Yurii Berkovsky Posted 1 hour ago Posted 1 hour ago Hi! Have some problem with Cubietrack Sometime boot some time not Kernel setenv fdtfile sun7i-a20-cubietruck.dtb # safe low addresses setenv kernel_addr_r 0x42000000 setenv fdt_addr_r 0x43000000 setenv ramdisk_addr_r 0x44000000 # limit relocations setenv fdt_high 0x47f00000 setenv initrd_high 0x47f00000 mmc dev 0 mmc rescan setenv bootargs "console=ttyS0,115200 console=tty0 ignore_loglevel loglevel=8 \ root=/dev/mmcblk0p1 rootwait rootfstype=ext4 rw \ panic=10 consoleblank=0 net.ifnames=0 biosdevname=0 enforcing=0 \ nosmp mem=1024M clk_ignore_unused" echo ">> Boot device: mmc 0:1 ext4" if ext4load mmc 0:1 ${kernel_addr_r} /boot/zImage; then echo ">> Kernel loaded" else echo "### ERROR: /boot/zImage not found" reset fi if ext4load mmc 0:1 ${fdt_addr_r} /boot/dtb/${fdtfile}; then echo ">> DTB loaded" else echo "### ERROR: dtb not found" reset fi setenv initrd_arg "-" if ext4load mmc 0:1 ${ramdisk_addr_r} /boot/uInitrd; then setenv initrd_arg ${ramdisk_addr_r} fi bootz ${kernel_addr_r} ${initrd_arg} ${fdt_addr_r} root@volumio:~# cd /boot root@volumio:/boot# ls -all total 35200 drwxr-xr-x 7 root root 4096 Mar 4 11:44 . drwxr-xr-x 23 root root 4096 Mar 4 09:17 .. drwxr-xr-x 2 root root 4096 Feb 28 2016 bin -rw-r--r-- 1 root root 966 Mar 4 12:04 boot.cmd -rw-r--r-- 1 root root 1038 Mar 4 12:04 boot.scr -rw-r--r-- 1 root root 101188 Jan 22 2017 config-4.4.44 -rw-r--r-- 1 root root 101262 Apr 24 2016 config-4.4.8 -rw-r--r-- 1 root root 133815 Mar 21 2019 config-5.0.2-sunxi -rw-r--r-- 1 root root 159559 Mar 1 17:03 config-6.6.75-legacy-sunxi drwxr-xr-x 2 root root 4096 Mar 4 09:16 dtb drwxr-xr-x 3 root root 12288 Sep 12 2019 dtb-5.0.2-sunxi drwxr-xr-x 3 root root 12288 Feb 7 18:41 dtb-6.6.75-legacy-sunxi drwxr-xr-x 2 root root 4096 Feb 28 2016 dtb.old -rw-r--r-- 1 root root 0 Mar 3 17:32 .next lrwxrwxrwx 1 root root 24 Mar 3 16:54 script.bin -> /boot/bin/cubietruck.bin -rw------- 1 root root 1464739 Jan 22 2017 System.map-4.4.44 -rw------- 1 root root 1460350 Apr 24 2016 System.map-4.4.8 -rw-r--r-- 1 root root 2376380 Mar 21 2019 System.map-5.0.2-sunxi -rw-r--r-- 1 root root 2957247 Mar 1 17:03 System.map-6.6.75-legacy-sunxi -rw------- 1 root root 3384008 Jan 22 2017 vmlinuz-4.4.44 -rw------- 1 root root 3367664 Apr 24 2016 vmlinuz-4.4.8 -rwxr-xr-x 1 root root 4810496 Mar 21 2019 vmlinuz-5.0.2-sunxi -rw-r--r-- 1 root root 7824568 Mar 1 17:03 vmlinuz-6.6.75-legacy-sunxi -rw-r--r-- 1 root root 7824568 Mar 4 09:16 zImage root@volumio:/boot# uname -a Linux volumio 6.6.75-legacy-sunxi #3 SMP PREEMPT Sat Feb 1 17:37:57 UTC 2025 armv7l GNU/Linux root@volumio:/boot# 0 Quote
Yurii Berkovsky Posted 1 hour ago Author Posted 1 hour ago I try # Keep U-Boot relocations and early kernel mapping in a safe low window setenv bootm_low 0x40000000 setenv bootm_size 0x20000000 setenv bootm_mapsize 0x20000000 # Also cap where DTB/initrd may be copied setenv fdt_high 0x5fffffff setenv initrd_high 0x5fffffff but dont help * ( 0 Quote
