Posted (edited)
For those with a Radxa Cubie A7A, I made a custom Armbian Build using the BSP kernel.
https://github.com/NickAlilovic/build/releases/tag/Radxa-a7a-v0.2
https://github.com/NickAlilovic/build/tree/Radxa-A7A
Now supports automatic first boot configuration by default. No need for a usb serial device to boot into a desktop image. First boot takes awhile to load. If you are using a server image you need a usb serial device/ssh to interact with the console. There is no Framebuffer console support in the BSP kernel.
If you want to edit the automatic first boot configuration read the documentation.
https://docs.armbian.com/User-Guide_Autoconfig/
Username: radxa
password: radxa
Edited by Nick A
Updated release to v0.2
  • Nick A changed the title to Radxa Cubie A7A - Allwinner a733
Fixed the automatic first boot configuration on Bookwarm. Now you can boot into the desktop image without a usb serial device.
