DS Justice Posted November 6, 2017 Share Posted November 6, 2017 The espressobin has three ethernet ports. In Ubuntu Armbian, left to right (looking into the ports), they're called "lan1", "lan0", and "wan". The weird thing is that you can't bring them up until you've *first* brought up eth0, which is not associated with a physical port. This causes all kinds of havoc trying to use /etc/network/interfaces/, because it takes a couple of seconds for eth0 to come up, in which time the other interfaces have already failed. 1) What is this mysterious eth0? 2) My attempts to bridge lan0 and lan1 from .../interfaces have failed. Got an example you can give me? Link to comment Share on other sites More sharing options...
Igor Posted November 6, 2017 Share Posted November 6, 2017 We use systemd-networkd at Espressobin. Check those manuals/examples: http://xmodulo.com/switch-from-networkmanager-to-systemd-networkd.html https://wiki.archlinux.org/index.php/systemd-networkd Leave /etc/network/interfaces empty. 2 Link to comment Share on other sites More sharing options...
zador.blood.stained Posted November 6, 2017 Share Posted November 6, 2017 2 hours ago, DS Justice said: 1) What is this mysterious eth0? This is a SoC/CPU network interface that connects to the Topaz switch: http://wiki.espressobin.net/tiki-index.php?page=Block+diagram So it has to be brought up first in order to work with interfaces that are behind the the switch. 1 Link to comment Share on other sites More sharing options...
DS Justice Posted November 7, 2017 Author Share Posted November 7, 2017 On 11/5/2017 at 9:52 PM, Igor said: We use systemd-networkd at Espressobin. Check those manuals/examples: Fair enough. I guess I've been grumpy about systemd long enough, time to figure out what it is. Thanks for the nudge. Link to comment Share on other sites More sharing options...
DS Justice Posted November 7, 2017 Author Share Posted November 7, 2017 23 hours ago, zador.blood.stained said: SoC/CPU network interface that connects to the Topaz switch So I guess I'm one of today's 10,000. Lucky me! And thanks. Link to comment Share on other sites More sharing options...
arm-push Posted December 3, 2017 Share Posted December 3, 2017 On 11/6/2017 at 11:22 AM, Igor said: We use systemd-networkd at Espressobin. Check those manuals/examples: http://xmodulo.com/switch-from-networkmanager-to-systemd-networkd.html https://wiki.archlinux.org/index.php/systemd-networkd Leave /etc/network/interfaces empty. I tried to set a static IP using armbian-config. It configured /etc/network/interfaces file instead of the file in /etc/systemd/network. When this happened, br0 had 2 IPs, which were set by systemd DHCP and /etc/network/interfaces static IP I guess. Anyway commenting out /etc/network/interfaces and setting the correct values in /etc/systemd/network/10-br0.network worked for me. Link to comment Share on other sites More sharing options...
