D roZDi Posted April 6 Posted April 6 (edited) Armbian image placed on internal soldered eMMC 64GB - only one issue now aic8800 not supported yet by kernel 7.0-rc6 so no wifi 😕 No PCI as no PCI slots... also no HDMI... Experimental image based on Kwiboo repo dispo here. Edited April 7 by D roZDi 1 Quote
johlnx Posted April 8 Posted April 8 apply this patch for a working wifi: diff --git a/extensions/radxa-aic8800.sh b/extensions/radxa-aic8800.sh index e3e99eaa8..7ab721353 100644 --- a/extensions/radxa-aic8800.sh +++ b/extensions/radxa-aic8800.sh @@ -10,7 +10,7 @@ function extension_finish_config__install_kernel_headers_for_aic8800_dkms() { function post_install_kernel_debs__install_aic8800_dkms_package() { - if linux-version compare "${KERNEL_MAJOR_MINOR}" ge 6.20; then + if linux-version compare "${KERNEL_MAJOR_MINOR}" ge 7.1; then display_alert "Kernel version is too recent" "skipping aic8800 dkms for kernel v${KERNEL_MAJOR_MINOR}" "warn" return 0 fi 0 Quote
D roZDi Posted April 8 Posted April 8 (edited) It is not working with this patch because offcially AIC8800 is not supported in kernel > 7.0-rc6 plus in my image Wifi was initially disabled With new image it is better: I made a small fix to make it running with some commands as root: ``` # unzip AIC_FIX.zip # mkdir -p /lib/modules/$(uname -r)/kernel/drivers/net/wireless/aic8800 # cp aic_btusb.ko aic_load_fw.ko aic8800_fdrv.ko /lib/modules/$(uname -r)/kernel/drivers/net/wireless/aic8800/ # depmod -a # cat /etc/modules-load.d/aic8800.conf aic_load_fw aic8800_fdrv aic_btusb # cp -r aic8800_fw /lib/firmware/ # cp -pr aic8800_fw/USB/aic8800D80/ /lib/firmware/ # modprobe aic_load_fw # modprobe aic8800_fdrv # modprobe aic_btusb # lsmod |grep -i aic aic_btusb 57344 0 aic8800_fdrv 626688 0 cfg80211 1200128 1 aic8800_fdrv aic_load_fw 86016 1 aic8800_fdrv ``` Please also remember as it is experimental and all you do it is on your own risk HDMI is not working and we need some code first, I guess for this part: CONFIG_PHY_ROCKCHIP_INNO_HDMI_QP Edited April 8 by D roZDi 1 Quote
D roZDi Posted May 12 Posted May 12 (edited) Radxa Rock 2A Kernel version 7.1: link Radxa Rock 2A AIC_FIX_7.1: link Still no HDMI QP support Please also remember as it is experimental and all you do it is on your own risk Edited May 13 by D roZDi 0 Quote
humanus Posted May 12 Author Posted May 12 to use it on Rock 2F I can just point it to the 2F device tree, right? 0 Quote
D roZDi Posted May 12 Posted May 12 (edited) To be honnest, try my image above... including fix for aic8800 Or try this one compiled for Radxa Rock 2F - only uboot changed but not tested as I have no board... Edited May 13 by D roZDi 0 Quote
humanus Posted May 12 Author Posted May 12 Where did you get the kernel source? I want to add some kernel modules to the config. Or is it vanilla 7.1 from Armbian? 0 Quote
humanus Posted May 12 Author Posted May 12 (edited) amdgpu this one is crucial. nouveau and radeon could be useful but the first one is for nvidia cards (I don't have any to test) and the second one is useful for very old cards mainly. But I'll try passing them through to a VM, for this I don't need any modules other than IOMMU working Just tried your image for Rock 2F, it boots. Edited May 12 by humanus update 0 Quote
D roZDi Posted May 13 Posted May 13 (edited) Here you are as you wished but check out or download individually due to "Possible missing firmware /lib/firmware/amdgpu/" Edited May 13 by D roZDi 0 Quote
humanus Posted May 13 Author Posted May 13 Thanks. Missing firmware is not a problem, to fix it one just needs to install armbian-firmware-full. 0 Quote
D roZDi Posted May 13 Posted May 13 (edited) please just share output from lsusb and lspci commands from your board here Edited May 13 by D roZDi 0 Quote
humanus Posted May 13 Author Posted May 13 (edited) Here's lspci -vvv with an older Radeon: https://paste.armbian.com/zisezuqoza.yaml and boot UART log (it boots but no display is visible) https://paste.armbian.com/asizofulux.sql Here's the same with Radeon RX 550: https://paste.armbian.com/ovinibafux.yaml The kernel complained about missing firmware (for polaris11), which actually was not missing. I had to regenerate initramfs using initramfsctl. After regenerating, the board stopped booting with the card connected: https://paste.armbian.com/qitiwiwoge.yaml Not sure how useful lsusb would be. So it's not super stable yet. I saw that you made these modules built-in. This is not necessary, selecting [M] is enough because then they can be loaded or unloaded (to try passing the card through to a VM I need to blacklist the module, which doesn't work for built-in modules). This is something I can try to do to get display output. Oh and WiFi isn't detected at all but that's probably not a surprise. Edited May 13 by humanus bad hastebins 0 Quote
