Rein Posted September 24, 2017 Posted September 24, 2017 Maybe a discussed problem. Using Armbian Jessie on Banana Pi M1. Using USB keyboard and Mouse. Can use usb wifi adapter but presently unused. Power supply standard PS for Banana Pi normal output from lsusb and lsusb -t But it won't read files from usb key. Why ? can you help?
Igor Posted September 24, 2017 Posted September 24, 2017 I assume you have some win32/ntfs file system on that key? Please provide logs to see which kernel are you use: armbianmonitor -u
Rein Posted September 24, 2017 Author Posted September 24, 2017 Hi Igor, Output of ‘armbianmoniyor -u': /var/log/armhwinfo.log has been uploaded to gzip: /var/log/armhwinfo.log.1.gz: unexpected end of file curl: (56) Recv failure: Connection reset by peer Please post the URL in the Armbian forum where you've been asked for. I have tried to untar this file to no avail. It is not just USB keys that can't be read. I've tried external hard drives formatted for HTFS and HFS+ They show up in fdisk -l as /dev/sda or /dev/sdb but do not appear in /media
Igor Posted September 24, 2017 Posted September 24, 2017 You need to have internet connection on that board to upload logs On CLI images there is no automount. You need to mount it manually and AFAIK there is no support for HTFS. Where on earth did you find that?
Rein Posted September 24, 2017 Author Posted September 24, 2017 The files I am dealing with are basic microsoft files .One of the hd is formatted for my mac system but can be read by another linux box i am using . I have internet connection because my banana pi with jessie runs my web site and is permanently on line. Output of fdisk -l with 2 hard drives connected to try out what's going on: Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram1: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram2: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram3: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/mmcblk0: 29.7 GiB, 31914983424 bytes, 62333952 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x249148a9 Device Boot Start End Sectors Size Id Type /dev/mmcblk0p1 2048 30253055 30251008 14.4G 83 Linux Disk /dev/sda: 931.5 GiB, 1000204886016 bytes, 1953525168 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: gpt Disk identifier: E951B0B4-37B1-4EF4-AFE9-7962AF4A7CBD Device Start End Sectors Size Type /dev/sda1 40 409639 409600 200M EFI System /dev/sda2 411648 973064191 972652544 463.8G Microsoft basic data /dev/sda3 973064192 1953523711 980459520 467.5G Microsoft basic data Disk /dev/sdb: 93.4 GiB, 100256292864 bytes, 195813072 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: gpt Disk identifier: E028AA81-8EEC-48D1-A6A0-0E4F14A84377 Device Start End Sectors Size Type /dev/sdb1 40 409639 409600 200M EFI System /dev/sdb2 411648 195550887 195139240 93.1G Apple HFS/HFS+ Output of uname -a: Linux reica 4.11.6-sunxi #6 SMP Fri Jun 23 19:56:18 CEST 2017 armv7l GNU/Linux
Rein Posted September 24, 2017 Author Posted September 24, 2017 Previously I was running 'lubuntu' which did not have this problem. I am only interested in being able to plug in a USB key and read or transfer the contents. I normally use ftp to transfer files.
Igor Posted September 24, 2017 Posted September 24, 2017 2 hours ago, Rein said: Output of ‘armbianmoniyor -u': /var/log/armhwinfo.log has been uploaded to gzip: /var/log/armhwinfo.log.1.gz: unexpected end of file curl: (56) Recv failure: Connection reset by peer 2 Are you sure that you are using original Armbian image? And for USB automount, you need to use a desktop image or enable this feature on your own. Can you manually mount this USB drive? I don't own any Apple stuff to check.
tkaiser Posted September 24, 2017 Posted September 24, 2017 3 hours ago, Rein said: Previously I was running 'lubuntu' which did not have this problem Get an Armbian **DESKTOP** image, do a 'sudo apt install hfsutils' and try again. Also try again uploading debug log (the first time it failed for whatever reasons since the online pasteboard service resetted connection -- happens sometimes so just try it again). BTW: I'm a macOS user, do a lot of storage and filesystem related stuff and would never try to access HFS+ from Linux (driver support is too limited and feature compatible to HFS+ used in maybe OS X 10.5 or something like that)
