can anybody please help me with device tree overlays to enable serial uarts?
Maybe I'm missing a step or I'm doing it wrong? UART3 and UART4 are not working on Cubieboard2 and Cubietruck running the latest mainline armbian image.
I've added the dto by following command:
echo overlays=uart3 uart4 >> /boot/armbianEnv.txt
dmesg shows they are enabled:
root@cubieboard2:~# dmesg | grep tty
[    0.000000] Kernel command line: root=UUID=871ffecf-ac1f-4168-bca0-f4ba6a2d8f33 rootwait rootfstype=ext4 console=tty1 console=ttyS0,115200 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 loglevel=1 ubootpart=efa8d984-01 ubootsource=mmc   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
[    0.001059] console [tty1] enabled
[    3.728936] console [ttyS0] disabled
[    3.749124] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 44, base_baud = 1500000) is a U6_16550A
[    3.749186] console [ttyS0] enabled
[    3.772691] 1c28c00.serial: ttyS1 at MMIO 0x1c28c00 (irq = 45, base_baud = 1500000) is a U6_16550A
[    3.796192] 1c29000.serial: ttyS4 at MMIO 0x1c29000 (irq = 46, base_baud = 1500000) is a U6_16550A
[    6.337168] systemd[1]: Expecting device dev-ttyS0.device...
Trying to get any output in Putty via FTDI USB adapter connected to PG6 & PG7 / PG10 & PG11 shows nothing. Also picocom doesn't show any output.
If you neet more info I'll provide it asap.
Best Regards
We are not clairvoyant or mind readers :P Please describe your setup as best as possible so we know what your operating environment is like.
1. Logs, when you can boot the board: armbianmonitor -u (paste URL to your forum post)
2. If your board does not boot, provide a log from serial console or at least make and attach a picture, where it stops.
3. Describe the problem the best you can and provide all necessary info that we can reproduce the problem.
