I received a Helios4 and was finally able to get it to boot.  As per instructions, I booted from microSD and flashed the latest Armbian image to sda1 via the nand-sata-install command.  This reboots fine now, but only with the microSD-card present and the SW1 dipswitch set to "SD card boot mode".  Is anybody here using "SPI NOR Flash" or "SATA1" boot mode to get rid of the microSD card? I am bit handicapped here since my serial port on the microUSB only comes up maybe 1 in 10 times.  I wonder if it's worn out or if I am simply doing something wrong.
Related Links: 1 2 3 4
Thank you for your quick answer, Jimbolaya.
Yes, I did try different cables all with the same result.
I wonder if there is another way to access the serial console, J13 perhaps?  Albeit with some required soldering, I suppose.  Then remains the question of which headers exactly relate to GND, TX and RX.
With the latest changes in Armbian and most importantly the update of u-boot to v2025.10 for Helios4, it is now possible to boot SATA and USB from u-boot flashed to SPI NOR flash, with the dip switch set to SPI boot mode.  This even includes booting straight from u-boot to btrfs now.
Hello,
I ruun an Helios4 myself, and I've been struck by the kernel image size issue some time ago. I managed to recover using an old version, but now need to upgrade... I foolishly tried an 'apt update', which obviously end up in a non booting board.
I manage to get it boot with the latest version on SD, but can not manage to make it work from SPI...
Could you please explain how to get the updated u-boot loaded into SPI ? No try using nand-sata-install I've made make a difference.