Yurii Berkovsky Posted 1 hour ago Author Posted 1 hour ago ____ _ _ _ _ / ___| _| |__ (_) ___| |_ _ __ _ _ ___| | __ | | | | | | '_ \| |/ _ \ __| '__| | | |/ __| |/ / | |__| |_| | |_) | | __/ |_| | | |_| | (__| < \____\__,_|_.__/|_|\___|\__|_| \__,_|\___|_|\_\ Welcome to ARMBIAN Debian GNU/Linux 8 (jessie) 6.6.75-legacy-sunxi System load: 1.07 Up time: 1 min Memory usage: 4 % of 1978Mb IP: 192.168.1.96 CPU temp: 43°C Usage of /: 27% of 7.9G [ 268 updates to install: apt-get upgrade ] root@volumio:~# dmesg [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 6.6.75-legacy-sunxi (build@armbian) (arm-linux-gnue abihf-gcc (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0, GNU ld (GNU Binutils for Ubuntu ) 2.42) #3 SMP PREEMPT Sat Feb 1 17:37:57 UTC 2025 [ 0.000000] CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=50c5387d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio n cache [ 0.000000] OF: fdt: Machine model: Cubietech Cubietruck [ 0.000000] printk: debug: ignoring loglevel setting. [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] Reserved memory: created CMA memory pool at 0x4a000000, size 96 M iB [ 0.000000] OF: reserved mem: initialized node default-pool, compatible id sh ared-dma-pool [ 0.000000] OF: reserved mem: 0x4a000000..0x4fffffff (98304 KiB) map reusable default-pool [ 0.000000] Zone ranges: [ 0.000000] Normal [mem 0x0000000040000000-0x000000006fffffff] [ 0.000000] HighMem [mem 0x0000000070000000-0x00000000bdffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000040000000-0x00000000bdffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bdffffff] [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: Using PSCI v0.1 Function IDs from DT [ 0.000000] percpu: Embedded 18 pages/cpu s43860 r8192 d21676 u73728 [ 0.000000] pcpu-alloc: s43860 r8192 d21676 u73728 alloc=18*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [ 0.000000] Kernel command line: console=ttyS0,115200 console=tty0 ignore_log level loglevel=8 \ root=/dev/mmcblk0p1 rootwait rootfstype=ext4 rw \ panic=10 consoleblank=0 net.ifnames=0 biosdevname=0 enforcing=0 \ clk_ignore_unused [ 0.000000] Unknown kernel command line parameters "\ \ \ biosdevname=0", wil l be passed to user space. [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, li near) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 514368 [ 0.000000] allocated 2064384 bytes of page_ext [ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off [ 0.000000] Memory: 1926540K/2064384K available (8192K kernel code, 1367K rwd ata, 6396K rodata, 1024K init, 317K bss, 39540K reserved, 98304K cma-reserved, 1 277952K highmem) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] ftrace: allocating 36178 entries in 107 pages [ 0.000000] ftrace: allocated 106 pages with 4 groups [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Rude variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 100 ji ffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000002] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 43980 46511097ns [ 0.000018] Switching to timer-based delay loop, resolution 41ns [ 0.000490] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_ idle_ns: 79635851949 ns [ 0.001502] Console: colour dummy device 80x30 [ 0.001528] printk: console [tty0] enabled [ 0.002602] Calibrating delay loop (skipped), value calculated using timer fr equency.. 