lauhub Posted December 4, 2017 Posted December 4, 2017 After creating my own initramfs using this command from a chroot-ed environment sudo update-initramfs -t -u -k `uname -r` And rebooting, I get the following error: Found U-Boot script /boot/boot.scr 3708 bytes read in 126 ms (28.3 KiB/s) ## Executing script at 43100000 U-boot loaded from eMMC or secondary SD Boot script loaded from mmc 202 bytes read in 80 ms (2 KiB/s) 5731772 bytes read in 668 ms (8.2 MiB/s) 6790944 bytes read in 759 ms (8.5 MiB/s) Found legacy kernel configuration ** File not found /boot/script.bin ** ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 5731708 Bytes = 5.5 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK EHCI failed to shut down host controller. Loading Ramdisk to 49a88000, end 49fff57c ... OK Starting kernel ... Uncompressing Linux... done, booting the kernel. Error: unrecognized/unsupported machine ID (r1 = 0x42000820). Available machine support: ID (hex) NAME ffffffff Generic DT based system ffffffff Allwinner sun9i Family ffffffff Allwinner sun8i Family ffffffff Allwinner sun7i (A20) Family ffffffff Allwinner sun6i (A31) Family ffffffff Allwinner sun4i/sun5i Families Please check your kernel config and/or bootloader. I chroot from a SD card with Armbian 5.35.installed to a eMMC with armbian 5.35 installed, with an encrypted LUKS partition (and a boot ext4 partition containing my boot files, including the initramfs). I am missing something but could not find it. What is the right way to update initrd ?
Igor Posted December 4, 2017 Posted December 4, 2017 53 minutes ago, lauhub said: Found legacy kernel configuration ** File not found /boot/script.bin ** Are you booting legacy 3.4.y kernel? Then lack of script.bin is a problem.
lauhub Posted December 4, 2017 Author Posted December 4, 2017 Thanks for your answer No it is 4.13.x kernel compiled on November 29
Igor Posted December 4, 2017 Posted December 4, 2017 50 minutes ago, lauhub said: Thanks for your answer No it is 4.13.x kernel compiled on November 29 I assume you are using your own build?
lauhub Posted December 4, 2017 Author Posted December 4, 2017 11 minutes ago, Igor said: I assume you are using your own build? Yes I completely erased the eMMC and re-installed everything: it now works As I have modified partitions I may have destroyed something while using fdisk with a wrong value I noticed that the first sector of boot partition had changed to 8192 Is there a reason for that ? Is it still a right way to re-install u-boot using the following command ? dd if=/usr/lib/linux-u-boot-next-lime2_5.35_armhf/u-boot-sunxi-with-spl.bin of=/dev/mmcblk1 bs=1k seek=8
