zital debian Posted June 7 Posted June 7 Hi, I'm using orange pi 5, and I noticed that I'm using 100Mb/s instead 1000Mb/s, i changed the cables that are working in another pc to a 1000Mb/s but still works to 100Mb/s, I changed to another kernel like 6.12.32-current-rockchip64 with no luck, any idea how to solve it? root@opi5 /home/pi# ethtool end0 Settings for end0: Supported ports: [ TP MII ] Supported link modes: 10baseT/Full 100baseT/Full 1000baseT/Full Supported pause frame use: Symmetric Receive-only Supports auto-negotiation: Yes Supported FEC modes: Not reported Advertised link modes: 10baseT/Full 100baseT/Full 1000baseT/Full Advertised pause frame use: Symmetric Receive-only Advertised auto-negotiation: Yes Advertised FEC modes: Not reported Link partner advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full Link partner advertised pause frame use: Symmetric Receive-only Link partner advertised auto-negotiation: Yes Link partner advertised FEC modes: Not reported Speed: 100Mb/s Duplex: Full Auto-negotiation: on master-slave cfg: preferred slave master-slave status: slave Port: Twisted Pair PHYAD: 1 Transceiver: external MDI-X: Unknown Supports Wake-on: ug Wake-on: d Current message level: 0x0000003f (63) drv probe link timer ifdown ifup Link detected: yes 0 Quote
Michael Robinson Posted June 8 Posted June 8 It looks like your board is advertising 1000mbps probably something with your router port/cable/switch/powersupply. 0 Quote
Werner Posted June 8 Posted June 8 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
zital debian Posted June 8 Author Posted June 8 (edited) I come back to kernel 6.1.115-vendor-rk35xx due to ffmpeg hardware encoding to use owncast, anyway here is the output of the armbianmonitor: ### lsusb: Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub /: Bus 08.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M /: Bus 07.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M /: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M /: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M ### lspci: 0004:40:00.0 PCI bridge: Rockchip Electronics Co., Ltd RK3588 (rev 01) 0004:41:00.0 Non-Volatile memory controller: Silicon Motion, Inc. SM2263EN/SM2263XT SSD Controller (rev 03) ### Userland generated with Armbian Build Framework: PRETTY_NAME="Armbian 25.5.1 bookworm" ARMBIAN_PRETTY_NAME="Armbian 25.5.1 bookworm" ### Installed packages: ii armbian-bsp-cli-orangepi5-legacy 24.5.1 arm64 Armbian CLI BSP for board 'orangepi5' branch 'legacy' ii armbian-config 25.8.0-trunk.100.0603.081117 all Armbian config: The Next Generation ii armbian-firmware 25.5.1 all Armbian - Linux firmware ii armbian-plymouth-theme 25.5.1 all boot animation, logger and I/O multiplexer - Armbian theme ii armbian-zsh 25.5.1 all Armbian improved ZShell (oh-my-zsh...) ii ladspa-sdk 1.17-1+b1 arm64 sample tools for linux-audio-dev plugin architecture ii linux-base 4.9 all Linux image base package ii linux-dtb-vendor-rk35xx 25.5.1 arm64 Armbian Linux vendor DTBs in /boot/dtb-6.1.115-vendor-rk35xx ii linux-headers-vendor-rk35xx 25.5.1 arm64 Armbian Linux vendor headers 6.1.115-vendor-rk35xx ii linux-image-vendor-rk35xx 25.5.1 arm64 Armbian Linux vendor kernel image 6.1.115-vendor-rk35xx ii linux-libc-dev:arm64 23.02.2 arm64 Armbian Linux support headers for userspace development ii linux-u-boot-orangepi5-legacy 24.5.1 arm64 Das U-Boot for orangepi5 ### Loaded modules: Module Size Used by xt_multiport 16384 3 xt_nat 16384 3 xt_addrtype 16384 2 xt_mark 16384 1 xt_conntrack 16384 7 veth 28672 0 bridge 245760 0 stp 16384 1 bridge llc 16384 2 bridge,stp tun 45056 2 overlay 118784 0 nft_chain_nat 16384 7 zram 28672 3 zsmalloc 20480 1 zram xt_MASQUERADE 16384 10 nf_nat 36864 3 xt_nat,nft_chain_nat,xt_MASQUERADE xt_comment 16384 30 nft_compat 20480 56 binfmt_misc 20480 1 squashfs 53248 6 rk805_pwrkey 16384 0 panfrost 61440 0 nvmem_rockchip_otp 20480 0 drm_shmem_helper 20480 1 panfrost gpu_sched 32768 1 panfrost rockchip_cpuinfo 16384 1 nvmem_rockchip_otp uio_pdrv_genirq 16384 0 uio 20480 1 uio_pdrv_genirq fuse 114688 1 dm_mod 110592 0 ipv6 458752 155 bridge ext4 684032 2 mbcache 16384 1 ext4 jbd2 118784 1 ext4 adc_keys 16384 0 ### Current system health: Time CPU_cl0/CPU_cl1 load %cpu %sys %usr %nice %io %irq Tcpu C.St. 09:05:31 1800/2256 MHz 0.06 11% 3% 5% 0% 0% 1% 37.9 °C 0/7 09:05:32 1800/2256 MHz 0.06 2% 1% 0% 0% 0% 0% 37.9 °C 0/7 09:05:32 1800/2256 MHz 0.06 2% 1% 0% 0% 0% 0% 37.9 °C 0/7 09:05:32 1800/2256 MHz 0.06 1% 1% 0% 0% 0% 0% 37.9 °C 0/7 09:05:33 1800/2256 MHz 0.06 1% 1% 0% 0% 0% 0% 37.9 °C 0/7 09:05:36 1800/2256 MHz 0.77 11% 3% 5% 0% 0% 1% 51.8 °C 0/7 09:05:36 1800/2256 MHz 0.77 10% 1% 9% 0% 0% 0% 45.3 °C 0/7 09:05:37 1800/2256 MHz 0.77 1% 1% 0% 0% 0% 0% 44.4 °C 0/7 09:05:37 1800/2256 MHz 0.77 1% 0% 0% 0% 0% 0% 43.5 °C 0/7 09:05:37 1800/2256 MHz 0.77 2% 1% 0% 0% 0% 0% 42.5 °C 0/7 ### resolv.conf -rw-r--r-- 1 root root 53 Jun 7 21:39 /etc/resolv.conf # Generated by NetworkManager nameserver XXX.XXX.2.1 ### Current sysinfo: Linux 6.1.115-vendor-rk35xx (opi5) 06/08/2025 _aarch64_ (8 CPU) avg-cpu: %user %nice %system %iowait %steal %idle 5.82 0.00 5.12 0.56 0.00 88.51 Device tps kB_read/s kB_wrtn/s kB_dscd/s kB_read kB_wrtn kB_dscd ram0 0.00 0.00 0.00 0.00 0 0 0 mtdblock0 0.00 0.01 0.00 0.00 336 0 0 nvme0n1 104.12 8169.92 12048.34 3447.60 337477214 497684183 142411156 nvme0n1p1 0.01 0.15 0.00 0.00 5993 7 0 nvme0n1p2 104.11 8169.69 12048.34 3447.60 337467545 497684176 142411156 zram0 0.07 0.07 0.19 0.00 3036 7980 0 zram1 0.13 0.14 2.89 0.00 5704 119464 0 zram2 0.00 0.00 0.00 0.00 0 0 0 --procs-- -----------------------memory---------------------- ---swap-- -----io---- -system-- ----------cpu---------- r b swpd free buff cache si so bi bo in cs us sy id wa st gu 1 0 7936 167084 115648 6250428 0 0 1057 1558 1734 1774 6 5 89 1 0 0 total used free shared buff/cache available Mem: 7.7Gi 1.6Gi 162Mi 40Mi 6.1Gi 6.1Gi Swap: 7.7Gi 7.8Mi 7.7Gi NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT /dev/zram1 zstd 125M 70.1M 15.5M 16.7M 8 /var/log /dev/zram0 lzo-rle 7.7G 6.5M 1.8M 2.2M 8 [SWAP] 09:05:38 up 11:28, 1 user, load average: 0.77, 0.20, 0.22 [ 9.075824] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop... [ 9.078049] systemd[1]: Starting nftables.service - nftables... [ 9.078526] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root). [ 9.085106] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com [ 9.089823] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules... [ 9.091790] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems... [ 9.093942] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices... [ 9.097421] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System. [ 9.097922] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System. [ 9.098297] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System. [ 9.098661] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System. [ 9.099358] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes. [ 9.099866] fuse: init (API version 7.38) [ 9.100218] systemd[1]: modprobe@configfs.service: Deactivated successfully. [ 9.100573] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs. [ 9.101121] systemd[1]: modprobe@dm_mod.service: Deactivated successfully. [ 9.101397] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod. [ 9.102091] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 9.102330] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm. [ 9.102817] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [ 9.103045] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore. [ 9.103506] systemd[1]: modprobe@fuse.service: Deactivated successfully. [ 9.103743] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse. [ 9.104217] systemd[1]: modprobe@loop.service: Deactivated successfully. [ 9.104445] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop. [ 9.107064] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System... [ 9.109345] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System... [ 9.109595] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met. [ 9.115063] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System. [ 9.116800] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock. [ 9.117512] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System. [ 9.128165] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules. [ 9.134222] EXT4-fs (nvme0n1p2): re-mounted. Quota mode: none. [ 9.168285] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables... [ 9.176241] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems. [ 9.176905] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore). [ 9.179577] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed... [ 9.182201] systemd[1]: Starting systemd-sysusers.service - Create System Users... [ 9.213209] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables. [ 9.221111] systemd[1]: Finished nftables.service - nftables. [ 9.222696] systemd[1]: Finished systemd-random-seed.service - Load/Save Random Seed. [ 9.223018] systemd[1]: first-boot-complete.target - First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes). [ 9.229562] systemd[1]: Finished systemd-sysusers.service - Create System Users. [ 9.258399] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev... [ 9.260467] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout. [ 9.299064] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev. [ 9.300412] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems. [ 9.307285] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files... [ 9.347589] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices. [ 9.354797] systemd[1]: Starting ifupdown-pre.service - Helper to synchronize boot up for ifupdown... [ 9.402035] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files. [ 9.434047] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen... [ 9.445685] systemd[1]: Found device dev-ttyFIQ0.device - /dev/ttyFIQ0. [ 9.500738] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen. [ 9.501527] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid). [ 9.501872] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch. [ 