@Jain Ziad I'm currently working on hardware acceleration, though I can't say yet if it will outperform the official Radxa builds since it uses the same drivers. I'll keep the community updated on the results.
Hello NickA, fire-hound from discord here ^_^ ...
You do a tremendous service for us all, keep it up buddy!
I loaded your recent build from here: https://github.com/NickAlilovic/build/releases
and can confirm it works on my A7A.
It correctly detected my Pimorony NVME Base
lsblk
NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
mtdblock0    31:0    0     8M  0 disk
mmcblk0     179:0    0  29.2G  0 disk
├─mmcblk0p1 179:1    0   256M  0 part /boot
└─mmcblk0p2 179:2    0  28.6G  0 part /var/lib/containers/storage/overlay
                                      /var/log.hdd
zram0       254:0    0   3.9G  0 disk [SWAP]
zram1       254:1    0    50M  0 disk /var/log
zram2       254:2    0     0B  0 disk
nvme0n1     259:0    0 238.5G  0 disk
└─nvme0n1p1 259:1    0 238.5G  0 part /srv/dev-disk-by-uuid-b28b2f5c-ee2e-4ded-959e-22bc63051b1d
and:
screenfetch
         _,met$$$$$gg.           root@radxa-cubie-a7a
      ,g$$$$$$$$$$$$$$$P.        OS: Debian 13 trixie
    ,g$$P""       """Y$$.".      Kernel: aarch64 Linux 6.6.98-vendor-sun60iw2
   ,$$P'              `$$$.      Uptime: 11h 14m
  ',$$P       ,ggs.     `$$b:    Packages: 661
  `d$$'     ,$P"'   .    $$$     Shell: bash 5.2.37
   $$P      d$'     ,    $$P     Disk: 4.9G / 271G (2%)
   $$:      $$.   -    ,d$$'     CPU: ARM Cortex-A55 Cortex-A76 @ 8x 1.794GHz
   $$\;      Y$b._   _,d$P'      RAM: 534MiB / 7928MiB
   Y$$.    `.`"Y$$$$P"'
   `$$b      "-.__
    `Y$$
     `Y$$.
       `$$b.
         `Y$$b.
            `"Y$b._
So far so good
The issues:
1. The typical Armbian image has a module in the armbian-config and radxa's rsetup where one can set up the two leds conveiently to other than full on and heartbeat for the green and blue gpio leds respectively.
I find it to be a nuisance to dig for that manually
2. The Ovralys module in armbian-config is returning an error - when entering DTO001 module (Device Tree Overlays) saying:
Invalid overlay_prefix
that might require deeper digging into the issue i guess?
What works:
Open Media Vault registers the NVME nicely as additional storage.
I suspect booting off that NVME would work for an updated SPI bootloader i could test that if you want me to?
If you need any other info or output I stand at Your disposal 😁
Hi all,
Over the past few months working on the A7Z, I’ve successfully ported a number of BSP drivers to Linux 6.18.
The code is available here:
https://github.com/alexcaoys/allwinner-bsp/tree/linux-6.18.y
It’s currently tested on 6.18.19 and should, in theory, work with newer 6.18.y releases. I’ve tried to reuse as much upstream (mainline) drivers as possible, and have also upstreamed support for PCK600 and ET7304 used on the A7Z.
Hopefully this helps accelerate ongoing mainline efforts. Feedback, issues, and PRs are very welcome.
I may also look into creating branches for Linux 7.x in the future.
hello
i have ths a7z with 8gb ram.
Actualy im using with only 4gb (ok for my application). I can boot only if i set mem=4g.
Any workaround for that? i tried all images ive found and no one can boot with 8gb.
Posted (edited)
@tiobily Is your a7z factory 8GB or modded out of curiosity (lpddr4 or lpddr5) ?
Are you able to connect serial console onto uart0 (pb9, pb10) header pins (3.3V TTL uart adapter) and see right after power is applied to the board the debug of dram detection and training?
Debug will show if full 8GB is being detected - once this is confirmed, we can take it from there.
Edited by chris178
hi @chris178!
1 - factory 8gb, not modded, lpddr4
2 - boot log:
[151]HELLO! BOOT0 is starting!
[154]BOOT0 commit : {9f6fab4f-dirty}
[168]dram_para_total:0xf
[171]vaild para:6  select dram para10
[175][mmc]: mmc driver ver 2024-03-20 10:36
[184][mmc]: Wrong media type 0x0
[188][mmc]: ***Try SD card 0***
[197][mmc]: HSSDR52/SDR25 4 bit
[200][mmc]: 50000000 Hz
[202][mmc]: 59638 MB
[205][mmc]: ***SD/MMC 0 init OK!!!***
[210]DRAM BOOT DRIVE INFO: V0.601
[215]DRAM_VCC set to 1100 mv
[217]DRAM CLK =1800 MHZ
[220]DRAM Type =8 (8:LPDDR4,9:LPDDR5)
[320]Training result is = 7
[323]DRAM Pstate 1 training, frequency is 1200 Mhz
[433]Training result is = 7
[436]DRAM Pstate 2 training, frequency is 800 Mhz
[642]Training result is = 7
[645]DRAM Pstate 3 training, frequency is 400 Mhz
[3829]Training result is = 7
[3832]DRAM Pstate 0 training, frequency is 1800 Mhz
[3840]Actual DRAM SIZE =8192 M
[3843]DRAM SIZE =8192 MBytes, para1 = 311a, para2 = 20001001, dram_tpr13 = 6067
[3858]DRAM simple test OK.
[3864]error:bad magic.
[3928]error: dtb not found for scp
[3931]mmc not para
[3933]Jump to ATF: monitor_base = 0x48000000, uboot_base = 0x4a000000, optee_base = 0x0
NOTICE:  BL31: OP-TEE 32bit detected
NOTICE:  BL31: U-BOOT 32bit detected
NOTICE:  BL31: v2.5(debug):5fc237a6a
NOTICE:  BL31: Built : 09:05:28, Feb 26 2025
NOTICE:  BL31: No DTB found.
ERROR:   Error initializing runtime service opteed_fast
U-Boot 2018.07-12-boot-aw2501-gb2d229198b2-dirty (Jan 06 2026 - 03:45:33 +0000) Allwinner Technology
[03.985]CPU:   Allwinner Family
[03.988]Model: Radxa Cubie A7A
I2C:   ready
[04.052]DRAM:  8 GiB
[04.061]Relocation Offset is: 75d89000
[04.114]secure enable bit: 0
[04.117]PMU: AXP8191
[04.119]PMU: AXP8191 VER_A
FDT ERROR:fdt_get_regulator_name:get property handle twi-supply error:FDT_ERR_INTERNAL
[04.131]bmu_axp515_probe pmic_bus_read fail
[04.135][AXP8191] onoff status: 0x50 = 0x1, 0x51 = 0x0
[04.140][AXP8191] charge status: 0x4 = 0x0
[04.144]CPU=1014 MHz,PLL6=1200 Mhz,AHB=200 Mhz, APB1=24Mhz  MBus=600Mhz
[04.150]gic: sec monitor mode
SPI ALL:   ready
[04.194]flash init start
[04.196]workmode = 0,storage type = 1
[04.200][mmc]: mmc driver ver uboot2018:2024-10-18 9:01:00 -- uboot2018:2025-03-28 10:03:00
[04.208][mmc]: get sdc_type fail and use default host:tm1.
[04.216][mmc]: can't find node "mmc0",will add new node
[04.221][mmc]: fdt err returned <no error>
[04.224][mmc]: Using default timing para
[04.228][mmc]: SUNXI SDMMC Controller Version:0x50530
[04.246][mmc]: card_caps:0x3000000a
[04.249][mmc]: host_caps:0x3000003f
[04.252]sunxi flash init ok
get value error
[04.262]Loading Environment from SUNXI_FLASH... OK
No ethernet found.
[04.299]NOT support bridge yet
[04.302]Warn: no find panel or bridge
[04.403]drm hdmi get mode: 1920x1080@60Hz
hdmi0@5520000: use force output detailed mode clock 139190 kHz, flags[5]
    H: 1920 2008 2052 2080
    V: 1080 1082 1087 1115
bus_format: 0
clk_set_rate: <NULL> has NULL parent
[04.505]suxni tcon hdmi set rate: 139190000Hz and get diff: -139190000Hz
[04.577]the secure storage item0 copy0 magic is bad
[04.589]the secure storage item0 copy1 magic is bad
[04.593]usb burn from boot
delay time 0
[04.599]usb prepare ok
[04.902]overtime
[04.906]do_burn_from_boot usb : no usb exist
skip update boot_param
cann't get the boot_base from the env
[04.917]update part info
[04.922]battery temp is -1
[04.926]update bootcmd
[04.934](not enough data: expected >= 8 cells, got 4 cells)
Link up timeout
Speed change timeout
PCIe speed of Gen1
Override default fdtfile to allwinner/sun60i-a733-cubie-a7z.dtb
[07.376]libfdt fdt_check_header(): FDT_ERR_BADMAGIC
[07.382]libfdt fdt_path_offset() returned FDT_ERR_BADMAGIC
[07.388][mmc]: get sunxi-mmc0 string failed
[07.392]The storage not support sample function
[07.398]## error: update_fdt_dram_para_from_bootpara : FDT_ERR_NOTFOUND
ret 0
[07.408]chip id : 0x00005100 0x00004900 0x00004810 0x00001d62
[07.414]mac addr => 08:51:49:58:7f:71
[07.417]chip id : 0x00005100 0x00004900 0x00004810 0x00001d62
[07.423]mac addr => 08:51:49:58:7f:70
[07.427]/chosen/rng-seed node not exit
[07.430]no battery, disabled battery functons
[07.434]Could not find nodeoffset for bat_supply
[07.439]update dts
curr_device:0
Device: SUNXI SD/MMC
Manufacturer ID: ff
OEM: 0
Bus Speed: 50000000
Mode : SD High Speed (50MHz)
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 58.2 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
[ufs]info:Driver version 0.0.24 2024.12.30 16:00
[ufs]info:Cal words 0x60:val 0xb0880000, 0x64:val 0x4f21a959
[ufs]err:uic c 16,uic a 0,1,0
[ufs]err:e 80000010,0,0,0,0
[ufs]err:int s 0,400
[ufs]err:Device not present
[ufs]err:wait device link startup failed
[ufs]info:peer link startup timeout
[ufs]err:link startup failed -6
[ufs]err:ufshcd_probe() failed -6
fail to init ufs
sunxi_flash - sunxi_flash sub-system
Usage:
sunxi_flash sunxi_flash init storage_type
sunxi_flash read mem_addr part_name [size]
sunxi_flash read_mtd mem_addr part_name [size]
sunxi_flash write <mem_addr> <part_name> [size]
sunxi_flash write <mem_addr> <part_name> [offset] [size]
sunxi_flash write_mtd <mem_addr> <part_name>
sunxi_flash boot0 force_dram_update_size <new_val>
sunxi_flash boot0 force_dram_update_flag <new_val>
starting USB...
USB0:   start sunxi  USB-DRD...
config usb clk ok
sunxi USB-DRD init ok...
USB EHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
USB1:   start sunxi  USB1-Host...
config usb clk ok
sunxi USB1-Host init ok...
USB EHCI 1.00
scanning bus 1 for devices... 1 USB Device(s) found
Device 0: device type unknown
... is now current device
** Bad device usb 0 **
mmc0 is current device
Scanning mmc 0:2...
Scanning mmc 0:3...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
1307 bytes read in 19 ms (66.4 KiB/s)
U-Boot menu
1:      Debian GNU/Linux 11 (bullseye) 5.15.147-14-a733
2:      Debian GNU/Linux 11 (bullseye) 5.15.147-14-a733 (rescue target)
Enter choice: 1:        Debian GNU/Linux 11 (bullseye) 5.15.147-14-a733
Retrieving file: /boot/initrd.img-5.15.147-14-a733
31153067 bytes read in 1310 ms (22.7 MiB/s)
Retrieving file: /boot/vmlinuz-5.15.147-14-a733
19030528 bytes read in 808 ms (22.5 MiB/s)
append: root=UUID=6f750720-329a-45f0-a4b5-abc5797b040a console=ttyAS0,115200n8 rootwait clk_ignore_unused mac_addr=08:51:49:58:7f:71 mac1_addr=08:51:49:58:7f:70 quiet splash loglevel=4 rw earlycon consoleblank=0 console=tty1 coherent_pool=2M irqchip.gicv3_pseudo_nmi=0 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 kasan=off
Retrieving file: /usr/lib/linux-image-5.15.147-14-a733/allwinner/sun60i-a733-cubie-a7z.dtb
193692 bytes read in 145 ms (1.3 MiB/s)
[16.025]libfdt fdt_path_offset() returned FDT_ERR_BADMAGIC
[16.034]The storage not support sample function
ret 0
[16.136]mac addr => 08:51:49:58:7f:71
[16.140]mac addr => 08:51:49:58:7f:70
[16.145]no battery, disabled battery functons
[16.152]update dts
stop sunxi USB-DRD ok...
stop sunxi USB1-Host ok...
