sven-ola Posted April 22 Author Posted April 22 (edited) Hello @Eule - what was you solution? When I had to guess: remove SD card to trigger eMMC boot? @Logan There's a real large bunch of reasons, why you where not able to install. That screen shot probably does not show any hints. Copy and paste your terminal session where you hacked in installation commands to a text file. Then post it here as attachment, then I may be able to help. Best // Sven-Ola Edited April 22 by sven-ola 0 Quote
sven-ola Posted April 22 Author Posted April 22 There is a Readme.txt stating: opirv2.img is for Nextcloud install, while Armbian is none of that. You probably want the latter. 0 Quote
sven-ola Posted April 23 Author Posted April 23 Hi @Logan thats probably the reason why your board does not boot from NVME. 0 Quote
VBB Posted April 23 Posted April 23 (edited) I flashed gnome desktop from your website. GPU script yields this error: ``` Preparing to unpack .../armbian-firmware_26.2.1_all.deb ... Unpacking armbian-firmware (26.2.1) over (26.02.0-trunk) ... dpkg: error processing archive /var/cache/apt/archives/armbian-firmware_26.2.1_all.deb (--unpack): unable to open '/lib/firmware/qcom/sm8550/ayn/odin2mini/a740_zap.mbn.dpkg-new': No such file or directory Errors were encountered while processing: /var/cache/apt/archives/armbian-firmware_26.2.1_all.deb E: Sub-process /usr/bin/dpkg returned an error code (1) ``` Edited April 23 by VBB 0 Quote
VBB Posted April 23 Posted April 23 (edited) To fix that error I removed `/lib/firmware/qcom/sm8550/ayn/odin2mini` and other 2 symlinks. run `ls -la /lib/firmware/qcom/sm8550/ayn/` to show them. I ran the script and did a reboot. Now I'm in the uboot command line and I see this error: ``` no nvme partition table available [ 10.473] Couldn't find partition nvme 0:1 [ 10.477] Couldn't find partition nvme 0:1 [ 10.481] Couldn't find partition nvme 0:1 [ 10.485] Couldn't find partition nvme 0:1 [ 10.489] Couldn't find partition nvme 0:1 ``` I only have sd card plugged in. Also this: ``` [ 4.478] Retrieving file: /boot/extlinux/extlinux.conf [ 4.510] 1: Armbian-unofficial [ 4.510] Retrieving file: /boot/uInitrd [ 5.712] Retrieving file: /boot/Image [ 8.067] append: root=UUID=818a9fb1-4820-445e-9c18-e94a975ca969 earlycon=sbi console=tty1 console=ttyS0,115200 loglevel=1 rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash plymouth.ignore-serial-consoles [ 8.086] Retrieving file: /boot/dtb/spacemit/k1-orangepi-rv2.dtb [ 8.133] ** File not found /boot/dtb/spacemit/k1-orangepi-rv2.dtb ** [ 8.136] Skipping Armbian-unofficial for failure retrieving FDT [ 8.150] pcie_dw_k1x pcie@ca400000: has no power-on-status flag, use default. [ 8.155] Now init Rterm... [ 8.157] pcie prot id = 1, porta_init_done = 0 [ 8.161] Now waiting portA resister tuning done... ``` In `/boot/extlinux/extlinux.conf` I renamed `k1-orangepi-rv2.dtb` to `k1-x-orangepi-rv2.dtb` and it did let me to boot into DE. Kernel has probably updated incorrectly. `uname -r` and boot log shows 6.6.99-current-spacemit. Wifi module doesn't work either. ``` # inxi -G Graphics: Device-1: saturn-le driver: spacemit_drm_drv v: N/A Device-2: hdmi driver: spacemit_hdmi_drv v: N/A Device-3: saturn-hdmi driver: spacemit_drm_drv v: N/A Display: server: X.Org v: 23.2.6 with: Xwayland v: 23.2.6 driver: N/A resolution: 1920x1080~75Hz API: EGL v: 1.4,1.5 drivers: pvr,swrast,zink platforms: gbm,x11,surfaceless,device API: OpenGL v: 3.3 compat-v: 2.1 vendor: mesa v: 24.0.1 renderer: softpipe API: Vulkan v: 1.3.275 drivers: N/A surfaces: N/A ``` I was able to update the kernel by installing `linux-kernel-edge-spacemit` and `linux-headers-edge-spacemit`, but wifi module still doesn't work. `bcmdhd-spacemit-sdio-dkms` is intalled though Edited April 24 by VBB 0 Quote
sven-ola Posted April 23 Author Posted April 23 Ah - sorry for the confusion. Those Armbian*.img files are pre-installed. Means: the GPU stuff is already there. I am not sure what happens, if you run that GPU install again (I need to investigate, give me an hour). 0 Quote
sven-ola Posted April 23 Author Posted April 23 (edited) Aiee! Installed my old "Noble" image. Updating will remove kernel 6.18.18 and install 6.6.99 and also has the error in the firmware package as decribed above by @VBB. Also, that funny "cli.github.com/packages" repo does not work. While that kernel downgrade is probably caused by linux-image-current-spacemit moved from 6.6.99 to 6.18.x recently (and the Armbian repos are out of date somehow) that firmware package should update without any errors. Will need time to sort this out. Anyhow, the "Noble" image works with GPU-activated Gnome desktop as long as you do not update (downgrade)... Edited April 23 by sven-ola 0 Quote
