Hmm... I remember that there's a ls and a cat command with U-Boot but their use are quite awkward. Something like ls mmc1:1 / or something like that.
Anyway, I'll investigate this tomorrow.
Meanwhile, if you can mount your MMC through USB, using the good old ums 0 mmc 1 command and paste the content of /your/mounted/mmc/boot/boot.scr and the content of ls -1 /your/mounted/mmc/boot
mmc ?  I put the SDcard in the SDcard-Reader, but I cannot read out boot.scr   just boot.cmd
Weird  boot.cmd  points to "rk3288-miqi.dtb".
# DO NOT EDIT THIS FILE
# Please edit /boot/armbianEnv.txt to set supported parameters
setenv rootdev "/dev/mmcblk0p1"
setenv fdt_file "rk3288-miqi.dtb"
setenv ramdisk_addr_r "0x21000000"
setenv console "ttyS2,115200n8"
setenv verbosity "1"
itest.b ${devnum} == 0 && echo "U-boot loaded from SD"
itest.b ${devnum} == 1 && echo "U-boot loaded from eMMC"
if load ${devtype} ${devnum}:1 ${ramdisk_addr_r} /boot/armbianEnv.txt || load ${devtype} ${devnum}:1 ${ramdisk_addr_r} armbianEnv.txt; then
	env import -t ${ramdisk_addr_r} ${filesize}
fi
setenv bootargs "consoleblank=0 scandelay root=${rootdev} rw console=${console} rootfstype=ext4 loglevel=${verbosity} rootwait ${extraargs}"
ext4load ${devtype} ${devnum}:1 ${fdt_addr_r} /boot/dtb/${fdt_file} || fatload ${devtype} ${devnum}:1 ${fdt_addr_r} dtb/${fdt_file} || ext4load ${devtype} ${devnum}:1 ${fdt_addr_r} dtb/${fdt_file}
ext4load ${devtype} ${devnum}:1 ${ramdisk_addr_r} /boot/uInitrd || fatload ${devtype} ${devnum}:1 ${ramdisk_addr_r} uInitrd || ext4load ${devtype} ${devnum}:1 ${ramdisk_addr_r} uInitrd
ext4load ${devtype} ${devnum}:1 ${kernel_addr_r} /boot/zImage || fatload ${devtype} ${devnum}:1 ${kernel_addr_r} zImage || ext4load ${devtype} ${devnum}:1 ${kernel_addr_r} zImage
bootz ${kernel_addr_r} ${ramdisk_addr_r} ${fdt_addr_r}
Whereas the armbianEnv.txt  to: rk3288-miniarm.dtb   @TonyMac32, is this intention or did I do something bogus ?
verbosity=1
fdt_file=rk3288-miniarm.dtb
rootdev=UUID=47abe137-7697-490d-b4ed-6212d35ea51f
rootfstype=ext4
tido@medion:/media/tido/47abe137-7697-490d-b4ed-6212d35ea51f/boot$ ll
insgesamt 21M
-rw-r--r-- 1 root root  106 Jul 23 08:34 armbianEnv.txt
-rw-r--r-- 1 root root 1.6K Jul 23 08:30 armbian_first_run.txt
-rw-r--r-- 1 root root  38K Jul 23 08:30 boot.bmp
-rw-r--r-- 1 root root 1.4K Jul 23 08:25 boot.cmd
-rw-r--r-- 1 root root 4.8K Jul 23 08:30 boot-desktop.png
-rw-r--r-- 1 root root 1.5K Jul 23 08:34 boot.scr
-rw-r--r-- 1 root root 136K Okt 22 02:02 config-4.13.9-rockchip
lrwxrwxrwx 1 root root   19 Okt 22 09:00 dtb -> dtb-4.13.9-rockchip
drwxr-xr-x 2 root root 4.0K Jul 31 18:04 dtb-4.12.3-rockchip
drwxr-xr-x 2 root root 4.0K Okt 22 16:24 dtb-4.13.2-rockchip
drwxr-xr-x 2 root root 4.0K Okt 22 08:59 dtb-4.13.9-rockchip
lrwxrwxrwx 1 root root   19 Okt 22 08:26 dtb.old -> dtb-4.13.8-rockchip
-rw-r--r-- 1 root root 4.4M Okt 29 10:36 initrd.img-4.13.9-rockchip
-rw-r--r-- 1 root root    0 Okt 22 09:00 .next
-rw-r--r-- 1 root root 3.5M Okt 22 02:02 System.map-4.13.9-rockchip