48.00 BogoMIPS (lpj=24000) [ 0.002652] CPU: Testing write buffer coherency: ok [ 0.002736] pid_max: default: 32768 minimum: 301 [ 0.009780] LSM: initializing lsm=capability,bpf,integrity [ 0.013970] LSM support for eBPF active [ 0.016037] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linea r) [ 0.016084] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) [ 0.026743] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.028723] RCU Tasks: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1 r cu_task_cpu_ids=2. [ 0.029062] RCU Tasks Rude: Setting shift to 1 and lim to 1 rcu_task_cb_adjus t=1 rcu_task_cpu_ids=2. [ 0.029317] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adju st=1 rcu_task_cpu_ids=2. [ 0.029554] Setting up static identity map for 0x40100000 - 0x40100054 [ 0.029882] rcu: Hierarchical SRCU implementation. [ 0.029918] rcu: Max phase no-delay instances is 400. [ 0.031448] smp: Bringing up secondary CPUs ... [ 0.043079] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.043342] smp: Brought up 1 node, 2 CPUs [ 0.043416] SMP: Total of 2 processors activated (96.00 BogoMIPS). [ 0.043444] CPU: All CPU(s) started in HYP mode. [ 0.043464] CPU: Virtualization extensions available. [ 0.045123] devtmpfs: initialized [ 0.061526] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 4 [ 0.062156] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 1911260446275000 ns [ 0.062265] futex hash table entries: 512 (order: 3, 32768 bytes, linear) [ 0.072993] pinctrl core: initialized pinctrl subsystem [ 0.076756] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.078880] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.080266] audit: initializing netlink subsys (disabled) [ 0.080872] audit: type=2000 audit(0.069:1): state=initialized audit_enabled= 0 res=1 [ 0.081641] thermal_sys: Registered thermal governor 'fair_share' [ 0.081659] thermal_sys: Registered thermal governor 'bang_bang' [ 0.081692] thermal_sys: Registered thermal governor 'step_wise' [ 0.081716] thermal_sys: Registered thermal governor 'user_space' [ 0.081739] thermal_sys: Registered thermal governor 'power_allocator' [ 0.081913] cpuidle: using governor ladder [ 0.081992] cpuidle: using governor menu [ 0.082269] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.082314] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.092957] /soc/lcd-controller@1c0c000: Fixed dependency cycle(s) with /soc/ hdmi@1c16000 [ 0.093153] /soc/lcd-controller@1c0c000: Fixed dependency cycle(s) with /soc/ display-backend@1e40000 [ 0.093313] /soc/lcd-controller@1c0c000: Fixed dependency cycle(s) with /soc/ display-backend@1e60000 [ 0.093479] /soc/lcd-controller@1c0d000: Fixed dependency cycle(s) with /soc/ hdmi@1c16000 [ 0.093624] /soc/lcd-controller@1c0d000: Fixed dependency cycle(s) with /soc/ display-backend@1e40000 [ 0.093771] /soc/lcd-controller@1c0d000: Fixed dependency cycle(s) with /soc/ display-backend@1e60000 [ 0.094207] /soc/hdmi@1c16000: Fixed dependency cycle(s) with /soc/lcd-contro ller@1c0d000 [ 0.094421] /soc/hdmi@1c16000: Fixed dependency cycle(s) with /soc/lcd-contro ller@1c0c000 [ 0.094895] /soc/interrupt-controller@1c81000: Fixed dependency cycle(s) with /soc/interrupt-controller@1c81000 [ 0.095139] /soc/display-frontend@1e00000: Fixed dependency cycle(s) with /so c/display-backend@1e40000 [ 0.095359] /soc/display-frontend@1e00000: Fixed dependency cycle(s) with /so c/display-backend@1e60000 [ 0.095590] /soc/display-frontend@1e20000: Fixed dependency cycle(s) with /so c/display-backend@1e40000 [ 0.095805] /soc/display-frontend@1e20000: Fixed dependency cycle(s) with /so c/display-backend@1e60000 [ 