Hi!
Could you please clarify, is there a way to increase default limitations for max cpu freq (H5) on Orange Pi Prime?
As i understand, according to driver (cpufreq-dt):
available frequency steps: 408 MHz, 648 MHz, 816 MHz, 912 MHz, 960 MHz, 1.01 GHz
/etc/default/cpufrequtils is a bit less restrictive:
cat /etc/default/cpufrequtils
ENABLE=true
MIN_SPEED=408000
MAX_SPEED=1296000
GOVERNOR=ondemand
Is this a driver limitation ? Or there is a way to increase cpu-freq, but it's not used by default ? ( ... and why, if it is so ?)
uname -a
Linux orangepiprime 4.13.14-sunxi64 #246 SMP Mon Nov 20 01:58:09 CET 2017 aarch64 aarch64 aarch64 GNU/Linux
Those number might be set higher later when the kernel is well tested and thermal protection working as it should.
You don't want to burn your board, do you?
@Igor
:) i put a 19x19x24 small-tower-like radiator for CPU (not too effective, but the best ones i got without "manual working with saw & rasp") and 9x9x12 for each mem + ethernet chips. So if you give me link to testing guide i could try. Of course, i suppose you have "well-defined QA-procedures" and "sporadic results from unknown guys" is not a too good idea, but ... maybe, i just want to burn my board ;)
As i "understood" (i guess) from "brief search" the problem is with setting correct DVFS levels (voltage + frequency/throttling) to keep system stable.
Simple FREQ=1008Mhz testing with
grep@orangepiprime:~$ stress -t 900 -c 2 -m 2 -i 2 -d 2
stress: info: [8154] dispatching hogs: 2 cpu, 2 io, 2 vm, 2 hdd
stress: info: [8154] successful run completed in 910s
gave  [max...min] = [45..49.1] (don't ask about median/avg/quantiles, it was just watching at "armbianmonitor -m" output); normal temp (non-idle, 1.25..2 LA) is ~35..37
P.S. PSU is 5V / 3A of course.
