timmymg Posted May 29, 2025 Posted May 29, 2025 I have connected matrix led display on max7219 by spi to orangepi. Module max7219 have power supply from 5v. On some during a 220v power failure (sparking between wires suspended on poles), there were some disruptions in the 5v power supply. This damaged the max7219 modules and possible spi port on orange pi. After this failure, the /boot/armbianEnv.txt file contained a fragment of the logrotate file, the kernel on the orange pi is unable to initialize the spi port despite no wires being connected. After connecting a working orange pi to the max7219 module, the problem with spi initialization also appears. Dmesg does not show anything related to spi, there is no /dev/spi0.0 file. Is it possible that damage to the spi port blocks its initialization by the kernel? There was also a problem with playing music using mpd, after a while the music stops playing and the kernel reports that the sound card is not available. Re-running mpc play resumes playing music, but not for long. 0 Quote
Werner Posted May 29, 2025 Posted May 29, 2025 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
going Posted May 29, 2025 Posted May 29, 2025 1 час назад, timmymg сказал: 220v power failure (sparking between wires suspended on poles), there were some disruptions in the 5v power supply. This damaged the max7219 modules and possible spi port on orange pi. Sparking between the wires on the poles produces high-frequency pulses of high power and transmits them through the wires to consumers of electricity. Household consumers such as a TV, vacuum cleaner, refrigerator do not have a built-in high-frequency protection filter and very often fail. As for the orange, it is not protected at all. My orange was just lying on the table and was connected by an Ethernet cable to the router. Both were not power up. Lightning struck a nearby building. The Ethernet cable caught an electromagnetic pulse. The orange burned down completely and the router has only 1 port damaged. You can draw your own conclusions. 0 Quote