0.095937] /soc/display-backend@1e40000: Fixed dependency cycle(s) with /soc /lcd-controller@1c0d000 [ 0.096067] /soc/display-backend@1e40000: Fixed dependency cycle(s) with /soc /lcd-controller@1c0c000 [ 0.096175] /soc/display-backend@1e40000: Fixed dependency cycle(s) with /soc /display-frontend@1e20000 [ 0.096280] /soc/display-backend@1e40000: Fixed dependency cycle(s) with /soc /display-frontend@1e00000 [ 0.096417] /soc/display-backend@1e60000: Fixed dependency cycle(s) with /soc /lcd-controller@1c0d000 [ 0.096534] /soc/display-backend@1e60000: Fixed dependency cycle(s) with /soc /lcd-controller@1c0c000 [ 0.096638] /soc/display-backend@1e60000: Fixed dependency cycle(s) with /soc /display-frontend@1e20000 [ 0.096742] /soc/display-backend@1e60000: Fixed dependency cycle(s) with /soc /display-frontend@1e00000 [ 0.097863] /soc/lcd-controller@1c0c000: Fixed dependency cycle(s) with /soc/ hdmi@1c16000 [ 0.098061] /soc/lcd-controller@1c0c000: Fixed dependency cycle(s) with /soc/ display-backend@1e40000 [ 0.098219] /soc/lcd-controller@1c0c000: Fixed dependency cycle(s) with /soc/ display-backend@1e60000 [ 0.098629] /soc/lcd-controller@1c0d000: Fixed dependency cycle(s) with /soc/ hdmi@1c16000 [ 0.098782] /soc/lcd-controller@1c0d000: Fixed dependency cycle(s) with /soc/ display-backend@1e40000 [ 0.098930] /soc/lcd-controller@1c0d000: Fixed dependency cycle(s) with /soc/ display-backend@1e60000 [ 0.101800] /soc/lcd-controller@1c0d000: Fixed dependency cycle(s) with /soc/ hdmi@1c16000 [ 0.102148] /soc/lcd-controller@1c0c000: Fixed dependency cycle(s) with /soc/ hdmi@1c16000 [ 0.102463] /soc/hdmi@1c16000: Fixed dependency cycle(s) with /soc/lcd-contro ller@1c0d000 [ 0.102766] /soc/hdmi@1c16000: Fixed dependency cycle(s) with /soc/lcd-contro ller@1c0c000 [ 0.106363] /soc/pinctrl@1c20800: Fixed dependency cycle(s) with /soc/pinctrl @1c20800/clk-out-a-pin [ 0.112205] /soc/display-frontend@1e00000: Fixed dependency cycle(s) with /so c/display-backend@1e40000 [ 0.112375] /soc/display-frontend@1e00000: Fixed dependency cycle(s) with /so c/display-backend@1e60000 [ 0.112818] /soc/display-frontend@1e20000: Fixed dependency cycle(s) with /so c/display-backend@1e40000 [ 0.112934] /soc/display-frontend@1e20000: Fixed dependency cycle(s) with /so c/display-backend@1e60000 [ 0.113451] /soc/display-frontend@1e20000: Fixed dependency cycle(s) with /so c/display-backend@1e40000 [ 0.113665] /soc/display-frontend@1e00000: Fixed dependency cycle(s) with /so c/display-backend@1e40000 [ 0.113839] /soc/lcd-controller@1c0d000: Fixed dependency cycle(s) with /soc/ display-backend@1e40000 [ 0.114046] /soc/lcd-controller@1c0c000: Fixed dependency cycle(s) with /soc/ display-backend@1e40000 [ 0.114212] /soc/display-backend@1e40000: Fixed dependency cycle(s) with /soc /lcd-controller@1c0d000 [ 0.114370] /soc/display-backend@1e40000: Fixed dependency cycle(s) with /soc /lcd-controller@1c0c000 [ 0.114620] /soc/display-backend@1e40000: Fixed dependency cycle(s) with /soc /display-frontend@1e20000 [ 0.114781] /soc/display-backend@1e40000: Fixed dependency cycle(s) with /soc /display-frontend@1e00000 [ 0.115342] /soc/display-frontend@1e20000: Fixed dependency cycle(s) with /so c/display-backend@1e60000 [ 0.115574] /soc/display-frontend@1e00000: Fixed dependency cycle(s) with /so c/display-backend@1e60000 [ 0.115751] /soc/lcd-controller@1c0d000: Fixed dependency cycle(s) with /soc/ display-backend@1e60000 [ 0.115959] /soc/lcd-controller@1c0c000: Fixed dependency cycle(s) with /soc/ display-backend@1e60000 [ 0.116126] /soc/display-backend@1e60000: Fixed dependency cycle(s) with /soc /lcd-controller@1c0d000 [ 0.116343] /soc/display-backend@1e60000: Fixed dependency cycle(s) with /soc /lcd-controller@1c0c000 [ 0.116526] /soc/display-backend@1e60000: Fixed dependency cycle(s) with /soc /display-frontend@1e20000 [ 0.116718] /soc/display-backend@1e60000: Fixed dependency cycle(s) with /soc /display-frontend@1e00000 [ 0.119975] /soc/hdmi@1c16000: Fixed dependency cycle(s) with /hdmi-connector [ 0.120269] /hdmi-connector: Fixed dependency cycle(s) with /soc/hdmi@1c16000 [ 0.129394] iommu: Default domain type: Translated [ 0.129462] iommu: DMA domain TLB invalidation policy: strict mode [ 0.130088] SCSI subsystem initialized [ 0.130771] libata version 3.00 loaded. [ 0.131174] usbcore: registered new interface driver usbfs [ 0.131290] usbcore: registered new interface driver hub [ 0.131387] usbcore: registered new device driver usb [ 0.131986] pps_core: LinuxPPS API ver. 1 registered [ 0.132031] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome tti <giometti@linux.it> [ 0.132088] PTP clock support registered [ 0.133187] Advanced Linux Sound Architecture Driver Initialized. [ 0.135931] clocksource: Switched to clocksource arch_sys_counter [ 0.145715] VFS: Disk quotas dquot_6.6.0 [ 0.145819] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.163052] NET: Registered PF_INET protocol family [ 0.163574] IP idents hash table entries: 16384 (order: 5, 131072 bytes, line ar) [ 0.167109] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear) [ 0.167208] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.167260] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear) [ 0.167403] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear ) [ 0.167858] TCP: Hash tables configured (established 8192 bind 8192) [ 0.168145] UDP hash table entries: 512 (order: 2, 16384 bytes, linear) [ 0.168325] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear) [ 0.169413] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.170260] armv7-pmu pmu: hw perfevents: no interrupt-affinity property, gue ssing. [ 0.173064] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counter s available [ 0.179385] workingset: timestamp_bits=14 max_order=19 bucket_order=5 [ 0.179585] zbud: loaded [ 0.385775] Key type asymmetric registered [ 0.386307] bounce: pool size: 64 pages [ 0.387002] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 48) [ 0.387472] io scheduler mq-deadline registered [ 0.387522] io scheduler kyber registered [ 0.388291] io scheduler bfq registered [ 0.511597] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled [ 0.519421] misc dump reg init [ 0.526431] brd: module loaded [ 0.541243] loop: module loaded [ 0.548773] sunxi-rtc 1c20d00.rtc: registered as rtc0 [ 0.548877] sunxi-rtc 1c20d00.rtc: setting system clock to 2026-03-04T11:25:5 1 UTC (1772623551) [ 0.549293] i2c_dev: i2c /dev entries driver [ 0.552776] sunxi-wdt 1c20c90.watchdog: Watchdog enabled (timeout=16 sec, now ayout=0) [ 0.555515] ledtrig-cpu: registered to indicate activity on CPUs [ 0.556282] clocksource: hstimer: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 