@Igor
It seems u-boot compilation fails.
Please note that this is the first time I build armbian.  Am I missing something?
[ o.k. ] Building boot image
cp: cannot stat 'build/a3700/debug/flash-image.bin': No such file or directory
[ error ] ERROR in function compile_uboot [ compilation.sh:174 ]
[ error ] U-boot file not found [ flash-image.bin ]
[ o.k. ] Process terminated
output.log: https://pastebin.com/Zc4sWzBb
Working here without issues, legacy or next. What kind of host do you use?
legacy.
I prepared a fresh VM on Fedora KVM and then followed the guide here.
Installed Ubuntu Xenial 16.04 x64
apt-get -y install git
git clone https://github.com/armbian/build
cd build
./compile.sh
:unsure:
Try once again - it will fail - and provide logs from debug/compilation.log
compilation.log is not generated.
root@ubuntu:~/build# find * | grep '\.log$'
output/debug/patching.log
output/debug/output.log
seems to be working now.  before this, I commented out /dev/null redirection and found out that gcc-arm-linux-gnueabi missing.  I installed it just before executing the script this time. not sure whether that fixed the issue or something you have done fixed the issue.
Building a3700
make: *** No rule to make target '/root/build/output/debug/compilation.log'.  Stop.
make: *** Waiting for unfinished jobs....
make -C wtmi
  CC      fiptool.c
  CC      tbbr_config.c
ARM GCC toolchain installation is missing!
Please install GNU ARM toolchain suitable for
compiling code for Cortex M3 targets
On Debian/Ubuntu run the following command for
the default toolchain installation:
 sudo apt-get install gcc-arm-linux-gnueabi
If non-default toolchain is used, please export
the CROSS_CM3 environment variable pointin to it.
For instance, with BASH shell:
 export CROSS_CM3=/opt/arm-cross/bin/arm-linux-gnueabi
Makefile:120: recipe for target 'tools' failed
make[2]: *** [tools] Error 1
make[2]: *** Waiting for unfinished jobs....
  CC    printf.c
  CC    uart.c
make[2]: arm-linux-gnueabi-gcc: Command not found
Makefile:103: recipe for target 'printf.o' failed
make[2]: *** [printf.o] Error 127
  LD      fiptool
Makefile:103: recipe for target 'uart.o' failed
make[2]: *** [uart.o] Error 127
  CC    apctl.c
  CC    clock.c
make[3]: arm-linux-gnueabi-gcc: Command not found
Makefile:61: recipe for target 'apctl.o' failed
make[3]: *** [apctl.o] Error 127
make[3]: *** Waiting for unfinished jobs....
  CC    avs.c
  CC    ddr_main.c
  CC    ddrcore/vref_training.c
Makefile:61: recipe for target 'ddr_main.o' failed
make[3]: *** [ddr_main.o] Error 127
Makefile:61: recipe for target 'clock.o' failed
make[3]: *** [clock.o] Error 127
Makefile:61: recipe for target 'avs.o' failed
make[3]: *** [avs.o] Error 127
Makefile:61: recipe for target 'ddrcore/vref_training.o' failed
make[3]: *** [ddrcore/vref_training.o] Error 127
Makefile:123: recipe for target 'wtmiddr' failed
make[2]: *** [wtmiddr] Error 2
Makefile:2: recipe for target 'all' failed
make[1]: *** [all] Error 2
Makefile:895: recipe for target '../../marvell-tools/wtptp/linux/TBB_linux' failed
make: *** [../../marvell-tools/wtptp/linux/TBB_linux] Error 2
The script should take care of all dependencies. I made a dirty workaround in this case and ... need to fix it. In the morning. Head is not operational anymore :wacko:
