building 3.14 kernel for Kii pro (s905)
MOHAMMAD HADI
I'm trying to build a kernel for my tv box (kii pro) , but the resulting kernel doesn't have framebuffer or mmc drivers,
first i tried to build the kernel from this git repo https://github.com/kszaq/linux-amlogic-le  but not mmc devices or framebuffer
then tried to build two versions of buildroot directly from amlogic site
http://openlinux.amlogic.com:8000/download/ARM/filesystem/buildroot-openlinux-20170310.tar.gz
http://openlinux.amlogic.com:8000/download/ARM/filesystem/Linux_BSP/buildroot_openlinux_kernel_3.14_fbdev_20170527.tar.gz
unfortunately i can't build the dtbs that came with them (i get syntax error)
basically i want to build a kernel with at least these features
-framebuffer device /dev/fb0
-mmc drivers /dev/mmcblk
-amlogic env device /dev/env
so what source files should i use and is there any additional drivers to enable these features?
Link to comment
Share on other sites
11 hours ago, balbes150 said:
What build you choose when configuring the BUILDROOT ?
well i didn't configure buildroot beacuse I only need the kernel so i'm trying to build the kernel only, anyway when booting a compiled kernel usually one of these dtbs work fine
gxbb_p200
gxbb_p200_2G
gxbb_p201
so i guss i'd use mesongxb_p200_release in buildroot
unfortunately this fails with the following error
package/gpu/gpu.mk:76: *** GPU_SITE cannot be empty when GPU_SOURCE is not.  Stop.
Link to comment
I have built the kernel successfully using the buildroot-openlinux-20170310 package with fb,nand,mmc support enabled in .config
but I can't boot it because I can't build a dtb from source, when trying to use a dtb for my device from libreelec image the boot process hangs
reading /multiboot/kernel-3.14//umbInitrd
6270626 bytes read in 296 ms (20.2 MiB/s)
reading /multiboot/kernel-3.14//zImage
17043544 bytes read in 789 ms (20.6 MiB/s)
reading /multiboot/kernel-3.14//dtb.img
38576 bytes read in 9 ms (4.1 MiB/s)
## Loading init Ramdisk from Legacy Image at 13000000 ...
   Image Name:   linux-next
   Image Type:   AArch64 Linux RAMDisk Image (uncompressed)
   Data Size:    6270562 Bytes = 6 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
load dtb from 0x1000000 ......
## Flattened Device Tree blob at 01000000
   Booting using the fdt blob at 0x1000000
   Loading Ramdisk to 738c6000, end 73ec0e62 ... OK
   Loading Device Tree to 000000001fff3000, end 000000001ffff6af ... OK
signature:
fdt_instaboot: get header err
Starting kernel ...
uboot time: 5007852 us
so it's definitely a dtb problem  but I can't solve it as i no nothing about dtb and dtbs provided with  the buildroot all fails to build with syntax error
▶ dtc -I dts -O dtb -o ../kii.dtb arch/arm64/boot/dts/amlogic/gxbb_p200_2G.dts
Error: arch/arm64/boot/dts/amlogic/gxbb_p200_2G.dts:8.1-9 syntax error
FATAL ERROR: Unable to parse input tree
Link to comment
trying to build a single dtb
▶ CROSS_COMPILE=/home/mohammad/Downloads/buildroot-openlinux-20170310/buildroot-openlinux-20170310/toolchain/gcc/linux-x86/aarch64/gcc-linaro-aarch64-linux-gnu-4.9/bin/aarch64-linux-gnu- ARCH=arm64 make gxbb_p200_2G.dtb
KBUILD_CFLAGS_MODULE:-DMODULE
  DTC     arch/arm64/boot/dts/amlogic/gxbb_p200_2G.dtb
Error: arch/arm64/boot/dts/amlogic/mesongxbb-gpu-mali450.dtsi:10.1-2 syntax error
make[1]: *** [scripts/Makefile.lib:274: arch/arm64/boot/dts/amlogic/gxbb_p200_2G.dtb] Error 1
make: *** [/home/mohammad/Downloads/buildroot-openlinux-20170310/buildroot-openlinux-20170310/kernel/aml-3.14/arch/arm64/Makefile:82: gxbb_p200_2G.dtb] Error 2
Link to comment
1 hour ago, balbes150 said:
Are you trying to use a dts data from another kernel version. This will not work. The kernel sources and dts sources should be the same.
I know that the dtb is version dependant, i used a dtb file from your armbian image with the same kernel version i built (3.14.29) but it doesn't work either, I can't build the dts files that came with the kernel that i built,
when passing "dtb" as a target to make while building the kernel i only get the kernel compiled and not the dtbs.
when trying to build the dtbs by using dtc tool  i get a syntax error
Error: arch/arm64/boot/dts/amlogic/gxbb_p200_2G.dts:1.1-2 syntax error
and when building and individual dtb with make i get a syntax error as well in another file
buildroot-openlinux-20170310/kernel/aml-3.14        ⍉
Link to comment
If you use my kernel sources. Add the correct dts file in the kernel sources (the directory arch/arm64/boot/dts) and paste in arch/arm64/boot/dts/Makefile a string that describes the desired goal. Then start build "make dtbs". For example, the added option nexbox_a95x_s905.dts
https://github.com/150balbes/Amlogic_s905-kernel/blob/armbian/arch/arm64/boot/dts/Makefile#L11
https://github.com/150balbes/Amlogic_s905-kernel/blob/armbian/arch/arm64/boot/dts/nexbox_a95x_s905.dts
Pay attention want the original dts , which is suitable for this version of the kernel source.
Link to comment
your kernel source fails to build, used the included config and each time i run set_make it builds some source files then error out
▶ ./set_make
KBUILD_CFLAGS_MODULE:-DMODULE -mfix-cortex-a53-843419 -mfix-cortex-a53-835769
scripts/kconfig/conf --silentoldconfig Kconfig
drivers/amlogic/wifi/bcmdhd/Kconfig:50:warning: defaults for choice values not supported
  CHK     include/generated/uapi/linux/version.h
make[1]: Nothing to be done for 'dtbs'.
