dolphs Posted 2 hours ago Posted 2 hours ago Hello, Noticed the NanoPi Zero2 the other day and it might help me setting up a wifibridge WiFi (WiFi6) to LAN. Since it has the RK3528A SoC there is an image avaiable based on that SoC , though for the Rock 2F Therefore wondering about its status and if it will be (not) adapted? Thanks 0 Quote
Werner Posted 30 minutes ago Posted 30 minutes ago Not planned but should be possible. A good start would be to copy the mentioend 2f and extract the device tree from official image and add it to vendor kernel source. If you're lucky that's all what's needed to get it to work. 0 Quote