6370868154 ns [ 0.646743] NET: Registered PF_PACKET protocol family [ 0.646889] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. [ 0.647545] Key type dns_resolver registered [ 0.647892] Registering SWP/SWPB emulation handler [ 0.662404] registered taskstats version 1 [ 0.678238] Key type .fscrypt registered [ 0.678308] Key type fscrypt-provisioning registered [ 0.684163] Key type encrypted registered [ 0.713816] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pi not found, using dum my regulator [ 0.714574] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.718035] sun4i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver [ 0.720063] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pb not found, using dum my regulator [ 0.721774] printk: console [ttyS0] disabled [ 0.742858] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 69, base_baud = 15 00000) is a U6_16550A [ 0.743044] printk: console [ttyS0] enabled [ 2.190471] 1c28800.serial: ttyS2 at MMIO 0x1c28800 (irq = 70, base_baud = 15 00000) is a U6_16550A [ 2.200103] serial serial0: tty port ttyS2 registered [ 2.206440] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pa not found, using dum my regulator [ 2.215289] sun7i-dwmac 1c50000.ethernet: IRQ eth_wake_irq not found [ 2.221756] sun7i-dwmac 1c50000.ethernet: IRQ eth_lpi not found [ 2.227972] sun7i-dwmac 1c50000.ethernet: PTP uses main clock [ 2.233811] sun7i-dwmac 1c50000.ethernet: no regulator found [ 2.240030] sun7i-dwmac 1c50000.ethernet: Version ID not available [ 2.246298] sun7i-dwmac 1c50000.ethernet: DWMAC1000 [ 2.251303] sun7i-dwmac 1c50000.ethernet: No HW DMA feature register supporte d [ 2.258560] sun7i-dwmac 1c50000.ethernet: TX Checksum insertion supported [ 2.265382] sun7i-dwmac 1c50000.ethernet: Normal descriptors [ 2.271074] sun7i-dwmac 1c50000.ethernet: Ring mode enabled [ 2.285888] axp20x-i2c 0-0034: AXP20x variant AXP209 found [ 2.301538] axp20x-adc axp20x-adc: DMA mask not set [ 2.309646] axp20x-battery-power-supply axp20x-battery-power-supply: DMA mask not set [ 2.343988] axp20x-ac-power-supply axp20x-ac-power-supply: DMA mask not set [ 2.368270] axp20x-usb-power-supply axp20x-usb-power-supply: DMA mask not set [ 2.400304] axp20x-i2c 0-0034: Backup (RTC) battery charging is enabled [ 2.407207] axp20x-i2c 0-0034: AXP20X driver loaded [ 2.421282] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pf not found, using dum my regulator [ 2.421327] sun4i-pinctrl 1c20800.pinctrl: supply vcc-ph not found, using dum my regulator [ 2.439280] sunxi-mmc 1c0f000.mmc: Got CD GPIO [ 2.449782] ahci-sunxi 1c18000.sata: supply ahci not found, using dummy regul ator [ 2.457675] ahci-sunxi 1c18000.sata: supply phy not found, using dummy regula tor [ 2.473211] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB [ 2.497373] ahci-sunxi 1c18000.sata: controller can't do PMP, turning off CAP _PMP [ 2.505148] ahci-sunxi 1c18000.sata: forcing PORTS_IMPL to 0x1 [ 2.511826] ahci-sunxi 1c18000.sata: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0 x1 impl platform mode [ 2.516771] mmc0: host does not support reading read-only switch, assuming wr ite-enable [ 2.522958] ahci-sunxi 1c18000.sata: flags: ncq sntf pm led clo only pio slum part ccc [ 2.531265] mmc0: new high speed SDXC card at address 0001 [ 2.545012] mmcblk0: mmc0:0001 SD64G 58.3 GiB [ 2.545108] scsi