lrwxrwxrwx 1 root root   23 Okt 29 10:36 uInitrd -> uInitrd-4.13.9-rockchip
-rw-r--r-- 1 root root 4.4M Okt 29 10:36 uInitrd-4.13.9-rockchip
-rwxr-xr-x 1 root root 7.8M Okt 29 22:23 vmlinuz-4.13.9-rockchip
lrwxrwxrwx 1 root root   23 Okt 22 09:00 zImage -> vmlinuz-4.13.9-rockchip
I have edited armbianEnv.txt  to use tinker.dtb, but did not help
Edited by Tido
last line added
tinker.dtb is not the dtb used with Armbian, the reason being twofold, firstly the mainline dtb keeps getting edited, and secondly the 4.4 vendor image uses rk3288-miniarm.dtb, so what I've essentially done is create a dtb from the mainline one that includes various fixes/adjustments without wondering if the next kernel patchlevel is going to break it, and avoiding renaming everything from the vendor/scripts.
I have to confess that I'm not 100% on how the armbianenv.txt plays into things, and haven't tried swapping out kernels for another.
Thank you for the information. I remember reading about it, but where to find in the forum :rolleyes:
Yesterday evening I had said, armbianEnv.txt  overrides entries in boot.bmp. That said I read now this:  https://docs.armbian.com/User-Guide_Allwinner_overlays/#example-bootarmbianenvtxt-contents
   and now I am not sure.
I would be helpful if @zador.blood.stained or @Igor would add 1-2 lines in the  armbianEnv.txt like:
armbianEnv.txt is currently used to override entries of boot.bmp without the necessity of recompiling it. As an add-on to the before mentioned function it shall be possible  "in the future"  to handle OVERLAYS in here as well. You will find more information https://docs.armbian.com search for: armbianEnv (2017 October)
A search for armbianenv in the forum discovered.. been there, done that - sorry Tony, it was late.
Edited by Tido
Search..
From what I'm seeing, it looks like you only have 4.13.9 kernels...
At worst, you can add an extlinux/extlinux.conf and have U-boot uses that instead. You'll lose the clean update system and will have to edit your extlinux.conf by hand every time you want to add a boot option, though.
I'll try to provide an example tomorrow.
I don't think so, there is a  sym link from  zImage -> vmlinuz-4.13.9-rockchip
I downloaded the git repo of Myy and copied some files into armbian eg. zImage. I believe because of the sym-link it looks like it is 4.13 but the date of the changed
Nightlys are already 4.14 rc6
Did you try using the rk3288-tinker.dtb provided with my build, or a 4.14.x ready rk3288-miniarm.dtb ? If you use a 4.13 or lower version DTB, it might fail to boot due to Rockchip 32 bits DTS using 64 bits addressing now, in order to use LPAE on some 32 bits boards. LPAE provides the ability to use more than 4 GB of memory on 32 bits systems, through magic, memory windows and ugly hacks.
Anyway, I tested my latest release (4.14.0-rc7) with glmark2 and the Rockchip's r14p0-wayland user-space binary drivers and it works. I'll try to install Rockchip xserver and test glmark2 on X11 this week, if I got the time.
