sven-ola Posted January 23 Author Posted January 23 (edited) Hello @JamesCL! The current image from https://privat-in.de/ should work. I will upload new images any minute now. However: if you only need Ethernet, Orange Pi R2S [1] is a better choice probably, b/c you got extra 2 times 2.5 gbit with that... Best // Sven-Ola [1] http://www.orangepi.org/html/hardWare/computerAndMicrocontrollers/service-and-support/Orange-Pi-R2S.html Edited January 23 by sven-ola Typo. Mention Ethernet IFs 0 Quote
sven-ola Posted January 23 Author Posted January 23 Already got answer from upstream programmer❣️ That kernel thread in RPMSG was removed due to excessive CPU usage. I got the impression that this is true: edge:desktop is nearly un-usable. Also they say: there is kernel 6.19 from upstream/upstream in the make. For now, I'm reverting HDMI audio (and all other rCPU funcs) for edge. LG // Sven-Ola 0 Quote
JamesCL Posted January 24 Posted January 24 Hi @sven-ola I downloaded this version, "Armbian-unofficial_26.02.0-trunk_Orangepirv2_trixie_current_6.6.99_minimal.img", and it's working on an SD card without problems... Is it possible for the OPI RV2 to boot from the eMMC with this image? Thanks. 0 Quote
Malay Posted January 24 Posted January 24 Hello @sven-ola! Yesterday, everything built fine for me using your git orangepi-rv2 branch with the EDGE kernel. After making the changes, 8 часов назад, sven-ola сказал: For now, I'm reverting HDMI audio (and all other rCPU funcs) for edge. Today, when applying the latest fixes I got an error while compiling the image. I used this build config ./compile.sh CPUTHREADS=$(nproc) BOARD=orangepirv2 BRANCH=edge RELEASE=trixie KERNEL_CONFIGURE=no BUILD_DESKTOP=yes DESKTOP_APPGROUPS_SELECTED= DESKTOP_ENVIRONMENT_CONFIG_NAME=config BUILD_MINIMAL=no DESKTOP_ENVIRONMENT=xfce KERNEL_GIT=shallow The error log is like this [🌱] SHA1 of commit bfeeda1491b5366aa5798a86cf6f3621536b171c [ 'bfeeda1491b5366aa5798a86cf6f3621536b171c' ] [🌱] Reversioning package [ re-version 'armbian-zsh(deb)::1-SAbfee-B07a9-R448a' to '26.02.0-trunk' ] [🌱] artifact [ armbian-plymouth-theme :: armbian-plymouth-theme() ] [🌱] Reversioning package [ re-version 'armbian-plymouth-theme(deb)::1-B5bd9-R448a' to '26.02.0-trunk' ] [🌱] artifact [ armbian-bsp-cli :: armbian-bsp-cli() ] [🌱] Using extlinux, regular bootscripts ignored [ SRC_EXTLINUX=yes ] [🌱] Reversioning package [ re-version 'armbian-bsp-cli-orangepirv2-edge(deb-tar)::1-PC0cac-Vfcc4-Hba69-B8122-R756d' to '26.02.0-trunk' ] [🌱] artifact [ armbian-desktop :: armbian-desktop() ] [🌱] Getting ORAS manifest [ ORAS manifest from ghcr.io/armbian/os/armbian-trixie-desktop-xfce:1-Vce3b-B333f-R448a ] Error response from registry: failed to fetch the content of "ghcr.io/armbian/os/armbian-trixie-desktop-xfce:1-Vce3b-B333f-R448a": ghcr.io/armbian/os/armbian-trixie-desktop-xfce:1-Vce3b-B333f-R448a: not found [🌱] Artifact is not available in remote cache [ ghcr.io/armbian/os/armbian-trixie-desktop-xfce:1-Vce3b-B333f-R448a ] /root/orangepi-rv2/lib/functions/compilation/packages/armbian-desktop-deb.sh: line 25: AGGREGATED_PACKAGES_DESKTOP_COMMA: AGGREGATED_PACKAGES_DESKTOP_COMMA is not set [💥] Exiting with error 1 [ at /root/orangepi-rv2/lib/functions/compilation/packages/armbian-desktop-deb.sh:1 compile_armbian-desktop() --> lib/functions/compilation/packages/armbian-desktop-deb.sh:1 do_with_logging() --> lib/functions/logging/section-logging.sh:81 