9.502038] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes. [ 9.502153] systemd[1]: Reached target paths.target - Path Units. [ 9.585344] rkcifhw fdce0000.rkcif: Adding to iommu group 17 [ 9.593135] rkcifhw fdce0000.rkcif: No reserved memory region assign to CIF [ 9.600571] rockchip-cpuinfo cpuinfo: SoC : 35881000 [ 9.600579] rockchip-cpuinfo cpuinfo: Serial : 5503dfd10dbecd6b [ 9.643578] systemd[1]: Found device dev-disk-by-uuid-F25A-330A.device - NVME SSD 1TB armbi_boot. [ 9.643936] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid). [ 9.667351] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod... [ 9.671525] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore... [ 9.674406] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop... [ 9.674533] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root). [ 9.675803] systemd[1]: Starting systemd-fsck@dev-disk-by-uuid-F25A-330A.service - File System Check on /dev/disk/by-uuid/F25A-330A... [ 9.676384] systemd[1]: modprobe@dm_mod.service: Deactivated successfully. [ 9.676585] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod. [ 9.676970] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [ 9.677152] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore. [ 9.677317] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore). [ 9.681523] systemd[1]: Reached target usb-gadget.target - Hardware activated USB gadget. [ 9.684343] systemd[1]: modprobe@loop.service: Deactivated successfully. [ 9.684544] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop. [ 9.686153] systemd[1]: Started systemd-fsckd.service - File System Check Daemon to report status. [ 9.686542] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met. [ 9.702655] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 9.714279] input: rk805 pwrkey as /devices/platform/feb20000.spi/spi_master/spi2/spi2.0/rk805-pwrkey.6.auto/input/input6 [ 9.764569] systemd[1]: Finished systemd-fsck@dev-disk-by-uuid-F25A-330A.service - File System Check on /dev/disk/by-uuid/F25A-330A. [ 9.810208] systemd[1]: Finished ifupdown-pre.service - Helper to synchronize boot up for ifupdown. [ 10.141111] systemd[1]: Mounting boot.mount - /boot... [ 10.147298] systemd[1]: Mounting snap-core20-2573.mount - Mount unit for core20, revision 2573... [ 10.152392] systemd[1]: Mounting snap-core20-2585.mount - Mount unit for core20, revision 2585... [ 10.165271] systemd[1]: Mounting snap-core24-892.mount - Mount unit for core24, revision 892... [ 10.165357] loop0: detected capacity change from 0 to 121968 [ 10.168718] systemd[1]: Mounting snap-core24-992.mount - Mount unit for core24, revision 992... [ 10.171084] loop1: detected capacity change from 0 to 121960 [ 10.173917] systemd[1]: Mounting snap-snapd-23772.mount - Mount unit for snapd, revision 23772... [ 10.176526] systemd[1]: Mounting snap-snapd-24509.mount - Mount unit for snapd, revision 24509... [ 10.176553] loop2: detected capacity change from 0 to 126584 [ 10.177160] loop3: detected capacity change from 0 to 79224 [ 10.177293] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 10.177790] loop4: detected capacity change from 0 to 126592 [ 10.179726] systemd[1]: Mounting tmp.mount - /tmp... [ 10.184540] loop5: detected capacity change from 0 to 90640 [ 10.191049] systemd[1]: Mounted boot.mount - /boot. [ 10.191632] systemd[1]: Mounted snap-core20-2573.mount - Mount unit for core20, revision 2573. [ 10.192108] systemd[1]: Mounted snap-core20-2585.mount - Mount unit for core20, revision 2585. [ 10.192547] systemd[1]: Mounted snap-core24-892.mount - Mount unit for core24, revision 892. [ 10.193017] systemd[1]: Mounted snap-core24-992.mount - Mount unit for core24, revision 992. [ 10.193468] systemd[1]: Mounted snap-snapd-23772.mount - Mount unit for snapd, revision 23772. [ 10.193964] systemd[1]: Mounted snap-snapd-24509.mount - Mount unit for snapd, revision 24509. [ 10.194401] systemd[1]: Mounted tmp.mount - /tmp. [ 10.195131] systemd[1]: Reached target local-fs.target - Local File Systems. [ 10.197907] systemd[1]: Starting apparmor.service - Load AppArmor profiles... [ 10.200342] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config... [ 10.202741] systemd[1]: Starting console-setup.service - Set console font and keymap... [ 10.205177] systemd[1]: Starting netfilter-persistent.service - netfilter persistent configuration... [ 10.207269] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data... [ 10.211778] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats... [ 10.211989] systemd[1]: systemd-machine-id-commit.service - Commit a transient machine-id on disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id). [ 10.218544] systemd[1]: Finished console-setup.service - Set console font and keymap. [ 10.221537] systemd[1]: Received SIGRTMIN+20 from PID 307 (plymouthd). [ 10.226820] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data. [ 10.235871] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 534 (systemd-binfmt) [ 10.240431] systemd[1]: Mounting proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System... [ 10.289849] systemd[1]: Mounted proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System. [ 10.301282] systemd[1]: Finished systemd-binfmt.service - Set Up Additional Binary Formats. [ 10.340585] audit: type=1400 audit(1749325038.903:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-senddoc" pid=554 comm="apparmor_parser" [ 10.343421] audit: type=1400 audit(1749325038.906:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-xpdfimport" pid=556 comm="apparmor_parser" [ 10.343517] audit: type=1400 audit(1749325038.906:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=551 comm="apparmor_parser" [ 10.343532] audit: type=1400 audit(1749325038.906:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=551 comm="apparmor_parser" [ 10.343836] audit: type=1400 audit(1749325038.910:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=550 comm="apparmor_parser" [ 10.344671] audit: type=1400 audit(1749325038.910:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=552 comm="apparmor_parser" [ 10.344685] audit: type=1400 audit(1749325038.910:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=552 comm="apparmor_parser" [ 10.344696] audit: type=1400 audit(1749325038.910:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=552 comm="apparmor_parser" [ 10.345786] audit: type=1400 audit(1749325038.910:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oosplash" pid=553 comm="apparmor_parser" [ 10.352229] audit: type=1400 audit(1749325038.916:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/haveged" pid=560 comm="apparmor_parser" [ 10.443659] zram: Added device: zram0 [ 10.444075] zram: Added device: zram1 [ 10.444571] zram: Added device: zram2 [ 10.507340] zram0: detected capacity change from 0 to 16237424 [ 10.526394] systemd[1]: Finished apparmor.service - Load AppArmor profiles. [ 10.533104] Adding 8118708k swap on /dev/zram0. Priority:5 extents:1 across:8118708k SSFS [ 10.547534] systemd[1]: Starting snapd.apparmor.service - Load AppArmor profiles managed internally by snapd... [ 10.583912] systemd[1]: Finished netfilter-persistent.service - netfilter persistent configuration. [ 10.683483] zram1: detected capacity change from 0 to 256000 [ 10.729789] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config. [ 10.775016] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging... [ 10.833194] EXT4-fs (zram1): mounted filesystem without journal. Quota mode: none. [ 11.171634] systemd[1]: Finished snapd.apparmor.service - Load AppArmor profiles managed internally by snapd. [ 14.129835] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging. [ 14.168541] systemd[1]: Starting systemd-journald.service - Journal Service... [ 14.339576] systemd[1]: Started systemd-journald.service - Journal Service. [ 14.397661] systemd-journald[678]: Received client request to flush runtime journal. [ 15.130594] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller [ 15.130711] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 7 [ 15.130789] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0002008002010010 [ 15.130813] xhci-hcd xhci-hcd.11.auto: irq 122, io mem 0xfc000000 [ 15.130872] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller [ 15.130877] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 8 [ 15.130881] xhci-hcd xhci-hcd.11.auto: Host supports USB 3.0 SuperSpeed [ 15.130947] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01 [ 15.130951] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 15.130954] usb usb7: Product: xHCI Host Controller [ 15.130957] usb usb7: Manufacturer: Linux 6.1.115-vendor-rk35xx xhci-hcd [ 15.130959] usb usb7: SerialNumber: xhci-hcd.11.auto [ 15.135848] hub 7-0:1.0: USB hub found [ 15.135867] hub 7-0:1.0: 1 port detected [ 15.136038] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM. [ 15.136082] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01 [ 15.136086] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 15.136089] usb usb8: Product: xHCI Host Controller [ 15.136092] usb usb8: Manufacturer: Linux 6.1.115-vendor-rk35xx xhci-hcd [ 15.136095] usb usb8: SerialNumber: xhci-hcd.11.auto [ 15.136420] hub 8-0:1.0: USB hub found [ 15.136435] hub 8-0:1.0: 1 port detected [ 15.524479] systemd-journald[678]: Received client request to relinquish /var/log/journal/7e1079e7649a45d2ab1ccbdeff6468de access. [ 17.153936] rk_gmac-dwmac fe1c0000.ethernet end1: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 17.159106] rk_gmac-dwmac fe1c0000.ethernet end1: PHY [stmmac-1:01] driver [YT8531 Gigabit Ethernet] (irq=POLL) [ 17.159632] dwmac4: Master AXI performs any burst length [ 17.159643] rk_gmac-dwmac fe1c0000.ethernet end1: No Safety Features support found [ 17.159657] rk_gmac-dwmac fe1c0000.ethernet end1: IEEE 1588-2008 Advanced Timestamp supported [ 17.159878] rk_gmac-dwmac fe1c0000.ethernet end1: registered PTP clock [ 17.160125] rk_gmac-dwmac fe1c0000.ethernet end1: FPE workqueue start [ 17.160131] rk_gmac-dwmac fe1c0000.ethernet end1: configuring for phy/rgmii-rxid link mode [ 19.764001] platform