Hi,
System: A20Lime2-4gb with latest legacy image
Linux lime2 3.4.113-sun7i #23 SMP PREEMPT Wed Jun 14 23:57:45 CEST 2017 armv7l armv7i armv7l GNU/Linux
When I shutdown or restart, it throws me back to login screen and again loads desktop even if I don't enter id and password and then shutdown automatically within 10 secs .
I want it to shutdown/restart without this login screen.
I tried shutdown from terminal ' sudo shutdown -h now' , 'sudo poweroff'  still giving login screen.
How can solve this issue ?
Thank you in advance
This is a bug related to nodm (no display manager). If you install/change to lightdm this won't happen. BTW. We plan to rebuild A20 Lime images this week. In case you plan to setup from scratch.
Hi Igor ,
As you suggested, I installed lightdm but there is no change. It is still giving  same thing. Do I need to change something in lightdm ?
I m newbie, can you tell me detail procedure to do that ?
Regards
Then the best is to wait few days that we come out with a new release, which is fixed for many troubles ... I don't recall if those old builds have troubles of this kind. In case you installed xfce on top of our server base or if build is very changed try help in "Peer to peer section".
