ER Samson Posted Saturday at 04:18 AM Posted Saturday at 04:18 AM Currently using Armbian as a PiHole DNS server, it seems that after a few days the server just shuts itself down (Armbian 25.5.1 Noble 6.12). Not sure if it is a hardware related issue, I'll do some more tests and revert back to 25.2.2 Bookworm for now and see if the issue is replicated. Please note that my primary Armbian PiHole DNS does not encounter the same issue, though the version of it is Noble v25.2.3 / 6.12.30. 0 Quote
Igor Posted Sunday at 03:56 PM Posted Sunday at 03:56 PM On 7/12/2025 at 6:18 AM, ER Samson said: it seems that after a few days the server just shuts itself down Board usually shuts down in case it reached critical temperatures. Can you add a heatsink? 0 Quote
Stephen Graf Posted Sunday at 08:56 PM Posted Sunday at 08:56 PM I have an orangepione running bookworm and am not having any problems with it. I will load up another unit with noble and see how it runs. v25.5.1 for Orange Pi One running Armbian Linux 6.12.30-current-sunxi Packages: Debian stable (bookworm) IPv4: (LAN) 192.168.1.65 (WAN) 209.121.228.132 IPv6: fd05:ce26:d593:0:81:2fff:fe1a:671e (WAN) 2001:569:5143:f100:81:2fff:fe1a:671e Performance: Load: 2% Up time: 11 days 2:09 Memory usage: 19% of 484M Zram usage: 1% of 1.00G CPU temp: 36°C Usage of /: 31% of 15G 0 Quote
Stephen Graf Posted Monday at 12:00 AM Posted Monday at 12:00 AM @ER Samson To help figure out why your unit is stopping you could connect to it via an ssh session and as root run "journalctl -f". this might catch any error messages just prior to failure. When running with logs in zram, as Armbian does, the last messages in the logs are quite often lost when the system abruptly stops. 0 Quote