host0: ahci-sunxi [ 2.553673] ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x1 00 irq 117 [ 2.554656] mmcblk0: p1 [ 2.565669] of_cfs_init [ 2.568521] ehci-platform 1c14000.usb: EHCI Host Controller [ 2.569221] ehci-platform 1c1c000.usb: EHCI Host Controller [ 2.576047] ehci-platform 1c14000.usb: new USB bus registered, assigned bus n umber 1 [ 2.580186] of_cfs_init: OK [ 2.589719] ohci-platform 1c14400.usb: Generic Platform OHCI controller [ 2.590587] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus n umber 2 [ 2.597388] ohci-platform 1c14400.usb: new USB bus registered, assigned bus n umber 3 [ 2.605964] ohci-platform 1c1c400.usb: Generic Platform OHCI controller [ 2.616244] clk: Not disabling unused clocks [ 2.619590] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus n umber 4 [ 2.624097] ALSA device list: [ 2.635425] ohci-platform 1c14400.usb: irq 120, io mem 0x01c14400 [ 2.635844] No soundcards found. [ 2.645447] ehci-platform 1c1c000.usb: irq 119, io mem 0x01c1c000 [ 2.651878] ohci-platform 1c1c400.usb: irq 121, io mem 0x01c1c400 [ 2.652025] ehci-platform 1c14000.usb: irq 118, io mem 0x01c14000 [ 2.664949] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00 [ 2.672005] ehci-platform 1c14000.usb: USB 2.0 started, EHCI 1.00 [ 2.672295] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bc dDevice= 6.06 [ 2.686636] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber= 1 [ 2.694325] usb usb2: Product: EHCI Host Controller [ 2.699996] usb usb2: Manufacturer: Linux 6.6.75-legacy-sunxi ehci_hcd [ 2.706612] usb usb2: SerialNumber: 1c1c000.usb [ 2.712373] hub 2-0:1.0: USB hub found [ 2.716296] hub 2-0:1.0: 1 port detected [ 2.725231] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bc dDevice= 6.06 [ 2.733744] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1 [ 2.741893] usb usb1: Product: EHCI Host Controller [ 2.747011] usb usb1: Manufacturer: Linux 6.6.75-legacy-sunxi ehci_hcd [ 2.753619] usb usb1: SerialNumber: 1c14000.usb [ 2.759304] hub 1-0:1.0: USB hub found [ 2.763177] hub 1-0:1.0: 1 port detected [ 2.768445] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bc dDevice= 6.06 [ 2.776948] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber= 1 [ 2.784266] usb usb3: Product: Generic Platform OHCI controller [ 2.790393] usb usb3: Manufacturer: Linux 6.6.75-legacy-sunxi ohci_hcd [ 2.796980] usb usb3: SerialNumber: 1c14400.usb [ 2.802726] hub 3-0:1.0: USB hub found [ 2.806603] hub 3-0:1.0: 1 port detected [ 2.811697] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bc dDevice= 6.06 [ 2.820337] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber= 1 [ 2.827653] usb usb4: Product: Generic Platform OHCI controller [ 2.833617] usb usb4: Manufacturer: Linux 6.6.75-legacy-sunxi ohci_hcd [ 2.840187] usb usb4: SerialNumber: 1c1c400.usb [ 2.845882] hub 4-0:1.0: USB hub found [ 2.849887] hub 4-0:1.0: 1 port detected [ 2.892640] ata1: SATA link down (SStatus 0 SControl 300) [ 2.924430] EXT4-fs (mmcblk0p1): mounted filesystem c15c8d11-cd4f-41fd-8824-d 41975865a75 r/w with writeback data mode. Quota mode: none. [ 2.937083] VFS: Mounted root (ext4 filesystem) on device 179:1. [ 2.953517] devtmpfs: mounted [ 2.967451] Freeing unused kernel image (initmem) memory: 1024K [ 2.974522] Run /sbin/init as init process [ 2.979713] with arguments: [ 2.982749] /sbin/init [ 2.985523] \ [ 2.987479] \ [ 2.989432] \ [ 2.991384] with environment: [ 2.994549] HOME=/ [ 2.996957] TERM=linux [ 2.999727] biosdevname=0 [ 3.299015] usb 3-1: new full-speed USB device number 2 using ohci-platform [ 3.505775] usb 3-1: New USB device found, idVendor=08bb, idProduct=2902, bcd Device= 1.00 [ 3.514061] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 3.521234] usb 3-1: Product: USB PnP Sound Device [ 3.526057] usb 3-1: Manufacturer: C-Media Electronics Inc. [ 3.640964] random: crng init done [ 3.673470] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SEL INUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR) [ 3.687637] systemd[1]: Detected architecture 'arm'. [ 3.777382] systemd[1]: Failed to insert module 'ipv6' [ 3.788482] systemd[1]: Set hostname to <volumio>. [ 4.378960] systemd[1]: [/lib/systemd/system/mpd.service:17] Unknown lvalue ' ControlGroup' in section 'Service' [ 4.389248] systemd[1]: [/lib/systemd/system/mpd.service:20] Unknown lvalue ' ControlGroupAttribute' in section 'Service' [ 4.538794] systemd[1]: Cannot add dependency job for unit display-manager.se rvice, ignoring: Unit display-manager.service failed to load: No such file or di rectory. [ 4.557766] systemd[1]: Expecting device dev-ttyS0.device... [ 4.564783] systemd[1]: Starting Forward Password Requests to Wall Directory Watch. [ 4.573012] systemd[1]: Started Forward Password Requests to Wall Directory W atch. [ 4.788778] fuse: init (API version 7.39) [ 5.301085] systemd-udevd[123]: starting version 215 [ 5.965330] sunxi-mmc 1c12000.mmc: allocated mmc-pwrseq [ 6.007107] sunxi-mmc 1c12000.mmc: initialized, max. request size: 16384 KB [ 6.034560] mmc1: Failed to initialize a non-removable card [ 6.275234] sun4i-ss 1c15000.crypto-engine: no reset control found [ 6.297699] sun4i-ss 1c15000.crypto-engine: Die ID 0 [ 6.416262] sun5i-a13-gpadc-iio: Failed to locate of_node [id: 0] [ 6.581124] input: axp20x-pek as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-00 34/axp20x-pek/input/input0 [ 6.853889] usbcore: registered new interface driver snd-usb-audio [ 6.941105] EXT4-fs (mmcblk0p1): re-mounted c15c8d11-cd4f-41fd-8824-d41975865 a75 r/w. Quota mode: none. [ 7.321837] systemd-journald[120]: Received request to flush runtime journal from PID 1 [ 11.038800] sun7i-dwmac 1c50000.ethernet eth0: Register MEM_TYPE_PAGE_POOL Rx Q-0 [ 11.049999] sun7i-dwmac 1c50000.ethernet eth0: PHY [stmmac-0:01] driver [Gene ric PHY] (irq=POLL) [ 11.058959] sun7i-dwmac 1c50000.ethernet eth0: No Safety Features support fou nd [ 11.066361] sun7i-dwmac 1c50000.ethernet eth0: RX IPC Checksum Offload disabl ed [ 11.073748] sun7i-dwmac 1c50000.ethernet eth0: No MAC Management Counters ava ilable [ 11.081476] sun7i-dwmac 1c50000.ethernet eth0: PTP not supported by HW [ 11.089606] sun7i-dwmac 1c50000.ethernet eth0: configuring for phy/rgmii-id l ink mode [ 15.213705] sun7i-dwmac 1c50000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx root@volumio:~# 0 Quote
Yurii Berkovsky Posted 1 hour ago Author Posted 1 hour ago Try setenv kernel_addr_r 0x42000000 setenv fdt_addr_r 0x43000000 setenv ramdisk_addr_r 0x44000000 setenv bootm_low 0x40000000 setenv bootm_size 0x20000000 setenv bootm_mapsize 0x20000000 setenv fdt_high 0x5fffffff setenv initrd_high 0x5fffffff Some time boot some time not (( Begain crazy 😷 0 Quote