mtd_vendor_storage: deferred probe pending [ 21.057665] loop6: detected capacity change from 0 to 8 [ 21.334602] ttyFIQ ttyFIQ0: tty_port_close_start: tty->count = 1 port count = 2 [ 21.386445] kauditd_printk_skb: 8 callbacks suppressed [ 21.386448] audit: type=1400 audit(1749325049.950:20): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="/snap/snapd/24509/usr/lib/snapd/snap-confine" pid=2025 comm="apparmor_parser" [ 21.386457] audit: type=1400 audit(1749325049.950:21): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="/snap/snapd/24509/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=2025 comm="apparmor_parser" [ 23.232550] rk_gmac-dwmac fe1c0000.ethernet end1: Link is Up - 100Mbps/Full - flow control rx/tx [ 23.232577] IPv6: ADDRCONF(NETDEV_CHANGE): end1: link becomes ready [ 109.364852] rk_gmac-dwmac fe1c0000.ethernet end1: Link is Down [ 131.659974] rk_gmac-dwmac fe1c0000.ethernet end1: Link is Up - 1Gbps/Full - flow control rx/tx [ 132.671410] rk_gmac-dwmac fe1c0000.ethernet end1: Link is Down [ 137.739538] rk_gmac-dwmac fe1c0000.ethernet end1: Link is Up - 100Mbps/Full - flow control rx/tx [ 389.739035] tun: Universal TUN/TAP device driver, 1.6 [ 390.169076] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. [ 390.193136] cni-podman7: port 1(veth50f9419a) entered blocking state [ 390.193152] cni-podman7: port 1(veth50f9419a) entered disabled state [ 390.193330] device veth50f9419a entered promiscuous mode [ 390.475158] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 390.475321] IPv6: ADDRCONF(NETDEV_CHANGE): veth50f9419a: link becomes ready [ 390.475464] cni-podman7: port 1(veth50f9419a) entered blocking state [ 390.475477] cni-podman7: port 1(veth50f9419a) entered forwarding state [ 391.242869] cni-podman7: port 2(vethbbedf056) entered blocking state [ 391.242896] cni-podman7: port 2(vethbbedf056) entered disabled state [ 391.243123] device vethbbedf056 entered promiscuous mode [ 391.243249] cni-podman7: port 2(vethbbedf056) entered blocking state [ 391.243259] cni-podman7: port 2(vethbbedf056) entered forwarding state [ 391.254592] IPv6: ADDRCONF(NETDEV_CHANGE): vethbbedf056: link becomes ready [ 393.993183] cni-podman6: port 1(veth389748ad) entered blocking state [ 393.993200] cni-podman6: port 1(veth389748ad) entered disabled state [ 393.993363] device veth389748ad entered promiscuous mode [ 394.002409] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 394.002459] IPv6: ADDRCONF(NETDEV_CHANGE): veth389748ad: link becomes ready [ 394.002490] cni-podman6: port 1(veth389748ad) entered blocking state [ 394.002494] cni-podman6: port 1(veth389748ad) entered forwarding state [ 394.388742] cni-podman6: port 2(veth1892f651) entered blocking state [ 394.388753] cni-podman6: port 2(veth1892f651) entered disabled state [ 394.388845] device veth1892f651 entered promiscuous mode [ 394.388887] cni-podman6: port 2(veth1892f651) entered blocking state [ 394.388892] cni-podman6: port 2(veth1892f651) entered forwarding state [ 394.396665] IPv6: ADDRCONF(NETDEV_CHANGE): veth1892f651: link becomes ready [ 394.987273] cni-podman6: port 1(veth389748ad) entered disabled state [ 394.988166] device veth389748ad left promiscuous mode [ 394.988180] cni-podman6: port 1(veth389748ad) entered disabled state [ 395.404461] cni-podman4: port 1(veth2ef9338b) entered blocking state [ 395.404482] cni-podman4: port 1(veth2ef9338b) entered disabled state [ 395.404665] device veth2ef9338b entered promiscuous mode [ 395.404778] cni-podman4: port 1(veth2ef9338b) entered blocking state [ 395.404787] cni-podman4: port 1(veth2ef9338b) entered forwarding state [ 395.413237] IPv6: ADDRCONF(NETDEV_CHANGE): veth2ef9338b: link becomes ready [ 395.735421] cni-podman6: port 1(veth8f6535ac) entered blocking state [ 395.735429] cni-podman6: port 1(veth8f6535ac) entered disabled state [ 395.735524] device veth8f6535ac entered promiscuous mode [ 395.735553] cni-podman6: port 1(veth8f6535ac) entered blocking state [ 395.735556] cni-podman6: port 1(veth8f6535ac) entered forwarding state [ 395.742951] IPv6: ADDRCONF(NETDEV_CHANGE): veth8f6535ac: link becomes ready [ 396.188009] cni-podman4: port 2(vethb8fc1132) entered blocking state [ 396.188019] cni-podman4: port 2(vethb8fc1132) entered disabled state [ 396.188117] device vethb8fc1132 entered promiscuous mode [ 396.188155] cni-podman4: port 2(vethb8fc1132) entered blocking state [ 396.188159] cni-podman4: port 2(vethb8fc1132) entered forwarding state [ 396.198232] IPv6: ADDRCONF(NETDEV_CHANGE): vethb8fc1132: link becomes ready [ 397.070802] cni-podman4: port 3(veth716e0e39) entered blocking state [ 397.070826] cni-podman4: port 3(veth716e0e39) entered disabled state [ 397.071066] device veth716e0e39 entered promiscuous mode [ 397.082498] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 397.082578] IPv6: ADDRCONF(NETDEV_CHANGE): veth716e0e39: link becomes ready [ 397.082630] cni-podman4: port 3(veth716e0e39) entered blocking state [ 397.082637] cni-podman4: port 3(veth716e0e39) entered forwarding state [ 1349.306179] TCP: eth0: Driver