During these tests, I discovered the magic of chvt, which changes the current virtual terminal displayed on the screen, which is very useful when you have control on a machine with SSH access, but no USB keyboard plugged on the machine, and want to switch to a terminal from X11. So basically instead of trying to find a keyboard, plug it and hit CTRL+ALT+F1, you just have to type :
sudo chvt 1
I also checked that using a shitty micro-USB cable will cause the MiQi to reboot instantly when doing 3D intensive work. Yay !
Remember kids, don't do drugs use bad micro-USB cables !
I have copied your rk3288-tinker.dtb, serveral times and renamed it to:
  • rk3288-miqi.dtb
  • rk3288-miniarm.dtb
It wouldn't boot.
Well, I copied all your files,   also the zImage - is there a way to proof which version/file I have beside the filename ?  Phuu, sounds complicated :-)   I believe I have done it right as the date of the file changed.
Uuups, yesterday night I already copied a fresh 4.14-rc6 on it - so I cannot do the thing from StackOverFlow.
Holy cow, I am impressed !!! I attach this nightly build (already booted, just sitting there, plug the HDMI-DVI cable in) to my Fujitsu Siemens P19-1s 19" 1280x1024 and it just works.
htop reports 203Mb used, 1,5% CPU load, 44° C no cooler attached.
So was this the Armbian nightly or the Myy kernel?  I only have 720p, 1080p, and 4k test monitors, so haven't been able to test any other "strange ones"
You must be kidding me, 1280x1024 is(was) one of the most common resolutions (5:4) - not this shitty 16:9. As this display only comes with DVI-Port I have a HDMI-to-DVI cable attached.
And it works out of the box with the latest nightly of  Armbian_5.34._Tinkerboard_Ubuntu_xenial_dev_4.14.0-rc6_desktop.img
So it must be getting EDID right.
Next step is to throw Myy's kernel at it :o
common resolutions, nowadays and before:
1920x1080 Full HD
1280x720 HD
1280x1024 SXGA
1024x768  XGA
800x600 SVGA
640x480 VGA
Edited by Tido
The only thing that *might* generate issues would be the initrd. But I don't think that it would cause the system to not boot and not print anything on the serial output.
Now, since you got a working kernel, try to list the modules used by your system, just in case |`・ω・)ノ .
Also try to use the rk3288-miniarm.dtb too, since we're sure that it works.
root@tinkerboard:~# lsmod
snd_soc_hdmi_codec     16384  0
r8723bs               548864  0
syscon_reboot_mode     16384  0
reboot_mode            16384  1 syscon_reboot_mode
rk_crypto              24576  0
at24                   16384  0
mali_kbase            339968  0
dw_hdmi_i2s_audio      16384  0
So I will copy all your files, except the DTB and reboot
Edited by Tido
copy
I don't have my MiQi here so I can't paste the extlinux/extlinux.conf I'm using.
Still, instead of copying zImage bluntly, you could do cp zImage /boot/Myy-Kernel and then configure your bootloader to boot Myy-Kernel instead of zImage
Also try to comment the initrd line in the boot.scr if it doesn't boot, just to see if that changes anything...
I have only replaced the kernel, put it to /boot/myy-kernel/
If I had a hex-editor, could I change the file boot.scr without the detour of: mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr  ?
U-Boot SPL 2017.09-armbian (Oct 30 2017 - 02:49:58)
Returning to boot ROM...
U-Boot 2017.09-armbian (Oct 30 2017 - 02:49:58 +0100)
Model: Tinker-RK3288
DRAM:  2 GiB
MMC:   dwmmc@ff0c0000: 1
In:    serial
Out:   serial
Err:   serial
Net:   eth0: ethernet@ff290000
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
1496 bytes read in 37 ms (39.1 KiB/s)
## Executing script at 00000000
155 bytes read in 33 ms (3.9 KiB/s)
43195 bytes read in 70 ms (602.5 KiB/s)
4493470 bytes read in 250 ms (17.1 MiB/s)
8168664 bytes read in 390 ms (20 MiB/s)
## Loading init Ramdisk from Legacy Image at 21000000 ...
   Image Name:   uInitrd
   Data Size:    4493406 Bytes = 4.3 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 01f00000
   Booting using the fdt blob at 0x1f00000
   Loading Ramdisk to 0fbb6000, end 0ffff05e ... OK
   Loading Device Tree to 0fba8000, end 0fbb58ba ... OK
Starting kernel ...
