's also included in Armbian sources so following builds will have this fix already. 1 Link to comment Share on other sites More sharing options...
0 martinayotte Posted September 25, 2017 Share Posted September 25, 2017 Good !!! Link to comment Share on other sites More sharing options...
0 zador.blood.stained Posted September 28, 2017 Share Posted September 28, 2017 @martinayotte Does the u-boot on PC2 or Prime work for you (next branch)? For me OPi PC2 u-boot currently crashes in SPL with a "Synchronous Abort". Link to comment Share on other sites More sharing options...
0 martinayotte Posted September 28, 2017 Share Posted September 28, 2017 If I remember (I'm chasing soo many things in recent days), OPiPC2 works for me, but OPiPrime getting floods of "Synchronous Abort", I had no choice to use older u-boot built somewhen in August. Link to comment Share on other sites More sharing options...
0 martinayotte Posted September 30, 2017 Share Posted September 30, 2017 I've built a fresh OPiPC2 today, and yes I've got one "Synchronous Abort", but it rebooted and boot fine ... Looking back to OPiPrime, it wasn't flood of "Synchronous Abort", but simply kernel oops, but replacing u-boot with older, the same kernel boot fine. Link to comment Share on other sites More sharing options...
0 tomter Posted October 28, 2017 Share Posted October 28, 2017 Hello, I don't understand this new procedure. Previously I have copied with flashcp, how can I made this work? Thanks in advance. Link to comment Share on other sites More sharing options...
0 martinayotte Posted October 28, 2017 Share Posted October 28, 2017 What do you mean by "new procedure" ? Link to comment Share on other sites More sharing options...
0 tomter Posted October 28, 2017 Share Posted October 28, 2017 3 hours ago, martinayotte said: What do you mean by "new procedure" ? Previously this year I asked about boot from USB without SD card. Solution was flashing u boot to spi flash. With this new image doesn't work. So I would like to know how to update u boot on SPI so it will boot from USB without SD card. Thanks Link to comment Share on other sites More sharing options...
0 martinayotte Posted October 29, 2017 Share Posted October 29, 2017 The procedure didn't really change, you need to activate the spi-jedec-nor overlay in /boot/armbianEnv.txt : overlays=spi-jedec-nor param_spinor_spi_bus=0 Then, after reboot, you should get from "cat /proc/mtd", something like that : dev: size erasesize name mtd0: 00200000 00001000 "spi0.0" This mean you can use "flashcp" to place the u-boot image into the flash. Link to comment Share on other sites More sharing options...
0 tomter Posted November 1, 2017 Share Posted November 1, 2017 Hello, I tried your solution, but I am doing something wrong, flashcp doesn't output nothing. Is that right? When I connect HDD and try to boot, I get error Trying to boot from sunxi SPI No matching DT out of these options: Configuration to load ATF before U-Boot No matching DT out of these options: Configuration to load ATF before U-Boot SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ### What am I doing wrong? Link to comment Share on other sites More sharing options...
0 martinayotte Posted November 1, 2017 Share Posted November 1, 2017 Maybe I don't understand the steps you achieve successfully and the one that maybe failed ... Using the overlay, did you successfully got "cat /proc/mtd ". If Yes, then you did the flashcp and got no errors. Next , you've halted the board, remove the SDCard, and repower the board, and U-Boot from Flash actually executed display the output you've mentioned above. Right ? This means the USB storage you used isn't discovered. I've got such issue with some USB thumb dongles. Did you tried a real USB-HDD drive ? You should see something like "USB 1 Storage detected" or similar message ... If you have placed a copy of /boot into that USB drive, you should see u-boot loading the DT/uInitrd/Image followed by "Starting kernel" Link to comment Share on other sites More sharing options...
0 tomter Posted November 2, 2017 Share Posted November 2, 2017 Finaly I understood why this procedure with flashcp doesn't work as it did with previous images. U-boot is split between spl.bin and u-boot file. Previously it was one file with all-in-one. So I don't know how to flash to SPI-NOR with two files. Anybody with ideas are welcome. Link to comment Share on other sites More sharing options...
0 martinayotte Posted November 3, 2017 Share Posted November 3, 2017 Ah ! Ok ! Now I understand ... Simply concatenate both files into one : cat /usr/lib/linux-u-boot-next-orangepipc2_5.34_arm64/sunxi-spl.bin /usr/lib/linux-u-boot-next-orangepipc2_5.34_arm64/u-boot.itb > /usr/lib/linux-u-boot-next-orangepipc2_5.34_arm64/u-boot-sunxi-with-spl.bin Then, you can use normal "flashcp" cmdline : flashcp /usr/lib/linux-u-boot-next-orangepipc2_5.34_arm64/u-boot-sunxi-with-spl.bin /dev/mtd0 Link to comment Share on other sites More sharing options...
0 tomter Posted November 3, 2017 Share Posted November 3, 2017 Now it worked and booted without any issues, many thanks to martinayotte Link to comment Share on other sites More sharing options...
Question
kope
Link to comment
17 answers to this question
