tast ky Posted Saturday at 10:32 PM Posted Saturday at 10:32 PM Using Jun 26's Sid_vendor_server-kali, my Zero 3W is stuck in a loop. I can't "Create a loop password" as it'll instantly jump to the "armbian-security login:" prompt. If I login with the default root:1234, I'll briefly see the welcome screen, followed by a very brief "waiting for the system to finish booting", then it's back to 1. This occurs regardless of internet access (provided by a USB-C ethernet adapter, for which Armbian reports a valid LAN IP address). 0 Quote
Werner Posted Sunday at 05:51 AM Posted Sunday at 05:51 AM 7 hours ago, tast ky said: waiting for the system to finish booting" How long did you wait for this? if you for example use a quite large microsd card that however has a slow pace this may take a few minutes. 0 Quote
Tomas Catone Posted Sunday at 06:46 PM Posted Sunday at 06:46 PM Probably worth a shot - I had an install one time that gave me fits at initial boot. For giggles I expanded the FS using Gparted in linux to fill the entire card. It solved that problem for me. 0 Quote
laibsch Posted 4 hours ago Posted 4 hours ago Are you twwn on github, @tast ky? As mentioned in the bug tracker, you need to try a different image. Please keep the discussion of run-time issues in the forum. This is where run-time bug triage happens. Until the time one can essentially make a PR with a clear code fix, the forum is where we discuss run-time problems. 0 Quote
