blub4747 Posted November 20, 2017 Posted November 20, 2017 Hi guys, Quick question about the USB ports on the Cubietruck. Once I am done with the usual setup procedure (changing the root password and setup a user) system reboot. I sometimes end up in situations where I need to access the Cubietruck directly and not through ssh. In such situations I noticed that my usb keyboard and mouse do not respond at all, eventhough if these are the exact same ones hich I used to the 1first time setup. What could be the reason for this ? Thx,blub4747
Igor Posted November 20, 2017 Posted November 20, 2017 What is your power supply? If it's on the edge / not good enough, USB ports will remain dead.
blub4747 Posted November 20, 2017 Author Posted November 20, 2017 It does say the that power supply supports 5V 2500mA however when I do use it to setup the cubietruck it does make a strange squeeking noise which did make me wounder. Once the 1first time is through I use extender tab which has usb ports on it. Luckily I just found a different power supply which does not make squeeking noise and the usb ports also work fine. thx, for the help 1