  CHK     include/generated/utsrelease.h
  CC      arch/arm64/kernel/asm-offsets.s
  GEN     include/generated/asm-offsets.h
  CALL    scripts/checksyscalls.sh
<stdin>:1232:2: warning: #warning syscall renameat2 not implemented [-Wcpp]
  CC      init/main.o
  CHK     include/generated/compile.h
  CC      arch/arm64/mm/dma-mapping.o
  CC      arch/arm64/kernel/swp_emulate.o
  CC      init/do_mounts.o
  VDSOA   arch/arm64/kernel/vdso/gettimeofday.o
  CC      arch/arm64/mm/extable.o
  VDSOL   arch/arm64/kernel/vdso/vdso.so.dbg
  OBJCOPY arch/arm64/kernel/vdso/vdso.so
  VDSOSYM arch/arm64/kernel/vdso/vdso-offsets.h
  CC      arch/arm64/mm/fault.o
  CC      init/do_mounts_initrd.o
  AS      arch/arm64/kernel/vdso/vdso.o
  LD      arch/arm64/kernel/vdso/built-in.o
  AS      arch/arm64/kernel/head.o
  CC      arch/arm64/kernel/debug-monitors.o
  CC      init/noinitramfs.o
  CC      init/initramfs.o
  CC      arch/arm64/mm/init.o
  CC      init/init_task.o
  AS      arch/arm64/kernel/entry.o
  CC      arch/arm64/kernel/irq.o
  CC      init/version.o
  AS      arch/arm64/mm/cache.o
  CC      arch/arm64/mm/flush.o
  LD      init/mounts.o
  CC      arch/arm64/kernel/fpsimd.o
  AS      arch/arm64/kernel/entry-fpsimd.o
  CC      arch/arm64/kernel/process.o
  LD      init/built-in.o
  CC      arch/arm64/mm/ioremap.o
  CC      arch/arm64/kernel/ptrace.o
  CC      kernel/fork.o
  CC      arch/arm64/kernel/setup.o
  CC      arch/arm64/mm/mmap.o
  CC      arch/arm64/mm/pgd.o
  CC      arch/arm64/kernel/signal.o
  CC      arch/arm64/mm/mmu.o
  CC      arch/arm64/kernel/sys.o
  CC      arch/arm64/kernel/stacktrace.o
  CC      arch/arm64/mm/context.o
  CC      mm/filemap.o
  CC      arch/arm64/kernel/time.o
  CC      kernel/exec_domain.o
  AS      arch/arm64/mm/proc.o
  CC      arch/arm64/kernel/traps.o
  CC      arch/arm64/mm/hugetlbpage.o
  CC      kernel/panic.o
  LD      arch/arm64/mm/built-in.o
  CC      arch/arm64/kernel/vdso.o
  CC      fs/open.o
  CC      kernel/cpu.o
  AS      arch/arm64/kernel/hyp-stub.o
  CC      arch/arm64/kernel/psci.o
  CC      mm/mempool.o
  CC      arch/arm64/kernel/insn.o
  CC      kernel/exit.o
  CC      arch/arm64/kernel/return_address.o
  CC      fs/read_write.o
  CC      mm/oom_kill.o
  CC      arch/arm64/kernel/opcodes.o
  AS      arch/arm64/kernel/sys32.o
  CC      kernel/itimer.o
  CC      fs/file_table.o
  CC      mm/fadvise.o
  CC      arch/arm64/kernel/signal32.o
  CC      mm/page_alloc.o
  CC      kernel/time.o
  CC      fs/super.o
  CC      arch/arm64/kernel/sys_compat.o
  CC      arch/arm64/kernel/ftrace.o
  CC      kernel/softirq.o
  CC      arch/arm64/kernel/arm64ksyms.o
  CC      fs/char_dev.o
  CC      arch/arm64/kernel/module.o
  CC      kernel/resource.o
  CC      fs/stat.o
  CC      arch/arm64/kernel/smp.o
  CC      kernel/sysctl.o
  CC      fs/exec.o
  CC      arch/arm64/kernel/topology.o
  CC      mm/page-writeback.o
  CC      arch/arm64/kernel/perf_regs.o
  CC      arch/arm64/kernel/perf_event.o
  CC      fs/pipe.o
  CC      kernel/sysctl_binary.o
  CC      arch/arm64/kernel/hw_breakpoint.o
  CC      mm/readahead.o
  CC      fs/namei.o
  CC      kernel/capability.o
  CC      mm/swap.o
  AS      arch/arm64/kernel/sleep.o
  CC      arch/arm64/kernel/suspend.o
  CC      kernel/ptrace.o
  CC      arch/arm64/kernel/kgdb.o
  CC      arch/arm64/kernel/cpuidle.o
  CC      kernel/timer.o
  CC      mm/truncate.o
  CC      arch/arm64/kernel/hibernate.o
  LD      arch/arm64/kernel/built-in.o
  CC      ipc/compat.o
  CC      mm/vmscan.o
  CC      fs/fcntl.o
  CC      kernel/user.o
  CC      ipc/util.o
  CC      fs/ioctl.o
  CC      kernel/signal.o
  CC      fs/readdir.o
  CC      ipc/msgutil.o
  CC      ipc/msg.o
  CC      fs/select.o
  CC      ipc/sem.o
  CC      mm/shmem.o
  CC      fs/dcache.o
  CC      kernel/sys.o
  CC      ipc/shm.o
  CC      mm/util.o
  CC      ipc/ipcns_notifier.o
  CC      kernel/kmod.o
  CC      ipc/ipc_sysctl.o
  CC      fs/inode.o
  CC      ipc/mqueue.o
  CC      mm/vmstat.o
  CC      kernel/workqueue.o
  CC      fs/attr.o
  CC      mm/backing-dev.o
  CC      ipc/compat_mq.o
  CC      fs/bad_inode.o
  CC      ipc/namespace.o
  CC      mm/mm_init.o
  CC      ipc/mq_sysctl.o
  CC      fs/file.o
  CC      mm/mmu_context.o
  LD      ipc/built-in.o
  CC      security/apparmor/apparmorfs.o
  CC      mm/percpu.o
  CC      fs/filesystems.o
  CC      kernel/pid.o
  CC      security/apparmor/audit.o
  CC      fs/namespace.o
  CC      kernel/task_work.o
  CC      mm/slab_common.o
  CC      security/apparmor/capability.o
  CC      kernel/extable.o
  CC      security/apparmor/context.o
  CC      mm/compaction.o
  CC      kernel/params.o
  CC      security/apparmor/ipc.o
  CC      kernel/posix-timers.o
  CC      security/apparmor/lib.o
  CC      mm/balloon_compaction.o
  CC      security/apparmor/match.o
  CC      fs/seq_file.o
  CC      mm/vmacache.o
  CC      security/apparmor/path.o
  CC      mm/interval_tree.o
  CC      kernel/kthread.o
  CC      fs/xattr.o
  CC      security/apparmor/domain.o
  CC      mm/list_lru.o
  CC      kernel/posix-cpu-timers.o
  CC      mm/fremap.o
  CC      fs/libfs.o
  CC      security/apparmor/policy.o
  CC      mm/highmem.o
  CC      kernel/hrtimer.o
  CC      mm/madvise.o
  CC      fs/fs-writeback.o
  CC      security/apparmor/policy_unpack.o
  CC      mm/memory.o
  CC      security/apparmor/procattr.o
  CC      kernel/nsproxy.o
  CC      security/apparmor/lsm.o
  CC      kernel/notifier.o
  CC      fs/pnode.o
  CC      kernel/ksysfs.o
  CC      fs/splice.o
  CC      kernel/cred.o
  CC      security/apparmor/resource.o
  CC      mm/mincore.o
  CC      kernel/reboot.o
  CC      security/apparmor/file.o
  CC      mm/mlock.o
  CC      kernel/async.o
  CC      fs/sync.o
  CC      security/apparmor/crypto.o
  CC      kernel/groups.o
  LD      security/apparmor/apparmor.o
  LD      security/apparmor/built-in.o
  CC      fs/utimes.o
  CC      mm/mmap.o
  CC      security/keys/gc.o
  CC      fs/stack.o
  CC      kernel/smpboot.o
  CC      security/keys/key.o
  CC      fs/fs_struct.o
  CC      kernel/cpu/idle.o
  CC      fs/statfs.o
  CC      security/keys/keyring.o
  LD      kernel/cpu/built-in.o
  CC      kernel/debug/debug_core.o
  CC      fs/buffer.o
  CC      mm/mprotect.o
  CC      security/keys/keyctl.o
  CC      mm/mremap.o
  CC      kernel/debug/gdbstub.o
  CC      mm/msync.o