D roZDi Posted May 14 Posted May 14 There is nothing to see with you project. I wish only to know the output from lsusb and lspci. For wifi you probably have to apply Fix 7.1 as above. Driver for aic8800 is not yet supported 0 Quote
humanus Posted May 14 Author Posted May 14 (edited) I'm not sure what "nothing to see with you project" means but above you I've included the most complete lspci there is. I'll send lsusb too, but there won't be much there as it works properly. Do you want me to have something connected to the USB or just print it without anything (it would be one line, unless you want verbose). Edited May 14 by humanus Typo 0 Quote
D roZDi Posted May 14 Posted May 14 (edited) I dont need details just lsusb and lspci without switches to see what my image 7.1 discovers on your board Of course you can pług on USB stick to see if it works also make steps like mentioned above to fix wifi aic driver Edited May 14 by D roZDi 0 Quote
humanus Posted May 14 Author Posted May 14 You have the lspci verbose output so you can work back to get the non-verbose output as well. Should I have anything connected to the PCI lane or not? I know my USB devices work, at least with the internal controller, the question was about what exactly is the output/situation you need me to test. 0 Quote
Nate R Posted June 10 Posted June 10 Hello, what's the current status of kernel 6.18+ on the rock 2F? I haven't tried building it on my own yet, I just need Wi-Fi and USB working with a fairly recent kernel as 6.1 is way too old now. 0 Quote
D roZDi Posted June 13 Posted June 13 (edited) I put image 7.1 for humanus here but now it has been removed due to running of space on my drive Edited June 14 by D roZDi 0 Quote
Nate R Posted June 15 Posted June 15 Nice work! I saw those messages but couldn't download it Can you tell me how you built it? or could you upload it again to filebin.net if possible.. I need the image too 0 Quote
D roZDi Posted June 19 Posted June 19 As I have no board 2f to test it I made the image and dts blindly a bit... Image Fix to wifi card (I guess it should work) 0 Quote
Nate R Posted June 20 Posted June 20 depmod: ERROR: failed to load symbols from /lib/modules/7.1.0-rc4-next-20260518-edge-rockchip64/kernel/drivers/net/wireless/aic8800/aic8800_fdrv.ko: Invalid argument 0 Quote
Werner Posted June 20 Posted June 20 1 hour ago, Nate R said: 7.1.0-rc4-next-20260518-edge-rockchip64 never heard of that kernel before 0 Quote
D roZDi Posted June 20 Posted June 20 I have checked .... true.... my fix 7.1 was creted for 7.1-rc1 here we have got 7.1-rc4 so not working... Problably it needs to fix dirver aic8800 as still not supported plus compilation... usb2/usb3/ethernet are working? 0 Quote
johlnx Posted June 22 Posted June 22 In case you're interested I’ve uploaded my experiments with the current and edge kernels for my board (X88pro13, RK3528) to GitHub x88pro. LAN and USB are working; HDMI is not. Wifi only in current with aic8800 chip. Device Tree for my Board : userpatches/kernel/archive/rockchip64-.../dt/x88pro.dts might interest you. 0 Quote
D roZDi Posted June 23 Posted June 23 Try those modules for WIFI driver 7.1-rc-4. Now it should work as I have tested on my rock-2a. For HDMI Samsung QP driver... This is a huge work... but who knows it might happen soon 0 Quote
Nate R Posted June 27 Posted June 27 Still doesn't work for me.. USB works fine, only wifi is bugging and I don't have any other wifi card # sudo cp aic_btusb.ko aic_load_fw.ko aic8800_fdrv.ko /lib/modules/$(uname -r)/kernel/drivers/net/wireless/aic8800 # sudo depmod -a depmod: ERROR: failed to load symbols from /lib/modules/7.1.0-.ko: Invalid argument l/drivers/net/wireless/aic8800/aic_btusb.ko: Invalid argument-rc4-next-20260518-edge-rockchip64/kernel/drivers/net/wireless/aic8800/aic_btusb.ko: Invalid argument # sudo rm /lib/modules/7.1.0-rc4-next-20260518-edge-rockchip64/kernel/drivers/net/wireless/aic8800/aic_btusb.ko # sudo depmod -a depmod: ERROR: failed to load symbols from /lib/modules/7.1.0-aic8800/aic_load_fw.ko: Invalid argument depmod: ERROR: failed to load symbols from /lib/modules/7.1.0-rc4-next-20260518-edge-rockchip64/kernel/drivers/net/wireless/aic8800/aic8800_fdrv.ko: Invalid argument 0 Quote
D roZDi Posted June 28 Posted June 28 (edited) lsusb? Aic8800 is on USB or PCI in radxa 2f? uname -a, uname -r I have impression you made some tests? Please refer to my post from June 19th and take an image/wifi fix from there and from a post from 23 June take only new modules... Edited June 29 by D roZDi 0 Quote
