dmorse Posted September 27, 2017 Share Posted September 27, 2017 Just as the title says. I have taken the current version of debian armbian from the archives, flashed this onto a micro sd card and then installed the mainline kernel packages over this. It boots to a login prompt, but after a few seconds the whole system locks up. Does anyone have any idea what coudl cause this? Link to comment Share on other sites More sharing options...
dmorse Posted September 27, 2017 Author Share Posted September 27, 2017 I have found a solution to this. 1.) mount the SD card on some other linux box 2.) using chroot, uninstall ntp and wpa-suplicant from the SD card 3.) unmount the SD card, and reboot the orangpi using it. 4.) once you have it booted and conencted to a wired network, do an apt-get update and then reinstall wpa-suplicant and ntp You might not need to do both of these packages, but i had a gut feeling it was going to be one of them. Link to comment Share on other sites More sharing options...
chwe Posted September 27, 2017 Share Posted September 27, 2017 You did this? or this? Whatever you did, I hope you made a backup before switching kernel. Link to comment Share on other sites More sharing options...
dmorse Posted September 27, 2017 Author Share Posted September 27, 2017 No, I did not do that 90% of what I do with these small arm board might break my system. I'm used to it. Link to comment Share on other sites More sharing options...
martinayotte Posted September 28, 2017 Share Posted September 28, 2017 Using my own build of Mainline, I've never had to do that, but I'm always doing the first login using a USB-TTL, and then, only then, I'm configuring the WiFi network ... Link to comment Share on other sites More sharing options...