Edit: When this happens, the SoC gets as hot, that you can just hold the finger on it, almost hurts. This is around 60°C
Okay so I will comment now:
Edited by Tido
heat
Ah, yeah, the boot.scr is the binary file and boot.cmd is the one used to generate it so comment the ramdisk line in the boot.cmd and regenarate the boot.scr... if the kernel doesn't boot of course.
the output of 'screen' is scrumbled:
t SP30-49)tunoot17.09-arm 2 - 9:01odkMC:wmmf01* Wing - bad us:  r
tny topboswitch to partit 0,
                            mnt
 mmcFound U-Boot script
1497 byrd (s in 0
                 5 byt1 ms (4.9
                               43195 m938 KiB816byms (MiB/s
                                                           Wr Rdisk Imae ein
        SCRIILcinstinSB..rlUSB1  : _oeou_ooroiou_oorstt_oreho: Tiut!
dwc_otg_core_host_t: Tic_otg_cho: _ocoi: u
                                          dwg_hotmeann b fe 2 sanus 1 ic
        ce  Df
:n
   r9in Pneoo
@Tido surely you're not so serious as all that?  I haven't had a non-16x9 monitor since I abandoned the VGA cable.
The amazing amount of unnecessary extraneous noise aside, I'm glad to see EDID is functioning properly.
Now, I will continue to give candy to strangers as part of Halloween.  And maybe freeze to death.  :D
And that's how @TonyMac32 became a SnowMan. :lol:
Anyway, I guess I'll have to find a Tinkerboard during December, since that clearly needs special testing.
Now that I have access to my MiQi, here's the /boot/extlinux/extlinux.conf I'm using to boot my kernels :
root@miqi:~# cat /boot/extlinux/extlinux.conf
label kernel-4.4
    kernel /boot/zImage
    fdt /boot/rk3288-miqi.dtb
    append  earlyprintk console=ttyS2,115200n8 rw root=/dev/mmcblk1p1 rootfstype=ext4 init=/sbin/init
Note that I'm not using a /boot partition.
Anyway, here's ls -l /boot
root@miqi:~# ls -l /boot
total 92172
-rw-r--r-- 1 root root       78 May  3  2017 armbianEnv.txt
-rw-r--r-- 1 root root     1557 May  3  2017 armbian_first_run.txt
-rw-r--r-- 1 root root   129427 May  3  2017 config-4.11.0+
-rw-r--r-- 1 root root   155497 Sep 12 00:36 config-4.13.0-RockMyy-XIII
-rw-r--r-- 1 root root   155497 Sep 10 19:44 config-4.13.0-RockMyy-XIII.old
-rw-r--r-- 1 root root   156664 Sep 16 07:53 config-4.14.0-rc4-RockMyy-XIV-A-Myy-Reborn
-rw-r--r-- 1 root root   156664 Sep 16 07:36 config-4.14.0-rc4-RockMyy-XIV-Myy-Returns
-rw-r--r-- 1 root root   156664 Nov  2 09:05 config-4.14.0-rc7-RockMyy-XIV-A-Myy-Reborn
-rw-r--r-- 1 root root   125351 Aug 12 17:31 config-4.4.81-rockchip
drwxr-xr-x 2 root root     4096 Jun 20 15:42 dtb-4.11.0-rockchip
drwxr-xr-x 2 root root     4096 Aug  7 16:50 dtb-4.13.0-rockchip
drwxr-xr-x 2 root root     4096 Aug 18 16:49 dtb-4.4.81-rockchip
drwxr-xr-x 2 root root     4096 Sep 12 00:26 extlinux
-rw-r--r-- 1 root root  4438628 Oct 30 16:10 initrd.img-4.11.4-rockchip
-rw-r--r-- 1 root root  4421353 Aug 18 16:55 initrd.img-4.4.81-rockchip