has suspect GRO implementation, TCP performance may be compromised. [ 8574.898037] systemd-journald[678]: Received client request to flush runtime journal. [ 8575.027019] systemd-journald[678]: Received client request to relinquish /var/log/journal/7e1079e7649a45d2ab1ccbdeff6468de access. ### interrupts: CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7 9: 0 0 0 0 0 0 0 0 GICv3 25 Level vgic 11: 0 0 0 0 0 0 0 0 GICv3 30 Level kvm guest ptimer 12: 0 0 0 0 0 0 0 0 GICv3 27 Level kvm guest vtimer 13: 7232326 4571545 2497686 2420429 3346080 3319816 3370715 3386094 GICv3 26 Level arch_timer 14: 1539993 467885 1145522 1345384 1144496 1156844 1133118 1324265 GICv3 321 Level rk_timer 20: 0 0 0 0 0 0 0 0 GICv3 455 Edge debug-signal 21: 0 0 0 0 0 0 0 0 GICv3 365 Level debug 22: 970 0 0 0 0 0 0 0 GICv3 429 Level rockchip_thermal 23: 0 0 0 0 0 0 0 0 GICv3 23 Level arm-pmu 24: 0 0 0 0 0 0 0 0 GICv3 425 Level rockchip_usb2phy 25: 2 0 0 0 0 0 0 0 GICv3 423 Level rockchip_usb2phy 26: 2 0 0 0 0 0 0 0 GICv3 424 Level rockchip_usb2phy 28: 0 0 0 0 0 0 0 0 GICv3 285 Level pcie-sys 30: 0 0 0 0 0 0 0 0 GICv3 118 Level fea10000.dma-controller 31: 0 0 0 0 0 0 0 0 GICv3 119 Level fea10000.dma-controller 32: 0 0 0 0 0 0 0 0 GICv3 120 Level fea30000.dma-controller 33: 0 0 0 0 0 0 0 0 GICv3 121 Level fea30000.dma-controller 34: 0 0 0 0 0 0 0 0 GICv3 122 Level fed10000.dma-controller 35: 0 0 0 0 0 0 0 0 GICv3 123 Level fed10000.dma-controller 37: 0 0 0 0 0 0 0 0 GICv3 142 Level fdab9000.iommu, fdab0000.npu 38: 0 0 0 0 0 0 0 0 GICv3 143 Level fdab9000.iommu, fdab0000.npu 39: 0 0 0 0 0 0 0 0 GICv3 144 Level fdab9000.iommu, fdab0000.npu 40: 0 0 0 0 0 0 0 0 GICv3 150 Level fdb50800.iommu 41: 0 0 0 0 0 0 0 0 GICv3 146 Level fdb60f00.iommu, rga3 42: 0 0 0 0 0 0 0 0 GICv3 147 Level fdb70f00.iommu, rga3 43: 0 0 0 0 0 0 0 0 GICv3 162 Level fdb90480.iommu 44: 0 0 0 0 0 0 0 0 GICv3 153 Level fdba0800.iommu 45: 0 0 0 0 0 0 0 0 GICv3 155 Level fdba4800.iommu 46: 0 0 0 0 0 0 0 0 GICv3 157 Level fdba8800.iommu 47: 0 0 0 0 0 0 0 0 GICv3 159 Level fdbac800.iommu 48: 0 0 0 0 0 0 0 0 GICv3 149 Level fdbb0800.iommu, fdbb0000.iep 49: 0 0 0 0 0 0 0 0 GICv3 131 Level fdbdf000.iommu 50: 0 0 0 0 0 0 0 0 GICv3 132 Level fdbdf000.iommu 51: 0 0 0 0 0 0 0 0 GICv3 134 Level fdbef000.iommu 52: 0 0 0 0 0 0 0 0 GICv3 135 Level fdbef000.iommu 53: 0 0 0 0 0 0 0 0 GICv3 128 Level fdc38700.iommu 54: 0 0 0 0 0 0 0 0 GICv3 130 Level fdc48700.iommu 55: 0 0 0 0 0 0 0 0 GICv3 141 Level fdca0000.iommu 56: 0 0 0 0 0 0 0 0 GICv3 164 Level fdcb7f00.iommu 57: 0 0 0 0 0 0 0 0 GICv3 168 Level fdcc7f00.iommu 58: 0 0 0 0 0 0 0 0 GICv3 145 Level fdce0800.iommu 59: 0 0 0 0 0 0 0 0 GICv3 188 Level fdd97e00.iommu, fdd90000.vop 60: 0 0 0 0 0 0 0 0 GICv3 193 Level fde50000.dp 61: 0 0 0 0 0 0 0 0 GICv3 392 Level dw-hdmi-qp-hpd 62: 0 0 0 0 0 0 0 0 GICv3 201 Level fde80000.hdmi 63: 0 0 0 0 0 0 0 0 GICv3 202 Level dw-hdmi-qp-cec 64: 0 0 0 0 0 0 0 0 GICv3 203 Level fde80000.hdmi 65: 0 0 0 0 0 0 0 0 GICv3 204 Level fde80000.hdmi 66: 37916 0 0 0 0 0 0 0 GICv3 360 Level feb20000.spi 67: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 7 Level rk806 68: 0 0 0 0 0 0 0 0 rk806 0 Edge rk805_pwrkey_fall 69: 0 0 0 0 0 0 0 0 rk806 1 Edge rk805_pwrkey_rise 70: 674 0 0 0 0 0 0 0 GICv3 238 Level fe2b0000.spi 71: 267567533 0 0 0 0 0 0 0 GICv3 266 Level end1 72: 0 0 0 0 0 0 0 0 GICv3 265 Level end1 73: 0 0 0 0 0 0 0 0 GICv3 254 Level xhci-hcd:usb1 74: 0 0 0 0 0 0 0 0 GICv3 247 Level ehci_hcd:usb3 75: 0 0 0 0 0 0 0 0 GICv3 250 Level ehci_hcd:usb5 76: 0 0 0 0 0 0 0 0 GICv3 248 Level ohci_hcd:usb4 77: 0 0 0 0 0 0 0 0 GICv3 251 Level ohci_hcd:usb6 78: 206468 0 0 0 0 0 0 0 GICv3 349 Level fd880000.i2c 79: 174 0 0 0 0 0 0 0 GICv3 351 Level feaa0000.i2c 80: 522 0 0 0 0 0 0 0 GICv3 355 Level fec80000.i2c 81: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 27 Level fsc_interrupt_int_n 82: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 8 Level hym8563 83: 0 0 0 0 0 0 0 0 GICv3 356 Level fec90000.i2c 84: 0 0 0 0 0 0 0 0 GICv3 175 Level rockchip-mipi-csi2-hw 85: 0 0 0 0 0 0 0 0 GICv3 176 Level rockchip-mipi-csi2-hw 86: 0 0 0 0 0 0 0 0 GICv3 177 Level rockchip-mipi-csi2-hw 87: 0 0 0 0 0 0 0 0 GICv3 178 Level rockchip-mipi-csi2-hw 88: 0 0 0 0 0 0 0 0 GICv3 179 Level rockchip-mipi-csi2-hw 89: 0 0 0 0 0 0 0 0 GICv3 180 Level rockchip-mipi-csi2-hw 90: 0 0 0 0 0 0 0 0 GICv3 181 Level rockchip-mipi-csi2-hw 91: 0 0 0 0 0 0 0 0 GICv3 182 Level rockchip-mipi-csi2-hw 92: 0 0 0 0 0 0 0 0 GICv3 183 Level rockchip-mipi-csi2-hw 93: 0 0 0 0 0 0 0 0 GICv3 184 Level rockchip-mipi-csi2-hw 94: 0 0 0 0 0 0 0 0 GICv3 185 Level rockchip-mipi-csi2-hw 95: 0 0 0 0 0 0 0 0 GICv3 186 Level rockchip-mipi-csi2-hw 96: 0 0 0 0 0 0 0 0 GICv3 163 Level rkisp_hw 97: 0 0 0 0 0 0 0 0 GICv3 165 Level rkisp_hw 98: 0 0 0 0 0 0 0 0 GICv3 166 Level rkisp_hw 99: 0 0 0 0 0 0 0 0 GICv3 167 Level rkisp_hw 100: 0 0 0 0 0 0 0 0 GICv3 169 Level rkisp_hw 101: 0 0 0 0 0 0 0 0 GICv3 170 Level rkisp_hw 102: 0 0 0 0 0 0 0 0 GICv3 347 Edge feaf0000.watchdog 112: 0 0 0 0 0 0 0 0 ITS-MSI 570425352 Edge PCIe PME 113: 0 25 0 0 0 