Logan Posted April 26 Posted April 26 (edited) https://blog.aurel32.net/upstream-opensbi-spacemit-k1.html will try dev version of u-boot and openbsi Edited April 26 by Logan 0 Quote
armfan Posted 16 hours ago Posted 16 hours ago @sven-ola Hi sven-ola! Thanks a ton for making RV2 work on Armbian! I'll go about trying to make an RV2 start for the first time shortly. Interfacing it via the serial port is fine, and equally fine is connecting it via HDMI and USB to screen and keyboard, right? As for boot media, will booting the Armbian Debian image from a USB storage device work out of the box or must I install some image on an onboard flash chip first, if so what's the URL to that? And then: Do you think it makes any sense for me to use the Armbian Edge which has kernel 6.19 right now, does it seem stable? If so can you provide an URL to it (upload it on armbian.org or mega.nz etc.) On SpaceMIT's mainlining page https://github.com/spacemit-com/linux/wiki#user-content-K1_SoC I see that the PCI support got an update in 6.19, would this be a reason to use Armbian Edge. This URL is linked: https://lore.kernel.org/all/20251013153526.2276556-1-elder@riscstar.com/ . I have no idea if this update has been backported to the 6.18 kernel used. The 6.19 and 6.18 kernels used, where are they taken from actually? At least for 6.18 I think the repo is https://github.com/jmontleon/linux-spacemit/ or https://github.com/spacemit-com/linux-k1x , do you use it? And for clarity, there is no Armbian with Linux 7.1 yet right? Otherwise just downloading the Armbian with 6.18 from https://armbian.com/boards/orangepirv2 . For CLI and packages and no desktop, the Debian flavour is preferable I guess. At this point do you think PCI and USB interfaces are stable in Armbian or Armbian Edge? Thanks! 0 Quote
Werner Posted 15 hours ago Posted 15 hours ago 17 minutes ago, armfan said: And for clarity, there is no Armbian with Linux 7.1 yet right? Support for 7.1 has been merged yesterday https://github.com/armbian/build/pull/9784 0 Quote
armfan Posted 15 hours ago Posted 15 hours ago (edited) @Werner Do you think Armbian Edge with Linux 7.1 is available and works on OrangePI RV2 already? If so I'd love to get that image. As I understand it the SoC's support has been fully mainlined in Linux 7. (By the way request to admin to lift my messaging quota. Will edit this request away in a few hours.) I just checked inside Armbian Imager, and Armbian Edge is not available there - the same two images as are on https://armbian.com/boards/orangepirv2 are in there, that's all. Edited 15 hours ago by armfan 0 Quote
Werner Posted 5 hours ago Posted 5 hours ago No, probably not. CI takes days to catch up. Best is to use the build framework to create an up-to-date image/kernel 9 hours ago, armfan said: request to admin to lift my messaging quota. This happens automatically after a few days. 0 Quote
rm_ Posted 1 hour ago Posted 1 hour ago armbianmonitor picks up the wrong temperature to show as "Tcpu". 19:40:09 1600/1600 MHz 0.63 12% 0% 12% 0% 0% 0% 34.9 °C 0/1 19:40:14 1600/1600 MHz 0.66 12% 0% 12% 0% 0% 0% 34.9 °C 0/1 19:40:19 614/ 614 MHz 0.60 5% 0% 4% 0% 0% 0% 34.9 °C 0/1 19:40:24 614/ 614 MHz 0.56 0% 0% 0% 0% 0% 0% 34.9 °C 0/1 19:40:29 614/ 614 MHz 0.51 0% 0% 0% 0% 0% 0% 34.9 °C 0/1 19:40:34 614/ 614 MHz 0.55 1% 0% 0% 0% 0% 0% 34.9 °C 0/1 19:40:39 1000/1000 MHz 0.51 3% 1% 1% 0% 0% 0% 34.9 °C 0/1 19:40:44 614/ 614 MHz 0.47 0% 0% 0% 0% 0% 0% 34.9 °C 0/1 Time CPU_cl0/CPU_cl1 load %cpu %sys %usr %nice %io %irq Tcpu C.St. 19:40:49 1600/1600 MHz 0.51 12% 3% 8% 0% 0% 0% 34.9 °C 0/1 19:40:54 1600/1600 MHz 0.55 15% 4% 10% 0% 0% 0% 34.9 °C 0/1 19:41:00 1600/1600 MHz 0.58 15% 4% 10% 0% 0% 0% 34.9 °C 0/1 19:41:05 1600/1600 MHz 0.70 15% 4% 10% 0% 0% 0% 34.9 °C 0/1^C Meanwhile in 'sensors': cluster1_thermal-virtual-0 Adapter: Virtual device temp1: +45.0°C nvme-pci-10100 Adapter: PCI adapter Composite: +34.9°C (low = -40.1°C, high = +119.8°C) (crit = +129.8°C) Sensor 1: +42.9°C (low = -40.1°C, high = +139.8°C) Sensor 2: +34.9°C (low = -40.1°C, high = +119.8°C) cluster0_thermal-virtual-0 Adapter: Virtual device temp1: +45.0°C So it shows the NVMe SSD temperature instead. 0 Quote
