djtecha6 Posted October 4 Posted October 4 On an orangepi 5 this image failed to post. Armbian_25.8.2_Orangepi5_noble_vendor_6.1.115.img.xz worked just fine via balena etcher and booting from a nvme. 0 Quote
Werner Posted October 4 Posted October 4 moved. All boards using rk3588/s soc most likely work best with either vendor or edge kernel. Current has limited functionality since when this kernel became LTS only basic support was there. All further enhancements regarding hardware featureless were upstreamed later. 1 Quote
djtecha6 Posted October 9 Author Posted October 9 Ok, that makes sense. Is there an edge build for this or does one have to compile "edge" builds? Sry, I'm just a little confused. 0 Quote
mitu Posted October 9 Posted October 9 Try the 'minimal-iot' flavor, I think that's the only one that boots from the current images. You can then add the desired packages and even switch to the 'edge' kernel from armbian-config. 0 Quote
djtecha6 Posted October 10 Author Posted October 10 Thanks, ok this works but only over SSH. Maybe the other ones did too and the fact my monitor wouldn't turn on for them had me stuck. 0 Quote
Solution djtecha6 Posted October 10 Author Solution Posted October 10 Just to help anyone else that ran into this. I was able to get up and running by Armbian_25.8.2_Orangepi5_noble_current_6.12.49_minimal (1).img.xz then on boot I found the IP address on my network and SSH'd to it. Once on I used armbian-config to go and fetch the edge kernel 6.16.4-edge-rockchip64 Display is now working, but the older USB for the keyboard doesn't work. Only the USB 3.0 does. 0 Quote
KhanhDTP Posted October 13 Posted October 13 @djtecha6 Quote but the older USB for the keyboard doesn't work. Only the USB 3.0 does I have faced the same issue. And it's the Armbian 25.8.2 problem, use the Armbian 25.5.1 image indeed. 0 Quote
Fredrik Posted 5 hours ago Posted 5 hours ago Hi is there a way to enable the old USB port without re-installing Armbian? I have done to much setup work to start all over again. 0 Quote
