Hello guys
I know that this image is still under development and probably there are lots of more important things to do.
but this problem bothering me for weeks.
I am trying to create a hotspot using rtl8188cus
the one in the armbian-config didn't work
I have used different methods searching the net
now I am using this driver:
https://github.com/pvaret/rtl8192cu-fixes
and the hostapd-realtek which is in apt.armbian.com (the one armbian-config installs)
and now I am getting the following error:
wlan1: interface state UNINITIALIZED->COUNTRY_UPDATE
ioctl[RTL_IOCTL_HOSTAPD]: Operation not supported
wlan1: Could not connect to kernel driver
+rtl871x_sta_deauth_ops, ff:ff:ff:ff:ff:ff is deauth, reason=2
rtl871x_set_key_ops
I would be gratefull if you could tell me what's the problem and how can I resolve it
rtl871x_set_key_ops
I had same issue on almost same hardware. And I have already seen it on previous H5 build. Gave up and used Ralink2800 as a hostapd device. But really appreciate if there will be a tip/solution since rtlXXXC devices support concurrent mode - I can use one adapter for both AP and client.
I have already bought two rtl! in rpi it wasn't a problem and I thought it would be the same in opi-pc2!
37 minutes ago, zador.blood.stained said:
This is not related to OPi PC2 and H5 in any way. And I wold try to get working a combination the existing in-kernel driver and non-Realkek hostapd first.
Thank you, I understand that probably it's not related to the hardware, but would you please explain a bit more that what is the problem?
I cut out this part of messages from PC2 topic since they are pretty much off topic.
1
And this part is also hard to explain. Some drivers are done badly and simply does not support AP mode. It's common. I am not sure if this is the case with your adapter, but at least its possible. There are many tips around the net, try different drivers or better use adaptors that work. Under specific kernel. If some adaptor works with Raspberry Pi or on PC, there is absolutely no warranty that will work here. Zero.
And do try hostapd with non-realtek hostapd as well.
Check this:
Unfortunately the wireless driver area in Vanilla Linux is getting worse and worse.
Part of the problem are the vendors, but honestly I cannot give them all the faults, since the 802.11x framework in Linux Kernel is one of the most unstable part of the kernel itself, and I cannot blame the silicon vendor if they don't want to maintain the official driver at avery change....
Having said so, before buying ANY USB-WiFi dongle, if the goal is to use it in AP mode, you should check this page:
https://wireless.wiki.kernel.org/en/users/drivers
As you can see none of the rtl usb chipset support AP. Where you read "?", you can just consider it as "not supported"
BTW you should go for ath9k_hc chipset or RaLink rt2800usb, the latter is what I currently use in AP, and it works wuite ok
You are not alone with the RealTek chipset, the R1 comes with: rtl8192c  if you expand the posting you see my error message. The rtl8192c was running in the past, but I think the combination of driver & hostapd is the crux.
https://forum.armbian.com/topic/3476-bpi-r1-with-new-b53-switch-driver-dsa/?do=findComment&comment=37009
Hmm, for the  rtl8192cu  it comes with a few YES - maybe I should give it a try again just as Zador & Igor suggested.
Debian suggests for your Chipset: https://wiki.debian.org/rtl819x  Supports USB devices based on the RTL8188CUS and RTL8192CU chips. On this document you maybe find an interesting Link ..
