Nanopineo - build fails when I use both CPUMIN and CPUMAX on the command-line
Go to solution Solved by indianajones,
Posted (edited)
This issue isn't for orangepione, but for nanopineo - which I can't find in the dropdowns anymore.  Perhaps it is no longer supported.  I'm able to build a working image using this command:
./compile.sh BOARD=nanopineo BRANCH=current RELEASE=noble BUILD_MINIMAL=no BUILD_DESKTOP=no KERNEL_CONFIGURE=no COMPRESS_OUTPUTIMAGE=xz
However, if I add the CPU governance variables, such as this:
./compile.sh BOARD=nanopineo BRANCH=current RELEASE=noble BUILD_MINIMAL=no BUILD_DESKTOP=no KERNEL_CONFIGURE=no COMPRESS_OUTPUTIMAGE=xz CPUMIN=81600 CPUMAX=96000
...the build fails with the following error text:
./compile.sh mike
[🚸] This script requires root privileges; Docker is unavailable [ trying to use sudo ]
[🌿] Applying cmdline param [ 'PREFER_DOCKER': '(unset)' --> 'no' early ]
[🌱] Skip     cmdline param [ 'ARMBIAN_RELAUNCHED': already set to 'yes' early ]
[🌿] Applying cmdline param [ 'SET_OWNER_TO_UID': '(unset)' --> '1000' early ]
[🌱] Skip     cmdline param [ 'PREFER_DOCKER': already set to 'no' after config 'config-mike.conf' ]
[🌱] Skip     cmdline param [ 'ARMBIAN_RELAUNCHED': already set to 'yes' after config 'config-mike.conf' ]
[🌱] Skip     cmdline param [ 'SET_OWNER_TO_UID': already set to '1000' after config 'config-mike.conf' ]
[🌱] Starting single build process [ nanopineo ]
[🌱] Checking [ basic host setup ]
[🌱] Build host OS release [ noble ]
[🌱] Build host architecture [ arm64 ]
[🌱] Sourcing board configuration [ /home/mike/build/config/boards/nanopineo.csc ]
[] change-tracking: after sourcing board file config/boards/nanopineo.csc [ BOARDFAMILY='sun8i' ]
[] change-tracking: after sourcing board file config/boards/nanopineo.csc [ BOOTCONFIG='nanopi_neo_defconfig' ]
[] change-tracking: after defaulting LINUXFAMILY to BOARDFAMILY [ LINUXFAMILY='sun8i' ]
[🌱] Starting main configuration
[🌱] Using REVISION from [ main VERSION file: '25.11.0-trunk' ]
[🌿] Enabling extension [ armbian-config ]
[🌱] Sourcing family configuration [ /home/mike/build/config/sources/families/sun8i.conf ]
[🌿] Enabling extension [ sunxi-tools ]
[💥] Error 1 occurred in main shell [ at /home/mike/build/lib/functions/configuration/main-config.sh:552
   source_family_config_and_arch() --> lib/functions/configuration/main-config.sh:552
          do_main_configuration() --> lib/functions/configuration/main-config.sh:291
                do_with_logging() --> lib/functions/logging/section-logging.sh:81
    do_with_conditional_logging() --> lib/functions/logging/section-logging.sh:111
    prep_conf_main_build_single() --> lib/functions/main/config-prepare.sh:29
         cli_standard_build_run() --> lib/functions/cli/cli-build.sh:22
        armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136
                 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:208
                           main() --> compile.sh:50
I looked at the source_family_config_and_arch() function source, and the file that gets passed into it (/home/mike/build/config/sources/families/sun8i.conf) exists on my box, but something is causing the failure at line 552 anyway.  What's strange is that the exact same LINUXFAMILY / BOARDFAMILY is configured in my working command (with all the params passed on the cmdline), like this:
[] change-tracking: after sourcing family config [ KERNEL_MAJOR_MINOR='6.12' ]
[] change-tracking: after sourcing family config [ LINUXFAMILY='sunxi'  # (was: 'sun8i') ]
[] change-tracking: after sourcing family config [ KERNELPATCHDIR='archive/sunxi-6.12' ]
[] change-tracking: after sourcing family config [ BOOTBRANCH='tag:v2024.01' ]
[] change-tracking: after sourcing family config [ BOOTPATCHDIR='u-boot-sunxi' ]
[] change-tracking: after sourcing family config [ NETWORKING_STACK='network-manager' ]
The build/config/sources/families/sun8i.conf file, referenced in the log output, contains a proper CPUMIN and CPUMAX, so I'm not sure why specifying them on the command line blows up the build.
# SPDX-License-Identifier: GPL-2.0
# Copyright (c) 2013-2023 Igor Pecovnik, igor@armbian.com
# This file is a part of the Armbian Build Framework
# https://github.com/armbian/build/
# shellcheck source=config/sources/families/include/sunxi_common.inc
source "${BASH_SOURCE%/*}/include/sunxi_common.inc"
if [[ -z ${OVERLAY_PREFIX} ]]; then
        OVERLAY_PREFIX='sun8i-h3'
fi
[[ -z $CPUMIN ]] && CPUMIN=480000
[[ -z $CPUMAX ]] && CPUMAX=1400000
Any thoughts on what I'm doing wrong?
Edited by indianajones
  • indianajones changed the title to Nanopineo - build fails when I use both CPUMIN and CPUMAX on the command-line
  • Solution
Posted (edited)
@Igor Thanks for that, I guess I can move on to the newer tools.  So does that mean that the GOVERNOR and CPUMIN params are useless and can be discarded?  And BTW your Armbian tools are utterly fantastic.
Currently yes. A replacement for this package / service needs to be found and implement - in case you want to get involved.
Thank you! It's a work of many people, impossible for me to poke into every issue or feature that exists :)