  CC      security/keys/permission.o
  LD      kernel/debug/built-in.o
  CC      mm/rmap.o
  CC      kernel/events/core.o
  CC      security/keys/process_keys.o
  CC      security/keys/request_key.o
  CC      fs/bio.o
  CC      mm/vmalloc.o
  CC      security/keys/request_key_auth.o
  CC      security/keys/user_defined.o
  CC      security/keys/proc.o
  CC      security/keys/sysctl.o
  CC      fs/block_dev.o
  LD      security/keys/built-in.o
  CC      security/selinux/avc.o
  CC      mm/pagewalk.o
  CC      mm/pgtable-generic.o
  CC      mm/process_vm_access.o
  CC      fs/direct-io.o
  CC      security/selinux/hooks.o
  CC      kernel/events/ring_buffer.o
  CC      mm/nobootmem.o
  CC      kernel/events/callchain.o
  CC      mm/memblock.o
  CC      kernel/events/hw_breakpoint.o
  LD      kernel/events/built-in.o
  CC      fs/mpage.o
  CC      kernel/irq/irqdesc.o
  CC      mm/page_io.o
  CC      kernel/irq/handle.o
  CC      fs/ioprio.o
  CC      mm/swap_state.o
  CC      kernel/irq/manage.o
  CC      fs/proc_namespace.o
  CC      mm/swapfile.o
  CC      security/selinux/selinuxfs.o
  CC      kernel/irq/spurious.o
  CC      fs/btrfs/super.o
  CC      kernel/irq/resend.o
  CC      kernel/irq/chip.o
  CC      security/selinux/netlink.o
  CC      kernel/irq/devres.o
  CC      security/selinux/nlmsgtab.o
  CC      mm/frontswap.o
  CC      kernel/irq/autoprobe.o
  CC      mm/dmapool.o
  CC      security/selinux/netif.o
  CC      kernel/irq/irqdomain.o
  CC      mm/hugetlb.o
  CC      security/selinux/netnode.o
  CC      kernel/irq/proc.o
  CC      fs/btrfs/ctree.o
  CC      security/selinux/netport.o
  CC      kernel/irq/pm.o
  LD      kernel/irq/built-in.o
  CC      kernel/locking/mutex.o
  CC      security/selinux/exports.o
  CC      security/selinux/ss/ebitmap.o
  CC      kernel/locking/semaphore.o
  CC      kernel/locking/rwsem.o
  CC      mm/sparse.o
  CC      kernel/locking/lglock.o
  CC      security/selinux/ss/hashtab.o
  CC      kernel/locking/rtmutex.o
  CC      mm/sparse-vmemmap.o
  CC      security/selinux/ss/sidtab.o
  CC      kernel/locking/rwsem-spinlock.o
  CC      mm/slub.o
  LD      kernel/locking/built-in.o
  CC      kernel/power/qos.o
  CC      security/selinux/ss/avtab.o
  CC      kernel/power/main.o
  CC      security/selinux/ss/policydb.o
  CC      kernel/power/console.o
  CC      kernel/power/process.o
  CC      kernel/power/suspend.o
  CC      mm/migrate.o
  CC      kernel/power/hibernate.o
  CC      security/selinux/ss/services.o
  CC      kernel/power/snapshot.o
  CC      fs/btrfs/extent-tree.o
  CC      mm/memcontrol.o
mm/memcontrol.c: In function 'mem_cgroup_allow_attach':
mm/memcontrol.c:7116:36: error: passing argument 1 of 'subsys_cgroup_allow_attach' from incompatible pointer type [-Werror]
  return subsys_cgroup_allow_attach(css->cgroup, tset);
In file included from include/linux/memcontrol.h:22:0,
                 from mm/memcontrol.c:29:
include/linux/cgroup.h:860:5: note: expected 'struct cgroup_subsys_state *' but argument is of type 'struct cgroup *'
 int subsys_cgroup_allow_attach(struct cgroup_subsys_state *css,
  CC      kernel/power/wakelock_android.o
  CC      security/selinux/ss/conditional.o
  CC      kernel/power/userwakelock.o
  CC      kernel/power/earlysuspend.o
  CC      security/selinux/ss/mls.o
  CC      kernel/power/wakeup_reason.o
  LD      kernel/power/built-in.o
  CC      kernel/printk/printk.o
  CC      security/selinux/ss/status.o
cc1: all warnings being treated as errors
make[1]: *** [scripts/Makefile.build:308: mm/memcontrol.o] Error 1
make: *** [Makefile:859: mm] Error 2
make: *** Waiting for unfinished jobs....
  CC      security/selinux/netlabel.o
  CC      kernel/rcu/update.o
  LD      security/selinux/selinux.o
  LD      security/selinux/built-in.o
  CC      security/smack/smack_lsm.o
  LD      kernel/printk/built-in.o
  CC      kernel/rcu/srcu.o
  CC      kernel/rcu/tree.o
  CC      fs/btrfs/print-tree.o
  CC      kernel/rcu/tree_trace.o
  CC      fs/btrfs/root-tree.o
  CC      fs/btrfs/dir-item.o
  CC      security/smack/smack_access.o
  CC      fs/btrfs/file-item.o
  CC      fs/btrfs/inode-item.o
  CC      security/smack/smackfs.o
  CC      fs/btrfs/inode-map.o
  CC      fs/btrfs/disk-io.o
  LD      kernel/rcu/built-in.o
  CC      kernel/sched/core.o
  CC      fs/btrfs/transaction.o
  LD      security/smack/smack.o
  LD      security/smack/built-in.o
  CC      security/commoncap.o
  CC      security/min_addr.o
  CC      security/security.o
  CC      fs/btrfs/inode.o
  CC      kernel/sched/proc.o
  CC      security/capability.o
  CC      kernel/sched/clock.o
  CC      kernel/sched/cputime.o
  CC      kernel/sched/idle_task.o
  CC      security/inode.o
  CC      kernel/sched/fair.o
  CC      kernel/sched/rt.o
  CC      security/lsm_audit.o
  CC      kernel/sched/deadline.o
  CC      security/device_cgroup.o
  LD      security/built-in.o
  CC      kernel/sched/stop_task.o
  CC      kernel/sched/wait.o
  CC      kernel/sched/completion.o
  CC      fs/btrfs/file.o
  CC      kernel/sched/cpupri.o
  CC      kernel/sched/cpudeadline.o
  CC      kernel/sched/cpuacct.o
  CC      fs/btrfs/tree-defrag.o
  CC      fs/btrfs/extent_map.o
  CC      fs/btrfs/sysfs.o
  CC      fs/btrfs/struct-funcs.o
  LD      kernel/sched/built-in.o
  CC      kernel/time/timekeeping.o
  CC      fs/btrfs/xattr.o
  CC      fs/btrfs/ordered-data.o
  CC      fs/btrfs/extent_io.o
  CC      fs/btrfs/volumes.o
  CC      fs/btrfs/async-thread.o
  CC      fs/btrfs/ioctl.o
  CC      kernel/time/ntp.o
  CC      kernel/time/clocksource.o
  CC      kernel/time/jiffies.o
  CC      kernel/time/timer_list.o
  CC      kernel/time/timeconv.o
  CC      fs/btrfs/locking.o
  CC      kernel/time/posix-clock.o
  CC      fs/btrfs/orphan.o
  CC      fs/btrfs/export.o
  CC      fs/btrfs/tree-log.o
  CC      kernel/time/alarmtimer.o
  CC      fs/btrfs/free-space-cache.o
  CC      fs/btrfs/zlib.o
  CC      kernel/time/clockevents.o
  CC      fs/btrfs/lzo.o
  CC      kernel/time/tick-common.o
  CC      fs/btrfs/compression.o
  CC      kernel/time/tick-broadcast.o
  CC      fs/btrfs/delayed-ref.o
  CC      kernel/time/sched_clock.o
  CC      fs/btrfs/relocation.o
  CC      kernel/time/tick-oneshot.o
  CC      fs/btrfs/delayed-inode.o
  CC      kernel/time/tick-sched.o
  CC      fs/btrfs/scrub.o
  CC      kernel/time/timer_stats.o