artifact_armbian-desktop_build_from_sources() --> lib/functions/artifacts/artifact-armbian-desktop.sh:71 artifact_build_from_sources() --> lib/functions/artifacts/artifacts-obtain.sh:34 obtain_complete_artifact() --> lib/functions/artifacts/artifacts-obtain.sh:280 build_artifact_for_image() --> lib/functions/artifacts/artifacts-obtain.sh:392 main_default_build_packages() --> lib/functions/main/build-packages.sh:102 full_build_packages_rootfs_and_image() --> lib/functions/main/default-build.sh:31 do_with_default_build() --> lib/functions/main/default-build.sh:42 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:25 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:208 main() --> ./compile.sh:50 ] [💥] Cleaning up [ please wait for cleanups to finish ] [✨] Repeat Build Options [ ./compile.sh BOARD=orangepirv2 BRANCH=edge BUILD_DESKTOP=yes BUILD_MINIMAL=no CPUTHREADS=8 DESKTOP_APPGROUPS_SELECTED= DESKTOP_ENVIRONMENT=xfce DESKTOP_ENVIRONMENT_CONFIG_NAME=config KERNEL_CONFIGURE=no KERNEL_GIT=shallow RELEASE=trixie ] [🌿] ANSI log file built; inspect it by running: [ less -RS output/logs/log-build-436f72e6-3064-4b72-8a4a-64d579c2ea1f.log.ans ] Do I need to clear all previous build data? Or how can I fix this error? Thank you. 0 Quote
sven-ola Posted January 24 Author Posted January 24 Hello @JamesCL! I got the same error. You need to select at least one desktop package - error shows up with empty DESKTOP_APPGROUPS_SELECTED= Hello @Malay: That was on my todo list. I grabbed an eMMC from an old Odroid. It tried to boot if inserted. Thus boot sequence is: SD/TF, then eMMC, then MTD. So I booted with SD. eMMC showed up in /dev/mmcblk2. I started armbian-install, selected "Install on eMMC". Now it tries to boot that old Odroid image. So boot0, uboot, and SBI are there. Should work if you copy an image to /dev/mmcblk2. @All others: if that kernel thread for realtime-CPU (and HDMI audio) is active, the board always reports a load=2.0 or higher. This does not cause a very un-responsive Wayland-Gnome3-Desktop, this has other causes. Anyhow, this desires more investigation, since running a polling process to grab data from a realtime CPU does not sound right, there has to be an Interrupt or so, so I may again revert the reverted reversion (of the RPMSG kthread). Also I learned, that the Fedora project has an even larger esos.elf (rCPU firmware). I am curious what additional stuff may be in there 🤔 LG // Sven-Ola 0 Quote
sven-ola Posted January 25 Author Posted January 25 In the meantime, I fixed internal audio for "edge" (was: missing headphone GPIO). And also investigated around the esos.elf RTOS firmware. There's a license for that, which I added to my tree. The license basically says: use but do not infect with GPL: https://gitee.com/spacemit-buildroot/buildroot-ext/blob/k1-bl-v2.2.y/board/spacemit/k1/target_overlay/lib/firmware/LICENSE.spacemit_esos. Continuing on kthread issue. LG // Sven-Ola 0 Quote
Guest Posted January 25 Posted January 25 Sven, I stumbled across this thread last night and have created this account to thank you. After purchasing this board some time ago, it was quite disappointing to discover how lacking software support was. Again, thank you for your fantastic work so far. 0 Quote
