boot from nvme, install via armbian-install ?
Go to solution Solved by H_Berger,
Posted (edited)
i also have issues to move the system to the nvme ssd 😞
my base is the
Armbian 25.5.1 with 6.1.115 (vendor kernel) image ....
"copied" (usbimager) it to the sdcard and its booting ... 🙂
so I upgraded the system on the sdcard, still running 🙂
I read some posts and advices ....
so I partioned the nvme with one big partition (/dev/nvme0n1p1)
running armbian-install
choosing option 7, (loading/upgrading bootloader to mtd )
after this i choose option 4 (boot from mtd, system on sata, usb ... )
only possible selection was /dev/nvme0n1 ... looked ok
said yes to everything
no Error
system goes to shutdown /power off
removed power, removed sdcard
plugin power again .... and ... no boot 😞
serial console saying:
DDR 9fa84341ce typ 24/09/06-09:51:11,fwver: v1.18
ch0 ttot10
ch1 ttot10
ch2 ttot10
ch3 ttot10
ch0 ttot18
LPDDR4X, 2112MHz
channel[0] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
ch1 ttot18
channel[1] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
ch2 ttot18
channel[2] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
ch3 ttot18
channel[3] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
Manufacturer ID:0xff
DQS rds:h1,h1
CH0 RX Vref:27.1%, TX Vref:21.8%,22.8%
DQ rds:h1 l0 h2 l0 h1 h5 l0 l0, l0 h3 l0 h3 h7 h2 l0 h1
DQS rds:l0,h1
CH1 RX Vref:28.5%, TX Vref:23.8%,23.8%
DQ rds:h1 h2 h1 h3 h1 h3 l0 h1, h1 h4 h1 h4 h1 h3 l0 h4
DQS rds:l0,h1
CH2 RX Vref:27.5%, TX Vref:23.8%,22.8%
DQ rds:h1 h3 h2 h1 h1 h6 h4 h1, h1 h2 h6 l0 h6 h2 h6 h3
DQS rds:h1,l0
CH3 RX Vref:29.7%, TX Vref:21.8%,20.8%
DQ rds:h5 h3 h2 h1 h3 h2 h2 h2, h5 h2 h1 h2 h4 l0 l0 h5
stride=0x2, ddr_config=0x4
hash ch_mask0-1 0x20 0x40, bank_mask0-3 0xa00 0x1400 0x2800 0x0, rank_mask0 0x401000
change to F1: 528MHz
ch0 ttot10
ch1 ttot10
ch2 ttot10
ch3 ttot10
change to F2: 1068MHz
ch0 ttot14
ch1 ttot14
ch2 ttot14
ch3 ttot14
change to F3: 1560MHz
ch0 ttot16
ch1 ttot16
ch2 ttot16
ch3 ttot16
change to F0: 2112MHz
ch0 ttot18
ch1 ttot18
ch2 ttot18
ch3 ttot18
out
U-Boot SPL board init
U-Boot SPL 2017.09-armbian-2017.09-S3e40-P187d-He5fc-Ve691-Bb703-R448a (May 30 2025 - 10:51:06)
sfc cmd=03H(6BH-x4)
Trying to boot from MMC2
MMC: no card present
mmc_init: -123, time 0
spl: mmc init failed with error: -123
Trying to boot from MTD2
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x00040000 ... sha256(7612223b82...) + OK
## Checking uboot 0x00200000 ... sha256(11a994b967...) + OK
## Checking fdt 0x00354c30 ... sha256(e3b0c44298...) + OK
fdt_record_loadable: FDT_ERR_BADMAGIC
## Checking atf-2 0xff100000 ... sha256(70505bb764...) + OK
## Checking atf-3 0x000f0000 ... sha256(b2af21b504...) + OK
Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000)
Total: 496.285/765.931 ms
INFO:    Preloader serial: 2
NOTICE:  BL31: v2.3():v2.3-868-g040d2de11:derrick.huang, fwver: v1.48
NOTICE:  BL31: Built : 15:02:44, Dec 19 2024
INFO:    spec: 0x1
INFO:    code: 0x88
INFO:    ext 32k is valid
INFO:    ddr: stride-en 4CH
INFO:    GICv3 without legacy support detected.