  CC      fs/btrfs/reada.o
  CC      kernel/time/timekeeping_debug.o
  LD      kernel/time/built-in.o
  CC      kernel/trace/trace_clock.o
  CC      kernel/trace/ftrace.o
  CC      fs/btrfs/backref.o
  CC      kernel/trace/ring_buffer.o
  CC      fs/btrfs/ulist.o
  CC      fs/btrfs/qgroup.o
  CC      kernel/freezer.o
  CC      kernel/trace/trace.o
  CC      kernel/trace/trace_output.o
  CC      kernel/profile.o
  CC      fs/btrfs/send.o
  CC      kernel/stacktrace.o
  CC      kernel/trace/trace_stat.o
  CC      kernel/futex.o
  CC      kernel/trace/trace_printk.o
  CC      kernel/trace/trace_sched_switch.o
  CC      kernel/trace/trace_functions.o
  CC      kernel/trace/trace_nop.o
  CC      kernel/futex_compat.o
  CC      kernel/trace/trace_stack.o
  CC      kernel/trace/trace_functions_graph.o
  CC      kernel/smp.o
  CC      kernel/trace/blktrace.o
  CC      fs/btrfs/dev-replace.o
  CC      kernel/trace/trace_events.o
  CC      kernel/uid16.o
  CC      kernel/trace/trace_export.o
  CC      kernel/trace/trace_event_perf.o
  CC      kernel/module.o
  CC      fs/btrfs/raid56.o
  CC      kernel/trace/trace_events_filter.o
  CC      kernel/trace/trace_events_trigger.o
  CC      kernel/trace/power-traces.o
  CC      fs/btrfs/uuid-tree.o
  CC      kernel/trace/rpm-traces.o
  CC      fs/btrfs/props.o
  CC      kernel/kallsyms.o
  LD      kernel/trace/libftrace.o
  CC      kernel/compat.o
  LD      kernel/trace/built-in.o
  CC      kernel/cgroup.o
  CC      kernel/cgroup_freezer.o
  CC      fs/btrfs/hash.o
  CC      fs/btrfs/acl.o
  CC      kernel/cpuset.o
  CC      kernel/utsname.o
  CC      fs/btrfs/tests/free-space-tests.o
  CC      kernel/user_namespace.o
  CC      fs/btrfs/tests/extent-buffer-tests.o
  CC      fs/btrfs/tests/btrfs-tests.o
  CC      kernel/pid_namespace.o
  GZIP    kernel/config_data.gz
  CC      kernel/res_counter.o
  CC      fs/btrfs/tests/extent-io-tests.o
  CC      kernel/stop_machine.o
  CC      kernel/audit.o
  CC      kernel/auditfilter.o
  CC      fs/btrfs/tests/inode-tests.o
  CC      kernel/utsname_sysctl.o
  CC      kernel/tracepoint.o
  LD      fs/btrfs/btrfs.o
  CC      fs/cachefiles/bind.o
  LD      fs/btrfs/built-in.o
  CC      fs/configfs/inode.o
  CC      kernel/elfcore.o
  CC      kernel/irq_work.o
  CC      fs/cachefiles/daemon.o
  CC      fs/configfs/file.o
  CC      fs/cifs/cifsfs.o
  CC      kernel/cpu_pm.o
  CC      fs/configfs/dir.o
  CC      fs/cachefiles/interface.o
  CC      kernel/padata.o
  CC      fs/cifs/cifssmb.o
  CC      fs/cachefiles/key.o
  CC      fs/configfs/symlink.o
  CC      kernel/jump_label.o
  CC      fs/cachefiles/main.o
  CC      fs/configfs/mount.o
  CHK     kernel/config_data.h
  UPD     kernel/config_data.h
  CC      kernel/configs.o
  CC      fs/cachefiles/namei.o
  CC      fs/configfs/item.o
  LD      kernel/built-in.o
  LD      fs/configfs/configfs.o
  LD      fs/configfs/built-in.o
  CC      fs/cramfs/inode.o
  CC      fs/cachefiles/rdwr.o
  CC      fs/cifs/cifs_debug.o
  LD      fs/cramfs/cramfs.o
  LD      fs/cramfs/built-in.o
  CC      fs/debugfs/inode.o
  CC      fs/cachefiles/security.o
  CC      fs/cachefiles/xattr.o
  CC      fs/cifs/connect.o
  CC      fs/cifs/dir.o
  CC      fs/debugfs/file.o
  LD      fs/cachefiles/cachefiles.o
  LD      fs/cachefiles/built-in.o
  LD      fs/debugfs/debugfs.o
  LD      fs/debugfs/built-in.o
  CC      fs/cifs/file.o
  CC      fs/devpts/inode.o
  CC      fs/exportfs/expfs.o
  LD      fs/exportfs/exportfs.o
  LD      fs/exportfs/built-in.o
  LD      fs/devpts/devpts.o
  LD      fs/devpts/built-in.o
  CC      fs/cifs/inode.o
  CC      fs/ext4/balloc.o
  CC      fs/ext4/bitmap.o
  CC      fs/ext4/dir.o
  CC      fs/ext4/file.o
  CC      fs/cifs/link.o
  CC      fs/ext4/fsync.o
  CC      fs/cifs/misc.o
  CC      fs/ext4/ialloc.o
  CC      fs/cifs/netmisc.o
  CC      fs/ext4/inode.o
  CC      fs/cifs/smbencrypt.o
  CC      fs/cifs/transport.o
  CC      fs/cifs/asn1.o
  CC      fs/ext4/page-io.o
  CC      fs/cifs/cifs_unicode.o
  CC      fs/cifs/nterr.o
  CC      fs/ext4/ioctl.o
  CC      fs/cifs/xattr.o
  CC      fs/cifs/cifsencrypt.o
  CC      fs/ext4/namei.o
  CC      fs/cifs/readdir.o
  CC      fs/ext4/super.o
  CC      fs/cifs/ioctl.o
  CC      fs/cifs/sess.o
  CC      fs/cifs/export.o
  CC      fs/ext4/symlink.o
  CC      fs/cifs/smb1ops.o
  CC      fs/ext4/hash.o
  CC      fs/ext4/resize.o
  CC      fs/ext4/extents.o
  CC      fs/cifs/dns_resolve.o
  CC      fs/cifs/cifs_dfs_ref.o
  CC      fs/ext4/ext4_jbd2.o
  CC      fs/cifs/smb2ops.o
  CC      fs/ext4/migrate.o
  CC      fs/cifs/smb2maperror.o
  CC      fs/ext4/mballoc.o
  CC      fs/ext4/block_validity.o
  CC      fs/cifs/smb2transport.o
  CC      fs/ext4/move_extent.o
  CC      fs/cifs/smb2misc.o
  CC      fs/ext4/mmp.o
  CC      fs/cifs/smb2pdu.o
  CC      fs/ext4/indirect.o
  CC      fs/ext4/extents_status.o
  CC      fs/cifs/smb2inode.o
  CC      fs/ext4/xattr.o
  CC      fs/ext4/xattr_user.o
  CC      fs/ext4/xattr_trusted.o
  CC      fs/ext4/inline.o
  CC      fs/ext4/acl.o
  CC      fs/cifs/smb2file.o
  CC      fs/ext4/xattr_security.o
  CC      fs/fat/cache.o
  LD      fs/cifs/cifs.o
  LD      fs/cifs/built-in.o
  CC      fs/fscache/cache.o
  CC      fs/fscache/cookie.o
  CC      fs/fat/dir.o
  LD      fs/ext4/ext4.o
  LD      fs/ext4/built-in.o
  CC      fs/hugetlbfs/inode.o
  CC      fs/isofs/namei.o
  CC      fs/fscache/fsdef.o
  CC      fs/fscache/main.o
  CC      fs/isofs/inode.o
  CC      fs/fscache/netfs.o
  LD      fs/hugetlbfs/hugetlbfs.o
  LD      fs/hugetlbfs/built-in.o
  CC      fs/fat/fatent.o
  CC      fs/jbd2/transaction.o
  CC      fs/fscache/object.o
  CC      fs/isofs/dir.o
  CC      fs/fat/file.o
  CC      fs/fscache/operation.o
  CC      fs/isofs/util.o
  CC      fs/isofs/rock.o
  CC      fs/fat/inode.o
  CC      fs/fscache/page.o
  CC      fs/jbd2/commit.o
  CC      fs/isofs/export.o
  CC      fs/fscache/proc.o
  CC      fs/isofs/joliet.o
  CC      fs/fat/misc.o
  LD      fs/fscache/fscache.o
  LD      fs/fscache/built-in.o
  CC      fs/isofs/compress.o
  CC      fs/fat/nfs.o
  CC      fs/jbd2/recovery.o
  CC      fs/fat/namei_msdos.o
  CC      fs/fat/namei_vfat.o
  LD      fs/isofs/isofs.o
  LD      fs/isofs/built-in.o
  LD      fs/jfs/built-in.o
  CC      fs/kernfs/mount.o
  CC      fs/jbd2/checkpoint.o
  CC      fs/jbd2/revoke.o
  CC      fs/kernfs/inode.o
