shaulreznik Posted August 14 Posted August 14 I’m trying to set up a lightweight desktop environment on Armbian Trixie. When I use tasksel, it installs a lot of extra packages, including GNOME. How can I install LXQt manually? 0 Quote
laibsch Posted August 14 Posted August 14 In addition to what Werner said, I would like to point to the option of not installing recommended packages. "sudo apt install --no-install-recommends lxqt". Personally, i like to use aptitude for package management for more control and transparency. 0 Quote
maka Posted August 14 Posted August 14 It seems to me that Gnome is installed by tasksel because you didnt deselect it. I mean that gnome is selected by default. 0 Quote
Giordano Sologuren Posted 5 hours ago Posted 5 hours ago (edited) From a minimal image type this (If you are going to use it in English, skip the "l10n" commands or translations) sudo apt update sudo apt install task-lxqt-desktop papirus-icon-theme gvfs locales polkitd xdg-desktop-portal-lxqt sudo reboot sudo apt install gvfs-backends lxqt-l10n-es liblxqt-l10n qterminal-l10n pcmanfm-qt-l10n featherpad-l10n lxqt-panel-l10n lxqt-session-l10n lxqt-powermanagement-l10n lxqt-config-l10n lxqt-about-l10n lxqt-admin-l10n lxqt-archiver-l10n sudo apt install gvfs-backends liblxqt-l10n qterminal-l10n pcmanfm-qt-l10n featherpad-l10n lxqt-panel-l10n lxqt-session-l10n lxqt-powermanagement-l10n lxqt-config-l10n lxqt-about-l10n lxqt-admin-l10n lxqt-archiver-l10n sudo apt install lxqt-globalkeys-l10n lxqt-policykit-l10n lxqt-runner-l10n lxqt-sudo-l10n lximage-qt-l10n libfm-qt-l10n lxqt-openssh-askpass-l10n ls xdg-user-dirs sudo apt install pavucontrol-qt-l10n sudo apt install dmz-cursor-theme sudo apt install openbox sudo apt purge --remove xfwm4 sudo apt autoremove sudo apt install obconf-qt obconf-qt-l10n sudo apt search xterm sudo apt purge --remove xterm sudo apt install qpdfview qpdfview-translations sudo apt install screengrab Edited 5 hours ago by Giordano Sologuren 0 Quote
The Tall Man Posted 4 hours ago Posted 4 hours ago The way the Debian .iso installer does it: sudo apt-get -o APT::Install-Recommends="true" install task-lxqt-desktop That will install a fully functional desktop with a minimal set of applications. If you set Install-Recommends to false, or any other way of installing it (i.e. lxqt), in my experience, the result may not be quite functional. 0 Quote