INFO:    ARM GICv3 driver initialized in EL3
INFO:    valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0
INFO:    l3 cache partition cfg-0
INFO:    system boots from cpu-hwid-0
INFO:    disable memory repair
INFO:    idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001
INFO:    dfs DDR fsp_params[0].freq_mhz= 2112MHz
INFO:    dfs DDR fsp_params[1].freq_mhz= 528MHz
INFO:    dfs DDR fsp_params[2].freq_mhz= 1068MHz
INFO:    dfs DDR fsp_params[3].freq_mhz= 1560MHz
INFO:    BL31: Initialising Exception Handling Framework
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
No valid device tree binary found - please append one to U-Boot binary, use u-boot-dtb.bin or define CONFIG_OF_EMBED. For sandbox, use -d <file.dtb>
initcall sequence 00000000002d2af8 failed at call 00000000002c502c (err=-1)
### ERROR ### Please RESET the board ###
if im boot with sdcard in the system and mount /dev/nvm0n1p1 there is the whole system ....
inklusive /boot und boot/dtb .....
what didd I miss ?
Does anyone hav a link to a working  tutorial ?
Edited by H_Berger
3 hours ago, H_Berger said:
what didd I miss ?
You are running with a broken firmware:
Your version is also quite outdated:
U-Boot SPL 2017.09
A current firmware log looks like this:
Spoiler
DDR ff1a08bde6 typ 25/03/13-15:39:39,fwver: v1.19
ch0 ttot6
ch1 ttot6
ch2 ttot6
ch3 ttot6
ch0 ttot7
LPDDR5, 2400MHz
channel[0] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB
ch1 ttot7
channel[1] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB
ch2 ttot7
channel[2] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB
ch3 ttot7
channel[3] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB
Manufacturer ID:0x1
DQS rds:h1,h2,.
CH0 RX Vref:29.3%, TX Vref:22.0%,21.0%
DQ rds:h2 l0 h5 h2 h3 h2 h2 h5 ., h1 h1 h3 h5 h2 h1 h4 h2
DQS rds:h1,l0,.
CH1 RX Vref:28.9%, TX Vref:22.0%,22.0%
DQ rds:h3 h2 l1 h3 h4 l0 h3 h1 ., h3 l0 h5 h1 h1 l0 h1 l0
DQS rds:l0,l0,.
CH2 RX Vref:28.5%, TX Vref:22.0%,22.0%
DQ rds:h1 h1 h1 h4 l0 h1 h2 h1 ., h7 h5 h2 h1 h3 h1 l0 l0
DQS rds:l0,h1,.
CH3 RX Vref:29.3%, TX Vref:22.0%,21.0%
DQ rds:h6 h4 h2 h6 h2 h2 h3 h1 ., h5 h6 h4 h1 h7 h5 h2 h2
stride=0x2, ddr_config=0x6
hash ch_mask0-1 0x20 0x40, bank_mask0-3 0x0 0x2400 0x44800 0x89000, rank_mask0 0x2000
change to F1: 534MHz
ch0 ttot6
ch1 ttot6
ch2 ttot6
ch3 ttot6
change to F2: 1320MHz
ch0 ttot8
ch1 ttot8
ch2 ttot8
ch3 ttot8
change to F3: 1968MHz
ch0 ttot6
ch1 ttot6
ch2 ttot6
ch3 ttot6
change to F0: 2400MHz
ch0 ttot7
ch1 ttot7
ch2 ttot7
ch3 ttot7
out
U-Boot SPL 2025.07 (Jul 11 2025 - 00:00:00 +0000)
## Checking hash(es) for config config-1 ... OK
## Checking hash(es) for Image atf-1 ... sha256+ OK
## Checking hash(es) for Image u-boot ... sha256+ OK
## Checking hash(es) for Image fdt-1 ... sha256+ OK
## Checking hash(es) for Image atf-2 ... sha256+ OK
## Checking hash(es) for Image atf-3 ... sha256+ OK
NOTICE:  BL31: v2.13.0(release):
NOTICE:  BL31: Built : 00:00:00, May 22 2025
U-Boot 2025.07 (Jul 11 2025 - 00:00:00 +0000)
Model: Hardkernel ODROID-M2
SoC:   RK3588S2
DRAM:  16 GiB
PMIC:  RK806 (on=0x80, off=0x08)
Core:  382 devices, 35 uclasses, devicetree: separate
MMC:   mmc@fe2c0000: 1, mmc@fe2e0000: 0
Loading Environment from nowhere... OK
In:    serial@feb50000
Out:   serial@feb50000
Err:   serial@feb50000
SoC:   RK3588S2
Net:   eth0: ethernet@fe1c0000
starting USB...