  LD      fs/fat/fat.o
  LD      fs/fat/vfat.o
  LD      fs/fat/msdos.o
  LD      fs/fat/built-in.o
  CC      fs/kernfs/dir.o
  CC      fs/jbd2/journal.o
  CC      fs/lockd/clntlock.o
  CC      fs/nfs/client.o
  CC      fs/kernfs/file.o
  CC      fs/lockd/clntproc.o
  CC      fs/kernfs/symlink.o
  LD      fs/kernfs/built-in.o
  CC      fs/nfs/dir.o
  CC      fs/lockd/clntxdr.o
  CC      fs/nfs/file.o
  LD      fs/jbd2/jbd2.o
  LD      fs/jbd2/built-in.o
  CC      fs/nfs/getroot.o
  CC      fs/lockd/host.o
  CC      fs/nls/nls_base.o
  CC      fs/nfs/inode.o
  CC      fs/nfs/super.o
  CC      fs/nls/nls_cp437.o
  CC      fs/nls/nls_ascii.o
  CC      fs/lockd/svc.o
  CC      fs/nls/nls_iso8859-1.o
  CC      fs/nls/nls_utf8.o
  LD      fs/nls/built-in.o
  CC      fs/lockd/svclock.o
  CC      fs/notify/fsnotify.o
  CC      fs/nfs/direct.o
  CC      fs/nfs/pagelist.o
  CC      fs/notify/notification.o
  CC      fs/lockd/svcshare.o
  CC      fs/notify/group.o
  CC      fs/nfs/read.o
  CC      fs/nfs/symlink.o
  CC      fs/notify/inode_mark.o
  CC      fs/lockd/svcproc.o
  CC      fs/notify/mark.o
  CC      fs/nfs/unlink.o
  CC      fs/nfs/write.o
  CC      fs/lockd/svcsubs.o
  CC      fs/notify/vfsmount_mark.o
  CC      fs/notify/fdinfo.o
  CC      fs/nfs/namespace.o
  CC      fs/lockd/mon.o
  CC      fs/notify/dnotify/dnotify.o
  CC      fs/nfs/mount_clnt.o
  CC      fs/lockd/xdr.o
  LD      fs/notify/dnotify/built-in.o
  CC      fs/notify/fanotify/fanotify.o
  CC      fs/proc/task_mmu.o
  CC      fs/notify/fanotify/fanotify_user.o
  CC      fs/nfs/nfstrace.o
  CC      fs/lockd/grace.o
  LD      fs/notify/fanotify/built-in.o
  CC      fs/lockd/clnt4xdr.o
  CC      fs/proc/inode.o
  CC      fs/proc/root.o
  CC      fs/lockd/xdr4.o
  CC      fs/nfs/nfsroot.o
  CC      fs/proc/base.o
  CC      fs/lockd/svc4proc.o
  CC      fs/nfs/sysctl.o
  LD      fs/lockd/lockd.o
  LD      fs/lockd/built-in.o
  CC      fs/nfs/nfs4filelayout.o
  CC      fs/quota/dquot.o
  CC      fs/proc/generic.o
  CC      fs/proc/array.o
  CC      fs/proc/fd.o
  CC      fs/nfs/nfs4filelayoutdev.o
  CC      fs/quota/quota_v2.o
  CC      fs/proc/proc_tty.o
  CC      fs/quota/quota_tree.o
  CC      fs/proc/cmdline.o
  CC      fs/nfs/nfs2super.o
  CC      fs/proc/consoles.o
  CC      fs/proc/cpuinfo.o
  CC      fs/quota/quota.o
  CC      fs/proc/devices.o
  CC      fs/nfs/proc.o
  CC      fs/proc/interrupts.o
  CC      fs/proc/loadavg.o
  CC      fs/proc/meminfo.o
  CC      fs/quota/kqid.o
  CC      fs/nfs/nfs2xdr.o
  LD      fs/quota/built-in.o
  CC      fs/proc/stat.o
  CC      fs/proc/uptime.o
  CC      fs/notify/inotify/inotify_fsnotify.o
  CC      fs/proc/version.o
  CC      fs/proc/softirqs.o
  CC      fs/notify/inotify/inotify_user.o
  CC      fs/proc/namespaces.o
  CC      fs/proc/self.o
  CC      fs/nfs/nfs3super.o
  CC      fs/ramfs/inode.o
  CC      fs/proc/proc_sysctl.o
  LD      fs/notify/inotify/built-in.o
  LD      fs/notify/built-in.o
  LD      fs/reiserfs/built-in.o
  CC      fs/nfs/nfs3client.o
  CC      fs/sysfs/file.o
  CC      fs/ramfs/file-mmu.o
  LD      fs/ramfs/ramfs.o
  LD      fs/ramfs/built-in.o
  CC      fs/nfs/nfs3proc.o
  CC      fs/sysfs/dir.o
  CC      fs/ubifs/shrinker.o
  CC      fs/proc/proc_net.o
  CC      fs/sysfs/symlink.o
  CC      fs/proc/kcore.o
  CC      fs/ubifs/journal.o
  CC      fs/sysfs/mount.o
  CC      fs/nfs/nfs3xdr.o
  CC      fs/sysfs/group.o
  CC      fs/proc/proc_devtree.o
  LD      fs/sysfs/built-in.o
  CC      fs/ubifs/file.o
  CC      fs/proc/kmsg.o
  CC      fs/ubifs/dir.o
  CC      fs/proc/page.o
  CC      fs/nfs/nfs4proc.o
  CC      fs/nfs/nfs4xdr.o
  LD      fs/proc/proc.o
  LD      fs/proc/built-in.o
  CC      fs/ubifs/super.o
  CC      fs/udf/balloc.o
  CC      fs/udf/dir.o
  CC      fs/udf/file.o
  CC      fs/ubifs/sb.o
  CC      fs/udf/ialloc.o
  CC      fs/udf/inode.o
  CC      fs/ubifs/io.o
  CC      fs/ubifs/tnc.o
  CC      fs/nfs/nfs4state.o
  CC      fs/udf/lowlevel.o
  CC      fs/nfs/nfs4renewd.o
  CC      fs/udf/namei.o
  CC      fs/nfs/nfs4super.o
  CC      fs/ubifs/master.o
  CC      fs/nfs/nfs4file.o
  CC      fs/udf/partition.o
  CC      fs/ubifs/scan.o
  CC      fs/nfs/delegation.o
  CC      fs/nfs/idmap.o
  CC      fs/udf/super.o
  CC      fs/ubifs/replay.o
  CC      fs/nfs/callback.o
  CC      fs/ubifs/log.o
  CC      fs/ubifs/commit.o
  CC      fs/udf/truncate.o
  CC      fs/ubifs/gc.o
  CC      fs/nfs/callback_xdr.o
  CC      fs/ubifs/orphan.o
  CC      fs/udf/symlink.o
  CC      fs/ubifs/budget.o
  CC      fs/udf/directory.o
  CC      fs/ubifs/find.o
  CC      fs/nfs/callback_proc.o
  CC      fs/udf/misc.o
  CC      fs/ubifs/tnc_commit.o
  CC      fs/udf/udftime.o
  CC      fs/ubifs/compress.o
  CC      fs/nfs/nfs4namespace.o
  CC      fs/ubifs/lpt.o
  CC      fs/udf/unicode.o
  CC      fs/ubifs/lprops.o
  LD      fs/udf/udf.o
  LD      fs/udf/built-in.o
  CC      fs/ubifs/recovery.o
  CC      fs/nfs/nfs4getroot.o
  CC      fs/nfs/nfs4client.o
  CC      fs/ubifs/ioctl.o
  CC      fs/ubifs/lpt_commit.o
  CC      fs/ubifs/tnc_misc.o
  CC      fs/ubifs/xattr.o
  CC      fs/nfs/nfs4session.o
  CC      fs/ubifs/debug.o
  CC      fs/nfs/dns_resolve.o
  CC      fs/nfs/nfs4trace.o
  LD      fs/xfs/built-in.o
  CC      fs/eventpoll.o
  CC      fs/nfs/nfs4sysctl.o
  CC      fs/nfs/pnfs.o
  CC      fs/anon_inodes.o
  LD      fs/ubifs/ubifs.o
  LD      fs/ubifs/built-in.o
  CC      fs/signalfd.o
  CC      fs/timerfd.o
  CC      fs/nfs/pnfs_dev.o
  CC      fs/eventfd.o
  CC      fs/aio.o
  CC      fs/locks.o
  CC      fs/compat.o
  LD      fs/nfs/nfs.o
  LD      fs/nfs/nfsv2.o
  LD      fs/nfs/nfsv3.o
  LD      fs/nfs/nfsv4.o
  LD      fs/nfs/nfs_layout_nfsv41_files.o
  LD      fs/nfs/built-in.o
  CC      fs/compat_ioctl.o
  CC      fs/binfmt_misc.o
  CC      fs/binfmt_script.o
  CC      fs/binfmt_elf.o
  CC      fs/compat_binfmt_elf.o
  CC      fs/mbcache.o
  CC      fs/posix_acl.o
  CC      fs/coredump.o
  CC      fs/drop_caches.o
  CC      fs/fhandle.o
  CC      fs/dcookies.o
  LD      fs/built-in.o
~/Amlogic_s905-kernel  3.14 ✗        82d ✖ ⚑ ◒  ⍉
▶ ./set_make
  CC      arch/arm64/kernel/cputable.o
  CC      arch/arm64/kernel/io.o
  CC      arch/arm64/kernel/cpu_ops.o
  CC      mm/memcontrol.o
  AS      arch/arm64/kernel/psci-call.o
  AS      arch/arm64/kernel/kuser32.o
  AS      arch/arm64/kernel/entry-ftrace.o