geev03 Posted January 26 Posted January 26 🦀 Rust PiCalculator on Orange Pi RV2 (riscv64, Armbian Trixie) Compiled and ran a high-precision Pi calculator in Rust on my Orange Pi RV2 (K1X, 8-core @ 1.6 GHz) running Armbian-unofficial Trixie riscv64. The goal: test rustc performance and validate big-integer workloads on RISC-V. ✅ Environment OS: Armbian-unofficial 26.02.0-trunk (Debian Trixie) Kernel: Linux 6.18.5-edge-spacemit Rust: rustc 1.85.0, cargo 1.85.0 (built from source) Display: EZCAP28X @ 1920×1080 Memory: 3.7 GiB RAM, 1.3 GiB used Disk: ext4, 28.96 GiB total GPU: Mesa llvmpipe (LLVM 19.1.7) 🧮 Project: PiCalculator Rust implementation using rug (GMP-backed) to compute 1000 digits of π: rust use rug::{float::Constant, Float}; fn main() { let digits: usize = 1000; let bits: u32 = ((digits as f64) * 3.321928).ceil() as u32 + 10; let pi = Float::with_val(bits, Constant::Pi); let s = pi.to_string_radix(10, Some(digits)); println!("{s}"); } 🧩 Build Notes Needed libgmp-dev and m4 to compile rug cleanly. cargo build --release succeeded without patching. Output verified against known π digits. ⚖️ Performance Comparison Board CPU Time (ms) Real Time (ms) Pi 400 Faster (1.8 GHz, fewer cores) Lower latency RV2 (K1X) Slower per-core, but stable Good throughput Despite having 8 cores, the RV2’s in-order K1X is slower than the Pi 400’s Cortex-A72 for single-threaded math. Still, the build was smooth and the output correct — a great stress test for rustc on riscv64. 1 Quote
Solution sven-ola Posted January 26 Author Solution Posted January 26 (edited) I uploaded fresh images, that includes a trixie-edge-desktop-mate image I tested with my Hardware. Mate looks good and working, but switching between internal / HDMI audio needs some fiddling with the audio setting widget (may be a misunderstanding between pulseaudio and drivers). Changeing Sound-Pref:HW:profiles seems to do the trick. There is no chromium for RISCV, thus you need to install firefox-esr or netsurf-gtk manually. I think this is ready for primetime now, so I clicked on the "Pull-Request" button (see https://github.com/armbian/build/pull/9299). Got lots of auto email from the Github robots, will check tomorrow. LG // Sven-Ola Edited January 26 by sven-ola 0 Quote
Malay Posted January 27 Posted January 27 (edited) Hello, sven-ola! First of all, thank you very much for your work! HDMI audio now works well on the Edge. Secondly, I'm not particularly knowledgeable about this, so please forgive me in advance for this possibly stupid question 🙂 It's impossible to implement video hardware acceleration support in the firmware, from here - https://sdk.spacemit.com/en/faqs/ ? If I understand correctly, patched versions of FFmpeg and GStreamer are needed, and they should also be integrated in firmware into the k1x-vpu-firmware and mpp . Is this possible? When playing any video (even at very low resolution), there is terrible lag. The board should easily support 4K HEVC, but it can't play 720p video properly. At the same time, the Banana Pi BPI-F3 board with similar technical characteristics copes with video 4K HEVC https://docs.banana-pi.org/en/BPI-F3/BananaPi_BPI-F3. Edited January 27 by Malay 0 Quote