0 0 0 ITS-MSI 570949632 Edge nvme0q0 114: 97019 0 0 0 0 0 0 0 ITS-MSI 570949633 Edge nvme0q1 115: 0 73910 0 0 0 0 0 0 ITS-MSI 570949634 Edge nvme0q2 116: 0 0 122769 0 0 0 0 0 ITS-MSI 570949635 Edge nvme0q3 117: 0 0 0 54385 0 0 0 0 ITS-MSI 570949636 Edge nvme0q4 118: 0 0 0 0 979184 0 0 0 ITS-MSI 570949637 Edge nvme0q5 119: 0 0 0 0 0 733979 0 0 ITS-MSI 570949638 Edge nvme0q6 120: 0 0 0 0 0 0 1206645 0 ITS-MSI 570949639 Edge nvme0q7 121: 0 0 0 0 0 0 0 1017754 ITS-MSI 570949640 Edge nvme0q8 122: 0 0 0 0 0 0 0 0 GICv3 252 Level xhci-hcd:usb7 123: 399417 0 0 0 0 0 0 0 GICv3 430 Level fec10000.saradc 124: 0 0 0 0 0 0 0 0 GICv3 217 Level i2s 125: 0 0 0 0 0 0 0 0 GICv3 212 Level i2s 126: 0 0 0 0 0 0 0 0 GICv3 213 Level i2s 127: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 29 Edge headset_detect 128: 0 0 0 0 0 0 0 0 GICv3 148 Level rga2 129: 0 0 0 0 0 0 0 0 GICv3 151 Level fdb51000.avsd-plus, fdb50400.vdpu 130: 0 0 0 0 0 0 0 0 GICv3 152 Level fdb50000.vepu 131: 0 0 0 0 0 0 0 0 GICv3 154 Level fdba0000.jpege-core 132: 0 0 0 0 0 0 0 0 GICv3 156 Level fdba4000.jpege-core 133: 0 0 0 0 0 0 0 0 GICv3 158 Level fdba8000.jpege-core 134: 0 0 0 0 0 0 0 0 GICv3 160 Level fdbac000.jpege-core 135: 0 0 0 0 0 0 0 0 GICv3 161 Level fdb90000.jpegd 136: 0 0 0 0 0 0 0 0 GICv3 127 Level fdc38100.rkvdec-core 137: 0 0 0 0 0 0 0 0 GICv3 129 Level fdc48100.rkvdec-core 138: 380118 0 0 0 0 0 0 0 GICv3 133 Level fdbd0000.rkvenc-core 139: 250139 0 0 0 0 0 0 0 GICv3 136 Level fdbe0000.rkvenc-core 140: 0 0 0 0 0 0 0 0 GICv3 140 Level fdc70000.av1d 142: 1 0 0 0 0 0 0 0 GICv3 124 Level fb000000.gpu 143: 1 0 0 0 0 0 0 0 GICv3 125 Level fb000000.gpu 144: 3 0 0 0 0 0 0 0 GICv3 126 Level fb000000.gpu 145: 0 0 0 0 0 0 0 0 GICv3 235 Level dw-mci 146: 1454 0 0 0 0 0 0 0 GICv3 105 Level dmc 147: 0 0 0 0 0 0 0 0 GICv3 187 Level rkcifhw IPI0: 222765 594333 326752 286201 389220 385042 301836 288139 Rescheduling interrupts IPI1: 5083251 172366207 29343396 11967742 7021329 4809483 3703373 3045281 Function call interrupts IPI2: 0 0 0 0 0 0 0 0 CPU stop interrupts IPI3: 0 0 0 0 0 0 0 0 CPU stop (for crash dump) interrupts IPI4: 36574 57958 132176 164098 136750 150896 166299 191886 Timer broadcast interrupts IPI5: 24835 34122 19984 19109 86555 79402 82008 80430 IRQ work interrupts IPI6: 0 0 0 0 0 0 0 0 CPU wake-up interrupts Err: 0 Edited June 8 by zital debian 0 Quote
zital debian Posted June 8 Author Posted June 8 Here is the ethernet part: [ 23.232550] rk_gmac-dwmac fe1c0000.ethernet end1: Link is Up - 100Mbps/Full - flow control rx/tx [ 23.232577] IPv6: ADDRCONF(NETDEV_CHANGE): end1: link becomes ready [ 109.364852] rk_gmac-dwmac fe1c0000.ethernet end1: Link is Down [ 131.659974] rk_gmac-dwmac fe1c0000.ethernet end1: Link is Up - 1Gbps/Full - flow control rx/tx [ 132.671410] rk_gmac-dwmac fe1c0000.ethernet end1: Link is Down [ 137.739538] rk_gmac-dwmac fe1c0000.ethernet end1: Link is Up - 100Mbps/Full - flow control rx/tx Michael Robinson but why with the same cable that is using 1000 in another pc in the same port? 0 Quote
eselarm Posted June 8 Posted June 8 40 minutes ago, zital debian said: but why with the same cable that is using 1000 in another pc in the same port? I have had various sorts of issues like this since there is twistedpair ethernet RJ45 (and more troubles with coax BNC). 'PC' is radically different hardware/chips than OPi5, in the end is is analog signals and simbols and channal coding, many leavels were 1 device can do or make slightly different decisions then another one. You only know if you debug kernel and also have dedicated equipment for testing ethernet. But a simple slight less conducting RJ45 pin connector 4 or 5 or 7 or 8 can already make the difference. Can be corrosion or so or not enough pressure in s certain (up or down) direction. Or RF interference difference between PC and OPi5 situation. Or GND connected or not. Or metal surroundings or not. I have made most Armbian installations multi-kernel bootable/selectable (serial console cable en extlinux.conf or GRUB when UEFI) so I would first do a temporary test boot with latest greatest mainline based kernel. It might also mean other U-Boot, I do not know details of OPi5, but my ROCK3A cannot work correct with every U-Boot an kernel combination (only Radxa U-Boot 2017 and Armbian vendor kernel 6.1.115). My ROCK5B is more flexable although if I want to use vendor 6.1.115 I also have to change setting in EDK2-UEFI v1.1 SPI bootloader that I am currently using/testing. And ROCK5B does not use on-chip GMAC ethernet, is has external RTL 2.5GbE chip. Maybe easiest to temporary boot with some fresh downloaded Armbian image on test SD-card and make sure also U-Boot is started from there. 0 Quote