  CC      arch/arm64/kernel/smp_spin_table.o
  CC      arch/arm64/kernel/early_printk.o
  CC      arch/arm64/kernel/jump_label.o
  CC      crypto/api.o
  CC      block/elevator.o
  CC      crypto/cipher.o
  CC      block/blk-core.o
  CC      crypto/compress.o
  CC      drivers/amba/bus.o
  CC      crypto/memneq.o
  LD      drivers/amba/built-in.o
  CC      drivers/amlogic/amaudio/amaudio.o
  CC      crypto/algapi.o
  LD      drivers/amlogic/amaudio/amlogic_amaudio.o
  LD      drivers/amlogic/amaudio/built-in.o
  CC      drivers/amlogic/amaudio2/amaudio2.o
  CC      drivers/amlogic/amlnf/dev/amlnf_ctrl.o
  CC      crypto/scatterwalk.o
  CC      drivers/amlogic/amlnf/dev/amlnf_dev.o
  CC      crypto/proc.o
  LD      drivers/amlogic/amaudio2/amlogic_amaudio2.o
  LD      drivers/amlogic/amaudio2/built-in.o
  CC      drivers/amlogic/amports/amstream.o
  CC      crypto/ablkcipher.o
  CC      drivers/amlogic/amlnf/dev/amlnf_env.o
  CC      block/blk-tag.o
  CC      drivers/amlogic/amlnf/dev/amlnf_dtb.o
  CC      block/blk-sysfs.o
  CC      crypto/blkcipher.o
  CC      drivers/amlogic/amlnf/dev/phydev.o
  CC      block/blk-flush.o
  CC      crypto/ahash.o
  CC      block/blk-settings.o
  CC      drivers/amlogic/amports/streambuf.o
  CC      crypto/shash.o
  CC      drivers/amlogic/amlnf/dev/nandkey.o
  CC      block/blk-ioc.o
  CC      drivers/amlogic/amports/vdec.o
  CC      drivers/amlogic/amlnf/dev/secure_storage.o
  CC      block/blk-map.o
  CC      crypto/algboss.o
  LD      drivers/amlogic/amlnf/dev/amlnf_api.o
  LD      drivers/amlogic/amlnf/dev/built-in.o
  CC      drivers/amlogic/amlnf/ntd/aml_ntd_blkdevs.o
  CC      block/blk-exec.o
  CC      crypto/testmgr.o
  CC      block/blk-merge.o
  CC      crypto/crypto_wq.o
  CC      drivers/amlogic/amlnf/ntd/aml_ntdcore.o
  LD      crypto/crypto_algapi.o
  CC      crypto/aead.o
  CC      drivers/amlogic/amlnf/ntd/aml_ntdpart.o
  CC      drivers/amlogic/amports/adec.o
  CC      block/blk-softirq.o
  LD      crypto/crypto_blkcipher.o
  CC      crypto/chainiv.o
  LD      drivers/amlogic/amlnf/ntd/aml_ntd.o
  LD      drivers/amlogic/amlnf/ntd/built-in.o
  CC      drivers/amlogic/amlnf/phy/chip.o
  CC      block/blk-timeout.o
  CC      drivers/amlogic/amports/tsdemux.o
  CC      crypto/eseqiv.o
  CC      block/blk-iopoll.o
  CC      drivers/amlogic/amlnf/phy/chip_operation.o
  CC      drivers/amlogic/amports/psparser.o
  CC      crypto/seqiv.o
  CC      block/blk-lib.o
  LD      crypto/crypto_hash.o
  CC      crypto/pcompress.o
  CC      block/blk-mq.o
  CC      drivers/amlogic/amports/esparser.o
  CC      drivers/amlogic/amlnf/phy/chipenv.o
  LD      crypto/cryptomgr.o
  CC      crypto/cmac.o
  CC      crypto/hmac.o
  CC      drivers/amlogic/amports/amvdec.o
  CC      block/blk-mq-tag.o
  CC      crypto/md4.o
  CC      block/blk-mq-sysfs.o
  CC      crypto/md5.o
  CC      drivers/amlogic/amlnf/phy/amlnand_init.o
  CC      drivers/amlogic/amports/amstream_profile.o
  CC      block/blk-mq-cpu.o
  CC      crypto/sha1_generic.o
  CC      drivers/amlogic/amports/tsync_pcr.o
  CC      drivers/amlogic/amlnf/phy/hw_controller.o
  CC      block/blk-mq-cpumap.o
  CC      crypto/sha256_generic.o
  CC      block/ioctl.o
  CC      drivers/amlogic/amlnf/phy/id_table.o
  CC      drivers/amlogic/amports/amports_gate.o
  CC      drivers/amlogic/amlnf/phy/new_nand.o
  CC      block/genhd.o
  CC      crypto/ecb.o
  CC      drivers/amlogic/amports/gp_pll.o
  CC      crypto/cbc.o
  CC      drivers/amlogic/amports/thread_rw.o
  CC      crypto/pcbc.o
  CC      block/scsi_ioctl.o
  CC      crypto/ctr.o
  CC      drivers/amlogic/amports/vdec_input.o
  CC      block/partition-generic.o
  CC      drivers/amlogic/amlnf/phy/boot_operation.o
  CC      crypto/ccm.o
  CC      drivers/amlogic/amports/config_parser.o
  LD      drivers/amlogic/amlnf/phy/amlnf_phy.o
  CC      block/partitions/check.o
  CC      drivers/amlogic/amports/amvideocap.o
  LD      drivers/amlogic/amlnf/phy/built-in.o
  LD      drivers/amlogic/amlnf/built-in.o
  CC      drivers/amlogic/amvecm/amve.o
  CC      crypto/des_generic.o
  CC      block/partitions/mac.o
  CC      block/partitions/ldm.o
  CC      drivers/amlogic/amports/tsync.o
  CC      crypto/aes_generic.o
  CC      drivers/amlogic/amports/timestamp.o
  CC      block/partitions/msdos.o
  CC      crypto/arc4.o
  CC      drivers/amlogic/amports/vavs.o
  CC      block/partitions/efi.o
  CC      crypto/deflate.o
  CC      crypto/crc32c.o
  LD      block/partitions/built-in.o
  CC      block/bsg.o
  CC      crypto/crct10dif_common.o
  CC      drivers/amlogic/amports/avsp_trans.o
  CC      crypto/crct10dif_generic.o
  CC      crypto/authenc.o
  CC      block/bsg-lib.o
  CC      drivers/amlogic/amvecm/amcm.o
  CC      block/blk-cgroup.o
  CC      crypto/authencesn.o
  CC      drivers/amlogic/amvecm/amcsc.o
  CC      drivers/amlogic/amports/vh264.o
  CC      block/blk-throttle.o
  CC      crypto/lzo.o
  CC      crypto/rng.o
  CC      crypto/krng.o
  CC      block/noop-iosched.o
  CC      crypto/xor.o
  CC      drivers/amlogic/amports/vh264_4k2k.o
  CC      block/deadline-iosched.o
  CC      drivers/amlogic/amvecm/amvecm.o
  CC      block/cfq-iosched.o
  LD      crypto/crypto.o
  LD      crypto/built-in.o
  CC      block/compat_ioctl.o
  CC      drivers/amlogic/amports/vh264mvc.o
  CC      drivers/amlogic/amports/vh265.o
  CC      drivers/amlogic/amports/vmjpeg.o
  LD      block/built-in.o
  CC      drivers/amlogic/amports/vmpeg12.o
  CC      drivers/amlogic/amports/vmpeg4.o
  CC      drivers/amlogic/amvecm/amdolby_vision.o
  CC      drivers/amlogic/amports/vreal.o
  CC      drivers/amlogic/amports/rmparser.o
  CC      drivers/amlogic/amports/vvc1.o
  CC      drivers/amlogic/amports/vvp9.o
drivers/amlogic/amports/vvp9.c: In function 'prepare_display_buf':
drivers/amlogic/amports/vvp9.c:5675:3: error: 'gvs' undeclared (first use in this function)
   gvs->frame_dur = pbi->frame_dur;
drivers/amlogic/amports/vvp9.c:5675:3: note: each undeclared identifier is reported only once for each function it appears in
drivers/amlogic/amports/vvp9.c: In function 'vvp9_dec_status':
drivers/amlogic/amports/vvp9.c:6424:22: error: 'gvs' undeclared (first use in this function)
  vstatus->bit_rate = gvs->bit_rate;
make[3]: *** [scripts/Makefile.build:308: drivers/amlogic/amports/vvp9.o] Error 1
make[3]: *** Waiting for unfinished jobs....