USB EHCI 1.00
USB OHCI 1.0
USB EHCI 1.00
USB OHCI 1.0
Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
Bus usb@fc800000: 1 USB Device(s) found
Bus usb@fc840000: 1 USB Device(s) found
Bus usb@fc880000: 5 USB Device(s) found
Bus usb@fc8c0000: 1 USB Device(s) found
Bus usb@fcd00000: 1 USB Device(s) found
Cannot persist EFI variables without system partition
*** U-Boot Boot Menu ***
Press UP/DOWN to move, ENTER to select, ESC to quit
 Standard Boot
 NVME USB Mass Storage
 eMMC USB Mass Storage
 microSD USB Mass Storage
 Power Off
 mmc 1
 mmc 0
 nvme 0
 Exit
Hit any key to stop autoboot: 2 1 0
Scanning for bootflows in all bootdevs
Seq  Method       State   Uclass    Part  Name                      Filename
Scanning global bootmeth 'efi_mgr':
  0  efi_mgr      ready   (none)       0  <NULL>
** Booting bootflow '<NULL>' with efi_mgr
Loading Boot0000 'mmc 1' failed
Loading Boot0001 'mmc 0' failed
Loading Boot0002 'nvme 0' failed
EFI boot manager: Cannot load any image
Boot failed (err=-14)
Scanning bootdev 'mmc@fe2c0000.bootdev':
  1  extlinux     ready   mmc          1  mmc@fe2c0000.bootdev.part /extlinux/extlinux.conf
** Booting bootflow 'mmc@fe2c0000.bootdev.part_1' with extlinux
Jumpstart Boot Options
1:      ODROID-M1/M2 default
2:      ODROID-M1/M2 previous kernel
3:      ODROID-M1/M2 verbose
4:      Odroid-N2/N2+ default
5:      Odroid-N2/N2+ previous kernel
Enter choice: 1:        ODROID-M1/M2 default
Retrieving file: /usr/lib/modules/linux/vmlinuz
append: loglevel=7 root=PARTUUID=75235836-01 consolee=ttyS02,1500000 console=tty0 rootwait rootfstype=ext4
Retrieving file: /usr/lib/modules/linux/dtb/rockchip/rk3588s-odroid-m2.dtb
   Uncompressing Kernel Image to 0
## Flattened Device Tree blob at 12000000
   Booting using the fdt blob at 0x12000000
Working FDT set to 12000000
   Loading Device Tree to 00000000ece60000, end 00000000ece779b7 ... OK
Working FDT set to ece60000
Starting kernel ...
Thanks for your answer 🙂
And Sorry for my Stupidness .... and stupid questions in advance 🙂
with "firmware" you mean the "uboot - loader" mainly right ? at least It should be part of it ?
The one I'm used is from the Armbian 25.5.1 image, thats what im copied with the arm-install to the /dev/mtdblock0
So I need a new uboot version for the orange pi 5 (that the chip gets configured properly) with support for my boot device
I think this uboot version is lacking at least on nvme support, right ?
Usually my plan was not to boot from nvme, but from the extra emmc .... but this had the same result.