sven-ola Posted January 27 Author Posted January 27 Hello @Malay, et.al, after submitting my PullRQ to the Armbian repo, I think it's best to cope first with the annotations I received from that. It complains about missing board photos, and some LLM generated blurb partly valid suggestions, partly not. The current status of Armbian's Spacemit support does not make the RV2 board a good video player: GPU support is missing and I'm pretty unsure if it's possible to include the HW video encoding / decoding feature that is in the chip. Which is 4k@30 with diverse codecs according to the chip description PDF. I am glad, that X11 framebuffer video runs and I am unsure if I can proceed here b/c I am not a video / GPU / EGL / vulkan specialist. Anyhow, thank you for the pointer to the Spacemit FAQ I did not recognize until now. While the PowerVR page from mesa3d states: "no IMG BXE-2-32" (https://docs.mesa3d.org/drivers/powervr.html), the respective Gitee repo contains closed-source BSD licensed Risc64 compiled shard objects (*.so), probably similar to the Nvida binary user space closed drivers that does the GPU support for the big videos cards. This may be worth a look, but as I wrote above, prio task is to bring the support into the Armbian tree. Best // Sven-Ola 1 Quote
rayrayrayraycat Posted Friday at 11:58 PM Posted Friday at 11:58 PM THANK YOU so much for this effort. I no longer regret buying an OrangePi RV2! 0 Quote
maxsub Posted yesterday at 07:50 PM Posted yesterday at 07:50 PM This is fantastic work! Thank you so much. I was able to build from source. Tested it on RV2 and R2S and both work great. Your changes are patched on to the 6.6.99 kernel as far as I can tell. Are these going to be merged upstream and make their way into 6.17? Thanks again for your amazing work. 0 Quote
sven-ola Posted 22 hours ago Author Posted 22 hours ago (edited) Hello @maxsub! Thank you for testing this. Especially on the R2S, since I do not have this device at hand. I am in the final spurt to get this merged into Armbian, but there are one or two rabbits to be hunted down (aka coding quirks). You compiled BRANCH=current and kernel=6.6.99. Can you repeat and recompile with BRANCH=edge, which is the same u-boot but should give you kernel 6.18.7? LG // Sven-Ola Edited 22 hours ago by sven-ola 0 Quote
maxsub Posted 22 hours ago Posted 22 hours ago @sven-ola I did try the BRANCH=edge build and got an ELF error: 🐳|🔨] libbpf: failed to find '.BTF' ELF section in vmlinux.unstripped [🐳|🔨] FAILED: load BTF from vmlinux.unstripped: No data available [🐳|🔨] make[2]: *** [scripts/Makefile.vmlinux:72: vmlinux.unstripped] Error 255 [🐳|🔨] make[2]: *** Deleting file 'vmlinux.unstripped' [🐳|🔨] make[1]: *** [/armbian/cache/sources/linux-kernel-worktree/6.18__spacemit__riscv64/Makefile:1242: vmlinux] Error 2 [🐳|🔨] make: *** [Makefile:248: __sub-make] Error 2 0 Quote
sven-ola Posted 21 hours ago Author Posted 21 hours ago Hello @maxsub Compiling without Docker? You probably need apt-get install pahole, since ./compile.sh docker-shell shows: Zitat root@588763cb8d04:/armbian# dpkg -l pahole ... ii pahole 1.25-0ubuntu3 amd64 set of advanced DWARF utilities From the relevant kernel Kconfig: Zitat CONFIG_DEBUG_INFO_BTF: Generate deduplicated BTF type information from DWARF debug info. Turning this on requires pahole v1.16 or later (v1.21 or later to support DWARF 5), which will convert DWARF type info into equivalent deduplicated BTF type info. HTH // Sven-Ola 0 Quote
maxsub Posted 21 hours ago Posted 21 hours ago @sven-ola I have docker. The build BRANCH=current works but BRANCH=edge errors in the BTF section. 0 Quote