  CC      drivers/amlogic/amvecm/keystone_correction.o
  CC      drivers/amlogic/amvecm/bitdepth.o
  CC      drivers/amlogic/audinfo_kernel/audio_data.o
  CC      drivers/amlogic/audiodsp/audiodsp_module.o
  LD      drivers/amlogic/audinfo_kernel/built-in.o
  CC      drivers/base/component.o
  LD      drivers/amlogic/amvecm/am_vecm.o
  LD      drivers/amlogic/amvecm/built-in.o
  LD      drivers/amlogic/audiodsp/audiodsp.o
  LD      drivers/amlogic/audiodsp/built-in.o
  CC      drivers/base/core.o
  CC      drivers/base/bus.o
  CC      drivers/base/dd.o
  CC      drivers/base/syscore.o
  CC      drivers/base/driver.o
  CC      drivers/base/class.o
  CC      drivers/base/platform.o
  CC      drivers/base/cpu.o
  CC      drivers/base/firmware.o
  CC      drivers/base/init.o
  CC      drivers/base/map.o
  CC      drivers/base/devres.o
  CC      drivers/base/attribute_container.o
  CC      drivers/base/transport_class.o
  CC      drivers/base/topology.o
  CC      drivers/base/container.o
  CC      drivers/base/devtmpfs.o
  CC      drivers/base/dma-contiguous.o
  CC      drivers/base/power/sysfs.o
  CC      drivers/base/power/generic_ops.o
  CC      drivers/base/power/common.o
  CC      drivers/base/power/qos.o
  CC      drivers/base/power/main.o
  CC      drivers/base/power/wakeup.o
  CC      drivers/base/power/runtime.o
  CC      drivers/base/power/opp.o
  CC      drivers/base/power/clock_ops.o
  LD      drivers/base/power/built-in.o
  CC      drivers/base/regmap/regmap.o
  CC      drivers/base/regmap/regcache.o
  CC      drivers/base/regmap/regcache-rbtree.o
  CC      drivers/base/regmap/regcache-lzo.o
  CC      drivers/base/regmap/regcache-flat.o
  CC      drivers/base/regmap/regmap-debugfs.o
  CC      drivers/base/regmap/regmap-i2c.o
  CC      drivers/base/regmap/regmap-spi.o
  CC      drivers/base/regmap/regmap-mmio.o
  LD      drivers/base/regmap/built-in.o
  CC      drivers/base/dma-mapping.o
  CC      drivers/base/dma-coherent.o
  CC      drivers/base/dma-buf.o
  CC      drivers/base/firmware_class.o
  CC      drivers/base/module.o
  CC      drivers/base/pinctrl.o
  LD      drivers/base/built-in.o
make[2]: *** [scripts/Makefile.build:455: drivers/amlogic/amports] Error 2
make[2]: *** Waiting for unfinished jobs....
  CC      drivers/block/loop.o
  CC      drivers/cdrom/cdrom.o
  CC      drivers/amlogic/bluetooth/bt_device.o
  LD      drivers/bluetooth/built-in.o
  CC      drivers/char/mem.o
  LD      drivers/amlogic/bluetooth/built-in.o
make[1]: *** [scripts/Makefile.build:455: drivers/amlogic] Error 2
make[1]: *** Waiting for unfinished jobs....
  CC      drivers/char/random.o
  CC      drivers/char/ttyprintk.o
  CC      drivers/char/misc.o
  CC      drivers/block/virtio_blk.o
  CC      drivers/char/hw_random/core.o
  LD      drivers/cdrom/built-in.o
  CC      drivers/char/hw_random/meson-rng.o
  LD      drivers/char/hw_random/rng-core.o
  LD      drivers/char/hw_random/built-in.o
  LD      drivers/block/built-in.o
  LD      drivers/char/built-in.o
make: *** [Makefile:859: drivers] Error 2
▶ ./set_make
  CC      mm/memcontrol.o
  CC      sound/sound_core.o
  LD      sound/arm/built-in.o
  LD      sound/atmel/built-in.o
  CC      sound/core/compress_offload.o
  CC      sound/core/pcm.o
  CC      sound/core/pcm_native.o
  CC      sound/core/pcm_lib.o
  CC      sound/core/pcm_timer.o
  CC      sound/core/pcm_misc.o
  CC      sound/core/pcm_memory.o
  CC      sound/core/memalloc.o
  CC      sound/core/timer.o
  CC      sound/core/sound.o
  CC      sound/core/init.o
  CC      sound/core/memory.o
  CC      sound/core/info.o
  CC      sound/core/control.o
  CC      sound/core/misc.o
  CC      sound/core/device.o
  CC      sound/core/vmaster.o
  CC      sound/core/jack.o
  LD      sound/drivers/mpu401/built-in.o
  LD      sound/drivers/opl3/built-in.o
  LD      sound/drivers/opl4/built-in.o
  LD      sound/drivers/pcsp/built-in.o
  LD      sound/drivers/vx/built-in.o
  LD      sound/drivers/built-in.o
  LD      sound/firewire/built-in.o
  LD      sound/i2c/other/built-in.o
  LD      sound/i2c/built-in.o
  LD      sound/isa/ad1816a/built-in.o
  LD      sound/isa/ad1848/built-in.o
  LD      sound/isa/cs423x/built-in.o
  LD      sound/mips/built-in.o
  LD      sound/isa/es1688/built-in.o
  LD      sound/isa/galaxy/built-in.o
  LD      sound/parisc/built-in.o
  LD      sound/isa/gus/built-in.o
  LD      sound/isa/msnd/built-in.o
  LD      sound/pci/ac97/built-in.o
  LD      sound/isa/sb/built-in.o
  LD      sound/isa/opti9xx/built-in.o
  LD      sound/pci/ali5451/built-in.o
  LD      sound/isa/wss/built-in.o
  LD      sound/isa/wavefront/built-in.o
  LD      sound/pci/asihpi/built-in.o
  LD      sound/isa/built-in.o
  LD      sound/pci/au88x0/built-in.o
  LD      sound/pci/aw2/built-in.o
  LD      sound/pcmcia/pdaudiocf/built-in.o
  LD      sound/pci/ca0106/built-in.o
  LD      sound/pci/cs46xx/built-in.o
  LD      sound/pcmcia/vx/built-in.o
  LD      sound/pcmcia/built-in.o
  LD      sound/pci/cs5535audio/built-in.o
  LD      sound/pci/ctxfi/built-in.o
  LD      sound/core/snd.o
  LD      sound/ppc/built-in.o