I have red somewhere that the actual released git branch of uboot has support for the orange pi 5 plus
so building a uboot from git would help here ?
Exactly
Since I don't know the build, I can't make any concrete statements about it.
It is also not possible under any circumstances, as the access procedures are far too complex to be meaningfully encoded in the MASK-ROM. As firmware devices, only SPI flash, MMC (eMMC, SD card), and USB with a proprietary protocol are available.
This is correct. I just quickly built this version out of curiosity. I was just about to provide the binary artifacts when I quickly took a look at the schematic of your device.
If I am not misinterpreting the schematic, your device only allows the fixed SPI-MMC-USB sequence and the forced immediate proprietary USB device. This means that you cannot execute the firmware completely from the microSD card, for example, if there is still a valid firmware signature in a device (SPI, eMMC) that is higher up in the priority list.
It is therefore essential that you are familiar with the USB recovery procedure (MASK-ROM-MODE), in case something goes wrong during the firmware experiments with the higher prioritized devices (SPI, eMMC).
thanks for the answer.
i wonna boot from the emmc, so i have bought an little emmc module, so there should no hassle with the MASK-ROM, right ?
just  trying to build mainline u-boot ragarding this:
https://uthings.uniud.it/building-mainline-u-boot-and-linux-kernel-for-orange-pi-boards
but, of course, getting errors 😞
Image 'simple-bin' is missing external blobs and is non-functional: rockchip-tpl atf-bl31
/binman/simple-bin/mkimage/rockchip-tpl (rockchip-tpl):
   An external TPL is required to initialize DRAM. Get the external TPL
   binary and build with ROCKCHIP_TPL=/path/to/ddr.bin. One possible source
   for the external TPL binary is https://github.com/rockchip-linux/rkbin.
/binman/simple-bin/fit/images/@atf-SEQ/atf-bl31 (atf-bl31):
   See the documentation for your board. You may need to build ARM Trusted
   Firmware and build with BL31=/path/to/bl31.bin
Image 'simple-bin' has faked external blobs and is non-functional: rockchip-tpl
Image 'simple-bin' is missing optional external blobs but is still functional: tee-os
/binman/simple-bin/fit/images/@tee-SEQ/tee-os (tee-os):
   See the documentation for your board. You may need to build Open Portable
   Trusted Execution Environment (OP-TEE) and build with TEE=/path/to/tee.bin
Image 'simple-bin-spi' is missing external blobs and is non-functional: rockchip-tpl atf-bl31
/binman/simple-bin-spi/mkimage/rockchip-tpl (rockchip-tpl):
/binman/simple-bin-spi/fit/images/@atf-SEQ/atf-bl31 (atf-bl31):
Image 'simple-bin-spi' has faked external blobs and is non-functional: rockchip-tpl
Image 'simple-bin-spi' is missing optional external blobs but is still functional: tee-os
/binman/simple-bin-spi/fit/images/@tee-SEQ/tee-os (tee-os):
Some images are invalid
so getting the blobs from the rokchip repos
-rw-rw-r-- 1 baumgart baumgart 430880 Jul 23 10:58 rk3588_bl31_v1.48.elf
-rw-rw-r-- 1 baumgart baumgart 473512 Jul 23 10:58 rk3588_bl32_v1.19.bin
-rw-rw-r-- 1 baumgart baumgart  75320 Jul 23 10:58 rk3588_ddr_lp4_2112MHz_lp5_2400MHz_v1.18.bin
-rw-rw-r-- 1 baumgart baumgart  71600 Jul 23 10:58 rk3588_ddr_lp4_2112MHz_lp5_2736MHz_eyescan_v1.11.bin
-rw-rw-r-- 1 baumgart baumgart   6464 Jul 23 10:58 rk3588_pcie_v2.20.bin
-rw-rw-r-- 1 baumgart baumgart    512 Jul 23 10:58 rk3588_ramboot_null0.bin
-rw-rw-r-- 1 baumgart baumgart    512 Jul 23 10:58 rk3588_ramboot_null1.bin
-rw-rw-r-- 1 baumgart baumgart  49276 Jul 23 10:58 rk3588_ramboot_v1.06.bin
-rw-rw-r-- 1 baumgart baumgart 239010 Jul 23 10:58 rk3588_spl_v1.13.bin
-rw-rw-r-- 1 baumgart baumgart  90268 Jul 23 10:58 rk3588_usbplug_v1.11.bin
so,
ROCKCHIP_TPL should be the rk3588_ddr_lp4_2112MHz_lp5_2400MHz_v1.18.bin
but  BL31 ?  rk3588_bl31_v1.48.elf or rk3588_bl32_v1.19.bin
where do i get an OP-TEE bin ?
