Orange PI 5 Armbian 25.8.2 Ubuntu Server 24.04/6.12 does not boot (kernel panic)
Posted (edited)
Hello,
my Orange Pi 5 works well with the stock OS (1.22, Ubuntu Jammy, BSP kernel 6.1.99), using the SD as a boot device.
It also works ok with Armbian Minimal-IoT / Debian 13 / 6.1:
 v25.8.2 for Orange Pi 5 running Armbian Linux 6.1.115-vendor-rk35xx
But I prefer Ubuntu and wanted to try 6.12, so I downloaded 25.8.2 / Ubuntu Server / 6.12.
Wrote to SD, hooked up the debug UART and powered on.
The bootloader is fine, the kernel starts, but at a certain point it panics:
[  OK  ] Reached target sockets.target - Socket Units.
         Starting armbian-hardware-monitor.…ce - Armbian hardware monitoring...
         Starting armbian-hardware-optimize… - Armbian hardware optimization...
         Starting armbian-led-state.service - Armbian leds state...
         Starting armbian-resize-filesystem…vice - Armbian filesystem resize...
armbian-hardware-monitor.service
[  OK  ] Finished armbian-hardware-monitor.…vice - Armbian hardware monitoring.
[  OK  ] Finished armbian-led-state.service - Armbian leds state.
[  OK  ] Finished armbian-hardware-optimize…ce - Armbian hardware optimization.
armbian-hardware-optimize.service
[  OK  ] Finished console-setup.service - Set console font and keymap.
sys-kernel-debug-tracing.mount
[  158.363359] rockchip-pm-domain fd8d8000.power-management:power-controller: failed to get ack on domain 'gpu', val=0xa9fff
[  158.364324] SError Interrupt on CPU7, code 0x00000000be000411 -- SError
[  158.364327] CPU: 7 UID: 0 PID: 462 Comm: (udev-worker) Tainted: G   M     C         6.12.49-current-rockchip64 #1
[  158.364332] Tainted: [M]=MACHINE_CHECK, [C]=CRAP
[  158.364333] Hardware name: Xunlong Orange Pi 5 (DT)
[  158.364334] pstate: 404000c9 (nZcv daIF +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[  158.364336] pc : _raw_spin_lock_irqsave+0x38/0x8c
[  158.364342] lr : regmap_lock_spinlock+0x18/0x2c
[  158.364347] sp : ffff800083f03660
[  158.364348] x29: ffff800083f03660 x28: 0000000000000000 x27: ffff800083f03c60
[  158.364351] x26: 0000000000000000 x25: ffff710bf0c4c080 x24: ffff710bf0f64098
[  158.364354] x23: 0000000000000000 x22: 0000000000000001 x21: 0000000000000000
[  158.364356] x20: 000000000000000c x19: 0000000000000000 x18: ffffffffffffffff
[  158.364358] x17: 66203a72656c6c6f x16: 72746e6f632d7265 x15: 776f703a746e656d
[  158.364361] x14: 6567616e616d2d72 x13: 00000000000002ac x12: 00000000ffffffea
[  158.364363] x11: 0000000000000001 x10: 0000000000000001 x9 : ffffc80dcfdf9250
[  158.364365] x8 : 000000000002ffe8 x7 : c0000000ffffdfff x6 : 00000000000affa8
[  158.364368] x5 : ffffc80dce6c1b54 x4 : 0000000000000008 x3 : ffffc80dce6c15c8
[  158.364370] x2 : 0000000000000001 x1 : 0000000000000000 x0 : ffff710bf0f65c00
[  158.364373] Kernel panic - not syncing: Asynchronous SError Interrupt
[  158.364374] CPU: 7 UID: 0 PID: 462 Comm: (udev-worker) Tainted: G   M     C         6.12.49-current-rockchip64 #1
[  158.364377] Tainted: [M]=MACHINE_CHECK, [C]=CRAP
[  158.364378] Hardware name: Xunlong Orange Pi 5 (DT)
[  158.364379] Call trace:
[  158.364380]  dump_backtrace+0x94/0x114
[  158.364383]  show_stack+0x18/0x24
[  158.364385]  dump_stack_lvl+0x38/0x90
[  158.364387]  dump_stack+0x18/0x24
[  158.364389]  panic+0x39c/0x3f4
[  158.364392]  nmi_panic+0x40/0x8c
[  158.364394]  arm64_serror_panic+0x70/0x80
[  158.364396]  do_serror+0x3c/0x78
[  158.364398]  el1h_64_error_handler+0x30/0x48
[  158.364401]  el1h_64_error+0x64/0x68
[  158.364402]  _raw_spin_lock_irqsave+0x38/0x8c
[  158.364404]  regmap_lock_spinlock+0x18/0x2c
[  158.364407]  regmap_write+0x3c/0x78
[  158.364409]  rockchip_pd_power+0xf8/0x5e8
[  158.364414]  rockchip_pd_power_on+0x14/0x20
[  158.364417]  _genpd_power_on+0x94/0x188
[  158.364418]  genpd_power_on.part.0+0xa4/0x1ac
[  158.364421]  __genpd_dev_pm_attach+0x144/0x2dc
[  158.364423]  genpd_dev_pm_attach+0x60/0x70
[  158.364425]  dev_pm_domain_attach+0x20/0x34
[  158.364429]  platform_probe+0x50/0xdc
[  158.364431]  really_probe+0xc0/0x38c
[  158.364434]  __driver_probe_device+0x7c/0x15c
[  158.364437]  driver_probe_device+0x40/0x114
[  158.364440]  __driver_attach+0xf4/0x1fc
[  158.364443]  bus_for_each_dev+0x74/0xd4
[  158.364445]  driver_attach+0x24/0x30
[  158.364448]  bus_add_driver+0x110/0x234
[  158.364451]  driver_register+0x60/0x128
[  158.364453]  __platform_driver_register+0x24/0x30
[  158.364455]  panthor_init+0x64/0x1000 [panthor]
[  158.364467]  do_one_initcall+0x44/0x2a8
[  158.364470]  do_init_module+0x58/0x20c
[  158.364472]  load_module+0x1e4c/0x1f3c
[  158.364474]  init_module_from_file+0x84/0xc4
[  158.364476]  __arm64_sys_finit_module+0x1f4/0x2f0
[  158.364478]  invoke_syscall+0x48/0x110
[  158.364481]  el0_svc_common.constprop.0+0xc8/0xe8
[  158.364484]  do_el0_svc+0x20/0x2c
[  158.364487]  el0_svc+0x30/0xfc
[  158.364488]  el0t_64_sync_handler+0x13c/0x158
[  158.364491]  el0t_64_sync+0x190/0x194
[  158.364492] SMP: stopping secondary CPUs
[  158.364557] Kernel Offset: 0x480d4dc00000 from 0xffff800080000000
[  158.364558] PHYS_OFFSET: 0xffff8ef600000000
[  158.364559] CPU features: 0x1c,00000017,00280928,4200720b
[  158.364561] Memory Limit: none
[  158.393407] ---[ end Kernel panic - not syncing: Asynchronous SError Interrupt ]---
Power brick is a solid 5V/4A and as I said works OK with the stock OS (7zip benchmark and all) and Armbian Minimal
Any suggestion?
Thanks a lot
Fernando
Edited by XFer012
Added reference to Armbian Minimal