Werner Posted June 8 Posted June 8 Cannot reproduce root@build:~# dmesg|grep 'rk_gmac\|model' [ 3.044416] Machine model: Orange Pi 5 [ 5.539395] rk_gmac-dwmac fe1c0000.ethernet: IRQ eth_lpi not found [ 5.539572] rk_gmac-dwmac fe1c0000.ethernet: Looking up phy-supply from device tree [ 5.539584] rk_gmac-dwmac fe1c0000.ethernet: Looking up phy-supply property in node /ethernet@fe1c0000 failed [ 5.539604] rk_gmac-dwmac fe1c0000.ethernet: supply phy not found, using dummy regulator [ 5.539686] rk_gmac-dwmac fe1c0000.ethernet: clock input or output? (output). [ 5.539702] rk_gmac-dwmac fe1c0000.ethernet: TX delay(0x42). [ 5.539715] rk_gmac-dwmac fe1c0000.ethernet: Can not read property: rx_delay. [ 5.539727] rk_gmac-dwmac fe1c0000.ethernet: set rx_delay to 0xffffffff [ 5.539745] rk_gmac-dwmac fe1c0000.ethernet: integrated PHY? (no). [ 5.539760] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_rx [ 5.539774] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_tx [ 5.539796] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock clk_mac_speed [ 5.540029] rk_gmac-dwmac fe1c0000.ethernet: init for RGMII_RXID [ 5.540156] rk_gmac-dwmac fe1c0000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 5.540176] rk_gmac-dwmac fe1c0000.ethernet: DWMAC4/5 [ 5.540189] rk_gmac-dwmac fe1c0000.ethernet: DMA HW capability register supported [ 5.540202] rk_gmac-dwmac fe1c0000.ethernet: RX Checksum Offload Engine supported [ 5.540215] rk_gmac-dwmac fe1c0000.ethernet: TX Checksum insertion supported [ 5.540227] rk_gmac-dwmac fe1c0000.ethernet: Wake-Up On Lan supported [ 5.540271] rk_gmac-dwmac fe1c0000.ethernet: TSO supported [ 5.540283] rk_gmac-dwmac fe1c0000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 5.540297] rk_gmac-dwmac fe1c0000.ethernet: Enabled L3L4 Flow TC (entries=2) [ 5.540310] rk_gmac-dwmac fe1c0000.ethernet: Enabled RFS Flow TC (entries=10) [ 5.540323] rk_gmac-dwmac fe1c0000.ethernet: TSO feature enabled [ 5.540335] rk_gmac-dwmac fe1c0000.ethernet: Using 32/32 bits DMA host/device width [ 12.372333] rk_gmac-dwmac fe1c0000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 12.376013] rk_gmac-dwmac fe1c0000.ethernet eth0: PHY [stmmac-1:01] driver [YT8531 Gigabit Ethernet] (irq=POLL) [ 12.376537] rk_gmac-dwmac fe1c0000.ethernet eth0: No Safety Features support found [ 12.376546] rk_gmac-dwmac fe1c0000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported [ 12.376657] rk_gmac-dwmac fe1c0000.ethernet eth0: registered PTP clock [ 12.376832] rk_gmac-dwmac fe1c0000.ethernet eth0: FPE workqueue start [ 12.376837] rk_gmac-dwmac fe1c0000.ethernet eth0: configuring for phy/rgmii-rxid link mode [ 16.441134] rk_gmac-dwmac fe1c0000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx [ 496.767911] rk_gmac-dwmac fe1c0000.ethernet eth0: Link is Down [13273.107988] rk_gmac-dwmac fe1c0000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx root@build:~# uname -a Linux build 6.1.115-vendor-rk35xx #1 SMP Tue Apr 15 18:23:00 UTC 2025 aarch64 aarch64 aarch64 GNU/Linux 0 Quote
zital debian Posted June 8 Author Posted June 8 OK, I had the fan disconnected, I have connected the fan into gpio pins and reboot system, now is 1000Mb/s, and maybe is an GND issue as eselarm commented, thank you guys 0 Quote
zital debian Posted June 8 Author Posted June 8 Mmmmm no, comes back to 100, wtf [ 12.809646] systemd-journald[666]: Received client request to relinquish /var/log/journal/7e1079e7649a45d2ab1ccbdeff6468de access. [ 16.329124] rk_gmac-dwmac fe1c0000.ethernet end1: Link is Up - 1Gbps/Full - flow control rx/tx [ 16.329146] IPv6: ADDRCONF(NETDEV_CHANGE): end1: link becomes ready [ 16.674304] platform mtd_vendor_storage: deferred probe pending [ 18.300250] loop6: detected capacity change from 0 to 8 [ 18.667832] ttyFIQ ttyFIQ0: tty_port_close_start: tty->count = 1 port count = 2 [ 830.033971] rk_gmac-dwmac fe1c0000.ethernet end1: Link is Down [ 849.288915] rk_gmac-dwmac fe1c0000.ethernet end1: Link is Up - 100Mbps/Full - flow control rx/tx 0 Quote
zital debian Posted June 8 Author Posted June 8 (edited) now is at 1000 again, I have bought a switch to check if is about router... When it will arrive I will post again with results, thank you all zital@s-400 /tmp> rsync -avzhP --delete /tmp/a/ pi@opi5:/tmp/a/ sending incremental file list deleting D01.mp4 ./ D04-01.mp4 1,24G 100% 111,51MB/s 0:00:10 (xfr#1, to-chk=0/2) sent 1,23G bytes received 49 bytes 98,55M bytes/sec total size is 1,24G speedup is 1,00 Edited June 8 by zital debian 0 Quote
djurny Posted Sunday at 07:27 PM Posted Sunday at 07:27 PM Hi @zital debian, Some things you could also try: Replace cables - again. I've had similar issues where the NIC of SBC would drop to 10Mbe half duplex, persistently after using different cables. In the end it was all the cables i had lying around that were not of good quality. Replaced the cat "5e" ones with cat 6 and the issues went away. Disable autoneg on your NIC or only advertise 1Gbe. Try a different switch port, switch or router. Check if you have some of those green options on your router/switch enabled, i think it's called EEE. I had some issues with and my Orangepi zero SBCs in combination with those bad cat "5e" ethernet cables. Groetjes, 0 Quote
Michael Robinson Posted Monday at 01:16 AM Posted Monday at 01:16 AM Put a multi meter on the PSU you are using to power the pi a flakey PSU can cause strange intermittent issues same for router. 0 Quote