drwx------ 2 root root     4096 Jul 16 22:17 lost+found
-rw-r--r-- 1 root root    40525 Nov  2 09:05 rk3288-evb-act8846.dtb
-rw-r--r-- 1 root root    40922 Nov  2 09:05 rk3288-evb-rk808.dtb
-rw-r--r-- 1 root root    37039 Nov  2 09:05 rk3288-fennec.dtb
-rw-r--r-- 1 root root    40777 Nov  2 09:05 rk3288-firefly-beta.dtb
-rw-r--r-- 1 root root    40769 Nov  2 09:05 rk3288-firefly.dtb
-rw-r--r-- 1 root root    41955 Nov  2 09:05 rk3288-firefly-reload.dtb
-rw-r--r-- 1 root root    39656 Nov  2 09:05 rk3288-miqi.dtb
-rw-r--r-- 1 root root    41029 Jul 18 16:59 rk3288-miqi.dtb.bak
-rw-r--r-- 1 root root    39604 Nov  2 09:05 rk3288-popmetal.dtb
-rw-r--r-- 1 root root    37310 Nov  2 09:05 rk3288-r89.dtb
-rw-r--r-- 1 root root    40289 Nov  2 09:05 rk3288-rock2-square.dtb
-rw-r--r-- 1 root root    41026 Nov  2 09:05 rk3288-tinker.dtb
-rw-r--r-- 1 root root    39316 Nov  2 09:05 rk3288-veyron-brain.dtb
-rw-r--r-- 1 root root    47442 Nov  2 09:05 rk3288-veyron-jaq.dtb
-rw-r--r-- 1 root root    47495 Nov  2 09:05 rk3288-veyron-jerry.dtb
-rw-r--r-- 1 root root    39921 Nov  2 09:05 rk3288-veyron-mickey.dtb
-rw-r--r-- 1 root root    48314 Nov  2 09:05 rk3288-veyron-minnie.dtb
-rw-r--r-- 1 root root    45862 Nov  2 09:05 rk3288-veyron-pinky.dtb
-rw-r--r-- 1 root root    47270 Nov  2 09:05 rk3288-veyron-speedy.dtb
-rw-r--r-- 1 root root  3702224 Sep 12 00:36 System.map-4.13.0-RockMyy-XIII
-rw-r--r-- 1 root root  3702224 Sep 10 19:44 System.map-4.13.0-RockMyy-XIII.old
-rw-r--r-- 1 root root  3781860 Sep 16 07:53 System.map-4.14.0-rc4-RockMyy-XIV-A-Myy-Reborn
-rw-r--r-- 1 root root  3781964 Sep 16 07:36 System.map-4.14.0-rc4-RockMyy-XIV-Myy-Returns
-rw-r--r-- 1 root root  3782323 Nov  2 09:05 System.map-4.14.0-rc7-RockMyy-XIV-A-Myy-Reborn
lrwxrwxrwx 1 root root       23 Oct 30 16:10 uInitrd -> uInitrd-4.11.4-rockchip
-rw-r--r-- 1 root root  4438692 Oct 30 16:10 uInitrd-4.11.4-rockchip
-rw-r--r-- 1 root root  4421417 Aug 18 16:55 uInitrd-4.4.81-rockchip
-rw-r--r-- 1 root root 19873868 Sep 10 19:44 vmlinuz-4.13.0-RockMyy-XIII
-rw-r--r-- 1 root root 19897976 Sep 16 07:09 vmlinuz-4.14.0-rc4-RockMyy-XIV-Myy-Returns
-rwxr-xr-x 1 root root  8039272 Aug 21 05:05 vmlinuz-4.4.81-rockchip
-rwxr-xr-x 1 root root  8167960 Nov  2 09:05 zImage
And the motd SSH output :
 __  __ _  ___  _
|  \/  (_)/ _ \(_)
| |  | | | |_| | |
|_|  |_|_|\__\_\_|
Welcome to ARMBIAN 5.30 stable Ubuntu 16.04.2 LTS 4.14.0-rc7-RockMyy-XIV-A-Myy-Reborn
System load:   0.52 0.19 0.07   Up time:       0 min
Memory usage:  7 % of 2009MB    IP:            10.100.0.55
CPU temp:      61°C
Usage of /:    27% of 15G
[ 0 security updates available, 97 updates total: apt upgrade ]
Last check: 2017-11-02 09:08
[ General system configuration: armbian-config ]
Last login: Mon Oct 30 16:21:04 2017 from 10.100.0.1
To run a command as administrator (user "root"), use "sudo <command>".