sven-ola Posted 21 hours ago Author Posted 21 hours ago The try ./compile.sh docker-shell to start the Armbian compile environment. In the VM, check the pahole package version. If it's missing, you probably need to re-create by removing all from docker images|grep armbian which should be re-created on the next round. <whisper><small><hidden>And if nothing helps, docker system prune --force --all?</hidden></small></whisper> HTH // Sven-Ola 0 Quote
sven-ola Posted 21 hours ago Author Posted 21 hours ago Next idea: run ./compile.sh kernel-config and switch off DEBUG_INFO_BTF. But this should not happen. Also (probably) this BTF stuff now pops up here and there anyhow... 0 Quote
maxsub Posted 21 hours ago Posted 21 hours ago pahole is current. The build fails inside the docker-shell when manually invoked as well. Looks like the BTF invocation is getting killed (maybe needs more RAM)? 🐳|🔨] BTF .tmp_vmlinux1.btf.o [🐳|🔨] Killed root@c408bbb4ccde:/armbian# apt show pahole Package: pahole Version: 1.25-0ubuntu3 Priority: optional Section: universe/utils Source: dwarves Origin: Ubuntu Maintainer: Ubuntu Developers <ubuntu-devel-discuss@lists.ubuntu.com> Original-Maintainer: Thomas Girard <thomas.g.girard@free.fr> Bugs: https://bugs.launchpad.net/ubuntu/+filebug Installed-Size: 2012 kB Depends: libbpf1 (>= 1:1.0.0), libc6 (>= 2.38), libdw1t64 (>= 0.157), libelf1t64 (>= 0.142), zlib1g (>= 1:1.1.4) Breaks: dwarves (<< 1.22) Replaces: dwarves (<< 1.22) Homepage: https://git.kernel.org/pub/scm/devel/pahole/pahole.git Download-Size: 275 kB APT-Manual-Installed: no APT-Sources: http://ports.ubuntu.com/ubuntu-ports noble/universe arm64 Packages Description: set of advanced DWARF utilities 0 Quote
sven-ola Posted 20 hours ago Author Posted 20 hours ago @maxsub: Out-of-RAM may be possible if it simply spits out "killed". My machine has 32 Gb RAM and 16 Gb swap, does not encountered the OOM-killer lately. Until now, but exhausting RAM is probably kernel-dev-hobby 😗 0 Quote
maxsub Posted 20 hours ago Posted 20 hours ago I found the problem: [ 2299.766819] Out of memory: Killed process 43216 (pahole) total-vm:8235296kB, anon-rss:4667816kB, file-rss:0kB, shmem-rss:0kB, UID:0 pgtables:12912kB oom_score_adj:0 0 Quote
Igor Posted 12 hours ago Posted 12 hours ago 8 hours ago, maxsub said: maybe needs more RAM BTF is hungry for memory, yes. KERNEL_BTF=n and it needs less. On 16Gb+ machine you should be fine. If not memory is eaten away by something else. 0 Quote
maxsub Posted 3 hours ago Posted 3 hours ago I am so thrilled to be able to get this working. Donation to Armbian on the way. 0 Quote
sven-ola Posted 1 hour ago Author Posted 1 hour ago @maxsub: if you still have compile probs, I just uploaded new images to my site on https://privat-in.de (navigate to downloads). LG // Sven-Ola 0 Quote
maxsub Posted 43 minutes ago Posted 43 minutes ago I have managed to compile this on two different platforms (Ubuntu and MacOS) for both boards: RV2 and R2S. My RV2 has 8GB and has a 64GB eMMC. I am hoping to be able to build it on the R2S natively. Will let you know how that goes. Looking forward to seeing this PR merged into armbian:main. I think the GPU will remain orphaned. OrangePi decided to use a unsupported GPU and it seems mostly a check box for them v/s them truly intending to support it. 0 Quote
sven-ola Posted 31 minutes ago Author Posted 31 minutes ago I think I've completed all tasks. Thus the OpiRV2 PR now waits for a team member to press the [merge] button probably. @maxsub I compiled 6.6.99 kernel on my board with 2Gb RAM once. Needed 3 hours and a decent swap file. HTH // Sven-Ola 0 Quote
