August 14, 20251 yr I’m trying to set up a lightweight desktop environment on Armbian Trixie. When I use tasksel, it installs a lot of extra packages, including GNOME. How can I install LXQt manually?
August 14, 20251 yr In addition to what Werner said, I would like to point to the option of not installing recommended packages. "sudo apt install --no-install-recommends lxqt". Personally, i like to use aptitude for package management for more control and transparency.
August 14, 20251 yr It seems to me that Gnome is installed by tasksel because you didnt deselect it. I mean that gnome is selected by default.
October 15, 20251 yr From a minimal image type this (If you are going to use it in English, skip the "l10n" commands or translations) sudo apt update sudo apt install task-lxqt-desktop papirus-icon-theme gvfs locales polkitd xdg-desktop-portal-lxqt sudo reboot sudo apt install gvfs-backends lxqt-l10n-es liblxqt-l10n qterminal-l10n pcmanfm-qt-l10n featherpad-l10n lxqt-panel-l10n lxqt-session-l10n lxqt-powermanagement-l10n lxqt-config-l10n lxqt-about-l10n lxqt-admin-l10n lxqt-archiver-l10n sudo apt install gvfs-backends liblxqt-l10n qterminal-l10n pcmanfm-qt-l10n featherpad-l10n lxqt-panel-l10n lxqt-session-l10n lxqt-powermanagement-l10n lxqt-config-l10n lxqt-about-l10n lxqt-admin-l10n lxqt-archiver-l10n sudo apt install lxqt-globalkeys-l10n lxqt-policykit-l10n lxqt-runner-l10n lxqt-sudo-l10n lximage-qt-l10n libfm-qt-l10n lxqt-openssh-askpass-l10n ls xdg-user-dirs sudo apt install pavucontrol-qt-l10n sudo apt install dmz-cursor-theme sudo apt install openbox sudo apt purge --remove xfwm4 sudo apt autoremove sudo apt install obconf-qt obconf-qt-l10n sudo apt search xterm sudo apt purge --remove xterm sudo apt install qpdfview qpdfview-translations sudo apt install screengrab Edited October 15, 20251 yr by Giordano Sologuren
October 15, 20251 yr The way the Debian .iso installer does it: sudo apt-get -o APT::Install-Recommends="true" install task-lxqt-desktop That will install a fully functional desktop with a minimal set of applications. If you set Install-Recommends to false, or any other way of installing it (i.e. lxqt), in my experience, the result may not be quite functional.