See "man sudo_root" for details.
Anyway, I still have some issues with the HDMI screen that I have to unplug / plug back sometimes. I'll try to see if adding back some the old DRM patches fix the issue.
Here's my modules list btw :
root@miqi:~# lsmod
bnep                   20480  2
mali_kbase            512000  1
dw_hdmi_cec            16384  0
rk_crypto              24576  0
Why is the bnep loaded ? Well, that's a good question ! I have no single idea, since there's no Bluetooth chip integrated into the MiQi, as far as I remember.
When launching glmark2, you should get that kind of output :
root@miqi:~# glmark2-es2-drm
    glmark2 2017.07
    OpenGL Information
    GL_VENDOR:     ARM
    GL_RENDERER:   Mali-T760
    GL_VERSION:    OpenGL ES 3.2 v1.r14p0-01rel0-git(966ed26).810f535757d8c9adaaa72f5da29c688e
[build] use-vbo=false: FPS: 59 FrameTime: 16.949 ms
[build] use-vbo=true:^C FPS: 60 FrameTime: 16.667 ms
                                  glmark2 Score: 59
The ^C is due to me hitting CTRL+C. The first batch should be at 59 fps generally, after a cold start.
Well, the 1280x1024 I have since ca. 2007 it became retired (spare) in 2013 when I got a Dell IPS 16:10 (16:9) for a desktop is an absolutely NO GO ;)
Around 2014 I fixed a 17" 1280x1024 of a friend by replacing the  blown up electrolytic capacitors.
For my dad we bought around 2008 one of the last 1600x1200 20" display (at that time for a fortune of $800.-)  it still runs.
So you ask me if I am kidding, not at all. For the company I work,  I just got more than 8000 displays 16:10  IPS  (1920x1200).
But to come back to SBCs. 52pi sells displays with 800x480 up to 1280x800 7". I have ordered this one, but if it won't run on SBC, I can run it on one of my RPi.
While I want to use this as a touch-display in combination with a SBC. But while testing and sitting at my desk, I have this 19" 1280x1024 next to me :P
root@tinkerboard:/boot# glmark2-es2-drm
Error: Failed to find a suitable DRM device
Error: main: Could not initialize canvas
Segmentation fault
As I can only run armbian kernel properly..
@Tido What version of glmark2 do you have ? The old versions seemed to have a broken DRM detection system based on some whitelist, that I kind of fixed in the later versions. I highly suggest using the GIT version of glmark2 and uninstalling glmark2 Debian packages for the moment.
sudo apt remove glmark2
git clone --depth 1 https://github.com/glmark2/glmark2
cd glmark2
./waf configure --with-flavors=drm-glesv2
./waf
sudo ./waf install
glmark2-es2-drm
Also, be sure to execute that version from a TTY (Ctrl+ALT+F1 or chvt 1)
ii  glmark2-data        2014.03+git201 all            data files for the glmark2 OpenGL (ES) 2.0
ii  glmark2-es2-drm     2014.03+git201 armhf          OpenGL ES 2.0 DRM benchmark
looks to me I need to follow your instruction to properly test it ;)
