Armbian Linux 6.6 (Ubuntu 24.04 Noble) Cubox server image doesn't boot
Greetings;
I have downloaded this https://dl.armbian.com/cubox-i/Noble_current_server and verified that I got what I was supposed to (ASC, SHA).
I have used a brand new usbimager to install it on various freshly formatted (brand new SD Formatter) and verified working Samsung Evo 32GB, SanDisk Extreme Plus 16GB, Extreme Plus 32GB.
All the formatting, imaging and installation done on an Ubuntu 25.04 laptop.
After usbimager is done, if I use the Ubuntu Disks application to look at the drive, the first partion shows as free space, which seems suspicious.
When I insert the newly-set up SD cards in the Cubox-i4, I see the bootloader start and then do its handoff to the operating system... and then nothing.  No more signal on the HDMI cable, nothing out on ssh, nothing.  The Cubox-i4 tries to reboot every few minutes with no more successful outcome.
This same Cubox-i4 runs fine with the last SD card system disk I built for it using the previous Debian server image.
Does anyone have any ideas?
Thanks in advance!
Thanks for your replies!
@Igor is that screen shot you've pastebinned from a connection to the usb TTY?
I've ordered a new card reader / writer which should be here tomorrow.  The only one I currently have is in my elderly System76 laptop and I'm not fully confident in its driver support (for example it doesn't eject or unmount, so my only recourse is to run sync a bunch of times and then shut the machine down).
I don't think there's much point in building new cards with the Bookworm minimal version as that's what I currently have on my Cuboxes.
I will report back.  Thanks again!
Connected via SSH. DHCP client is automatically getting IP, so you should be able to find the device on network after few minutes ... in case HDMI output is really broken. I can't test that as device is stashed to some rack.
@Igor thanks for the reply.
In my case, I can't even ping the Cubox much less connect to it.  I'm pretty sure something is failing as the device reboots itself every ~ 2 minutes; each time I see the initial boot with logo on the HDMI, then the screen goes blank, then my monitor claims that HDMI signal is lost, then nothing (including no successful pings) for a couple of minutes, then around again.
I've ordered some new SD cards and a USB SD card reader writer which should arrive Wednesday.  Maybe things will improve after that.  If not I will try a serial connection via USB.
I will report back.
That would be good. Cubox-i has standard microUSB connector for serial console, so its easy. That would give some insights on what is happening.
