rezaee Posted November 1, 2017 Posted November 1, 2017 I have nanopi-m1 and use Armbian-5.30(Ubuntu server 16.04/ Linux nanopim1 3.4.113-sun8i). I did make these to .conf files : Add to file /etc/modules-load.d/fbtft.conf spi-bcm2835 fbtft_device and Add to file /etc/modprobe.d/fbtft.conf options fbtft_device custom name=fb_ili9341 gpios=reset:1,dc:201,led:6 speed=16000000 rotate=90 bgr=1 Then I tried to make another file by this content: Add to file: /usr/share/X11/xorg.conf.d/99-fbdev.conf Section "Device" Identifier "myfb" Driver "fbdev" Option "fbdev" "/dev/fb1" EndSection But, After reboot, I think only this command will execute automatically: sudo modprobe fbtft_device custom name=fb_ili9341 gpios=reset:1,dc:201,led:6 speed=16000000 rotate=90 bgr=1 Because my LCD turns on and has blank screen(like when I run that command manually), but I should execute startx command to have my xwindow (a gray screen with a black mouse and right-click ability). But I like this done automatically(like HDMI monitor). So I searched a lot for it and I think found the soulution here: I did convert my "/boot.script.bin" to "custom.fex" file with this content: GNU nano 2.5.3 File: custom.fex [product] version = "100" machine = "FriendlyARM NanoPi M1" [platform] debug_mode = 1 eraseflag = 1 next_work = 2 [target] boot_clock = 1008 storage_type = -1 [key_detect_en] keyen_flag = 0 [fel_key] fel_key_max = 7 fel_key_min = 2 And I think I must add something like this for my LCD: script.bin/fex file The settings in the [disp_init] section of the script.bin/fex file define the display output enabled at boot. An example configuration for HDMI: [disp_init] disp_init_enable = 1 disp_mode = 0 screen0_output_type = 3 screen0_output_mode = 4 fb0_framebuffer_num = 2 fb0_format = 10 fb0_pixel_sequence = 0 fb0_scaler_mode_enable = 0 disp_mode selects single-screen output or different dual screen modes. Generally this is 0, which means use screen0 with fb0 (one screen). screen0_output_type = 3 means HDMI output. screen0_output_mode selects the video/monitor mode to use (resolution and refresh rate). See the table in the Fex guide. fb0_framebuffer_num selects the number of buffers for fb0, generally you need 2 or more for video acceleration or Mali (3D), 3 is better. fb0_format and fb0_pixel_sequence determine the pixel format in the framebuffer. The above example (values of 10 and 0) selects the most common variant of 32bpp truecolor (ARGB). fb0_scaler_mode_enable selects whether the scaler should be enabled. Enabling it does not really scale pixels, it configures the scaler to scale pixels 1-to-1 which can fix screen refresh-related problems at 1080p resolution. See the section below. Similar parameter are defined for screen1 (which is usually disabled in practice). But, as I know my LCD uses " fb8 " , I dont know how should I change this code? And can this code solve my problem and gives me my LCD running automatically at startup or I must compile my kernel for this purpose?
martinayotte Posted November 1, 2017 Posted November 1, 2017 Did you configured the SPI itself in FEX using FEX Guide ? http://linux-sunxi.org/Fex_Guide#spi_configuration 1
rezaee Posted November 1, 2017 Author Posted November 1, 2017 42 minutes ago, martinayotte said: Did you configured the SPI itself in FEX using FEX Guide ? http://linux-sunxi.org/Fex_Guide#spi_configuration No, I didn't do it, but I did create two .conf files as I said above and after boot my display turns on and I think it means SPI works. BTW, I am very thankful for your participation in my topic. I tried to add "startx" to my "etc/rc.local" and it worked and saved 200EUR for me But I have two questions if you can help me: 1- what is difference between changing "script.bin" or "rc.local" ? Is first one faster? 2- If I want to write a C++ program, and want it runs just after boot (kiosk linux), should I put my program inside "rc.local"? How?
Igor Posted November 1, 2017 Posted November 1, 2017 25 minutes ago, rezaee said: I tried to add "startx" to my "etc/rc.local" and it worked and saved 200EUR for me You don't understand, do you? Forwarding not answered topics to my/our private communication addresses is recognized as abuse. Perhaps a ban would be better? We/I do answer if possible, but you are (nobody is) not in a position to add pressure on support or demand help. SPI based display video drivers are not our work - better seek help in general forum or ask driver author.
rezaee Posted November 1, 2017 Author Posted November 1, 2017 2 minutes ago, Igor said: You don't understand, do you? Forwarding not answered topics to my/our private communication addresses is recognized as abuse. We/I do answer if possible, but you are not in a position to add pressure on support or demand help. SPI based display video drivers are not our work - better seek help in general forum or ask driver author. Calm down Igor! That was just kidding! I appreciate your works and can understand you, and for that reason tried other site and found the solution! Be happy!