IMHO this is a waste of money. In a device with NVME support, the advantages of an NVME SSD far outweigh those of an eMMC. The proprietary module interface also makes it difficult to use in other devices. And as a boot device for the firmware, it also offers no significant advantages over a microSD card.
In any case, I would prefer a microSD card as a boot device, simply because of the easier handling when, for example, experimenting with the firmware. Only when everything works perfectly can one think about using an eMMC, but only if it is already permanently built into the device and the microSD card slot is to be kept free for other tasks.
Only as long as there is no valid firmware signature in the SPI flash. Otherwise, firmware components will be loaded from there, and they may be able to load subsequent components (U-Boot) from other devices, but compatibility must be ensured.
To avoid this, one must clean the SPI flash or store their own firmware in the SPI flash.
However, since there is no way to fully test one's own firmware for functionality in advance, one may find oneself in a situation that requires a MASK-ROM recovery procedure.
just  trying to build mainline u-boot ragarding this: ttps://uthings.uniud.it/building-mainline-u-boot-and-linux-kernel-for-orange-pi-boards
I prefer to trust the official documentation.
thanks again 🙂
the official doc is much better of course 🙂
so i have built the u-boot loader, only warning about op-tee (optional)
think i dont need this ?
but I'm struggeling a little bit with flashing ....
I have an
u-boot-rockchip.bin
u-boot-rockchip-spi.bin
the opi5+ has SPI, so the device is mtdblock0
Zitat
SPI
Write u-boot-rockchip-spi.bin to offset 0 of SPI flash.
Copy u-boot-rockchip-spi.bin into SD card and boot from SD:
sf probe load mmc 1:1 $kernel_addr_r u-boot-rockchip-spi.bin sf update $fileaddr 0 $filesize
im booted into the device via an armbian image
why do i need to write it on the sd card (/dev/mmcblk1) ?
where comes the sf command from ?
if Im read right, its from the uboot sandbox .... ?
So do i have access from the u-boot sandbox to the filesystem ?
or does this mean .... i have to copy the u-boot-rockchip-spi.bin to the root of the sd card
(can do it on external PC)
than boot into the already before existed u-boot
stop the boot to get into the sandbox
and call the command from there ?
Posted (edited)
ok, think second way was meant
so i formated a sd card with 1 partiton with ext4
putted the images on the root
copied the new compiled u-boot-rockchip.bin on the device (sudo dd if=u-boot-rockchip.bin of=/dev/sda seek=64)
inserted the sd and boot
aborting the boot (ctrl+c)
sf probe
SF: Detected XM25QU128C with page size 256 Bytes, erase size 4 KiB, total 16 MiB
=> sf update $fileaddr 0 $filesize
device 0 offset 0x0, size 0x174800
1384448 bytes written, 141312 bytes skipped in 14.774s, speed 105751 B/s
the bytes skipped, is this correct ?
