Minh Tiến Nguyễn Posted June 14 Posted June 14 (edited) Hi everyone, I have wrong color in screen MPI3501 , when i test to output buffer to color red,green, blue, it seem like Red. —> blue Green —> red Blue. —> green Here is how i test (i need to stop lightdm service before this) Spoiler python3 -c 'open("red.raw", "wb").write(b"\xF8\x00" * 153600)' sudo dd if=red.raw of=/dev/fb0 bs=1 python3 -c 'open("green.raw", "wb").write(b"\x07\xE0" * 153600)' sudo dd if=green.raw of=/dev/fb0 bs=1 python3 -c 'open("blue.raw", "wb").write(b"\x00\x1F" * 153600)' sudo dd if=blue.raw of=/dev/fb0 bs=1 (when boot the image should be orange not green) I am using display MPI3501 http://www.lcdwiki.com/3.5inch_RPi_Display which i heard that is a clone of waveshare 3,5 inch https://www.waveshare.com/3.5inch-RPi-LCD-C.htm I'm using Debian Bookworm. I know that it not the same as Armbian, but the config kinda the same. Spoiler orangepi@Gigi-Connect:/boot$ uname -a Linux Gigi-Connect 6.1.31-sun50iw9 #1.0.2 SMP Thu Jul 11 17:24:28 CST 2024 aarch64 GNU/Linux orangepi@Gigi-Connect:/boot$ lsb_release -a No LSB modules are available. Distributor ID: Debian Description: Orange Pi 1.0.2 Bookworm Release: 12 Codename: bookworm About driver for ili9486, here is the info Spoiler orangepi@Gigi-Connect:/boot$ cat /sys/class/graphics/fb0/virtual_size && cat /sys/class/graphics/fb0/bits_per_pixel && cat /sys/class/graphics/fb0/name 480,320 16 ili9486drmfb To use this screen i create overlay-user. and and ili9486.dts. Here is the content of it Spoiler orangepi@Gigi-Connect:/boot$ cat overlay-user/test.dts /dts-v1/; / { compatible = "allwinner,sun50i-h616"; fragment@0 { target = <0xffffffff>; __overlay__ { status = "okay"; cs-gpios = <0xffffffff 0x07 0x05 0x00>; ili9486@1 { compatible = "fb,ili9486"; reg = <0x00>; pinctrl-names = "default"; spi-max-frequency = <0x2dc6c00>; rotation = <0xb4>; bgr = <0x01>; fps = <0x1e>; buswidth = <0x08>; reset-gpios = <0xffffffff 0x08 0x06 0x00>; dc-gpios = <0xffffffff 0x07 0x04 0x00>; debug = <0x00>; init = <0x10000b0 0x00 0x1000011 0x20000ff 0x100003a 0x53 0x1000036 0x38 0x10000c2 0x44 0x10000c5 0x00 0x00 0x00 0x00 0x10000e0 0x0f 0x1f 0x1c 0x0c 0x0f 0x08 0x48 0x98 0x37 0x0a 0x13 0x04 0x11 0x0d 0x00 0x10000e1 0x0f 0x32 0x2e 0x0b 0x0d 0x05 0x47 0x75 0x37 0x06 0x10 0x03 0x24 0x20 0x00 0x10000e2 0x0f 0x32 0x2e 0x0b 0x0d 0x05 0x47 0x75 0x37 0x06 0x10 0x03 0x24 0x20 0x00 0x1000036 0x38 0x1000011 0x1000029>; phandle = <0x01>; }; ads7846@0 { compatible = "ti,ads7846"; reg = <0x01>; pinctrl-names = "default"; spi-max-frequency = <0x1e8480>; interrupts = <0x07 0x02 0x01>; interrupt-parent = <0xffffffff>; pendown-gpio = <0xffffffff 0x07 0x02 0x00>; ti,keep-vref-on = <0x01>; ti,pressure-min = [00 0a]; ti,pressure-max = [03 e8]; ti,debounce-rep = [00 01]; ti,debounce-tol = [00 02]; ti,debounce-max = [00 64]; ti,settle-delay-usec = [00 14]; ti,penirq-recheck-delay-usecs = [00 14]; ti,x-plate-ohms = [01 90]; ti,y-plate-ohms = [01 90]; phandle = <0x02>; }; }; }; __symbols__ { ili9486 = "/fragment@0/__overlay__/ili9486@1"; ads7846 = "/fragment@0/__overlay__/ads7846@0"; }; __fixups__ { spi1 = "/fragment@0:target:0"; pio = "/fragment@0/__overlay__:cs-gpios:0\0/fragment@0/__overlay__/ili9486@1:reset-gpios:0\0/fragment@0/__overlay__/ili9486@1:dc-gpios:0\0/fragment@0/__overlay__/ads7846@0:interrupt-parent:0\0/fragment@0/__overlay__/ads7846@0:pendown-gpio:0"; }; }; and I add this overlay to /boot/orangepiEnv.txt Spoiler orangepi@Gigi-Connect:/boot$ cat orangepiEnv.txt verbosity=1 bootlogo=false console=both disp_mode=1920x1080p60 overlay_prefix=sun50i-h616 rootdev=UUID=143432a6-939f-4b67-86ee-efefb4389531 rootfstype=ext4 user_overlays=ili9486 sun50i-h616-i2s0 Note that i think the field "bgr" and "init" not working, i try to change it to make bgr from 0x00 to 0x01, or send init different at 0x10000036 but nothing change. Also note that, i also try to cat raw data from /dev/fb0 and using ffmpeg --> It is true color Also here is the dmesg log Spoiler orangepi@Gigi-Connect:/boot$ sudo dmesg | grep -e ili -e fb [sudo] password for orangepi: [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 258048 [ 0.000000] Kernel command line: root=UUID=143432a6-939f-4b67-86ee-efefb4389531 rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 console=tty1 consoleblank=0 loglevel=1 ubootpart=8364a2aa-01 usb-storage.quirks= bgr=1 cgroup_enable=memory swapaccount=1 [ 1.696201] Loaded X.509 cert 'Build time autogenerated kernel key: fb722209fb4a0676648f73c963b6906adcfad97c' [ 1.700147] evm: security.capability [ 1.759274] ili9486@1 enforce active low on chipselect handle [ 5.325954] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe. [ 6.429029] SPI driver ili9486 has no spi_device_id for waveshare,rpi-lcd-35 [ 6.429052] SPI driver ili9486 has no spi_device_id for ozzmaker,piscreen [ 6.429835] [drm] Initialized ili9486 1.0.0 20200118 for spi1.0 on minor 1 [ 7.301486] ili9486 spi1.0: [drm] fb0: ili9486drmfb frame buffer device [ 7.353500] fbtft: module is from the staging directory, the quality is unknown, you have been warned. [ 7.358345] fb_ili9486: module is from the staging directory, the quality is unknown, you have been warned. [ 7.358644] SPI driver fb_ili9486 has no spi_device_id for ilitek,ili9486 Is anyone here familiar with this problem, or ever try to change bgr field of this ili9486 ? Best Regard !! Edited June 14 by Minh Tiến Nguyễn 0 Quote
Solution robertoj Posted Monday at 10:34 AM Solution Posted Monday at 10:34 AM (edited) https://forum.armbian.com/topic/46824-orange-pi-zero-3-ili9486-tft-lcd/ user wdr_s had success with that same lcd. Try it with linux 6.1 (check the success case) If you have a file named orangeEnv.txt... you arent using armbian yet! Make sure to use armbian-add-overlay In the ili9341 or ili9488 there's someone trying with orange pi zero 2w, which is very close to zero 3 Edited Monday at 10:39 AM by robertoj 0 Quote
Minh Tiến Nguyễn Posted Monday at 03:03 PM Author Posted Monday at 03:03 PM Thank you so much for sharing me the thread, i finally make the screen true color follow dts of user wdr_s Here is my dts file Spoiler /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h616"; fragment@0 { target = <&spi1>; __overlay__ { status = "okay"; cs-gpios = <&pio 7 5 0>; /*PH5=CS0 PH9=CS1*/ ili9486: ili9486@1 { compatible = "ilitek,ili9486"; reg = <0>; pinctrl-names = "default"; spi-max-frequency = <16000000>; rotate = <360>; bgr = <0>; fps = <30>; buswidth = <8>; reset-gpios = <&pio 8 6 0>; /* PI6 */ dc-gpios = <&pio 7 4 0>; /* PH4 */ debug = <0>; init = <0x10000b0 0x00 0x1000011 0x20000ff 0x100003a 0x55 0x1000036 0x48 0x10000c2 0x44 0x10000c5 0x00 0x00 0x00 0x00 0x10000e0 0x0f 0x1f 0x1c 0x0c 0x0f 0x08 0x48 0x98 0x37 0x0a 0x13 0x04 0x11 0x0d 0x00 0x10000e1 0x0f 0x32 0x2e 0x0b 0x0d 0x05 0x47 0x75 0x37 0x06 0x10 0x03 0x24 0x20 0x00 0x10000e2 0x0f 0x32 0x2e 0x0b 0x0d 0x05 0x47 0x75 0x37 0x06 0x10 0x03 0x24 0x20 0x00 0x1000036 0x48 0x1000011 0x1000029>; }; ads7846: ads7846@0 { compatible = "ti,ads7846"; reg = <1>; pinctrl-names = "default"; spi-max-frequency = <2000000>; interrupts = <7 2 1>; /* PH2 - IRQ */ interrupt-parent = <&pio>; pendown-gpio = <&pio 7 2 0>; /* PH2 */ /* OPTIONS */ ti,keep-vref-on = <1>; ti,pressure-min = /bits/ 16 <10>; ti,pressure-max = /bits/ 16 <1000>; ti,debounce-rep = /bits/ 16 <1>; ti,debounce-tol = /bits/ 16 <2>; ti,debounce-max = /bits/ 16 <100>; ti,settle-delay-usec = /bits/ 16 <20>; ti,penirq-recheck-delay-usecs = /bits/ 16 <20>; ti,x-plate-ohms = /bits/ 16 <400>; ti,y-plate-ohms = /bits/ 16 <400>; }; }; }; }; The thing i change compare with dts in https://github.com/dev-null2019/orangepizero2w35tft : 1. spi-max-frequency from 48000000 to 16000000 (I think it due to speed of spi on the board) 2. And in init, i change both value of 0x1000036 0x48 I test on Debian Bookworm, Armbian it work ok Note that, with