   Loading Ramdisk to 4824a000, end 49fffbab ... OK
ERROR: reserving fdt memory region failed (addr=48000000 size=1000000)
[16.232]Starting kernel ...
[16.235]total: 16235 ms
[16.237][mmc]: MMC Device 2 not found
[16.240][mmc]: mmc 2 not find, so not exit
NOTICE:  [SCP] :wait arisc ready....
NOTICE:  [SCP] :arisc version: [d463b9da43dc50320f21ba51c6c51afe2db20d83]
NOTICE:  [SCP] :arisc startup ready
NOTICE:  [SCP] :arisc startup notify message feedback
NOTICE:  [SCP] :sunxi-arisc driver is starting
NOTICE:  BL3-1: Next image address = 0x40200000
NOTICE:  BL3-1: Next image spsr = 0x3c5
nothing happen after that
my workaround ( with claude help )
edit extlinux.conf and add mem=4G
append root=UUID=0e1a597a-1884-4b41-a07c-733efecf176c console=ttyAS0,115200n8 earlyprintk=sunxi-uart,0x2500000 rootwait mem=4G clk_ignore_unused
any higher value dosent work.
Posted (edited)
@tiobily Ram detect and training looks just fine above.... you could interrupt the boot and test memory.
 what OS image did you use above? I could try it on my device (also 8GB but modded).
Did you try different microSD cards?
Just tried @Nick A image and u-boot section is very similar. However boot continues with linux kernel at the point your debug stalled....
I can't see much clue as to why you're having that issue from the log above unfortunately...
Just tried https://github.com/radxa-build/radxa-a733/releases/download/rsdk-r5/radxa-a733_bullseye_cli_r5.output_512.img.xz on a 8GB moded A7Z and it boot fine and free mem as expected...
Edited by chris178
@chris178 im using this image ( r5 512 ) with the mem=4g param
i tried the nick A image too, same problem. ( i tried the r4, r1, 512 and 4096 )
i didnt tried a different microsd, im going to buy a new one and make a new test
maybe i got a faulty board. (im using npu and a lot of cpu, everything running fine)
Srry about my poor english, is not my native language 😅
@qq20739111 thks, official community = github? https://github.com/radxa-docs/docs/
i asked claude to make a summary of my project with npu:
We use the vendor's ACUITY toolkit inside a Docker container (ubuntu-npu:v2.0.10.1) to convert ONNX → quantized .nb files.
  - Pipeline: onnxsim → pegasus_import → pegasus_quantize → pegasus_export, uint8 quantization, deployed to ~/npu_models/ via push.sh.
  - Runtime: custom npu_server.c (pre-allocated input buffer, no per-call mmap) that the Python app talks to.
  - Hard lesson #1 — quantization: only pure Conv+BN+ReLU survives uint8. Attention, SE blocks, hard-swish, LayerNorm all collapse to constant outputs. So no MobileNetV3+, no transformers.
  - Hard lesson #2 — concurrency hang: NPU IRQs get lost when camera ISP DMA runs in parallel (shared memory bus). Fix: suppress GStreamer buffer copies during inference. Never STREAMOFF/ON the sunxi-vin driver — instant kernel crash.
  - Result: 12 models running (9 NPU + 3 CPU) at ~40ms/inference.
Posted (edited)
@Nick A hi, I noticed a big difference in my tests on A7Z. The official image runs cool at 60°C, but your image boosts performance by roughly 30% while hitting 90°C. Did you apply an overclock, or is the stock image just limiting the potential?
Edited by qq20739111
Posted (edited)
@qq20739111 The only change I can think of is the Thermal Governor is set to STEP_WISE by default. Without it the fan would run full speed all the time. Radxa had it set to CONFIG_THERMAL_DEFAULT_GOV_POWER_ALLOCATOR=y . I guess it would be safer to switch back to POWER_ALLOCATOR and figure another way to fix the fan issue.
The 0.6.x images don't have these changes. Is this an image you compiled yourself?
The CPU needs proper cooling you should install one of these.
https://radxa.com/products/accessories/heatsink-6530b
Edited by Nick A