removed the sdcard, im getting
ch0 ttot10
ch1 ttot10
ch2 ttot10
ch3 ttot10
ch0 ttot18
LPDDR4X, 2112MHz
ch1 ttot18
ch2 ttot18
ch3 ttot18
DQS rds:h1,h1
CH0 RX Vref:26.7%, TX Vref:20.8%,22.8%
DQ rds:h1 l0 h3 l0 h2 h6 l0 l0, l0 h3 l0 h4 h7 h3 l0 h2
DQS rds:l0,l0
DQ rds:h1 h1 h1 h3 h1 h3 l0 h1, h1 h5 h1 h5 h1 h4 h1 h5
DQS rds:l0,h1
CH2 RX Vref:27.5%, TX Vref:22.8%,22.8%
DQ rds:h1 h3 h2 h1 h1 h6 h4 h1, h1 h3 h6 l0 h6 h2 h7 h4
DQS rds:h1,l0
CH3 RX Vref:29.7%, TX Vref:21.8%,21.8%
DQ rds:h5 h4 h2 h1 h3 h2 h2 h2, h5 h2 h1 h2 h3 l0 l0 h6
ch0 ttot10
ch1 ttot10
ch2 ttot10
ch3 ttot10
ch0 ttot14
ch1 ttot14
ch2 ttot14
ch3 ttot14
ch0 ttot16
ch1 ttot16
ch2 ttot16
ch3 ttot16
ch0 ttot18
ch1 ttot18
ch2 ttot18
ch3 ttot18
out
U-Boot SPL 2025.07-g3532f1f5edfc (Jul 24 2025 - 12:04:14 +0200)
Trying to boot from SPI
NOTICE:  BL31: v2.13.0(release):c1ad67a
NOTICE:  BL31: Built : 11:44:50, Jul 24 2025
U-Boot 2025.07-g3532f1f5edfc (Jul 24 2025 - 12:04:14 +0200)
Model: Xunlong Orange Pi 5 Plus
SoC:   RK3588
DRAM:  8 GiB
Core:  356 devices, 31 uclasses, devicetree: separate
In:    serial@feb50000
SoC:   RK3588
Net:   No ethernet found.
Hit any key to stop autoboot: 0
Card did not respond to voltage select! : -110
Loading Boot0000 'mmc 0' failed
Scanning bootdev 'mmc@fe2e0000.bootdev':
pcie_dw_rockchip pcie@fe170000: PCIe-6 Link Fail
Scanning bootdev 'nvme#0.blk#1.bootdev':
scanning bus for devices...
USB EHCI 1.00
USB OHCI 1.0
USB EHCI 1.00
USB OHCI 1.0
USB XHCI 1.10
Bus usb@fc840000: 2 USB Device(s) found
Bus usb@fc880000: 1 USB Device(s) found
Bus usb@fc8c0000: 2 USB Device(s) found
Bus usb@fc400000: 3 USB Device(s) found
Warning: eth_rtl8169 MAC addresses don't match:
Address in DT is                c0:74:2b:fd:9c:da
Address in environment is       1a:21:86:aa:40:10
Address in DT is                c0:74:2b:fd:9c:db
Address in environment is       1a:21:86:aa:40:11
Scanning bootdev 'eth_rtl8169.bootdev':
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
its hanging on trying to boot over network 🙂
there is no bootable device !!! at least it should be
does it looks good?
whats about the  "card didd not respond to voltage select" ?
Edited by H_Berger
the intention was, not to boot from sdcard .... have read thats not a good solution, sd cards are slow (even if i have an A2 one) and they are not good for constant read and write ...
didnt know thats for emmc the same apply
for nvme i have read, thats not possible to boot from or its a hassle to get it to work ....
but:
looks like he is already try to boot from the emmc and nvme, right ?
It looks like you have your u-boot loaded to the spi based on what the log shows.  So all you should now need to do is install an Armbian image to the SD card, boot into that image and then use armbian-config to copy the image to either eMMC or nvme (you can try both and experiment which you want to go with long term).  You also have the option of having /boot on eMMC and the root filesystem on nvme (since the /boot is mostly read only that sometimes is a safer option than relying on being able to boot off of the nvme.  There are lots of options available depending on your usage pattern and hardware.
  • Solution
yaeh, thanks very much ....
i just flashed the armbian image to the sdcard
copied the base img also on the sd card
booted into
than dd'ed the copied img to the /dev/mmcblk0
checked the partitions
rebooted with removed sdcard
and it works !!!