this device tree, i got reversed touch screen (up to down work ok, but left to right is reversed) so i need to change the calib matrix Here is the content of /usr/share/X11/xorg.conf.d/80-calibration.conf Spoiler orangepi@Gigi-Connect:~$ cat /usr/share/X11/xorg.conf.d/80-calibration.conf Section "InputClass" Identifier "calibration" MatchProduct "ADS7846 Touchscreen" Option "TransformationMatrix" "0 1 0 1 0 0 0 0 1" Option "CalibrationMatrix" "1.1018606001099192 0.0 -0.04002647119970498 0.0 1.0915157162662792 -0.05172708470647051 0.0 0.0 1.0" EndSection Once again, Thank you very much. I stuck in this problem 3 days, and try so many device tree, and try full supported os from orange pi but it not work, until follow your thread. 0 Quote
robertoj Posted Monday at 04:21 PM Posted Monday at 04:21 PM (edited) I am glad you could do it with the orange pi zero 2w, because I also want to use a very small arm board I am having trouble with the red ili9488 red LCD's touch function, and if I keep having no results, I will replace with the waveshare LCD model (I wanted to have 4-inch LCD ) What armbian and linux version did you use? If you go to the latest linux, you may need to modify the DTS a little bit (modifications are in my ili9488 thread). Warning: I use a different driver (parameter "compatible") for DRM graphics, and different drivers might need different DTS lines. Always use a different microSD for experiments, so you don't mess with your working setup Does the orange pi zero 2w just need male pin headers on the 40-pin connector, and then plug the LCD on top? Edited Monday at 04:42 PM by robertoj 0 Quote
Minh Tiến Nguyễn Posted Tuesday at 12:49 PM Author Posted Tuesday at 12:49 PM Hi @robertoj Yes thank you for helping me For this board, i am using armbian follow this link https://www.armbian.com/orange-pi-zero-2w/ which is Armbian 25.5.1 Kernel: 6.12.23 Yes i use my 5 different sd card to back up and try so many os (at first i want the OS using fb_ili9486 to make it work just like raspberry pi 4) Yes after modify the device tree and add calib configuration, i just plug and play, for the orange pi zero 2w it look like this 0 Quote
robertoj Posted Tuesday at 04:33 PM Posted Tuesday at 04:33 PM Nice Are you going to use apps that will need high fps? If so, comment about the performance. Does the touch function feel steady and reliable? (dragging windows without jumpiness, with the stylus) The app for keyboard emulation with touch screen is "matchbox", if you need it. 0 Quote
Minh Tiến Nguyễn Posted 19 hours ago Author Posted 19 hours ago Sorry for late reply Currently i only use this display to show content which already in the board The touch is not so reliable and it seem with the same config it still not working the same for each flash new image, i still need to change the touch matrix value. But for now i think i can accept it Actually I now wonder that maybe color is reversed because of speed of SPI. Because when i set in init command 0x1000036 0x08 or 0x48 or 0x28 it already have BGR bit 3 (as i share the image in document above. ) is 1. Also can i ask you about How to build armbian image for this board Orange pi zero 2w, i want to improve security for this project, so i want to have configure more about init boot, kernel, ... I heard someone use buildroot, someone use https://github.com/orangepi-xunlong/orangepi-build in here for H616, someone use OS Manjiro..., Have you ever try one, which do you suggest most ? 0 Quote
robertoj Posted 7 hours ago Posted 7 hours ago You can build an armbian image with these instructions:https://docs.armbian.com/Developer-Guide_Build-Preparation/ You can configure it: https://docs.armbian.com/ When you have a setup you like, use this to backup as an image: https://forum.armbian.com/topic/29427-shrink-backup-a-tool-for-backing-up-sbcs/ I still suggest only armbian... but please share if you can use buildroot for opiz2w 0 Quote