  LD      sound/pci/echoaudio/built-in.o
  LD      sound/pci/emu10k1/built-in.o
  LD      sound/core/snd-timer.o
  LD      sound/sh/built-in.o
  LD      sound/core/snd-pcm.o
  LD      sound/pci/hda/built-in.o
  LD      sound/core/snd-compress.o
  LD      sound/core/built-in.o
  CC      sound/soc/soc-core.o
  LD      sound/sparc/built-in.o
  CC      sound/soc/soc-dapm.o
  LD      sound/pci/ice1712/built-in.o
  LD      sound/pci/korg1212/built-in.o
  CC      sound/soc/soc-jack.o
  LD      sound/pci/lola/built-in.o
  LD      sound/pci/lx6464es/built-in.o
  LD      sound/pci/nm256/built-in.o
  LD      sound/pci/mixart/built-in.o
  CC      sound/soc/soc-cache.o
  LD      sound/pci/oxygen/built-in.o
  LD      sound/pci/pcxhr/built-in.o
  LD      sound/pci/riptide/built-in.o
  LD      sound/pci/rme9652/built-in.o
  LD      sound/pci/trident/built-in.o
  LD      sound/pci/vx222/built-in.o
  LD      sound/pci/ymfpci/built-in.o
  LD      sound/pci/built-in.o
  LD      sound/spi/built-in.o
  LD      sound/synth/built-in.o
  LD      sound/usb/6fire/built-in.o
  LD      sound/usb/caiaq/built-in.o
  LD      sound/usb/hiface/built-in.o
  CC      sound/soc/soc-utils.o
  LD      sound/usb/misc/built-in.o
  CC      sound/soc/soc-pcm.o
  LD      sound/usb/usx2y/built-in.o
  LD      sound/usb/built-in.o
  CC      sound/last.o
  LD      sound/soundcore.o
  CC      sound/soc/soc-compress.o
  CC      sound/soc/soc-io.o
  CC      sound/soc/soc-devres.o
  LD      sound/soc/adi/built-in.o
  CC      sound/soc/aml/m8/aml_dmic.o
  LD      sound/soc/atmel/built-in.o
  LD      sound/soc/au1x/built-in.o
  LD      sound/soc/bcm/built-in.o
  LD      sound/soc/blackfin/built-in.o
  CC      sound/soc/codecs/aml_codec_t9015.o
  LD      sound/soc/cirrus/built-in.o
  LD      sound/soc/davinci/built-in.o
  LD      sound/soc/dwc/built-in.o
  LD      sound/soc/fsl/built-in.o
  LD      sound/soc/generic/built-in.o
  CC      sound/soc/aml/m8/aml_g9tv.o
  LD      sound/soc/intel/built-in.o
  LD      sound/soc/jz4740/built-in.o
  LD      sound/soc/kirkwood/built-in.o
  LD      sound/soc/mxs/built-in.o
  LD      sound/soc/nuc900/built-in.o
  LD      sound/soc/omap/built-in.o
  LD      sound/soc/pxa/built-in.o
  LD      sound/soc/s6000/built-in.o
  LD      sound/soc/sh/built-in.o
  LD      sound/soc/samsung/built-in.o
  CC      sound/soc/codecs/aml_codec_t9015S.o
  CC      sound/soc/aml/m8/aml_audio_hw_pcm.o
  CC      sound/soc/codecs/aml_codec_txlx_acodec.o
  CC      sound/soc/aml/m8/aml_audio_hw.o
  CC      sound/soc/codecs/aml_pmu4_codec.o
  LD      sound/soc/spear/built-in.o
  CC      sound/soc/codecs/dummy_codec.o
  CC      sound/soc/aml/m8/aml_i2s_dai.o
  CC      sound/soc/aml/m8/aml_i2s.o
  CC      sound/soc/codecs/pcm2bt.o
  CC      sound/soc/codecs/tas5707.o
  CC      sound/soc/aml/m8/aml_m8.o
  CC      sound/soc/codecs/tas5717.o
  CC      sound/soc/codecs/tas5731.o
  CC      sound/soc/aml/m8/aml_pcm_dai.o
  CC      sound/soc/aml/m8/aml_pcm.o
  CC      sound/soc/codecs/tlv320aic32x4.o
  CC      sound/soc/aml/m8/aml_snd_iomap.o
  CC      sound/soc/aml/m8/aml_spdif_codec.o
  CC      sound/soc/aml/m8/aml_spdif_dai.o
  CC      sound/soc/aml/m8/aml_notify.o
  LD      sound/soc/codecs/snd-soc-tlv320aic32x4.o
  LD      sound/soc/codecs/snd-soc-dummy_codec.o
  LD      sound/soc/codecs/snd-soc-pcm2bt.o
  LD      sound/soc/codecs/snd-soc-amlpmu4.o
  LD      sound/soc/codecs/snd-soc-aml_t9015.o
  LD      sound/soc/tegra/built-in.o
  LD      sound/soc/codecs/snd-soc-aml_t9015S.o
  LD      sound/soc/codecs/snd-soc-aml_txlx_acodec.o
  LD      sound/soc/txx9/built-in.o
  LD      sound/soc/codecs/snd-soc-tas5707.o
  LD      sound/soc/codecs/snd-soc-tas5717.o
  LD      sound/soc/codecs/snd-soc-tas5731.o
  LD      sound/soc/ux500/built-in.o
  LD      sound/soc/codecs/built-in.o
  LD      sound/soc/snd-soc-core.o
  LD      sound/soc/aml/m8/snd-soc-aml-pcm.o
  LD      sound/soc/aml/m8/snd-soc-aml-i2s.o
  LD      sound/soc/aml/m8/snd-soc-aml-i2s-dai.o
  LD      sound/soc/aml/m8/snd-soc-aml-pcm-dai.o
  LD      sound/soc/aml/m8/snd-soc-aml-hw.o
  LD      sound/soc/aml/m8/snd-soc-aml-hw-pcm2bt.o
  LD      sound/soc/aml/m8/snd-soc-aml-spdif-dai.o
  LD      sound/soc/aml/m8/snd-soc-aml-dmic.o
  LD      sound/soc/aml/m8/snd-soc-aml-spdif-codec.o
  LD      sound/soc/aml/m8/snd-soc-aml-m8.o
  LD      sound/soc/aml/m8/snd-soc-aml-snd-iomap.o
  LD      sound/soc/aml/m8/snd-soc-aml-g9tv.o
  LD      sound/soc/aml/m8/built-in.o
  LD      sound/soc/aml/built-in.o
  LD      sound/soc/built-in.o
  LD      sound/built-in.o
Link to comment
This might come a few months late, but in case someone runs into the same trouble and finds this (like I did):
It's probably the compiler version. Using a 4.9.x series compiler did the trick (at least for me). It didn't matter if I used gentoo's 4.9 crossdev compiler for aarch64 (gcc version 4.9.4 (Gentoo 4.9.4-r1 p1.1, pie-0.6.4) ) or the linaro compiler from the "official" amlogic toolchain (gcc version 4.9.2 20140904 (prerelease) (crosstool-NG linaro-1.13.1-4.9-2014.09 - Linaro GCC 4.9-2014.09) ), both worked.
Link to comment
