Desktop for odroid xu4?
Go to solution Solved by dev001,
If you need an image without desktop, there is always the build framework which allows you to build any combination of kernel and userspace and desktop you want.
Thanks for the reply.  My question was worded improperly. It should have been "Latest compile for odroid xu4 doesn't have a desktop. Any reason why?" Sorry
It is nog normal desktop images are not available.
You can always install a desktop to server images. I use taskset for desktops that need a lot of dependancies.
sudo apt install taskset
sudo taskset
For the xu4 there should be not much difference with the armbian desktop images except for the background image.
  • Solution
taskset is not found in the repository.
I have resolved the issue by install xubuntu-desktop package rather than installing xfce4 and xfce4-goodies.
Thanks for the help.
ref:
