Jean-Marc Posted March 8 Posted March 8 Dear team, On Armbian_25.11.1_Orangepi5-plus_trixie_vendor_6.1.115_minimal.img not possible to boot completely kernel, sytem reboot in infinie loop Bellow is the debug log on tty DDR V1.13 25cee80c4f cym 23/08/11-09:31:58 LPDDR4X, 2112MHz channel[0] BW=16 Col=10 Bk=8 CS0 Row=18 CS1 Row=18 CS=2 Die BW=8 Size=8192MB channel[1] BW=16 Col=10 Bk=8 CS0 Row=18 CS1 Row=18 CS=2 Die BW=8 Size=8192MB channel[2] BW=16 Col=10 Bk=8 CS0 Row=18 CS1 Row=18 CS=2 Die BW=8 Size=8192MB channel[3] BW=16 Col=10 Bk=8 CS0 Row=18 CS1 Row=18 CS=2 Die BW=8 Size=8192MB Manufacturer ID:0xff CH0 RX Vref:28.9%, TX Vref:22.8%,21.8% CH1 RX Vref:27.1%, TX Vref:21.8%,20.8% CH2 RX Vref:27.9%, TX Vref:21.8%,22.8% CH3 RX Vref:28.9%, TX Vref:20.8%,20.8% change to F1: 528MHz change to F2: 1068MHz change to F3: 1560MHz change to F0: 2112MHz out U-Boot SPL board init U-Boot SPL 2017.09-orangepi (Nov 15 2023 - 16:53:25) Trying to boot from MMC1 Trying fit image at 0x4000 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(7612223b82...) + OK ## Checking uboot 0x00200000 ... sha256(d41c62e80b...) + OK ## Checking fdt 0x00355940 ... sha256(7146109403...) + OK ## Checking atf-2 0xff100000 ... sha256(70505bb764...) + OK ## Checking atf-3 0x000f0000 ... sha256(b2af21b504...) + OK Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000) Total: 741.571 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-868-g040d2de11:derrick.huang, fwver: v1.48 NOTICE: BL31: Built : 15:02:44, Dec 19 2024 INFO: spec: 0x1 INFO: code: 0x88 INFO: ext 32k is valid INFO: ddr: stride-en 4CH INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0 INFO: l3 cache partition cfg-0 INFO: system boots from cpu-hwid-0 INFO: disable memory repair INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001 INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz INFO: BL31: Initialising Exception Handling Framework INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 usb dr_mode not found usb dr_mode not found U-Boot 2017.09_armbian-2017.09-S3f41-Pdfdd-H6539-Ve691-Bbf55-R448a (Nov 19 2025 - 17:07:00 +0000) Model: Orange Pi 5 Plus MPIDR: 0x0 PreSerial: 2, raw, 0xfeb50000 DRAM: 31.7 GiB Sysmem: init Relocation Offset: eda09000 Relocation fdt: eb9f7610 - eb9fecd0 CR: M/C/I usb dr_mode not found usb dr_mode not found Using default environment DM: v2 RESC: No bootdev Failed to load DTB, ret=-2 No valid DTB, ret=-22 Failed to get kernel dtb, ret=-22 Model: Orange Pi 5 Plus [Vendor ERROR]:Invalid boot device type(0) ## Error: Can't overwrite "ethaddr" ## Error inserting "ethaddr" variable, errno=1 ## Error: Can't overwrite "eth1addr" ## Error inserting "eth1addr" variable, errno=1 [Vendor ERROR]:Invalid boot device type(0) rockchip_set_ethaddr: vendor_storage_write failed -19 [Vendor ERROR]:Invalid boot device type(0) mmc@fe2c0000: 1, mmc@fe2e0000: 0 Card did not respond to voltage select! mmc_init: -95, time 14 switch to partitions #0, OK mmc1 is current device Boot from SDcard Bootdev(scan): mmc 1 No bootdev dev_desc is NULL! boot mode: None No bootdev CLK: (sync kernel. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A) b0pll 24000 KHz b1pll 24000 KHz lpll 24000 KHz v0pll 24000 KHz aupll 24000 KHz cpll 1500000 KHz gpll 1188000 KHz npll 24000 KHz ppll 1100000 KHz aclk_center_root 702000 KHz pclk_center_root 100000 KHz hclk_center_root 396000 KHz aclk_center_low_root 500000 KHz aclk_top_root 750000 KHz pclk_top_root 100000 KHz aclk_low_top_root 396000 KHz MMC1: Legacy, 52Mhz PartType: EFI No bootdev dev_desc is NULL! No bootdev Net: No ethernet found. Hit key to stop autoboot('CTRL+C'): 0 starting USB... Bus usb@fc000000: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus usb@fc800000: USB EHCI 1.00 Bus usb@fc840000: USB OHCI 1.0 Bus usb@fc880000: USB EHCI 1.00 Bus usb@fc8c0000: USB OHCI 1.0 Bus usb@fc400000: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fc000000 for devices... 1 USB Device(s) found scanning bus usb@fc800000 for devices... 1 USB Device(s) found scanning bus usb@fc840000 for devices... 1 USB Device(s) found scanning bus usb@fc880000 for devices... 1 USB Device(s) found scanning bus usb@fc8c0000 for devices... 1 USB Device(s) found scanning bus usb@fc400000 for devices... cannot reset port 1!? 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Device 0: unknown device switch to partitions #0, OK mmc1 is current device Could not find misc partition ANDROID: reboot reason: "(none)" Not AVB images, AVB skip android_image_load_by_partname: Can't find part: boot Android image load failed Android boot failed, error -1. Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 4149 bytes read in 24 ms (168 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1:1 200 bytes read in 23 ms (7.8 KiB/s) 14756344 bytes read in 1221 ms (11.5 MiB/s) 48886272 bytes read in 3964 ms (11.8 MiB/s) 278734 bytes read in 249 ms (1.1 MiB/s) Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' Fdt Ramdisk skip relocation No misc partition ## Loading init Ramdisk from Legacy Image at 0a200000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 14756280 Bytes = 14.1 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 0x08300000 Booting using the fdt blob at 0x08300000 reserving fdt memory region: addr=8300000 size=aa000 Using Device Tree in place at 0000000008300000, end 00000000083acfff ## reserved-memory: cma: addr=10000000 size=10000000 ramoops@110000: addr=110000 size=e0000 Adding bank: 0x00200000 - 0xf0000000 (size: 0xefe00000) Adding bank: 0x100000000 - 0x3fc000000 (size: 0x2fc000000) Adding bank: 0x3fc500000 - 0x3fff00000 (size: 0x03a00000) Adding bank: 0x400000000 - 0x800000000 (size: 0x400000000) Total: 14513.438/14546.469 ms Starting kernel ... [ 14.549838] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [ 14.549866] Linux version 6.1.115-vendor-rk35xx (build@armbian) (aarch64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP Fri Nov 21 14:02:48 UTC 2025 [ 14.557926] Machine model: Orange Pi 5 Plus [ 14.558092] efi: UEFI not found. [ 14.561609] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@0': base 0x0000000000000000, size 0 MiB [ 14.561630] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@0': base 0x0000000000000000, size 0 MiB [ 14.561723] Reserved memory: bypass cma node, using cmdline CMA params instead [ 14.561729] OF: reserved mem: node cma compatible matching fail [ 15.092501] Zone ranges: [ 15.092509] DMA [mem 0x0000000000200000-0x00000000ffffffff] [ 15.092521] DMA32 empty [ 15.092526] Normal [mem 0x0000000100000000-0x00000007ffffffff] [ 15.092533] Movable zone start for each node [ 15.092535] Early memory node ranges [ 15.092537] node 0: [mem 0x0000000000200000-0x00000000efffffff] [ 15.092546] node 0: [mem 0x0000000100000000-0x00000003fbffffff] [ 15.092555] node 0: [mem 0x00000003fc500000-0x00000003ffefffff] [ 15.092560] node 0: [mem 0x0000000400000000-0x00000007ffffffff] [ 15.092571] Initmem setup node 0 [mem 0x0000000000200000-0x00000007ffffffff] [ 15.112932] On node 0, zone DMA: 512 pages in unavailable ranges [ 15.178027] On node 0, zone Normal: 1280 pages in unavailable ranges [ 15.264742] On node 0, zone Normal: 256 pages in unavailable ranges [ 15.264773] cma: Reserved 256 MiB at 0x00000000e0000000 [ 15.264968] psci: probing for conduit method from DT. [ 15.264977] psci: PSCIv1.1 detected in firmware. [ 15.264982] psci: Using standard PSCI v0.2 function IDs [ 15.264987] psci: MIGRATE_INFO_TYPE not supported. [ 15.265029] psci: SMC Calling Convention v1.2 [ 15.265418] percpu: Embedded 30 pages/cpu s82728 r8192 d31960 u122880 [ 15.265623] Detected VIPT I-cache on CPU0 [ 15.265675] CPU features: detected: GIC system register CPU interface [ 15.265680] CPU features: detected: Virtualization Host Extensions [ 15.265695] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009 [ 15.265699] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 15.265705] alternatives: applying boot alternatives [ 15.266244] Built 1 zonelists, mobility grouping on. Total pages: 8190984 [ 15.266258] Kernel command line: root=UUID=21f59e6d-0e11-4ba2-85d3-e5fab5604f14 rootwait rootfstype=ext4 splash=verbose console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=7 ubootpart=f09d1995-765c-164f-bbae-c1ba9ef9a944 usb-storage.quirks= cma=256M cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory androidboot.fwver=bl31-v1.48,uboot-rmbian-201-11/19/2025 [ 15.266782] Unknown kernel command line parameters "splash=verbose ubootpart=f09d1995-765c-164f-bbae-c1ba9ef9a944 cgroup_enable=memory cgroup_memory=1", will be passed to user space. [ 15.269843] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear) [ 15.271375] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear) [ 15.271384] mem auto-init: stack:off, heap alloc:off, heap free:off [ 15.271390] software IO TLB: area num 8. [ 15.283936] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB) [ 15.542056] Memory: 32255616K/33284096K available (19072K kernel code, 4028K rwdata, 16148K rodata, 8320K init, 700K bss, 766336K reserved, 262144K cma-reserved) [ 15.542219] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1 [ 15.542258] ftrace: allocating 72100 entries in 282 pages [ 15.670937] ftrace: allocated 282 pages with 4 groups [ 15.671046] trace event string verifier disabled [ 15.671273] rcu: Hierarchical RCU implementation. [ 15.671278] rcu: RCU event tracing is enabled. [ 15.671282] Rude variant of Tasks RCU enabled. [ 15.671285] Tracing variant of Tasks RCU enabled. [ 15.671288] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies. [ 15.689264] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 15.692345] GICv3: GIC: Using split EOI/Deactivate mode [ 15.692350] GICv3: 480 SPIs implemented [ 15.692355] GICv3: 0 Extended SPIs implemented [ 15.692386] Root IRQ handler: gic_handle_irq [ 15.692402] GICv3: GICv3 features: 16 PPIs [ 15.692445] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000 [ 15.692832] ITS [mem 0xfe640000-0xfe65ffff] [ 15.692889] ITS@0x00000000fe640000: allocated 8192 Devices @100170000 (indirect, esz 8, psz 64K, shr 0) [ 15.692921] ITS@0x00000000fe640000: allocated 32768 Interrupt Collections @100180000 (flat, esz 2, psz 64K, shr 0) [ 15.692937] ITS: using cache flushing for cmd queue [ 15.692973] ITS [mem 0xfe660000-0xfe67ffff] [ 15.693021] ITS@0x00000000fe660000: allocated 8192 Devices @1001a0000 (indirect, esz 8, psz 64K, shr 0) [ 15.693051] ITS@0x00000000fe660000: allocated 32768 Interrupt Collections @1001b0000 (flat, esz 2, psz 64K, shr 0) [ 15.693066] ITS: using cache flushing for cmd queue [ 15.693320] GICv3: using LPI property table @0x00000001001c0000 [ 15.693452] GIC: using cache flushing for LPI property table [ 15.693461] GICv3: CPU0: using allocated LPI pending table @0x00000001001d0000 [ 15.693519] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 15.852397] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 15.852409] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 15.852420] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 15.853909] Console: colour dummy device 80x25 [ 15.854617] printk: console [tty1] enabled [ 15.854661] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000) [ 15.854686] pid_max: default: 32768 minimum: 301 [ 15.854763] LSM: Security Framework initializing [ 15.854894] AppArmor: AppArmor initialized [ 15.855036] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 15.855112] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 15.857168] cblist_init_generic: Setting adjustable number of callback queues. [ 15.857191] cblist_init_generic: Setting shift to 3 and lim to 1. [ 15.857309] cblist_init_generic: Setting adjustable number of callback queues. [ 15.857329] cblist_init_generic: Setting shift to 3 and lim to 1. [ 15.857568] rcu: Hierarchical SRCU implementation. [ 15.857584] rcu: Max phase no-delay instances is 1000. [ 15.859156] Platform MSI: msi-controller@fe640000 domain created [ 15.859188] Platform MSI: msi-controller@fe660000 domain created [ 15.859624] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe640000 domain created [ 15.859665] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe660000 domain created [ 15.859918] EFI services will not be available. [ 15.860378] smp: Bringing up secondary CPUs ... [ 15.861025] Detected VIPT I-cache on CPU1 [ 15.861121] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000 [ 15.861144] GICv3: CPU1: using allocated LPI pending table @0x00000001001e0000 [ 15.861186] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [ 15.861927] Detected VIPT I-cache on CPU2 [ 15.862021] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000 [ 15.862044] GICv3: CPU2: using allocated LPI pending table @0x00000001001f0000 [ 15.862082] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [ 15.862741] Detected VIPT I-cache on CPU3 [ 15.862832] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000 [ 15.862854] GICv3: CPU3: using allocated LPI pending table @0x0000000100200000 [ 15.862889] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [ 15.863555] CPU features: detected: Spectre-v4 [ 15.863560] CPU features: detected: Spectre-BHB [ 15.863564] CPU features: detected: SSBS not fully self-synchronizing [ 15.863566] Detected PIPT I-cache on CPU4 [ 15.863616] GICv3: CPU4: found redistributor 400 region 0:0x00000000fe700000 [ 15.863629] GICv3: CPU4: using allocated LPI pending table @0x0000000100210000 [ 15.863652] CPU4: Booted secondary processor 0x0000000400 [0x414fd0b0] [ 15.864307] Detected PIPT I-cache on CPU5 [ 15.864365] GICv3: CPU5: found redistributor 500 region 0:0x00000000fe720000 [ 15.864378] GICv3: CPU5: using allocated LPI pending table @0x0000000100220000 [ 15.864402] CPU5: Booted secondary processor 0x0000000500 [0x414fd0b0] [ 15.865031] Detected PIPT I-cache on CPU6 [ 15.865087] GICv3: CPU6: found redistributor 600 region 0:0x00000000fe740000 [ 15.865100] GICv3: CPU6: using allocated LPI pending table @0x0000000100230000 [ 15.865123] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b0] [ 15.865804] Detected PIPT I-cache on CPU7 [ 15.865862] GICv3: CPU7: found redistributor 700 region 0:0x00000000fe760000 [ 15.865874] GICv3: CPU7: using allocated LPI pending table @0x0000000100240000 [ 15.865897] CPU7: Booted secondary processor 0x0000000700 [0x414fd0b0] [ 15.865964] smp: Brought up 1 node, 8 CPUs [ 15.866251] SMP: Total of 8 processors activated. [ 15.866264] CPU features: detected: 32-bit EL0 Support [ 15.866276] CPU features: detected: Data cache clean to the PoU not required for I/D coherence [ 15.866293] CPU features: detected: Common not Private translations [ 15.866306] CPU features: detected: CRC32 instructions [ 15.866320] CPU features: detected: RCpc load-acquire (LDAPR) [ 15.866332] CPU features: detected: LSE atomic instructions [ 15.866344] CPU features: detected: Privileged Access Never [ 15.866356] CPU features: detected: RAS Extension Support [ 15.866369] CPU features: detected: Speculative Store Bypassing Safe (SSBS) [ 15.866461] CPU: All CPU(s) started at EL2 [ 15.866474] alternatives: applying system-wide alternatives [ 15.876522] devtmpfs: initialized [ 15.892812] Registered cp15_barrier emulation handler [ 15.892826] Registered setend emulation handler [ 15.892915] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns [ 15.892929] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 15.895047] pinctrl core: initialized pinctrl subsystem [ 15.895276] DMI not present or invalid. [ 15.895585] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 15.896383] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations [ 15.896740] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 15.896987] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 15.897014] audit: initializing netlink subsys (disabled) [ 15.897123] audit: type=2000 audit(0.043:1): state=initialized audit_enabled=0 res=1 [ 15.897701] Registered FIQ tty driver [ 15.897851] thermal_sys: Registered thermal governor 'fair_share' [ 15.897854] thermal_sys: Registered thermal governor 'step_wise' [ 15.897859] thermal_sys: Registered thermal governor 'user_space' [ 15.897864] thermal_sys: Registered thermal governor 'power_allocator' [ 15.897891] cpuidle: using governor menu [ 15.898100] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 15.898232] ASID allocator initialised with 65536 entries [ 15.900305] ramoops: dmesg-0 0x18000@0x0000000000110000 [ 15.900313] ramoops: dmesg-1 0x18000@0x0000000000128000 [ 15.900332] ramoops: console 0x80000@0x0000000000140000 [ 15.900343] ramoops: pmsg 0x30000@0x00000000001c0000 [ 15.900607] printk: console [ramoops-1] enabled [ 15.900614] pstore: Registered ramoops as persistent store backend [ 15.900620] ramoops: using 0xe0000@0x110000, ecc: 0 [ 15.938715] platform fdd90000.vop: Fixed dependency cycle(s) with /dp@fde50000 [ 15.938752] platform fde50000.dp: Fixed dependency cycle(s) with /vop@fdd90000 [ 15.939044] platform fdd90000.vop: Fixed dependency cycle(s) with /hdmi@fde80000 [ 15.939082] platform fde80000.hdmi: Fixed dependency cycle(s) with /vop@fdd90000 [ 15.944532] platform fed80000.phy: Fixed dependency cycle(s) with /i2c@fec80000/fusb302@22/connector [ 15.950230] rockchip-gpio fd8a0000.gpio: probed /pinctrl/gpio@fd8a0000 [ 15.950502] rockchip-gpio fec20000.gpio: probed /pinctrl/gpio@fec20000 [ 15.950726] rockchip-gpio fec30000.gpio: probed /pinctrl/gpio@fec30000 [ 15.950968] rockchip-gpio fec40000.gpio: probed /pinctrl/gpio@fec40000 [ 15.951246] rockchip-gpio fec50000.gpio: probed /pinctrl/gpio@fec50000 [ 15.951299] rockchip-pinctrl pinctrl: probed pinctrl [ 15.952701] platform fdd90000.vop: Fixed dependency cycle(s) with /hdmi@fdea0000 [ 15.952737] platform fdea0000.hdmi: Fixed dependency cycle(s) with /vop@fdd90000 [ 15.956761] KASLR disabled due to lack of seed [ 15.961962] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 15.961972] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 15.961981] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 15.961987] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 15.961995] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 15.962001] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 15.962008] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 15.962015] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 16.019202] raid6: neonx8 gen() 5414 MB/s [ 16.075957] raid6: neonx4 gen() 5491 MB/s [ 16.132711] raid6: neonx2 gen() 5094 MB/s [ 16.189467] raid6: neonx1 gen() 4266 MB/s [ 16.246230] raid6: int64x8 gen() 1354 MB/s [ 16.302982] raid6: int64x4 gen() 1714 MB/s [ 16.359740] raid6: int64x2 gen() 2426 MB/s [ 16.416500] raid6: int64x1 gen() 2007 MB/s [ 16.416506] raid6: using algorithm neonx4 gen() 5491 MB/s [ 16.473245] raid6: .... xor() 4224 MB/s, rmw enabled [ 16.473252] raid6: using neon recovery algorithm [ 16.474461] fiq_debugger fiq_debugger.0: error -ENXIO: IRQ fiq not found [ 16.474476] fiq_debugger fiq_debugger.0: error -ENXIO: IRQ wakeup not found [ 16.474486] fiq_debugger_probe: could not install nmi irq handler [ 16.474761] printk: console [ttyFIQ0] enabled [ 16.474907] Registered fiq debugger ttyFIQ0 [ 16.536509] debugfs: Directory 'vcc_mipicsi1' with parent 'regulator' already present! [ 16.536530] debugfs: Directory 'vcc_mipicsi1' with parent 'vcc_mipicsi1' already present! [ 16.536993] iommu: Default domain type: Translated [ 16.537004] iommu: DMA domain TLB invalidation policy: strict mode [ 16.537176] SCSI subsystem initialized [ 16.537262] usbcore: registered new interface driver usbfs [ 16.537283] usbcore: registered new interface driver hub [ 16.537301] usbcore: registered new device driver usb [ 16.537355] mc: Linux media interface: v0.10 [ 16.537378] videodev: Linux video capture interface: v2.00 [ 16.537418] pps_core: LinuxPPS API ver. 1 registered [ 16.537426] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 16.537440] PTP clock support registered [ 16.537645] arm-scmi firmware:scmi: Enabled polling mode TX channel - prot_id:16 [ 16.537703] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled. [ 16.537736] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0 [ 16.538652] Advanced Linux Sound Architecture Driver Initialized. [ 16.538913] Bluetooth: Core ver 2.22 [ 16.538933] NET: Registered PF_BLUETOOTH protocol family [ 16.538940] Bluetooth: HCI device and connection manager initialized [ 16.538951] Bluetooth: HCI socket layer initialized [ 16.538959] Bluetooth: L2CAP socket layer initialized [ 16.538969] Bluetooth: SCO socket layer initialized [ 16.539017] NetLabel: Initializing [ 16.539023] NetLabel: domain hash size = 128 [ 16.539030] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 16.539060] NetLabel: unlabeled traffic allowed by default [ 16.539239] vgaarb: loaded [ 16.539864] clocksource: Switched to clocksource arch_sys_counter [ 16.539999] VFS: Disk quotas dquot_6.6.0 [ 16.540025] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 16.540234] AppArmor: AppArmor Filesystem Enabled [ 16.545799] NET: Registered PF_INET protocol family [ 16.545984] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 16.552972] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear) [ 16.553150] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 16.553184] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 16.554512] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear) [ 16.555774] TCP: Hash tables configured (established 262144 bind 65536) [ 16.555924] MPTCP token hash table entries: 32768 (order: 7, 786432 bytes, linear) [ 16.556093] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear) [ 16.556591] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear) [ 16.557136] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 16.557409] RPC: Registered named UNIX socket transport module. [ 16.557419] RPC: Registered udp transport module. [ 16.557425] RPC: Registered tcp transport module. [ 16.557432] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 16.557855] PCI: CLS 0 bytes, default 64 [ 16.558243] Trying to unpack rootfs image as initramfs... [ 16.558611] rockchip-thermal fec00000.tsadc: Missing rockchip,grf property [ 16.559505] rockchip-thermal fec00000.tsadc: tsadc is probed successfully! [ 16.568269] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 16.568770] kvm [1]: IPA Size Limit: 40 bits [ 16.568788] kvm [1]: GICv3: no GICV resource entry [ 16.568795] kvm [1]: disabling GICv2 emulation [ 16.568802] kvm [1]: GIC system register CPU interface enabled [ 16.573423] kvm [1]: vgic interrupt IRQ9 [ 16.578406] kvm [1]: VHE mode initialized successfully [ 16.663543] Initialise system trusted keyrings [ 16.663678] workingset: timestamp_bits=46 max_order=23 bucket_order=0 [ 16.665943] zbud: loaded [ 16.666774] NFS: Registering the id_resolver key type [ 16.666796] Key type id_resolver registered [ 16.666803] Key type id_legacy registered [ 16.666840] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 16.666849] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 16.687921] NET: Registered PF_ALG protocol family [ 16.687937] xor: measuring software checksum speed [ 16.688466] 8regs : 6294 MB/sec [ 16.688870] 32regs : 8271 MB/sec [ 16.689210] arm64_neon : 9884 MB/sec [ 16.689217] xor: using function: arm64_neon (9884 MB/sec) [ 16.689227] Key type asymmetric registered [ 16.689235] Asymmetric key parser 'x509' registered [ 16.959955] Freeing initrd memory: 14404K [ 16.973962] alg: self-tests for CTR-KDF (hmac(sha256)) passed [ 16.974009] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 241) [ 16.974123] io scheduler mq-deadline registered [ 16.974132] io scheduler kyber registered [ 16.975423] rockchip-csi2-dphy-hw fedc8000.csi2-dphy1-hw: csi2 dphy hw probe successfully! [ 16.984662] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy init success [ 16.985526] rockchip-hdptx-phy-hdmi fed70000.hdmiphy: hdptx phy init success [ 16.987970] dw-pcie fe180000.pcie: invalid resource [ 16.987986] dw-pcie fe180000.pcie: Failed to initialize host [ 16.987994] dw-pcie: probe of fe180000.pcie failed with error -22 [ 16.988064] dw-pcie fe190000.pcie: invalid resource [ 16.988073] dw-pcie fe190000.pcie: Failed to initialize host [ 16.988080] dw-pcie: probe of fe190000.pcie failed with error -22 [ 16.988190] dw-pcie fe150000.pcie: invalid resource [ 16.988200] dw-pcie fe150000.pcie: Failed to initialize host [ 16.988219] dw-pcie: probe of fe150000.pcie failed with error -22 [ 16.988338] dw-pcie fe170000.pcie: invalid resource [ 16.988348] dw-pcie fe170000.pcie: Failed to initialize host [ 16.988355] dw-pcie: probe of fe170000.pcie failed with error -22 [ 16.988727] rk-pcie fe180000.pcie: using pcie default link_up because of rockchip,default-link-up [ 16.988880] rk-pcie fe190000.pcie: using pcie default link_up because of rockchip,default-link-up [ 16.988961] rk-pcie fe180000.pcie: invalid prsnt-gpios property in node [ 16.988963] rk-pcie fe190000.pcie: invalid prsnt-gpios property in node [ 16.989036] rk-pcie fe190000.pcie: no vpcie3v3 regulator found [ 16.989154] rk-pcie fe180000.pcie: no vpcie3v3 regulator found [ 16.989171] rk-pcie fe150000.pcie: invalid prsnt-gpios property in node [ 16.989361] rk-pcie fe170000.pcie: invalid prsnt-gpios property in node [ 16.989389] rk-pcie fe190000.pcie: host bridge /pcie@fe190000 ranges: [ 16.989409] rk-pcie fe190000.pcie: IO 0x00f4100000..0x00f41fffff -> 0x00f4100000 [ 16.989439] rk-pcie fe190000.pcie: MEM 0x00f4200000..0x00f4ffffff -> 0x00f4200000 [ 16.989461] rk-pcie fe190000.pcie: MEM 0x0a00000000..0x0a3fffffff -> 0x0a00000000 [ 16.989516] rk-pcie fe190000.pcie: iATU unroll: enabled [ 16.989519] iep: Module initialized. [ 16.989530] rk-pcie fe190000.pcie: iATU regions: 8 ob, 8 ib, align 64K, limit 8G [ 16.989549] mpp_service mpp-srv: 6c47657a381c author: Yandong Lin 2025-01-16 video: rockchip: mpp: Fix missing enable_irq in timeout work [ 16.989553] mpp_service mpp-srv: probe start [ 16.989687] rk-pcie fe180000.pcie: host bridge /pcie@fe180000 ranges: [ 16.989832] rk-pcie fe180000.pcie: IO 0x00f3100000..0x00f31fffff -> 0x00f3100000 [ 16.989847] rk-pcie fe180000.pcie: MEM 0x00f3200000..0x00f3ffffff -> 0x00f3200000 [ 16.989868] rk-pcie fe180000.pcie: MEM 0x09c0000000..0x09ffffffff -> 0x09c0000000 [ 16.989915] rk-pcie fe180000.pcie: iATU unroll: enabled [ 16.989924] rk-pcie fe180000.pcie: iATU regions: 8 ob, 8 ib, align 64K, limit 8G [ 16.991571] mpp_vepu2 jpege-ccu: probing start [ 16.991584] mpp_vepu2 jpege-ccu: probing finish [ 16.994566] mpp_rkvdec2 fdc30000.rkvdec-ccu: rkvdec-ccu, probing start [ 16.994639] mpp_rkvdec2 fdc30000.rkvdec-ccu: ccu-mode: 1 [ 16.994649] mpp_rkvdec2 fdc30000.rkvdec-ccu: probing finish [ 16.995008] mpp_rkvenc2 rkvenc-ccu: probing start [ 16.995019] mpp_rkvenc2 rkvenc-ccu: probing finish [ 16.995612] mpp_service mpp-srv: probe success [ 17.005549] rk-pcie fe150000.pcie: can't get current limit. [ 17.005806] rk-pcie fe150000.pcie: host bridge /pcie@fe150000 ranges: [ 17.005828] rk-pcie fe150000.pcie: IO 0x00f0100000..0x00f01fffff -> 0x00f0100000 [ 17.005846] rk-pcie fe150000.pcie: MEM 0x00f0200000..0x00f0ffffff -> 0x00f0200000 [ 17.005861] rk-pcie fe150000.pcie: MEM 0x0900000000..0x093fffffff -> 0x0900000000 [ 17.005915] rk-pcie fe150000.pcie: iATU unroll: enabled [ 17.005925] rk-pcie fe150000.pcie: iATU regions: 8 ob, 8 ib, align 64K, limit 8G [ 17.007528] dma-pl330 fea10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 17.007548] dma-pl330 fea10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 17.008470] dma-pl330 fea30000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 17.008485] dma-pl330 fea30000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 17.009395] dma-pl330 fed10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 17.009410] dma-pl330 fed10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 17.009891] rockchip-pvtm fda40000.pvtm: pvtm@0 probed [ 17.009963] rockchip-pvtm fda50000.pvtm: pvtm@1 probed [ 17.010025] rockchip-pvtm fda60000.pvtm: pvtm@2 probed [ 17.010083] rockchip-pvtm fdaf0000.pvtm: pvtm@3 probed [ 17.010137] rockchip-pvtm fdb30000.pvtm: pvtm@4 probed [ 17.010798] rockchip-system-monitor rockchip-system-monitor: system monitor probe [ 17.011715] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [ 17.012307] febc0000.serial: ttyS9 at MMIO 0xfebc0000 (irq = 45, base_baud = 1500000) is a 16550A [ 17.013669] random: crng init done [ 17.013743] led_vk2c21_init [ 17.013743] ============================================= [ 17.019335] rk_iommu fdca0000.iommu: av1d iommu enabled [ 17.021625] rockchip-vop2 fdd90000.vop: Adding to iommu group 17 [ 17.031191] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp0 assign plane mask: Cluster0 | Esmart0[0x5], primary plane phy id: Cluster0[0] [ 17.031226] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp1 assign plane mask: Cluster1 | Esmart1[0xa], primary plane phy id: Cluster1[1] [ 17.031245] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp2 assign plane mask: Cluster2 | Esmart2[0x140], primary plane phy id: Cluster2[6] [ 17.031263] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp3 assign plane mask: Cluster3 | Esmart3[0x280], primary plane phy id: Cluster3[7] [ 17.031373] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart0-win0 as cursor plane for vp0 [ 17.031474] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart1-win0 as cursor plane for vp1 [ 17.031563] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart2-win0 as cursor plane for vp2 [ 17.031592] [drm] failed to init overlay plane Cluster0-win1 [ 17.031601] [drm] failed to init overlay plane Cluster1-win1 [ 17.031610] [drm] failed to init overlay plane Cluster2-win1 [ 17.031648] [drm] failed to init overlay plane Cluster3-win1 [ 17.043446] rockchip-vop2 fdd90000.vop: bin=0 [ 17.043668] rockchip-vop2 fdd90000.vop: leakage=35 [ 17.043683] rockchip-vop2 fdd90000.vop: leakage-volt-sel=1 [ 17.043748] rockchip-vop2 fdd90000.vop: error -ENODEV: _opp_set_regulators: no regulator (vop) found [ 17.043779] rockchip-vop2 fdd90000.vop: failed to set opp config [ 17.043790] rockchip-vop2 fdd90000.vop: failed to init opp info [ 17.043799] rockchip-vop2 fdd90000.vop: Unsupported VOP aclk dvfs [ 17.043821] rockchip-drm display-subsystem: bound fdd90000.vop (ops 0xffff8000093fe4a8) [ 17.044446] dwhdmi-rockchip fde80000.hdmi: registered ddc I2C bus driver [ 17.045062] rockchip-drm display-subsystem: bound fde80000.hdmi (ops 0xffff800009417528) [ 17.045612] dwhdmi-rockchip fdea0000.hdmi: registered ddc I2C bus driver [ 17.046208] rockchip-drm display-subsystem: bound fdea0000.hdmi (ops 0xffff800009417528) [ 17.046452] rockchip-drm display-subsystem: bound fde50000.dp (ops 0xffff80000941a588) [ 17.047805] [drm] Initialized rockchip 4.0.0 20140818 for display-subsystem on minor 0 [ 17.047837] rockchip-drm display-subsystem: failed to parse loader memory [ 17.047916] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 17.047987] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 17.048017] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 17.048190] rockchip-drm display-subsystem: [drm] run display error_event monitor [ 17.048860] dw-hdmi-qp-hdcp dw-hdmi-qp-hdcp.2.auto: dw_hdcp_qp_hdcp_probe success [ 17.048988] dw-hdmi-qp-hdcp dw-hdmi-qp-hdcp.5.auto: dw_hdcp_qp_hdcp_probe success [ 17.049605] Registered IR keymap rc-cec [ 17.049672] rc rc0: dw_hdmi_qp as /devices/platform/fde80000.hdmi/rc/rc0 [ 17.049776] input: dw_hdmi_qp as /devices/platform/fde80000.hdmi/rc/rc0/input0 [ 17.049983] rk-pcie fe170000.pcie: can't get current limit. [ 17.050179] Registered IR keymap rc-cec [ 17.050246] rc rc1: dw_hdmi_qp as /devices/platform/fdea0000.hdmi/rc/rc1 [ 17.050340] input: dw_hdmi_qp as /devices/platform/fdea0000.hdmi/rc/rc1/input1 [ 17.050375] rk-pcie fe170000.pcie: host bridge /pcie@fe170000 ranges: [ 17.050435] rk-pcie fe170000.pcie: IO 0x00f2100000..0x00f21fffff -> 0x00f2100000 [ 17.050491] rk-pcie fe170000.pcie: MEM 0x00f2200000..0x00f2ffffff -> 0x00f2200000 [ 17.050535] rk-pcie fe170000.pcie: MEM 0x0980000000..0x09bfffffff -> 0x0980000000 [ 17.050626] rk-pcie fe170000.pcie: iATU unroll: enabled [ 17.050653] rk-pcie fe170000.pcie: iATU regions: 8 ob, 8 ib, align 64K, limit 8G [ 17.052457] brd: module loaded [ 17.055442] loop: module loaded [ 17.055673] rbd: loaded (major 254) [ 17.055842] lkdtm: No crash points registered, enable through debugfs [ 17.058049] rockchip-spi feb20000.spi: no high_speed pinctrl state [ 17.058457] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/rk806single@0/regulators/DCDC_REG7 [ 17.058508] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/rk806single@0/pinctrl_rk806/rk806_dvs1_pwrdn [ 17.058528] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/rk806single@0/pinctrl_rk806/rk806_dvs3_null [ 17.058546] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/rk806single@0/pinctrl_rk806/rk806_dvs2_null [ 17.058565] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/rk806single@0/pinctrl_rk806/rk806_dvs1_null [ 17.059094] rk806 spi2.0: chip id: RK806,ver:0x2, 0x1 [ 17.059226] rk806 spi2.0: ON: 0x40 OFF:0x0 [ 17.059353] rk806 spi2.0: shutdown-sequence missing! [ 17.059365] rk806 spi2.0: vb-shutdown-sequence missing! [ 17.059375] rk806 spi2.0: dvs-suspend-control-by missing! [ 17.068300] avdd_0v75_s0: Bringing 750000uV into 837500-837500uV [ 17.073038] rk806 spi2.0: no sleep-setting state [ 17.073056] rk806 spi2.0: no reset-setting pinctrl state [ 17.073066] rk806 spi2.0: no dvs-setting pinctrl state [ 17.073767] rockchip-spi feb20000.spi: register misc device rkspi-dev2 [ 17.073782] rockchip-spi feb20000.spi: probed, poll=0, rsd=0, cs-inactive=0, ready=0 [ 17.075148] spi-nor spi5.0: XM25QU128C (16384 Kbytes) read_data x4 [ 17.075192] 1 fixed-partitions partitions found on MTD device sfc_nor [ 17.075205] Creating 1 MTD partitions on "sfc_nor": [ 17.075215] 0x000000000000-0x000001000000 : "loader" [ 17.078062] usbcore: registered new interface driver rndis_wlan [ 17.078095] usbcore: registered new interface driver asix [ 17.078117] usbcore: registered new interface driver cdc_ether [ 17.078140] usbcore: registered new interface driver rndis_host [ 17.078165] usbcore: registered new interface driver cdc_ncm [ 17.078294] VFIO - User Level meta-driver version: 0.3 [ 17.078835] platform fc000000.usb: Fixed dependency cycle(s) with /i2c@fec80000/fusb302@22 [ 17.092634] phy phy-fd5d4000.syscon:usb2-phy@4000.3: illegal mode [ 17.092658] xhci-hcd xhci-hcd.12.auto: xHCI Host Controller [ 17.092676] xhci-hcd xhci-hcd.12.auto: new USB bus registered, assigned bus number 1 [ 17.092771] xhci-hcd xhci-hcd.12.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0002008002010010 [ 17.092804] xhci-hcd xhci-hcd.12.auto: irq 86, io mem 0xfc400000 [ 17.092890] xhci-hcd xhci-hcd.12.auto: xHCI Host Controller [ 17.092905] xhci-hcd xhci-hcd.12.auto: new USB bus registered, assigned bus number 2 [ 17.092920] xhci-hcd xhci-hcd.12.auto: Host supports USB 3.0 SuperSpeed [ 17.093014] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01 [ 17.093031] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 17.093043] usb usb1: Product: xHCI Host Controller [ 17.093053] usb usb1: Manufacturer: Linux 6.1.115-vendor-rk35xx xhci-hcd [ 17.093064] usb usb1: SerialNumber: xhci-hcd.12.auto [ 17.093386] hub 1-0:1.0: USB hub found [ 17.093412] hub 1-0:1.0: 1 port detected [ 17.093604] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 17.093672] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01 [ 17.093687] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 17.093699] usb usb2: Product: xHCI Host Controller [ 17.093709] usb usb2: Manufacturer: Linux 6.1.115-vendor-rk35xx xhci-hcd [ 17.093719] usb usb2: SerialNumber: xhci-hcd.12.auto [ 17.093981] hub 2-0:1.0: USB hub found [ 17.094005] hub 2-0:1.0: 1 port detected [ 17.094125] ehci-platform fc800000.usb: EHCI Host Controller [ 17.094135] ohci-platform fc840000.usb: Generic Platform OHCI controller [ 17.094173] ehci-platform fc800000.usb: new USB bus registered, assigned bus number 3 [ 17.094174] ohci-platform fc840000.usb: new USB bus registered, assigned bus number 4 [ 17.094191] ehci-platform fc880000.usb: EHCI Host Controller [ 17.094203] ehci-platform fc880000.usb: new USB bus registered, assigned bus number 5 [ 17.094221] usbcore: registered new interface driver cdc_acm [ 17.094220] ohci-platform fc8c0000.usb: Generic Platform OHCI controller [ 17.094231] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 17.094240] ohci-platform fc840000.usb: irq 89, io mem 0xfc840000 [ 17.094267] ehci-platform fc800000.usb: irq 87, io mem 0xfc800000 [ 17.094266] ohci-platform fc8c0000.usb: new USB bus registered, assigned bus number 6 [ 17.094283] ehci-platform fc880000.usb: irq 88, io mem 0xfc880000 [ 17.094374] usbcore: registered new interface driver uas [ 17.094393] ohci-platform fc8c0000.usb: irq 90, io mem 0xfc8c0000 [ 17.094417] usbcore: registered new interface driver usb-storage [ 17.094723] mousedev: PS/2 mouse device common for all mice [ 17.095302] .. rk pwm remotectl v2.0 init [ 17.095448] input: febf0030.pwm as /devices/platform/febf0030.pwm/input/input2 [ 17.095659] remotectl-pwm febf0030.pwm: Controller support pwrkey capture [ 17.095892] i2c_dev: i2c /dev entries driver [ 17.106548] ehci-platform fc800000.usb: USB 2.0 started, EHCI 1.00 [ 17.106740] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01 [ 17.106758] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 17.106771] usb usb3: Product: EHCI Host Controller [ 17.106781] usb usb3: Manufacturer: Linux 6.1.115-vendor-rk35xx ehci_hcd [ 17.106791] usb usb3: SerialNumber: fc800000.usb [ 17.107120] hub 3-0:1.0: USB hub found [ 17.107157] hub 3-0:1.0: 1 port detected [ 17.119879] ehci-platform fc880000.usb: USB 2.0 started, EHCI 1.00 [ 17.120221] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01 [ 17.120267] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 17.120300] usb usb5: Product: EHCI Host Controller [ 17.120335] usb usb5: Manufacturer: Linux 6.1.115-vendor-rk35xx ehci_hcd [ 17.120363] usb usb5: SerialNumber: fc880000.usb [ 17.120868] hub 5-0:1.0: USB hub found [ 17.120919] hub 5-0:1.0: 1 port detected [ 17.127739] rtc-hym8563 6-0051: rtc information is valid [ 17.130401] rtc-hym8563 6-0051: registered as rtc0 [ 17.130688] rtc-hym8563 6-0051: setting system clock to 2021-01-01T12:03:53 UTC (1609502633) [ 17.132176] rkcifhw fdce0000.rkcif: Adding to iommu group 16 [ 17.133045] rkcifhw fdce0000.rkcif: No reserved memory region assign to CIF [ 17.133815] rockchip-mipi-csi2-hw fdd10000.mipi0-csi2-hw: enter mipi csi2 hw probe! [ 17.133938] rockchip-mipi-csi2-hw fdd10000.mipi0-csi2-hw: probe success, v4l2_dev:mipi0-csi2-hw! [ 17.133986] rockchip-mipi-csi2-hw fdd20000.mipi1-csi2-hw: enter mipi csi2 hw probe! [ 17.134073] rockchip-mipi-csi2-hw fdd20000.mipi1-csi2-hw: probe success, v4l2_dev:mipi1-csi2-hw! [ 17.134116] rockchip-mipi-csi2-hw fdd30000.mipi2-csi2-hw: enter mipi csi2 hw probe! [ 17.134200] rockchip-mipi-csi2-hw fdd30000.mipi2-csi2-hw: probe success, v4l2_dev:mipi2-csi2-hw! [ 17.134242] rockchip-mipi-csi2-hw fdd40000.mipi3-csi2-hw: enter mipi csi2 hw probe! [ 17.134325] rockchip-mipi-csi2-hw fdd40000.mipi3-csi2-hw: probe success, v4l2_dev:mipi3-csi2-hw! [ 17.134366] rockchip-mipi-csi2-hw fdd50000.mipi4-csi2-hw: enter mipi csi2 hw probe! [ 17.134447] rockchip-mipi-csi2-hw fdd50000.mipi4-csi2-hw: probe success, v4l2_dev:mipi4-csi2-hw! [ 17.134488] rockchip-mipi-csi2-hw fdd60000.mipi5-csi2-hw: enter mipi csi2 hw probe! [ 17.134571] rockchip-mipi-csi2-hw fdd60000.mipi5-csi2-hw: probe success, v4l2_dev:mipi5-csi2-hw! [ 17.135646] rkisp_hw fdcb0000.rkisp: Adding to iommu group 15 [ 17.135752] rkisp_hw fdcb0000.rkisp: is_thunderboot: 0 [ 17.135764] rkisp_hw fdcb0000.rkisp: Missing rockchip,grf property [ 17.135785] rkisp_hw fdcb0000.rkisp: max input:0x0@0fps [ 17.135908] rkisp_hw fdcb0000.rkisp: no find phandle sram [ 17.137135] usbcore: registered new interface driver uvcvideo [ 17.138844] cpu cpu0: bin=0 [ 17.139033] cpu cpu0: leakage=12 [ 17.140485] cpu cpu0: pvtm=1415 [ 17.140639] cpu cpu0: pvtm-volt-sel=1 [ 17.142692] cpu cpu4: bin=0 [ 17.142876] cpu cpu4: leakage=9 [ 17.149519] cpu cpu4: pvtm=1633 [ 17.153602] cpu cpu4: pvtm-volt-sel=2 [ 17.154125] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01 [ 17.154175] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 17.154209] usb usb6: Product: Generic Platform OHCI controller [ 17.154236] usb usb6: Manufacturer: Linux 6.1.115-vendor-rk35xx ohci_hcd [ 17.154263] usb usb6: SerialNumber: fc8c0000.usb [ 17.154806] hub 6-0:1.0: USB hub found [ 17.154880] hub 6-0:1.0: 1 port detected [ 17.156435] cpu cpu6: bin=0 [ 17.156619] cpu cpu6: leakage=9 [ 17.157284] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01 [ 17.157304] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 17.157316] usb usb4: Product: Generic Platform OHCI controller [ 17.157326] usb usb4: Manufacturer: Linux 6.1.115-vendor-rk35xx ohci_hcd [ 17.157337] usb usb4: SerialNumber: fc840000.usb [ 17.157593] hub 4-0:1.0: USB hub found [ 17.157618] hub 4-0:1.0: 1 port detected [ 17.163211] cpu cpu6: pvtm=1620 [ 17.167264] cpu cpu6: pvtm-volt-sel=2 [ 17.169311] cpu cpu0: avs=0 [ 17.169371] cpu cpu0: rockchip_pvtpll_set_volt_sel: error cfg clk_id=0 voltsel (-1) [ 17.170661] cpu cpu4: avs=0 [ 17.170714] cpu cpu4: rockchip_pvtpll_set_volt_sel: error cfg clk_id=2 voltsel (-1) [ 17.171817] cpu cpu6: avs=0 [ 17.171871] cpu cpu6: rockchip_pvtpll_set_volt_sel: error cfg clk_id=3 voltsel (-1) [ 17.171980] cpu cpu0: l=15000 h=85000 hyst=5000 l_limit=0 h_limit=1608000000 h_table=0 [ 17.172346] cpu cpu0: EM: created perf domain [ 17.172801] cpu cpu4: l=15000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0 [ 17.181309] cpu cpu4: EM: created perf domain [ 17.181880] cpu cpu6: l=15000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0 [ 17.191235] cpu cpu6: EM: created perf domain [ 17.191709] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.192109] rk-pcie fe180000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.198244] sdhci: Secure Digital Host Controller Interface driver [ 17.198283] sdhci: Copyright(c) Pierre Ossman [ 17.198304] Synopsys Designware Multimedia Card Interface Driver [ 17.199227] sdhci-pltfm: SDHCI platform and OF driver helper [ 17.200341] dwmmc_rockchip fe2c0000.mmc: No normal pinctrl state [ 17.200382] dwmmc_rockchip fe2c0000.mmc: No idle pinctrl state [ 17.200471] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode. [ 17.200513] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller. [ 17.200541] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a [ 17.200611] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 118,32 bit host data width,256 deep fifo [ 17.202407] mmc0: CQHCI version 5.10 [ 17.202927] ledtrig-cpu: registered to indicate activity on CPUs [ 17.202984] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active. [ 17.203043] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 17.203954] cryptodev: driver 1.12 loaded. [ 17.204005] hid: raw HID events driver (C) Jiri Kosina [ 17.204223] usbcore: registered new interface driver usbhid [ 17.204241] usbhid: USB HID core driver [ 17.207705] rk-pcie fe150000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.210156] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42600 [ 17.210188] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42602 [ 17.210206] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42605 [ 17.210223] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42622 [ 17.210699] optee: probing for conduit method. [ 17.210719] optee: api uid mismatch [ 17.210731] optee: probe of firmware:optee failed with error -22 [ 17.211532] usbcore: registered new interface driver snd-usb-audio [ 17.212221] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 17.214974] [Awinic] aw87xxx_pa_init:driver version: v2.2.0 [ 17.216655] rockchip-i2s-tdm fddf0000.i2s: CLK-ALWAYS-ON: mclk: 12288000, bclk: 3072000, fsync: 48000 [ 17.217536] rockchip-i2s-tdm fe470000.i2s: Register PCM for TRCM mode [ 17.218219] rockchip-i2s-tdm fddf4000.i2s: CLK-ALWAYS-ON: mclk: 12288000, bclk: 3072000, fsync: 48000 [ 17.218428] rockchip-i2s-tdm fddf8000.i2s: Init RX wait-time-ms: 50 [ 17.220863] debugfs: File 'Capture' in directory 'dapm' already present! [ 17.221896] input: rockchip-dp0 rockchip-dp0 as /devices/platform/dp0-sound/sound/card0/input3 [ 17.223005] input: rockchip-hdmi0 rockchip-hdmi0 as /devices/platform/hdmi0-sound/sound/card1/input4 [ 17.223839] input: rockchip-hdmi1 rockchip-hdmi1 as /devices/platform/hdmi1-sound/sound/card2/input5 [ 17.224333] input: headset-keys as /devices/platform/es8388-sound/input/input6 [ 17.228832] rk-pcie fe150000.pcie: PCIe Linking... LTSSM is 0x210022 [ 17.233792] mmc0: SDHCI controller on fe2e0000.mmc [fe2e0000.mmc] using ADMA [ 17.253053] rk-pcie fe170000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.266722] rk-pcie fe180000.pcie: PCIe Link up, LTSSM is 0x130011 [ 17.266775] rk-pcie fe180000.pcie: PCIe Gen.2 x1 link up [ 17.266822] rk-pcie fe190000.pcie: PCIe Link up, LTSSM is 0x130011 [ 17.266876] rk-pcie fe190000.pcie: PCIe Gen.2 x1 link up [ 17.267011] rk-pcie fe180000.pcie: PCI host bridge to bus 0003:30 [ 17.267046] pci_bus 0003:30: root bus resource [bus 30-3f] [ 17.267075] pci_bus 0003:30: root bus resource [io 0x100000-0x1fffff] (bus address [0xf3100000-0xf31fffff]) [ 17.267108] pci_bus 0003:30: root bus resource [mem 0xf3200000-0xf3ffffff] [ 17.267114] rk-pcie fe190000.pcie: PCI host bridge to bus 0004:40 [ 17.267128] pci_bus 0003:30: root bus resource [mem 0x9c0000000-0x9ffffffff pref] [ 17.267144] pci_bus 0004:40: root bus resource [bus 40-4f] [ 17.267186] pci 0003:30:00.0: [1d87:3588] type 01 class 0x060400 [ 17.267201] pci_bus 0004:40: root bus resource [io 0x0000-0xfffff] (bus address [0xf4100000-0xf41fffff]) [ 17.267229] pci 0003:30:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref] [ 17.267243] pci_bus 0004:40: root bus resource [mem 0xf4200000-0xf4ffffff] [ 17.267283] pci_bus 0004:40: root bus resource [mem 0xa00000000-0xa3fffffff pref] [ 17.267313] pci 0003:30:00.0: supports D1 D2 [ 17.267340] pci 0003:30:00.0: PME# supported from D0 D1 D3hot [ 17.267338] pci 0004:40:00.0: [1d87:3588] type 01 class 0x060400 [ 17.267400] pci 0004:40:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref] [ 17.267484] pci 0004:40:00.0: supports D1 D2 [ 17.267508] pci 0004:40:00.0: PME# supported from D0 D1 D3hot [ 17.274238] rk-pcie fe170000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.285932] pci 0003:30:00.0: Primary bus is hard wired to 0 [ 17.285949] pci 0003:30:00.0: bridge configuration invalid ([bus 01-ff]), reconfiguring [ 17.286042] pci 0004:40:00.0: Primary bus is hard wired to 0 [ 17.286054] pci 0004:40:00.0: bridge configuration invalid ([bus 01-ff]), reconfiguring [ 17.286074] pci 0003:31:00.0: [10ec:8125] type 00 class 0x020000 [ 17.286134] pci 0003:31:00.0: reg 0x10: [io 0x0000-0x00ff] [ 17.286236] pci 0004:41:00.0: [10ec:8125] type 00 class 0x020000 [ 17.286247] pci 0003:31:00.0: reg 0x18: [mem 0x00000000-0x0000ffff 64bit] [ 17.286326] pci 0004:41:00.0: reg 0x10: initial BAR value 0x00000000 invalid [ 17.286330] pci 0003:31:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit] [ 17.286338] pci 0004:41:00.0: reg 0x10: [io size 0x0100] [ 17.286452] pci 0004:41:00.0: reg 0x18: [mem 0x00000000-0x0000ffff 64bit] [ 17.286530] pci 0004:41:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit] [ 17.287035] pci 0003:31:00.0: supports D1 D2 [ 17.287046] pci 0003:31:00.0: PME# supported from D0 D1 D2 D3hot D3cold [ 17.287104] input: rockchip-es8388 Headset as /devices/platform/es8388-sound/sound/card3/input7 [ 17.287133] pci 0004:41:00.0: supports D1 D2 [ 17.287138] pci 0004:41:00.0: PME# supported from D0 D1 D2 D3hot D3cold [ 17.295300] rk-pcie fe170000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.296615] pci_bus 0003:31: busn_res: [bus 31-3f] end is updated to 31 [ 17.296637] pci 0003:30:00.0: BAR 8: assigned [mem 0xf3200000-0xf32fffff] [ 17.296644] pci 0003:30:00.0: BAR 6: assigned [mem 0xf3300000-0xf330ffff pref] [ 17.296650] pci 0003:30:00.0: BAR 7: assigned [io 0x100000-0x100fff] [ 17.296657] pci 0003:31:00.0: BAR 2: assigned [mem 0xf3200000-0xf320ffff 64bit] [ 17.296687] pci 0003:31:00.0: BAR 4: assigned [mem 0xf3210000-0xf3213fff 64bit] [ 17.296718] pci 0003:31:00.0: BAR 0: assigned [io 0x100000-0x1000ff] [ 17.296730] pci 0003:30:00.0: PCI bridge to [bus 31] [ 17.296735] pci 0003:30:00.0: bridge window [io 0x100000-0x100fff] [ 17.296741] pci 0003:30:00.0: bridge window [mem 0xf3200000-0xf32fffff] [ 17.297536] pcieport 0003:30:00.0: PME: Signaling with IRQ 135 [ 17.302780] mmc_host mmc1: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0) [ 17.306649] rk-pcie fe150000.pcie: PCIe Link up, LTSSM is 0x230011 [ 17.306685] rk-pcie fe150000.pcie: PCIe Gen.3 x4 link up [ 17.306760] pci_bus 0004:41: busn_res: [bus 41-4f] end is updated to 41 [ 17.306809] pci 0004:40:00.0: BAR 8: assigned [mem 0xf4200000-0xf42fffff] [ 17.306832] pci 0004:40:00.0: BAR 6: assigned [mem 0xf4300000-0xf430ffff pref] [ 17.306849] rk-pcie fe150000.pcie: PCI host bridge to bus 0000:00 [ 17.306853] pci 0004:40:00.0: BAR 7: assigned [io 0x1000-0x1fff] [ 17.306866] pci_bus 0000:00: root bus resource [bus 00-0f] [ 17.306876] pci_bus 0000:00: root bus resource [io 0x200000-0x2fffff] (bus address [0xf0100000-0xf01fffff]) [ 17.306883] pci_bus 0000:00: root bus resource [mem 0xf0200000-0xf0ffffff] [ 17.306901] pci 0004:41:00.0: BAR 2: assigned [mem 0xf4200000-0xf420ffff 64bit] [ 17.306909] pci_bus 0000:00: root bus resource [mem 0x900000000-0x93fffffff pref] [ 17.306947] pci 0004:41:00.0: BAR 4: assigned [mem 0xf4210000-0xf4213fff 64bit] [ 17.306965] pci 0000:00:00.0: [1d87:3588] type 01 class 0x060400 [ 17.306998] pci 0004:41:00.0: BAR 0: assigned [io 0x1000-0x10ff] [ 17.307007] pci 0000:00:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref] [ 17.307026] pci 0004:40:00.0: PCI bridge to [bus 41] [ 17.307045] pci 0004:40:00.0: bridge window [io 0x1000-0x1fff] [ 17.307065] pci 0004:40:00.0: bridge window [mem 0xf4200000-0xf42fffff] [ 17.307072] pci 0000:00:00.0: supports D1 D2 [ 17.307078] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [ 17.310864] Initializing XFRM netlink socket [ 17.310895] NET: Registered PF_PACKET protocol family [ 17.311074] [BT_RFKILL]: Enter rfkill_rk_init [ 17.311079] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 17.314541] pcieport 0004:40:00.0: PME: Signaling with IRQ 145 [ 17.316392] rk-pcie fe170000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.316925] pci_bus 0000:01: busn_res: can not insert [bus 01-ff] under [bus 00-0f] (conflicts with (null) [bus 00-0f]) [ 17.317003] pci 0000:01:00.0: [c0a9:5427] type 00 class 0x010802 [ 17.317047] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ 17.317064] [WLAN_RFKILL]: can't find rockchip,grf property [ 17.317069] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6275p [ 17.317073] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ 17.317071] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit] [ 17.317078] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [ 17.317103] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 8, flags = 0. [ 17.317112] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found ! [ 17.317116] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ 17.317121] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1 [ 17.317126] [WLAN_RFKILL]: Exit rfkill_wlan_probe [ 17.317391] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 148. [ 17.317411] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 21. [ 17.317425] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 150. [ 17.317439] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 0. [ 17.317468] [BT_RFKILL]: Request irq for bt wakeup host [ 17.317510] pci 0000:01:00.0: 31.504 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x4 link at 0000:00:00.0 (capable of 63.012 Gb/s with 16.0 GT/s PCIe x4 link) [ 17.317657] [BT_RFKILL]: ** disable irq [ 17.317702] [BT_RFKILL]: bt shut off power [ 17.326625] pci 0000:00:00.0: BAR 8: assigned [mem 0xf0200000-0xf02fffff] [ 17.326659] pci 0000:00:00.0: BAR 6: assigned [mem 0xf0300000-0xf030ffff pref] [ 17.326686] pci 0000:01:00.0: BAR 0: assigned [mem 0xf0200000-0xf0203fff 64bit] [ 17.326729] pci 0000:00:00.0: PCI bridge to [bus 01-ff] [ 17.326747] pci 0000:00:00.0: bridge window [mem 0xf0200000-0xf02fffff] [ 17.328210] pcieport 0000:00:00.0: PME: Signaling with IRQ 156 [ 17.328517] nvme nvme0: pci function 0000:01:00.0 [ 17.328614] nvme 0000:01:00.0: enabling device (0000 -> 0002) [ 17.336856] rk-pcie fe170000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.343221] usb 1-1: new high-speed USB device number 2 using xhci-hcd [ 17.343263] [BT_RFKILL]: bt_default device registered. [ 17.343442] input: bt-powerkey as /devices/platform/wireless-bluetooth/input/input8 [ 17.343902] Key type dns_resolver registered [ 17.343955] Key type ceph registered [ 17.344580] libceph: loaded (mon/osd proto 15/24) [ 17.347220] registered taskstats version 1 [ 17.347271] Loading compiled-in X.509 certificates [ 17.351701] zswap: loaded using pool zstd/zbud [ 17.352322] Key type .fscrypt registered [ 17.352341] Key type fscrypt-provisioning registered [ 17.353408] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no [ 17.354271] pstore: Using crash dump compression: deflate [ 17.354796] Key type encrypted registered [ 17.355144] AppArmor: AppArmor sha1 policy hashing enabled [ 17.357936] rk-pcie fe170000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.368673] rga3 fdb60000.rga: Adding to iommu group 2 [ 17.369476] rga3 fdb60000.rga: probe successfully, irq = 50, hw_version:3.0.76831 [ 17.369736] rga3 fdb70000.rga: Adding to iommu group 3 [ 17.370447] rga3 fdb70000.rga: probe successfully, irq = 51, hw_version:3.0.76831 [ 17.371705] rga2 fdb80000.rga: probe successfully, irq = 158, hw_version:3.2.63318 [ 17.372080] rga: IOMMU binding successfully, default mapping core[0x1] [ 17.372305] rga: Module initialized. v1.3.7 [ 17.411406] mpp_vdpu1 fdb51000.avsd-plus: Adding to iommu group 1 [ 17.411965] mpp_vdpu1 fdb51000.avsd-plus: probe device [ 17.412347] mpp_vdpu1 fdb51000.avsd-plus: reset_group->rw_sem_on=0 [ 17.412388] mpp_vdpu1 fdb51000.avsd-plus: reset_group->rw_sem_on=0 [ 17.412509] mpp_vdpu1 fdb51000.avsd-plus: probing finish [ 17.412897] mpp_vdpu2 fdb50400.vdpu: Adding to iommu group 1 [ 17.413012] mpp_vdpu2 fdb50400.vdpu: probe device [ 17.413316] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0 [ 17.413350] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0 [ 17.413392] mpp_vdpu2 fdb50400.vdpu: probing finish [ 17.413725] mpp_vepu2 fdb50000.vepu: Adding to iommu group 1 [ 17.413838] mpp_vepu2 fdb50000.vepu: probing start [ 17.414117] mpp_vepu2 fdb50000.vepu: reset_group->rw_sem_on=0 [ 17.414148] mpp_vepu2 fdb50000.vepu: reset_group->rw_sem_on=0 [ 17.414217] mpp_vepu2 fdb50000.vepu: probing finish [ 17.414574] mpp_vepu2 fdba0000.jpege-core: Adding to iommu group 5 [ 17.414766] mpp_vepu2 fdba0000.jpege-core: probing start [ 17.414982] mpp_vepu2 fdba0000.jpege-core: attach ccu success [ 17.415004] mpp_vepu2 fdba0000.jpege-core: probing finish [ 17.415090] mpp_vepu2 fdba4000.jpege-core: Adding to iommu group 6 [ 17.415160] mpp_vepu2 fdba4000.jpege-core: probing start [ 17.415245] mpp_vepu2 fdba4000.jpege-core: attach ccu success [ 17.415265] mpp_vepu2 fdba4000.jpege-core: probing finish [ 17.415372] mpp_vepu2 fdba8000.jpege-core: Adding to iommu group 7 [ 17.415444] mpp_vepu2 fdba8000.jpege-core: probing start [ 17.415527] mpp_vepu2 fdba8000.jpege-core: attach ccu success [ 17.415545] mpp_vepu2 fdba8000.jpege-core: probing finish [ 17.415654] mpp_vepu2 fdbac000.jpege-core: Adding to iommu group 8 [ 17.415723] mpp_vepu2 fdbac000.jpege-core: probing start [ 17.415808] mpp_vepu2 fdbac000.jpege-core: attach ccu success [ 17.415828] mpp_vepu2 fdbac000.jpege-core: probing finish [ 17.415938] mpp-iep2 fdbb0000.iep: Adding to iommu group 9 [ 17.416016] mpp-iep2 fdbb0000.iep: probe device [ 17.416595] mpp-iep2 fdbb0000.iep: probing finish [ 17.416782] mpp_jpgdec fdb90000.jpegd: Adding to iommu group 4 [ 17.416978] mpp_jpgdec fdb90000.jpegd: probe device [ 17.417155] mpp_jpgdec fdb90000.jpegd: probing finish [ 17.417324] mpp_rkvdec2 fdc38100.rkvdec-core: Adding to iommu group 12 [ 17.417576] mpp_rkvdec2 fdc38100.rkvdec-core: rkvdec-core, probing start [ 17.417692] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found! [ 17.417700] rkvdec2_init:1198: No niu aclk reset resource define [ 17.417706] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found! [ 17.417712] rkvdec2_init:1201: No niu hclk reset resource define [ 17.419384] mpp_rkvdec2 fdc38100.rkvdec-core: no regulator, devfreq is disabled [ 17.419454] mpp_rkvdec2 fdc38100.rkvdec-core: core_mask=00010001 [ 17.419461] mpp_rkvdec2 fdc38100.rkvdec-core: attach ccu as core 0 [ 17.419580] mpp_rkvdec2 fdc38100.rkvdec-core: sram_start 0x00000000ff001000 [ 17.419587] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_iova 0x00000000fff00000 [ 17.419592] mpp_rkvdec2 fdc38100.rkvdec-core: sram_size 491520 [ 17.419597] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_size 1048576 [ 17.419603] mpp_rkvdec2 fdc38100.rkvdec-core: min_width 512 [ 17.419609] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_info_count 20 [ 17.419614] mpp_rkvdec2 fdc38100.rkvdec-core: [136, 24576] [ 17.419619] mpp_rkvdec2 fdc38100.rkvdec-core: [137, 49152] [ 17.419625] mpp_rkvdec2 fdc38100.rkvdec-core: [141, 90112] [ 17.419630] mpp_rkvdec2 fdc38100.rkvdec-core: [140, 49152] [ 17.419635] mpp_rkvdec2 fdc38100.rkvdec-core: [139, 180224] [ 17.419640] mpp_rkvdec2 fdc38100.rkvdec-core: [133, 49152] [ 17.419645] mpp_rkvdec2 fdc38100.rkvdec-core: [134, 8192] [ 17.419650] mpp_rkvdec2 fdc38100.rkvdec-core: [135, 4352] [ 17.419655] mpp_rkvdec2 fdc38100.rkvdec-core: [138, 13056] [ 17.419661] mpp_rkvdec2 fdc38100.rkvdec-core: [142, 291584] [ 17.419683] mpp_rkvdec2 fdc38100.rkvdec-core: probing finish [ 17.419776] mpp_rkvdec2 fdc48100.rkvdec-core: Adding to iommu group 13 [ 17.419943] mpp_rkvdec2 fdc48100.rkvdec-core: rkvdec-core, probing start [ 17.420028] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found! [ 17.420034] rkvdec2_init:1198: No niu aclk reset resource define [ 17.420040] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found! [ 17.420045] rkvdec2_init:1201: No niu hclk reset resource define [ 17.420070] mpp_rkvdec2 fdc48100.rkvdec-core: no regulator, devfreq is disabled [ 17.420099] mpp_rkvdec2 fdc48100.rkvdec-core: core_mask=00020002 [ 17.420116] mpp_rkvdec2 fdc48100.rkvdec-core: attach ccu as core 1 [ 17.420234] mpp_rkvdec2 fdc48100.rkvdec-core: sram_start 0x00000000ff079000 [ 17.420241] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_iova 0x00000000ffe00000 [ 17.420246] mpp_rkvdec2 fdc48100.rkvdec-core: sram_size 487424 [ 17.420251] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_size 1048576 [ 17.420256] mpp_rkvdec2 fdc48100.rkvdec-core: min_width 512 [ 17.420263] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_info_count 20 [ 17.420268] mpp_rkvdec2 fdc48100.rkvdec-core: [136, 24576] [ 17.420273] mpp_rkvdec2 fdc48100.rkvdec-core: [137, 49152] [ 17.420278] mpp_rkvdec2 fdc48100.rkvdec-core: [141, 90112] [ 17.420283] mpp_rkvdec2 fdc48100.rkvdec-core: [140, 49152] [ 17.420288] mpp_rkvdec2 fdc48100.rkvdec-core: [139, 180224] [ 17.420293] mpp_rkvdec2 fdc48100.rkvdec-core: [133, 49152] [ 17.420298] mpp_rkvdec2 fdc48100.rkvdec-core: [134, 8192] [ 17.420303] mpp_rkvdec2 fdc48100.rkvdec-core: [135, 4352] [ 17.420308] mpp_rkvdec2 fdc48100.rkvdec-core: [138, 13056] [ 17.420313] mpp_rkvdec2 fdc48100.rkvdec-core: [142, 291584] [ 17.420334] mpp_rkvdec2 fdc48100.rkvdec-core: probing finish [ 17.420437] mpp_rkvenc2 fdbd0000.rkvenc-core: Adding to iommu group 10 [ 17.420538] mpp_rkvenc2 fdbd0000.rkvenc-core: probing start [ 17.420645] mpp_rkvenc2 fdbd0000.rkvenc-core: rockchip_init_read_margin: no regulator (venc) found: -19 [ 17.420653] mpp_rkvenc2 fdbd0000.rkvenc-core: bin=0 [ 17.420840] mpp_rkvenc2 fdbd0000.rkvenc-core: leakage=11 [ 17.420847] mpp_rkvenc2 fdbd0000.rkvenc-core: leakage-volt-sel=0 [ 17.420897] mpp_rkvenc2 fdbd0000.rkvenc-core: error -ENODEV: _opp_set_regulators: no regulator (venc) found [ 17.420916] mpp_rkvenc2 fdbd0000.rkvenc-core: failed to set opp config [ 17.420922] mpp_rkvenc2 fdbd0000.rkvenc-core: failed to init opp info [ 17.420927] mpp_rkvenc2 fdbd0000.rkvenc-core: failed to init_opp_table [ 17.420931] rkvenc_init:2147: failed to add venc devfreq [ 17.420954] mpp_rkvenc2 fdbd0000.rkvenc-core: attach ccu as core 0 [ 17.420973] mpp_rkvenc2 fdbd0000.rkvenc-core: probing finish [ 17.421052] mpp_rkvenc2 fdbe0000.rkvenc-core: Adding to iommu group 11 [ 17.421155] mpp_rkvenc2 fdbe0000.rkvenc-core: probing start [ 17.421249] mpp_rkvenc2 fdbe0000.rkvenc-core: rockchip_init_read_margin: no regulator (venc) found: -19 [ 17.421256] mpp_rkvenc2 fdbe0000.rkvenc-core: bin=0 [ 17.421425] mpp_rkvenc2 fdbe0000.rkvenc-core: leakage=11 [ 17.421445] mpp_rkvenc2 fdbe0000.rkvenc-core: leakage-volt-sel=0 [ 17.421474] mpp_rkvenc2 fdbe0000.rkvenc-core: error -ENODEV: _opp_set_regulators: no regulator (venc) found [ 17.421486] mpp_rkvenc2 fdbe0000.rkvenc-core: failed to set opp config [ 17.421491] mpp_rkvenc2 fdbe0000.rkvenc-core: failed to init opp info [ 17.421496] mpp_rkvenc2 fdbe0000.rkvenc-core: failed to init_opp_table [ 17.421501] rkvenc_init:2147: failed to add venc devfreq [ 17.421540] mpp_rkvenc2 fdbe0000.rkvenc-core: attach ccu as core 1 [ 17.421556] mpp_rkvenc2 fdbe0000.rkvenc-core: probing finish [ 17.421642] mpp_av1dec fdc70000.av1d: Adding to iommu group 14 [ 17.421788] mpp_av1dec fdc70000.av1d: probing start [ 17.421892] mpp_av1dec fdc70000.av1d: probing finish [ 17.422332] rockchip-dmc dmc: bin=0 [ 17.422343] mali fb000000.gpu: Kernel DDK version g25p0-00eac0 [ 17.422462] mali fb000000.gpu: GPU metrics tracepoint support enabled [ 17.422502] rockchip-dmc dmc: leakage=35 [ 17.422546] rockchip-dmc dmc: leakage-volt-sel=1 [ 17.422553] rockchip-dmc dmc: soc version=0, speed=1 [ 17.423430] rockchip-dmc dmc: avs=0 [ 17.423441] rockchip-dmc dmc: current ATF version 0x100 [ 17.423598] rockchip-dmc dmc: normal_rate = 1560000000 [ 17.423605] rockchip-dmc dmc: reboot_rate = 2112000000 [ 17.423610] rockchip-dmc dmc: suspend_rate = 528000000 [ 17.423615] rockchip-dmc dmc: video_4k_rate = 1560000000 [ 17.423620] rockchip-dmc dmc: video_4k_10b_rate = 1560000000 [ 17.423625] rockchip-dmc dmc: video_svep_rate = 1560000000 [ 17.423630] rockchip-dmc dmc: boost_rate = 2112000000 [ 17.423635] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 2112000000 [ 17.423641] rockchip-dmc dmc: performance_rate = 2112000000 [ 17.423646] rockchip-dmc dmc: hdmirx_rate = 2112000000 [ 17.423651] rockchip-dmc dmc: deep_suspend_rate = 2112000000 [ 17.423659] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate [ 17.423664] rockchip-dmc dmc: failed to get vop pn to msch rl [ 17.423884] rockchip-dmc dmc: l=15000 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0 [ 17.425052] mali fb000000.gpu: bin=0 [ 17.425257] mali fb000000.gpu: leakage=14 [ 17.425325] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present! [ 17.426684] WCN: marlin_init entry! [ 17.426706] mali fb000000.gpu: pvtm=816 [ 17.426950] mali fb000000.gpu: pvtm-volt-sel=1 [ 17.427052] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present! [ 17.427460] RKNPU fdab0000.npu: Adding to iommu group 0 [ 17.427576] RKNPU fdab0000.npu: RKNPU: rknpu iommu is enabled, using iommu mode [ 17.428673] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff] [ 17.428697] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff] [ 17.428713] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff] [ 17.428958] [drm] Initialized rknpu 0.9.8 20240828 for fdab0000.npu on minor 1 [ 17.429012] mali fb000000.gpu: avs=0 [ 17.429109] mali fb000000.gpu: rockchip_pvtpll_set_volt_sel: error cfg clk_id=5 voltsel (-1) [ 17.429162] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 144; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available. [ 17.429703] mali fb000000.gpu: Register LUT 000a0800 initialized for GPU arch 0x000a0806 [ 17.429756] mali fb000000.gpu: r0p0 status 5 not found in HW issues table; [ 17.429780] mali fb000000.gpu: falling back to closest match: r0p0 status 0 [ 17.429803] mali fb000000.gpu: Execution proceeding normally with fallback match [ 17.429828] mali fb000000.gpu: GPU identified as 0x7 arch 10.8.6 r0p0 status 0 [ 17.430001] mali fb000000.gpu: CSF_GPU_RESET_TIMEOUT is capped from 20666ms to 4500ms [ 17.430032] mali fb000000.gpu: KBASE_PRFCNT_ACTIVE_TIMEOUT is capped from 40000ms to 4500ms [ 17.430058] mali fb000000.gpu: KBASE_AS_INACTIVE_TIMEOUT is capped from 40000ms to 4500ms [ 17.430083] mali fb000000.gpu: CSF_FIRMWARE_STOP_TIMEOUT is capped from 40000ms to 4500ms [ 17.430193] mali fb000000.gpu: No priority control manager is configured [ 17.430219] mali fb000000.gpu: Large page allocation set to false after hardware feature check [ 17.430617] mali fb000000.gpu: No memory group manager is configured [ 17.430680] mali fb000000.gpu: Protected memory allocator not available [ 17.431315] RKNPU fdab0000.npu: RKNPU: bin=0 [ 17.431519] RKNPU fdab0000.npu: leakage=8 [ 17.431560] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present! [ 17.432338] mali fb000000.gpu: EM: created perf domain [ 17.432948] mali fb000000.gpu: l=15000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0 [ 17.438898] mali fb000000.gpu: * MALI kbase_mmap_min_addr compiled to CONFIG_DEFAULT_MMAP_MIN_ADDR, no runtime update possible! * [ 17.438952] mali fb000000.gpu: Probed as mali0 [ 17.439012] RKNPU fdab0000.npu: pvtm=814 [ 17.446487] dwmmc_rockchip fe2c0000.mmc: Successfully tuned phase to 225 [ 17.446562] mmc1: new ultra high speed SDR104 SDHC card at address aaaa [ 17.447474] mmcblk1: mmc1:aaaa SC16G 14.8 GiB [ 17.450941] RKNPU fdab0000.npu: pvtm-volt-sel=0 [ 17.451086] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present! [ 17.453460] RKNPU fdab0000.npu: avs=0 [ 17.453560] RKNPU fdab0000.npu: rockchip_pvtpll_set_volt_sel: error cfg clk_id=6 voltsel (-1) [ 17.453737] RKNPU fdab0000.npu: l=15000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0 [ 17.455683] GPT:Primary header thinks Alt. header is not at the end of the disk. [ 17.455704] GPT:3235839 != 31116287 [ 17.455713] GPT:Alternate GPT header not at the end of the disk. [ 17.455722] GPT:3235839 != 31116287 [ 17.455729] GPT: Use GNU Parted to correct GPT errors. [ 17.455748] mmcblk1: p1 [ 17.465863] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 17.466942] hwmon hwmon8: temp1_input not attached to any thermal zone [ 17.467045] hwmon hwmon8: temp2_input not attached to any thermal zone [ 17.475432] nvme nvme0: allocated 64 MiB host memory buffer. [ 17.487725] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 17.488498] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600' [ 17.489147] clk: Disabling unused clocks [ 17.489781] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.91 [ 17.489817] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 17.489837] usb 1-1: Product: USB2.1 Hub [ 17.489853] usb 1-1: Manufacturer: GenesysLogic [ 17.490814] rockchip-pm rockchip-suspend: not set pwm-regulator-config [ 17.491810] rockchip-suspend not set sleep-mode-config for mem-lite [ 17.491827] rockchip-suspend not set wakeup-config for mem-lite [ 17.491846] rockchip-suspend not set sleep-mode-config for mem-ultra [ 17.491863] rockchip-suspend not set wakeup-config for mem-ultra [ 17.493567] ALSA device list: [ 17.493584] #0: rockchip-dp0 [ 17.493597] #1: rockchip-hdmi0 [ 17.493610] #2: rockchip-hdmi1 [ 17.493623] #3: rockchip-es8388 [ 17.541575] hub 1-1:1.0: USB hub found [ 17.542058] hub 1-1:1.0: 4 ports detected [ 17.597989] nvme nvme0: 8/0/0 default/read/poll queues [ 17.610482] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd [ 17.632846] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.91 [ 17.632929] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 17.632981] usb 2-1: Product: USB3.2 Hub [ 17.633021] usb 2-1: Manufacturer: GenesysLogic [ 17.653898] hub 2-1:1.0: USB hub found [ 17.654527] hub 2-1:1.0: 4 ports detected [ 17.666492] Freeing unused kernel memory: 8320K [ 17.667221] Run /init as init process [ 18.013752] input: adc-keys as /devices/platform/adc-keys/input/input9 DDR V1.13 25cee80c4f cym 23/08/11-09:31:58 LPDDR4X, 2112MHz channel[0] BW=16 Col=10 Bk=8 CS0 Row=18 CS1 Row=18 CS=2 Die BW=8 Size=8192MB channel[1] BW=16 Col=10 Bk=8 CS0 Row=18 CS1 Row=18 CS=2 Die BW=8 Size=8192MB channel[2] BW=16 Col=10 Bk=8 CS0 Row=18 CS1 Row=18 CS=2 Die BW=8 Size=8192MB channel[3] BW=16 Col=10 Bk=8 CS0 Row=18 CS1 Row=18 CS=2 Die BW=8 Size=8192MB Manufacturer ID:0xff CH0 RX Vref:28.5%, TX Vref:22.8%,21.8% CH1 RX Vref:27.1%, TX Vref:21.8%,20.8% CH2 RX Vref:27.9%, TX Vref:21.8%,21.8% CH3 RX Vref:28.9%, TX Vref:20.8%,20.8% change to F1: 528MHz change to F2: 1068MHz change to F3: 1560MHz change to F0: 2112MHz out U-Boot SPL board init U-Boot SPL 2017.09-orangepi (Nov 15 2023 - 16:53:25) Trying to boot from MMC1 Trying fit image at 0x4000 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(7612223b82...) + OK ## Checking uboot 0x00200000 ... sha256(d41c62e80b...) + OK ## Checking fdt 0x00355940 ... sha256(7146109403...) + OK ## Checking atf-2 0xff100000 ... sha256(70505bb764...) + OK ## Checking atf-3 0x000f0000 ... sha256(b2af21b504...) + OK Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000) Total: 741.510 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-868-g040d2de11:derrick.huang, fwver: v1.48 NOTICE: BL31: Built : 15:02:44, Dec 19 2024 INFO: spec: 0x1 INFO: code: 0x88 INFO: ext 32k is valid INFO: ddr: stride-en 4CH INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0 INFO: l3 cache partition cfg-0 INFO: system boots from cpu-hwid-0 INFO: disable memory repair INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001 INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz INFO: BL31: Initialising Exception Handling Framework INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 usb dr_mode not found usb dr_mode not found U-Boot 2017.09_armbian-2017.09-S3f41-Pdfdd-H6539-Ve691-Bbf55-R448a (Nov 19 2025 - 17:07:00 +0000) Model: Orange Pi 5 Plus MPIDR: 0x0 PreSerial: 2, raw, 0xfeb50000 DRAM: 31.7 GiB Sysmem: init Relocation Offset: eda09000 Relocation fdt: eb9f7610 - eb9fecd0 CR: M/C/I usb dr_mode not found usb dr_mode not found Using default environment DM: v2 RESC: No bootdev Failed to load DTB, ret=-2 No valid DTB, ret=-22 Failed to get kernel dtb, ret=-22 Model: Orange Pi 5 Plus [Vendor ERROR]:Invalid boot device type(0) ## Error: Can't overwrite "ethaddr" ## Error inserting "ethaddr" variable, errno=1 ## Error: Can't overwrite "eth1addr" ## Error inserting "eth1addr" variable, errno=1 [Vendor ERROR]:Invalid boot device type(0) rockchip_set_ethaddr: vendor_storage_write failed -19 [Vendor ERROR]:Invalid boot device type(0) mmc@fe2c0000: 1, mmc@fe2e0000: 0 Card did not respond to voltage select! mmc_init: -95, time 13 switch to partitions #0, OK mmc1 is current device Boot from SDcard Bootdev(scan): mmc 1 No bootdev dev_desc is NULL! boot mode: None No bootdev CLK: (sync kernel. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A) b0pll 24000 KHz b1pll 24000 KHz lpll 24000 KHz v0pll 24000 KHz aupll 24000 KHz cpll 1500000 KHz gpll 1188000 KHz npll 24000 KHz ppll 1100000 KHz aclk_center_root 702000 KHz pclk_center_root 100000 KHz hclk_center_root 396000 KHz aclk_center_low_root 500000 KHz aclk_top_root 750000 KHz pclk_top_root 100000 KHz aclk_low_top_root 396000 KHz MMC1: Legacy, 52Mhz PartType: EFI No bootdev dev_desc is NULL! No bootdev Net: No ethernet found. Hit key to stop autoboot('CTRL+C'): 0 starting USB... Bus usb@fc000000: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus usb@fc800000: USB EHCI 1.00 Bus usb@fc840000: USB OHCI 1.0 Bus usb@fc880000: USB EHCI 1.00 Bus usb@fc8c0000: USB OHCI 1.0 Bus usb@fc400000: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fc000000 for devices... 1 USB Device(s) found scanning bus usb@fc800000 for devices... 1 USB Device(s) found scanning bus usb@fc840000 for devices... 1 USB Device(s) found scanning bus usb@fc880000 for devices... 1 USB Device(s) found scanning bus usb@fc8c0000 for devices... 1 USB Device(s) found scanning bus usb@fc400000 for devices... cannot reset port 1!? 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Device 0: unknown device switch to partitions #0, OK mmc1 is current device Could not find misc partition ANDROID: reboot reason: "(none)" Not AVB images, AVB skip android_image_load_by_partname: Can't find part: boot Android image load failed Android boot failed, error -1. Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 4149 bytes read in 24 ms (168 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1:1 200 bytes read in 23 ms (7.8 KiB/s) 14756344 bytes read in 1221 ms (11.5 MiB/s) 48886272 bytes read in 3965 ms (11.8 MiB/s) 278734 bytes read in 249 ms (1.1 MiB/s) Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' Fdt Ramdisk skip relocation No misc partition ## Loading init Ramdisk from Legacy Image at 0a200000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 14756280 Bytes = 14.1 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 0x08300000 Booting using the fdt blob at 0x08300000 reserving fdt memory region: addr=8300000 size=aa000 Using Device Tree in place at 0000000008300000, end 00000000083acfff ## reserved-memory: cma: addr=10000000 size=10000000 ramoops@110000: addr=110000 size=e0000 Adding bank: 0x00200000 - 0xf0000000 (size: 0xefe00000) Adding bank: 0x100000000 - 0x3fc000000 (size: 0x2fc000000) Adding bank: 0x3fc500000 - 0x3fff00000 (size: 0x03a00000) Adding bank: 0x400000000 - 0x800000000 (size: 0x400000000) Total: 14512.764/14545.751 ms Starting kernel ... [ 14.549110] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [ 14.549137] Linux version 6.1.115-vendor-rk35xx (build@armbian) (aarch64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP Fri Nov 21 14:02:48 UTC 2025 [ 14.557192] Machine model: Orange Pi 5 Plus [ 14.557356] efi: UEFI not found. [ 14.560874] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@0': base 0x0000000000000000, size 0 MiB [ 14.560893] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@0': base 0x0000000000000000, size 0 MiB [ 14.560986] Reserved memory: bypass cma node, using cmdline CMA params instead [ 14.560994] OF: reserved mem: node cma compatible matching fail [ 15.091709] Zone ranges: [ 15.091717] DMA [mem 0x0000000000200000-0x00000000ffffffff] [ 15.091728] DMA32 empty [ 15.091733] Normal [mem 0x0000000100000000-0x00000007ffffffff] [ 15.091740] Movable zone start for each node [ 15.091742] Early memory node ranges [ 15.091744] node 0: [mem 0x0000000000200000-0x00000000efffffff] [ 15.091753] node 0: [mem 0x0000000100000000-0x00000003fbffffff] [ 15.091762] node 0: [mem 0x00000003fc500000-0x00000003ffefffff] [ 15.091767] node 0: [mem 0x0000000400000000-0x00000007ffffffff] [ 15.091779] Initmem setup node 0 [mem 0x0000000000200000-0x00000007ffffffff] [ 15.112139] On node 0, zone DMA: 512 pages in unavailable ranges [ 15.177227] On node 0, zone Normal: 1280 pages in unavailable ranges [ 15.263945] On node 0, zone Normal: 256 pages in unavailable ranges [ 15.263976] cma: Reserved 256 MiB at 0x00000000e0000000 [ 15.264171] psci: probing for conduit method from DT. [ 15.264180] psci: PSCIv1.1 detected in firmware. [ 15.264186] psci: Using standard PSCI v0.2 function IDs [ 15.264191] psci: MIGRATE_INFO_TYPE not supported. [ 15.264232] psci: SMC Calling Convention v1.2 [ 15.264621] percpu: Embedded 30 pages/cpu s82728 r8192 d31960 u122880 [ 15.264826] Detected VIPT I-cache on CPU0 [ 15.264880] CPU features: detected: GIC system register CPU interface [ 15.264884] CPU features: detected: Virtualization Host Extensions [ 15.264899] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009 [ 15.264903] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 15.264909] alternatives: applying boot alternatives [ 15.265448] Built 1 zonelists, mobility grouping on. Total pages: 8190984 [ 15.265462] Kernel command line: root=UUID=21f59e6d-0e11-4ba2-85d3-e5fab5604f14 rootwait rootfstype=ext4 splash=verbose console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=7 ubootpart=f09d1995-765c-164f-bbae-c1ba9ef9a944 usb-storage.quirks= cma=256M cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory androidboot.fwver=bl31-v1.48,uboot-rmbian-201-11/19/2025 [ 15.265987] Unknown kernel command line parameters "splash=verbose ubootpart=f09d1995-765c-164f-bbae-c1ba9ef9a944 cgroup_enable=memory cgroup_memory=1", will be passed to user space. [ 15.269048] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear) [ 15.270582] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear) [ 15.270591] mem auto-init: stack:off, heap alloc:off, heap free:off [ 15.270597] software IO TLB: area num 8. [ 15.283145] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB) [ 15.541302] Memory: 32255616K/33284096K available (19072K kernel code, 4028K rwdata, 16148K rodata, 8320K init, 700K bss, 766336K reserved, 262144K cma-reserved) [ 15.541467] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1 [ 15.541506] ftrace: allocating 72100 entries in 282 pages [ 15.670160] ftrace: allocated 282 pages with 4 groups [ 15.670271] trace event string verifier disabled [ 15.670499] rcu: Hierarchical RCU implementation. [ 15.670504] rcu: RCU event tracing is enabled. [ 15.670508] Rude variant of Tasks RCU enabled. [ 15.670510] Tracing variant of Tasks RCU enabled. [ 15.670514] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies. [ 15.688489] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 15.691607] GICv3: GIC: Using split EOI/Deactivate mode [ 15.691613] GICv3: 480 SPIs implemented [ 15.691617] GICv3: 0 Extended SPIs implemented [ 15.691648] Root IRQ handler: gic_handle_irq [ 15.691664] GICv3: GICv3 features: 16 PPIs [ 15.691707] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000 [ 15.692106] ITS [mem 0xfe640000-0xfe65ffff] [ 15.692163] ITS@0x00000000fe640000: allocated 8192 Devices @100170000 (indirect, esz 8, psz 64K, shr 0) [ 15.692196] ITS@0x00000000fe640000: allocated 32768 Interrupt Collections @100180000 (flat, esz 2, psz 64K, shr 0) [ 15.692212] ITS: using cache flushing for cmd queue [ 15.692248] ITS [mem 0xfe660000-0xfe67ffff] [ 15.692295] ITS@0x00000000fe660000: allocated 8192 Devices @1001a0000 (indirect, esz 8, psz 64K, shr 0) [ 15.692325] ITS@0x00000000fe660000: allocated 32768 Interrupt Collections @1001b0000 (flat, esz 2, psz 64K, shr 0) [ 15.692340] ITS: using cache flushing for cmd queue [ 15.692598] GICv3: using LPI property table @0x00000001001c0000 [ 15.692730] GIC: using cache flushing for LPI property table [ 15.692739] GICv3: CPU0: using allocated LPI pending table @0x00000001001d0000 [ 15.692796] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 15.851599] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 15.851612] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 15.851622] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 15.853115] Console: colour dummy device 80x25 [ 15.853822] printk: console [tty1] enabled [ 15.853866] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000) [ 15.853891] pid_max: default: 32768 minimum: 301 [ 15.853968] LSM: Security Framework initializing [ 15.854097] AppArmor: AppArmor initialized [ 15.854239] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 15.854316] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 15.856375] cblist_init_generic: Setting adjustable number of callback queues. [ 15.856398] cblist_init_generic: Setting shift to 3 and lim to 1. [ 15.856517] cblist_init_generic: Setting adjustable number of callback queues. [ 15.856536] cblist_init_generic: Setting shift to 3 and lim to 1. [ 15.856776] rcu: Hierarchical SRCU implementation. [ 15.856792] rcu: Max phase no-delay instances is 1000. [ 15.858362] Platform MSI: msi-controller@fe640000 domain created [ 15.858395] Platform MSI: msi-controller@fe660000 domain created [ 15.858827] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe640000 domain created [ 15.858868] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe660000 domain created [ 15.859121] EFI services will not be available. [ 15.859580] smp: Bringing up secondary CPUs ... [ 15.860229] Detected VIPT I-cache on CPU1 [ 15.860325] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000 [ 15.860349] GICv3: CPU1: using allocated LPI pending table @0x00000001001e0000 [ 15.860390] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [ 15.861132] Detected VIPT I-cache on CPU2 [ 15.861225] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000 [ 15.861247] GICv3: CPU2: using allocated LPI pending table @0x00000001001f0000 [ 15.861285] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [ 15.861947] Detected VIPT I-cache on CPU3 [ 15.862037] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000 [ 15.862059] GICv3: CPU3: using allocated LPI pending table @0x0000000100200000 [ 15.862095] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [ 15.862758] CPU features: detected: Spectre-v4 [ 15.862763] CPU features: detected: Spectre-BHB [ 15.862767] CPU features: detected: SSBS not fully self-synchronizing [ 15.862769] Detected PIPT I-cache on CPU4 [ 15.862820] GICv3: CPU4: found redistributor 400 region 0:0x00000000fe700000 [ 15.862833] GICv3: CPU4: using allocated LPI pending table @0x0000000100210000 [ 15.862856] CPU4: Booted secondary processor 0x0000000400 [0x414fd0b0] [ 15.863509] Detected PIPT I-cache on CPU5 [ 15.863566] GICv3: CPU5: found redistributor 500 region 0:0x00000000fe720000 [ 15.863580] GICv3: CPU5: using allocated LPI pending table @0x0000000100220000 [ 15.863603] CPU5: Booted secondary processor 0x0000000500 [0x414fd0b0] [ 15.864232] Detected PIPT I-cache on CPU6 [ 15.864288] GICv3: CPU6: found redistributor 600 region 0:0x00000000fe740000 [ 15.864301] GICv3: CPU6: using allocated LPI pending table @0x0000000100230000 [ 15.864324] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b0] [ 15.865005] Detected PIPT I-cache on CPU7 [ 15.865062] GICv3: CPU7: found redistributor 700 region 0:0x00000000fe760000 [ 15.865074] GICv3: CPU7: using allocated LPI pending table @0x0000000100240000 [ 15.865097] CPU7: Booted secondary processor 0x0000000700 [0x414fd0b0] [ 15.865164] smp: Brought up 1 node, 8 CPUs [ 15.865451] SMP: Total of 8 processors activated. [ 15.865464] CPU features: detected: 32-bit EL0 Support [ 15.865476] CPU features: detected: Data cache clean to the PoU not required for I/D coherence [ 15.865493] CPU features: detected: Common not Private translations [ 15.865506] CPU features: detected: CRC32 instructions [ 15.865520] CPU features: detected: RCpc load-acquire (LDAPR) [ 15.865532] CPU features: detected: LSE atomic instructions [ 15.865544] CPU features: detected: Privileged Access Never [ 15.865556] CPU features: detected: RAS Extension Support [ 15.865569] CPU features: detected: Speculative Store Bypassing Safe (SSBS) [ 15.865661] CPU: All CPU(s) started at EL2 [ 15.865674] alternatives: applying system-wide alternatives [ 15.875720] devtmpfs: initialized [ 15.892004] Registered cp15_barrier emulation handler [ 15.892018] Registered setend emulation handler [ 15.892108] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns [ 15.892123] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 15.894244] pinctrl core: initialized pinctrl subsystem [ 15.894472] DMI not present or invalid. [ 15.894782] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 15.895581] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations [ 15.895938] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 15.896183] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 15.896214] audit: initializing netlink subsys (disabled) [ 15.896323] audit: type=2000 audit(0.043:1): state=initialized audit_enabled=0 res=1 [ 15.896895] Registered FIQ tty driver [ 15.897047] thermal_sys: Registered thermal governor 'fair_share' [ 15.897050] thermal_sys: Registered thermal governor 'step_wise' [ 15.897056] thermal_sys: Registered thermal governor 'user_space' [ 15.897061] thermal_sys: Registered thermal governor 'power_allocator' [ 15.897088] cpuidle: using governor menu [ 15.897308] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 15.897439] ASID allocator initialised with 65536 entries [ 15.899515] ramoops: dmesg-0 0x18000@0x0000000000110000 [ 15.899523] ramoops: dmesg-1 0x18000@0x0000000000128000 [ 15.899542] ramoops: console 0x80000@0x0000000000140000 [ 15.899553] ramoops: pmsg 0x30000@0x00000000001c0000 [ 15.899819] printk: console [ramoops-1] enabled [ 15.899826] pstore: Registered ramoops as persistent store backend [ 15.899833] ramoops: using 0xe0000@0x110000, ecc: 0 [ 15.937963] platform fdd90000.vop: Fixed dependency cycle(s) with /dp@fde50000 [ 15.938001] platform fde50000.dp: Fixed dependency cycle(s) with /vop@fdd90000 [ 15.938299] platform fdd90000.vop: Fixed dependency cycle(s) with /hdmi@fde80000 [ 15.938333] platform fde80000.hdmi: Fixed dependency cycle(s) with /vop@fdd90000 [ 15.943755] platform fed80000.phy: Fixed dependency cycle(s) with /i2c@fec80000/fusb302@22/connector [ 15.949452] rockchip-gpio fd8a0000.gpio: probed /pinctrl/gpio@fd8a0000 [ 15.949725] rockchip-gpio fec20000.gpio: probed /pinctrl/gpio@fec20000 [ 15.949949] rockchip-gpio fec30000.gpio: probed /pinctrl/gpio@fec30000 [ 15.950189] rockchip-gpio fec40000.gpio: probed /pinctrl/gpio@fec40000 [ 15.950466] rockchip-gpio fec50000.gpio: probed /pinctrl/gpio@fec50000 [ 15.950520] rockchip-pinctrl pinctrl: probed pinctrl [ 15.951920] platform fdd90000.vop: Fixed dependency cycle(s) with /hdmi@fdea0000 [ 15.951957] platform fdea0000.hdmi: Fixed dependency cycle(s) with /vop@fdd90000 [ 15.955986] KASLR disabled due to lack of seed [ 15.961192] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 15.961203] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 15.961211] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 15.961218] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 15.961225] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 15.961232] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 15.961239] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 15.961246] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 16.018416] raid6: neonx8 gen() 5472 MB/s [ 16.075155] raid6: neonx4 gen() 5618 MB/s [ 16.131893] raid6: neonx2 gen() 5158 MB/s [ 16.188636] raid6: neonx1 gen() 4247 MB/s [ 16.245374] raid6: int64x8 gen() 1332 MB/s [ 16.302114] raid6: int64x4 gen() 1651 MB/s [ 16.358854] raid6: int64x2 gen() 2422 MB/s [ 16.415589] raid6: int64x1 gen() 2006 MB/s [ 16.415595] raid6: using algorithm neonx4 gen() 5618 MB/s [ 16.472329] raid6: .... xor() 4303 MB/s, rmw enabled [ 16.472336] raid6: using neon recovery algorithm [ 16.472953] fiq_debugger fiq_debugger.0: error -ENXIO: IRQ fiq not found [ 16.472969] fiq_debugger fiq_debugger.0: error -ENXIO: IRQ wakeup not found [ 16.472979] fiq_debugger_probe: could not install nmi irq handler [ 16.473257] printk: console [ttyFIQ0] enabled [ 16.473372] Registered fiq debugger ttyFIQ0 [ 16.532300] debugfs: Directory 'vcc_mipicsi1' with parent 'regulator' already present! [ 16.532321] debugfs: Directory 'vcc_mipicsi1' with parent 'vcc_mipicsi1' already present! [ 16.532746] iommu: Default domain type: Translated [ 16.532757] iommu: DMA domain TLB invalidation policy: strict mode [ 16.532928] SCSI subsystem initialized [ 16.533014] usbcore: registered new interface driver usbfs [ 16.533035] usbcore: registered new interface driver hub [ 16.533053] usbcore: registered new device driver usb [ 16.533105] mc: Linux media interface: v0.10 [ 16.533124] videodev: Linux video capture interface: v2.00 [ 16.533165] pps_core: LinuxPPS API ver. 1 registered [ 16.533173] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 16.533186] PTP clock support registered [ 16.533387] arm-scmi firmware:scmi: Enabled polling mode TX channel - prot_id:16 [ 16.533442] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled. [ 16.533475] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0 [ 16.534410] Advanced Linux Sound Architecture Driver Initialized. [ 16.534669] Bluetooth: Core ver 2.22 [ 16.534689] NET: Registered PF_BLUETOOTH protocol family [ 16.534697] Bluetooth: HCI device and connection manager initialized [ 16.534706] Bluetooth: HCI socket layer initialized [ 16.534714] Bluetooth: L2CAP socket layer initialized [ 16.534724] Bluetooth: SCO socket layer initialized [ 16.534771] NetLabel: Initializing [ 16.534777] NetLabel: domain hash size = 128 [ 16.534784] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 16.534814] NetLabel: unlabeled traffic allowed by default [ 16.534987] vgaarb: loaded [ 16.535312] clocksource: Switched to clocksource arch_sys_counter [ 16.535451] VFS: Disk quotas dquot_6.6.0 [ 16.535477] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 16.535688] AppArmor: AppArmor Filesystem Enabled [ 16.541390] NET: Registered PF_INET protocol family [ 16.541587] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 16.548590] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear) [ 16.548775] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 16.548810] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 16.550133] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear) [ 16.551395] TCP: Hash tables configured (established 262144 bind 65536) [ 16.551562] MPTCP token hash table entries: 32768 (order: 7, 786432 bytes, linear) [ 16.551736] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear) [ 16.552239] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear) [ 16.552787] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 16.553093] RPC: Registered named UNIX socket transport module. [ 16.553103] RPC: Registered udp transport module. [ 16.553110] RPC: Registered tcp transport module. [ 16.553116] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 16.553571] PCI: CLS 0 bytes, default 64 [ 16.554000] Trying to unpack rootfs image as initramfs... [ 16.554359] rockchip-thermal fec00000.tsadc: Missing rockchip,grf property [ 16.555253] rockchip-thermal fec00000.tsadc: tsadc is probed successfully! [ 16.569340] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 16.569901] kvm [1]: IPA Size Limit: 40 bits [ 16.569921] kvm [1]: GICv3: no GICV resource entry [ 16.569929] kvm [1]: disabling GICv2 emulation [ 16.569935] kvm [1]: GIC system register CPU interface enabled [ 16.570431] kvm [1]: vgic interrupt IRQ9 [ 16.571014] kvm [1]: VHE mode initialized successfully [ 16.571739] Initialise system trusted keyrings [ 16.571868] workingset: timestamp_bits=46 max_order=23 bucket_order=0 [ 16.574131] zbud: loaded [ 16.574935] NFS: Registering the id_resolver key type [ 16.574956] Key type id_resolver registered [ 16.574963] Key type id_legacy registered [ 16.575000] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 16.575009] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 16.595061] NET: Registered PF_ALG protocol family [ 16.595075] xor: measuring software checksum speed [ 16.595607] 8regs : 6245 MB/sec [ 16.596013] 32regs : 8271 MB/sec [ 16.596353] arm64_neon : 9876 MB/sec [ 16.596359] xor: using function: arm64_neon (9876 MB/sec) [ 16.596370] Key type asymmetric registered [ 16.596377] Asymmetric key parser 'x509' registered [ 16.949079] Freeing initrd memory: 14404K [ 16.967740] alg: self-tests for CTR-KDF (hmac(sha256)) passed [ 16.967781] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 241) [ 16.967911] io scheduler mq-deadline registered [ 16.967920] io scheduler kyber registered [ 16.969233] rockchip-csi2-dphy-hw fedc8000.csi2-dphy1-hw: csi2 dphy hw probe successfully! [ 16.978456] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy init success [ 16.979311] rockchip-hdptx-phy-hdmi fed70000.hdmiphy: hdptx phy init success [ 16.981707] dw-pcie fe180000.pcie: invalid resource [ 16.981723] dw-pcie fe180000.pcie: Failed to initialize host [ 16.981731] dw-pcie: probe of fe180000.pcie failed with error -22 [ 16.981800] dw-pcie fe190000.pcie: invalid resource [ 16.981809] dw-pcie fe190000.pcie: Failed to initialize host [ 16.981816] dw-pcie: probe of fe190000.pcie failed with error -22 [ 16.981925] dw-pcie fe150000.pcie: invalid resource [ 16.981934] dw-pcie fe150000.pcie: Failed to initialize host [ 16.981954] dw-pcie: probe of fe150000.pcie failed with error -22 [ 16.982087] dw-pcie fe170000.pcie: invalid resource [ 16.982097] dw-pcie fe170000.pcie: Failed to initialize host [ 16.982104] dw-pcie: probe of fe170000.pcie failed with error -22 [ 16.982476] rk-pcie fe180000.pcie: using pcie default link_up because of rockchip,default-link-up [ 16.982619] rk-pcie fe190000.pcie: using pcie default link_up because of rockchip,default-link-up [ 16.982667] rk-pcie fe180000.pcie: invalid prsnt-gpios property in node [ 16.982746] rk-pcie fe190000.pcie: invalid prsnt-gpios property in node [ 16.982810] rk-pcie fe180000.pcie: no vpcie3v3 regulator found [ 16.982874] rk-pcie fe190000.pcie: no vpcie3v3 regulator found [ 16.982890] rk-pcie fe150000.pcie: invalid prsnt-gpios property in node [ 16.983140] rk-pcie fe170000.pcie: invalid prsnt-gpios property in node [ 16.983294] iep: Module initialized. [ 16.983392] mpp_service mpp-srv: 6c47657a381c author: Yandong Lin 2025-01-16 video: rockchip: mpp: Fix missing enable_irq in timeout work [ 16.983391] rk-pcie fe180000.pcie: host bridge /pcie@fe180000 ranges: [ 16.983404] mpp_service mpp-srv: probe start [ 16.983449] rk-pcie fe190000.pcie: host bridge /pcie@fe190000 ranges: [ 16.983454] rk-pcie fe180000.pcie: IO 0x00f3100000..0x00f31fffff -> 0x00f3100000 [ 16.983474] rk-pcie fe180000.pcie: MEM 0x00f3200000..0x00f3ffffff -> 0x00f3200000 [ 16.983488] rk-pcie fe180000.pcie: MEM 0x09c0000000..0x09ffffffff -> 0x09c0000000 [ 16.983541] rk-pcie fe180000.pcie: iATU unroll: enabled [ 16.983549] rk-pcie fe190000.pcie: IO 0x00f4100000..0x00f41fffff -> 0x00f4100000 [ 16.983568] rk-pcie fe190000.pcie: MEM 0x00f4200000..0x00f4ffffff -> 0x00f4200000 [ 16.983582] rk-pcie fe190000.pcie: MEM 0x0a00000000..0x0a3fffffff -> 0x0a00000000 [ 16.983593] rk-pcie fe180000.pcie: iATU regions: 8 ob, 8 ib, align 64K, limit 8G [ 16.983649] rk-pcie fe190000.pcie: iATU unroll: enabled [ 16.983673] rk-pcie fe190000.pcie: iATU regions: 8 ob, 8 ib, align 64K, limit 8G [ 16.984874] mpp_vepu2 jpege-ccu: probing start [ 16.984886] mpp_vepu2 jpege-ccu: probing finish [ 16.988319] mpp_rkvdec2 fdc30000.rkvdec-ccu: rkvdec-ccu, probing start [ 16.988389] mpp_rkvdec2 fdc30000.rkvdec-ccu: ccu-mode: 1 [ 16.988398] mpp_rkvdec2 fdc30000.rkvdec-ccu: probing finish [ 16.988771] mpp_rkvenc2 rkvenc-ccu: probing start [ 16.988782] mpp_rkvenc2 rkvenc-ccu: probing finish [ 16.989377] mpp_service mpp-srv: probe success [ 16.999314] rk-pcie fe150000.pcie: can't get current limit. [ 16.999580] rk-pcie fe150000.pcie: host bridge /pcie@fe150000 ranges: [ 16.999606] rk-pcie fe150000.pcie: IO 0x00f0100000..0x00f01fffff -> 0x00f0100000 [ 16.999625] rk-pcie fe150000.pcie: MEM 0x00f0200000..0x00f0ffffff -> 0x00f0200000 [ 16.999640] rk-pcie fe150000.pcie: MEM 0x0900000000..0x093fffffff -> 0x0900000000 [ 16.999696] rk-pcie fe150000.pcie: iATU unroll: enabled [ 16.999706] rk-pcie fe150000.pcie: iATU regions: 8 ob, 8 ib, align 64K, limit 8G [ 17.001264] dma-pl330 fea10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 17.001284] dma-pl330 fea10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 17.002214] dma-pl330 fea30000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 17.002230] dma-pl330 fea30000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 17.003141] dma-pl330 fed10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 17.003156] dma-pl330 fed10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 17.003619] rockchip-pvtm fda40000.pvtm: pvtm@0 probed [ 17.003685] rockchip-pvtm fda50000.pvtm: pvtm@1 probed [ 17.003744] rockchip-pvtm fda60000.pvtm: pvtm@2 probed [ 17.003801] rockchip-pvtm fdaf0000.pvtm: pvtm@3 probed [ 17.003855] rockchip-pvtm fdb30000.pvtm: pvtm@4 probed [ 17.004518] rockchip-system-monitor rockchip-system-monitor: system monitor probe [ 17.005440] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [ 17.006039] febc0000.serial: ttyS9 at MMIO 0xfebc0000 (irq = 45, base_baud = 1500000) is a 16550A [ 17.007378] random: crng init done [ 17.007451] led_vk2c21_init [ 17.007451] ============================================= [ 17.013034] rk_iommu fdca0000.iommu: av1d iommu enabled [ 17.015293] rockchip-vop2 fdd90000.vop: Adding to iommu group 17 [ 17.024843] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp0 assign plane mask: Cluster0 | Esmart0[0x5], primary plane phy id: Cluster0[0] [ 17.024878] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp1 assign plane mask: Cluster1 | Esmart1[0xa], primary plane phy id: Cluster1[1] [ 17.024897] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp2 assign plane mask: Cluster2 | Esmart2[0x140], primary plane phy id: Cluster2[6] [ 17.024915] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp3 assign plane mask: Cluster3 | Esmart3[0x280], primary plane phy id: Cluster3[7] [ 17.025023] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart0-win0 as cursor plane for vp0 [ 17.025118] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart1-win0 as cursor plane for vp1 [ 17.025207] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] Esmart2-win0 as cursor plane for vp2 [ 17.025235] [drm] failed to init overlay plane Cluster0-win1 [ 17.025244] [drm] failed to init overlay plane Cluster1-win1 [ 17.025253] [drm] failed to init overlay plane Cluster2-win1 [ 17.025294] [drm] failed to init overlay plane Cluster3-win1 [ 17.037197] rockchip-vop2 fdd90000.vop: bin=0 [ 17.037419] rockchip-vop2 fdd90000.vop: leakage=35 [ 17.037433] rockchip-vop2 fdd90000.vop: leakage-volt-sel=1 [ 17.037499] rockchip-vop2 fdd90000.vop: error -ENODEV: _opp_set_regulators: no regulator (vop) found [ 17.037530] rockchip-vop2 fdd90000.vop: failed to set opp config [ 17.037540] rockchip-vop2 fdd90000.vop: failed to init opp info [ 17.037550] rockchip-vop2 fdd90000.vop: Unsupported VOP aclk dvfs [ 17.037571] rockchip-drm display-subsystem: bound fdd90000.vop (ops 0xffff8000093fe4a8) [ 17.038217] dwhdmi-rockchip fde80000.hdmi: registered ddc I2C bus driver [ 17.038833] rockchip-drm display-subsystem: bound fde80000.hdmi (ops 0xffff800009417528) [ 17.039405] dwhdmi-rockchip fdea0000.hdmi: registered ddc I2C bus driver [ 17.039987] rockchip-drm display-subsystem: bound fdea0000.hdmi (ops 0xffff800009417528) [ 17.040222] rockchip-drm display-subsystem: bound fde50000.dp (ops 0xffff80000941a588) [ 17.041489] [drm] Initialized rockchip 4.0.0 20140818 for display-subsystem on minor 0 [ 17.041520] rockchip-drm display-subsystem: failed to parse loader memory [ 17.041600] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 17.041665] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 17.041696] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 17.041860] rockchip-drm display-subsystem: [drm] run display error_event monitor [ 17.042549] dw-hdmi-qp-hdcp dw-hdmi-qp-hdcp.2.auto: dw_hdcp_qp_hdcp_probe success [ 17.042707] dw-hdmi-qp-hdcp dw-hdmi-qp-hdcp.5.auto: dw_hdcp_qp_hdcp_probe success [ 17.043265] Registered IR keymap rc-cec [ 17.043333] rc rc0: dw_hdmi_qp as /devices/platform/fde80000.hdmi/rc/rc0 [ 17.043436] input: dw_hdmi_qp as /devices/platform/fde80000.hdmi/rc/rc0/input0 [ 17.043811] Registered IR keymap rc-cec [ 17.043874] rc rc1: dw_hdmi_qp as /devices/platform/fdea0000.hdmi/rc/rc1 [ 17.043968] input: dw_hdmi_qp as /devices/platform/fdea0000.hdmi/rc/rc1/input1 [ 17.045378] rk-pcie fe170000.pcie: can't get current limit. [ 17.045647] rk-pcie fe170000.pcie: host bridge /pcie@fe170000 ranges: [ 17.045673] rk-pcie fe170000.pcie: IO 0x00f2100000..0x00f21fffff -> 0x00f2100000 [ 17.045691] rk-pcie fe170000.pcie: MEM 0x00f2200000..0x00f2ffffff -> 0x00f2200000 [ 17.045706] rk-pcie fe170000.pcie: MEM 0x0980000000..0x09bfffffff -> 0x0980000000 [ 17.045766] rk-pcie fe170000.pcie: iATU unroll: enabled [ 17.045776] rk-pcie fe170000.pcie: iATU regions: 8 ob, 8 ib, align 64K, limit 8G [ 17.046259] brd: module loaded [ 17.049196] loop: module loaded [ 17.049418] rbd: loaded (major 254) [ 17.049585] lkdtm: No crash points registered, enable through debugfs [ 17.051799] rockchip-spi feb20000.spi: no high_speed pinctrl state [ 17.052208] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/rk806single@0/regulators/DCDC_REG7 [ 17.052260] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/rk806single@0/pinctrl_rk806/rk806_dvs1_pwrdn [ 17.052280] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/rk806single@0/pinctrl_rk806/rk806_dvs3_null [ 17.052299] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/rk806single@0/pinctrl_rk806/rk806_dvs2_null [ 17.052317] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/rk806single@0/pinctrl_rk806/rk806_dvs1_null [ 17.052836] rk806 spi2.0: chip id: RK806,ver:0x2, 0x1 [ 17.052969] rk806 spi2.0: ON: 0x20 OFF:0x2 [ 17.053046] rk806 spi2.0: shutdown-sequence missing! [ 17.053058] rk806 spi2.0: vb-shutdown-sequence missing! [ 17.053068] rk806 spi2.0: dvs-suspend-control-by missing! [ 17.061782] avdd_0v75_s0: Bringing 750000uV into 837500-837500uV [ 17.066440] rk806 spi2.0: no sleep-setting state [ 17.066457] rk806 spi2.0: no reset-setting pinctrl state [ 17.066467] rk806 spi2.0: no dvs-setting pinctrl state [ 17.067053] rockchip-spi feb20000.spi: register misc device rkspi-dev2 [ 17.067068] rockchip-spi feb20000.spi: probed, poll=0, rsd=0, cs-inactive=0, ready=0 [ 17.068444] spi-nor spi5.0: XM25QU128C (16384 Kbytes) read_data x4 [ 17.068491] 1 fixed-partitions partitions found on MTD device sfc_nor [ 17.068504] Creating 1 MTD partitions on "sfc_nor": [ 17.068514] 0x000000000000-0x000001000000 : "loader" [ 17.071365] usbcore: registered new interface driver rndis_wlan [ 17.071398] usbcore: registered new interface driver asix [ 17.071420] usbcore: registered new interface driver cdc_ether [ 17.071443] usbcore: registered new interface driver rndis_host [ 17.071468] usbcore: registered new interface driver cdc_ncm [ 17.071585] VFIO - User Level meta-driver version: 0.3 [ 17.072156] platform fc000000.usb: Fixed dependency cycle(s) with /i2c@fec80000/fusb302@22 [ 17.085814] phy phy-fd5d4000.syscon:usb2-phy@4000.3: illegal mode [ 17.085838] xhci-hcd xhci-hcd.12.auto: xHCI Host Controller [ 17.085855] xhci-hcd xhci-hcd.12.auto: new USB bus registered, assigned bus number 1 [ 17.085949] xhci-hcd xhci-hcd.12.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0002008002010010 [ 17.085984] xhci-hcd xhci-hcd.12.auto: irq 86, io mem 0xfc400000 [ 17.086068] xhci-hcd xhci-hcd.12.auto: xHCI Host Controller [ 17.086081] xhci-hcd xhci-hcd.12.auto: new USB bus registered, assigned bus number 2 [ 17.086096] xhci-hcd xhci-hcd.12.auto: Host supports USB 3.0 SuperSpeed [ 17.086190] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01 [ 17.086206] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 17.086218] usb usb1: Product: xHCI Host Controller [ 17.086228] usb usb1: Manufacturer: Linux 6.1.115-vendor-rk35xx xhci-hcd [ 17.086239] usb usb1: SerialNumber: xhci-hcd.12.auto [ 17.086534] hub 1-0:1.0: USB hub found [ 17.086559] hub 1-0:1.0: 1 port detected [ 17.086759] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 17.086826] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01 [ 17.086841] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 17.086853] usb usb2: Product: xHCI Host Controller [ 17.086862] usb usb2: Manufacturer: Linux 6.1.115-vendor-rk35xx xhci-hcd [ 17.086873] usb usb2: SerialNumber: xhci-hcd.12.auto [ 17.087132] hub 2-0:1.0: USB hub found [ 17.087155] hub 2-0:1.0: 1 port detected [ 17.087354] usbcore: registered new interface driver cdc_acm [ 17.087366] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 17.087412] ehci-platform fc800000.usb: EHCI Host Controller [ 17.087437] ehci-platform fc800000.usb: new USB bus registered, assigned bus number 3 [ 17.087442] ohci-platform fc840000.usb: Generic Platform OHCI controller [ 17.087477] usbcore: registered new interface driver uas [ 17.087486] ehci-platform fc880000.usb: EHCI Host Controller [ 17.087499] ohci-platform fc840000.usb: new USB bus registered, assigned bus number 4 [ 17.087507] ehci-platform fc880000.usb: new USB bus registered, assigned bus number 5 [ 17.087515] ohci-platform fc8c0000.usb: Generic Platform OHCI controller [ 17.087521] usbcore: registered new interface driver usb-storage [ 17.087528] ehci-platform fc800000.usb: irq 87, io mem 0xfc800000 [ 17.087540] ohci-platform fc8c0000.usb: new USB bus registered, assigned bus number 6 [ 17.087610] ehci-platform fc880000.usb: irq 88, io mem 0xfc880000 [ 17.087637] ohci-platform fc840000.usb: irq 89, io mem 0xfc840000 [ 17.087672] ohci-platform fc8c0000.usb: irq 90, io mem 0xfc8c0000 [ 17.087807] mousedev: PS/2 mouse device common for all mice [ 17.088351] .. rk pwm remotectl v2.0 init [ 17.088497] input: febf0030.pwm as /devices/platform/febf0030.pwm/input/input2 [ 17.088711] remotectl-pwm febf0030.pwm: Controller support pwrkey capture [ 17.088942] i2c_dev: i2c /dev entries driver [ 17.098664] ehci-platform fc800000.usb: USB 2.0 started, EHCI 1.00 [ 17.098846] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01 [ 17.098868] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 17.098880] usb usb3: Product: EHCI Host Controller [ 17.098891] usb usb3: Manufacturer: Linux 6.1.115-vendor-rk35xx ehci_hcd [ 17.098901] usb usb3: SerialNumber: fc800000.usb [ 17.099188] hub 3-0:1.0: USB hub found [ 17.099225] hub 3-0:1.0: 1 port detected [ 17.111996] ehci-platform fc880000.usb: USB 2.0 started, EHCI 1.00 [ 17.112186] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01 [ 17.112206] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 17.112219] usb usb5: Product: EHCI Host Controller [ 17.112229] usb usb5: Manufacturer: Linux 6.1.115-vendor-rk35xx ehci_hcd [ 17.112240] usb usb5: SerialNumber: fc880000.usb [ 17.112541] hub 5-0:1.0: USB hub found [ 17.112579] hub 5-0:1.0: 1 port detected [ 17.119357] rtc-hym8563 6-0051: rtc information is valid [ 17.122027] rtc-hym8563 6-0051: registered as rtc0 [ 17.122310] rtc-hym8563 6-0051: setting system clock to 2021-01-01T12:04:12 UTC (1609502652) [ 17.123836] rkcifhw fdce0000.rkcif: Adding to iommu group 16 [ 17.124707] rkcifhw fdce0000.rkcif: No reserved memory region assign to CIF [ 17.125519] rockchip-mipi-csi2-hw fdd10000.mipi0-csi2-hw: enter mipi csi2 hw probe! [ 17.125626] rockchip-mipi-csi2-hw fdd10000.mipi0-csi2-hw: probe success, v4l2_dev:mipi0-csi2-hw! [ 17.125675] rockchip-mipi-csi2-hw fdd20000.mipi1-csi2-hw: enter mipi csi2 hw probe! [ 17.125761] rockchip-mipi-csi2-hw fdd20000.mipi1-csi2-hw: probe success, v4l2_dev:mipi1-csi2-hw! [ 17.125803] rockchip-mipi-csi2-hw fdd30000.mipi2-csi2-hw: enter mipi csi2 hw probe! [ 17.125884] rockchip-mipi-csi2-hw fdd30000.mipi2-csi2-hw: probe success, v4l2_dev:mipi2-csi2-hw! [ 17.125925] rockchip-mipi-csi2-hw fdd40000.mipi3-csi2-hw: enter mipi csi2 hw probe! [ 17.126008] rockchip-mipi-csi2-hw fdd40000.mipi3-csi2-hw: probe success, v4l2_dev:mipi3-csi2-hw! [ 17.126049] rockchip-mipi-csi2-hw fdd50000.mipi4-csi2-hw: enter mipi csi2 hw probe! [ 17.126130] rockchip-mipi-csi2-hw fdd50000.mipi4-csi2-hw: probe success, v4l2_dev:mipi4-csi2-hw! [ 17.126174] rockchip-mipi-csi2-hw fdd60000.mipi5-csi2-hw: enter mipi csi2 hw probe! [ 17.126254] rockchip-mipi-csi2-hw fdd60000.mipi5-csi2-hw: probe success, v4l2_dev:mipi5-csi2-hw! [ 17.127328] rkisp_hw fdcb0000.rkisp: Adding to iommu group 15 [ 17.127460] rkisp_hw fdcb0000.rkisp: is_thunderboot: 0 [ 17.127473] rkisp_hw fdcb0000.rkisp: Missing rockchip,grf property [ 17.127494] rkisp_hw fdcb0000.rkisp: max input:0x0@0fps [ 17.127612] rkisp_hw fdcb0000.rkisp: no find phandle sram [ 17.128874] usbcore: registered new interface driver uvcvideo [ 17.130538] cpu cpu0: bin=0 [ 17.130724] cpu cpu0: leakage=12 [ 17.132184] cpu cpu0: pvtm=1415 [ 17.132337] cpu cpu0: pvtm-volt-sel=1 [ 17.134384] cpu cpu4: bin=0 [ 17.134569] cpu cpu4: leakage=9 [ 17.141177] cpu cpu4: pvtm=1631 [ 17.145225] cpu cpu4: pvtm-volt-sel=2 [ 17.146236] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01 [ 17.146285] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 17.146318] usb usb4: Product: Generic Platform OHCI controller [ 17.146336] usb usb4: Manufacturer: Linux 6.1.115-vendor-rk35xx ohci_hcd [ 17.146364] usb usb4: SerialNumber: fc840000.usb [ 17.146918] hub 4-0:1.0: USB hub found [ 17.146986] hub 4-0:1.0: 1 port detected [ 17.147605] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01 [ 17.147648] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 17.147680] usb usb6: Product: Generic Platform OHCI controller [ 17.147707] usb usb6: Manufacturer: Linux 6.1.115-vendor-rk35xx ohci_hcd [ 17.147734] usb usb6: SerialNumber: fc8c0000.usb [ 17.148054] cpu cpu6: bin=0 [ 17.148238] cpu cpu6: leakage=9 [ 17.148316] hub 6-0:1.0: USB hub found [ 17.148386] hub 6-0:1.0: 1 port detected [ 17.154875] cpu cpu6: pvtm=1620 [ 17.158965] cpu cpu6: pvtm-volt-sel=2 [ 17.161011] cpu cpu0: avs=0 [ 17.161071] cpu cpu0: rockchip_pvtpll_set_volt_sel: error cfg clk_id=0 voltsel (-1) [ 17.162343] cpu cpu4: avs=0 [ 17.162396] cpu cpu4: rockchip_pvtpll_set_volt_sel: error cfg clk_id=2 voltsel (-1) [ 17.163497] cpu cpu6: avs=0 [ 17.163550] cpu cpu6: rockchip_pvtpll_set_volt_sel: error cfg clk_id=3 voltsel (-1) [ 17.163656] cpu cpu0: l=15000 h=85000 hyst=5000 l_limit=0 h_limit=1608000000 h_table=0 [ 17.164019] cpu cpu0: EM: created perf domain [ 17.164469] cpu cpu4: l=15000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0 [ 17.172863] cpu cpu4: EM: created perf domain [ 17.173582] cpu cpu6: l=15000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0 [ 17.185881] rk-pcie fe180000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.185958] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.191130] cpu cpu6: EM: created perf domain [ 17.193012] sdhci: Secure Digital Host Controller Interface driver [ 17.193037] sdhci: Copyright(c) Pierre Ossman [ 17.193051] Synopsys Designware Multimedia Card Interface Driver [ 17.193849] sdhci-pltfm: SDHCI platform and OF driver helper [ 17.194318] dwmmc_rockchip fe2c0000.mmc: No normal pinctrl state [ 17.194337] dwmmc_rockchip fe2c0000.mmc: No idle pinctrl state [ 17.194395] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode. [ 17.194419] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller. [ 17.194437] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a [ 17.194477] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 118,32 bit host data width,256 deep fifo [ 17.196461] mmc0: CQHCI version 5.10 [ 17.197225] ledtrig-cpu: registered to indicate activity on CPUs [ 17.197323] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active. [ 17.197388] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 17.198275] cryptodev: driver 1.12 loaded. [ 17.198324] hid: raw HID events driver (C) Jiri Kosina [ 17.198511] usbcore: registered new interface driver usbhid [ 17.198520] usbhid: USB HID core driver [ 17.201596] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42600 [ 17.201610] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42602 [ 17.201619] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42605 [ 17.201628] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42622 [ 17.201904] optee: probing for conduit method. [ 17.201915] optee: api uid mismatch [ 17.201922] optee: probe of firmware:optee failed with error -22 [ 17.201994] rk-pcie fe150000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.202412] usbcore: registered new interface driver snd-usb-audio [ 17.204456] [Awinic] aw87xxx_pa_init:driver version: v2.2.0 [ 17.205398] rockchip-i2s-tdm fddf0000.i2s: CLK-ALWAYS-ON: mclk: 12288000, bclk: 3072000, fsync: 48000 [ 17.205952] rockchip-i2s-tdm fe470000.i2s: Register PCM for TRCM mode [ 17.206350] rockchip-i2s-tdm fddf4000.i2s: CLK-ALWAYS-ON: mclk: 12288000, bclk: 3072000, fsync: 48000 [ 17.206474] rockchip-i2s-tdm fddf8000.i2s: Init RX wait-time-ms: 50 [ 17.208277] debugfs: File 'Capture' in directory 'dapm' already present! [ 17.208855] input: rockchip-dp0 rockchip-dp0 as /devices/platform/dp0-sound/sound/card0/input3 [ 17.209912] input: rockchip-hdmi0 rockchip-hdmi0 as /devices/platform/hdmi0-sound/sound/card1/input4 [ 17.210820] input: rockchip-hdmi1 rockchip-hdmi1 as /devices/platform/hdmi1-sound/sound/card2/input5 [ 17.211616] input: headset-keys as /devices/platform/es8388-sound/input/input6 [ 17.214912] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 17.223172] rk-pcie fe150000.pcie: PCIe Linking... LTSSM is 0x210022 [ 17.228179] mmc0: SDHCI controller on fe2e0000.mmc [fe2e0000.mmc] using ADMA [ 17.247966] rk-pcie fe170000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.262142] rk-pcie fe190000.pcie: PCIe Link up, LTSSM is 0x130011 [ 17.262214] rk-pcie fe190000.pcie: PCIe Gen.2 x1 link up [ 17.262233] rk-pcie fe180000.pcie: PCIe Link up, LTSSM is 0x130011 [ 17.262256] rk-pcie fe180000.pcie: PCIe Gen.2 x1 link up [ 17.262524] rk-pcie fe190000.pcie: PCI host bridge to bus 0004:40 [ 17.262578] pci_bus 0004:40: root bus resource [bus 40-4f] [ 17.262589] rk-pcie fe180000.pcie: PCI host bridge to bus 0003:30 [ 17.262614] pci_bus 0004:40: root bus resource [io 0x100000-0x1fffff] (bus address [0xf4100000-0xf41fffff]) [ 17.262637] pci_bus 0003:30: root bus resource [bus 30-3f] [ 17.262662] pci_bus 0004:40: root bus resource [mem 0xf4200000-0xf4ffffff] [ 17.262685] pci_bus 0003:30: root bus resource [io 0x0000-0xfffff] (bus address [0xf3100000-0xf31fffff]) [ 17.262703] pci_bus 0004:40: root bus resource [mem 0xa00000000-0xa3fffffff pref] [ 17.262731] pci_bus 0003:30: root bus resource [mem 0xf3200000-0xf3ffffff] [ 17.262795] pci 0004:40:00.0: [1d87:3588] type 01 class 0x060400 [ 17.262834] pci 0004:40:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref] [ 17.262920] pci_bus 0003:30: root bus resource [mem 0x9c0000000-0x9ffffffff pref] [ 17.262923] pci 0004:40:00.0: supports D1 D2 [ 17.262935] pci 0004:40:00.0: PME# supported from D0 D1 D3hot [ 17.262992] pci 0003:30:00.0: [1d87:3588] type 01 class 0x060400 [ 17.263028] pci 0003:30:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref] [ 17.263126] pci 0003:30:00.0: supports D1 D2 [ 17.263169] pci 0003:30:00.0: PME# supported from D0 D1 D3hot [ 17.268681] rk-pcie fe170000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.284557] input: rockchip-es8388 Headset as /devices/platform/es8388-sound/sound/card3/input7 [ 17.287639] pci 0004:40:00.0: Primary bus is hard wired to 0 [ 17.287665] pci 0004:40:00.0: bridge configuration invalid ([bus 01-ff]), reconfiguring [ 17.287819] pci 0004:41:00.0: [10ec:8125] type 00 class 0x020000 [ 17.287867] pci 0003:30:00.0: Primary bus is hard wired to 0 [ 17.287882] pci 0004:41:00.0: reg 0x10: [io 0x0000-0x00ff] [ 17.287886] pci 0003:30:00.0: bridge configuration invalid ([bus 01-ff]), reconfiguring [ 17.287951] pci 0004:41:00.0: reg 0x18: [mem 0x00000000-0x0000ffff 64bit] [ 17.288003] pci 0004:41:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit] [ 17.288094] pci 0003:31:00.0: [10ec:8125] type 00 class 0x020000 [ 17.288194] pci 0003:31:00.0: reg 0x10: initial BAR value 0x00000000 invalid [ 17.288209] pci 0003:31:00.0: reg 0x10: [io size 0x0100] [ 17.288329] pci 0003:31:00.0: reg 0x18: [mem 0x00000000-0x0000ffff 64bit] [ 17.288412] pci 0003:31:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit] [ 17.288550] pci 0004:41:00.0: supports D1 D2 [ 17.288564] pci 0004:41:00.0: PME# supported from D0 D1 D2 D3hot D3cold [ 17.288955] pci 0003:31:00.0: supports D1 D2 [ 17.288970] pci 0003:31:00.0: PME# supported from D0 D1 D2 D3hot D3cold [ 17.289399] pci_bus 0004:41: busn_res: [bus 41-4f] end is updated to 41 [ 17.289435] pci 0004:40:00.0: BAR 8: assigned [mem 0xf4200000-0xf42fffff] [ 17.289453] pci 0004:40:00.0: BAR 6: assigned [mem 0xf4300000-0xf430ffff pref] [ 17.289471] pci 0004:40:00.0: BAR 7: assigned [io 0x100000-0x100fff] [ 17.289490] pci 0004:41:00.0: BAR 2: assigned [mem 0xf4200000-0xf420ffff 64bit] [ 17.289535] pci 0004:41:00.0: BAR 4: assigned [mem 0xf4210000-0xf4213fff 64bit] [ 17.289588] pci 0004:41:00.0: BAR 0: assigned [io 0x100000-0x1000ff] [ 17.289613] pci 0004:40:00.0: PCI bridge to [bus 41] [ 17.289627] pci 0004:40:00.0: bridge window [io 0x100000-0x100fff] [ 17.289631] pci_bus 0003:31: busn_res: [bus 31-3f] end is updated to 31 [ 17.289646] pci 0003:30:00.0: BAR 8: assigned [mem 0xf3200000-0xf32fffff] [ 17.289653] pci 0004:40:00.0: bridge window [mem 0xf4200000-0xf42fffff] [ 17.289661] pci 0003:30:00.0: BAR 6: assigned [mem 0xf3300000-0xf330ffff pref] [ 17.289667] pci 0003:30:00.0: BAR 7: assigned [io 0x1000-0x1fff] [ 17.289700] pci 0003:31:00.0: BAR 2: assigned [mem 0xf3200000-0xf320ffff 64bit] [ 17.289745] pci 0003:31:00.0: BAR 4: assigned [mem 0xf3210000-0xf3213fff 64bit] [ 17.289789] pci 0003:31:00.0: BAR 0: assigned [io 0x1000-0x10ff] [ 17.289812] pci 0003:30:00.0: PCI bridge to [bus 31] [ 17.289826] pci 0003:30:00.0: bridge window [io 0x1000-0x1fff] [ 17.289831] rk-pcie fe170000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.289851] pci 0003:30:00.0: bridge window [mem 0xf3200000-0xf32fffff] [ 17.292635] pcieport 0004:40:00.0: PME: Signaling with IRQ 135 [ 17.292842] pcieport 0003:30:00.0: PME: Signaling with IRQ 144 [ 17.298789] rk-pcie fe150000.pcie: PCIe Link up, LTSSM is 0x230011 [ 17.298835] rk-pcie fe150000.pcie: PCIe Gen.3 x4 link up [ 17.299039] rk-pcie fe150000.pcie: PCI host bridge to bus 0000:00 [ 17.299071] pci_bus 0000:00: root bus resource [bus 00-0f] [ 17.299100] pci_bus 0000:00: root bus resource [io 0x200000-0x2fffff] (bus address [0xf0100000-0xf01fffff]) [ 17.299133] pci_bus 0000:00: root bus resource [mem 0xf0200000-0xf0ffffff] [ 17.299159] pci_bus 0000:00: root bus resource [mem 0x900000000-0x93fffffff pref] [ 17.299211] pci 0000:00:00.0: [1d87:3588] type 01 class 0x060400 [ 17.299251] pci 0000:00:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref] [ 17.299326] pci 0000:00:00.0: supports D1 D2 [ 17.299350] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [ 17.308621] mmc_host mmc1: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0) [ 17.310964] rk-pcie fe170000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.313985] pci_bus 0000:01: busn_res: can not insert [bus 01-ff] under [bus 00-0f] (conflicts with (null) [bus 00-0f]) [ 17.314101] pci 0000:01:00.0: [c0a9:5427] type 00 class 0x010802 [ 17.314199] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit] [ 17.314790] pci 0000:01:00.0: 31.504 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x4 link at 0000:00:00.0 (capable of 63.012 Gb/s with 16.0 GT/s PCIe x4 link) [ 17.325574] pci 0000:00:00.0: BAR 8: assigned [mem 0xf0200000-0xf02fffff] [ 17.325632] pci 0000:00:00.0: BAR 6: assigned [mem 0xf0300000-0xf030ffff pref] [ 17.325672] pci 0000:01:00.0: BAR 0: assigned [mem 0xf0200000-0xf0203fff 64bit] [ 17.325735] pci 0000:00:00.0: PCI bridge to [bus 01-ff] [ 17.325762] pci 0000:00:00.0: bridge window [mem 0xf0200000-0xf02fffff] [ 17.328988] pcieport 0000:00:00.0: PME: Signaling with IRQ 154 [ 17.329785] nvme nvme0: pci function 0000:01:00.0 [ 17.330019] nvme 0000:01:00.0: enabling device (0000 -> 0002) [ 17.332003] rk-pcie fe170000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.344648] usb 1-1: new high-speed USB device number 2 using xhci-hcd [ 17.353051] rk-pcie fe170000.pcie: PCIe Linking... LTSSM is 0x3 [ 17.359070] Initializing XFRM netlink socket [ 17.359119] NET: Registered PF_PACKET protocol family [ 17.359307] [BT_RFKILL]: Enter rfkill_rk_init [ 17.359314] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 17.359725] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ 17.359747] [WLAN_RFKILL]: can't find rockchip,grf property [ 17.359753] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6275p [ 17.359759] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ 17.359765] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [ 17.359810] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 8, flags = 0. [ 17.359820] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found ! [ 17.359826] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ 17.359832] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1 [ 17.359838] [WLAN_RFKILL]: Exit rfkill_wlan_probe [ 17.360248] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 148. [ 17.360275] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 21. [ 17.360295] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 150. [ 17.360314] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 0. [ 17.360354] [BT_RFKILL]: Request irq for bt wakeup host [ 17.360463] [BT_RFKILL]: ** disable irq [ 17.360553] [BT_RFKILL]: bt shut off power [ 17.385416] [BT_RFKILL]: bt_default device registered. [ 17.385611] input: bt-powerkey as /devices/platform/wireless-bluetooth/input/input8 [ 17.386104] Key type dns_resolver registered [ 17.386157] Key type ceph registered [ 17.386863] libceph: loaded (mon/osd proto 15/24) [ 17.389637] registered taskstats version 1 [ 17.389705] Loading compiled-in X.509 certificates [ 17.394797] zswap: loaded using pool zstd/zbud [ 17.395342] Key type .fscrypt registered [ 17.395370] Key type fscrypt-provisioning registered [ 17.396740] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no [ 17.397270] pstore: Using crash dump compression: deflate [ 17.397684] Key type encrypted registered [ 17.398082] AppArmor: AppArmor sha1 policy hashing enabled [ 17.409984] rga3 fdb60000.rga: Adding to iommu group 2 [ 17.410299] rga3 fdb60000.rga: probe successfully, irq = 50, hw_version:3.0.76831 [ 17.410378] rga3 fdb70000.rga: Adding to iommu group 3 [ 17.410591] rga3 fdb70000.rga: probe successfully, irq = 51, hw_version:3.0.76831 [ 17.411096] rga2 fdb80000.rga: probe successfully, irq = 157, hw_version:3.2.63318 [ 17.411197] rga: IOMMU binding successfully, default mapping core[0x1] [ 17.411307] rga: Module initialized. v1.3.7 [ 17.428976] mpp_vdpu1 fdb51000.avsd-plus: Adding to iommu group 1 [ 17.429491] mpp_vdpu1 fdb51000.avsd-plus: probe device [ 17.429863] mpp_vdpu1 fdb51000.avsd-plus: reset_group->rw_sem_on=0 [ 17.429904] mpp_vdpu1 fdb51000.avsd-plus: reset_group->rw_sem_on=0 [ 17.430015] mpp_vdpu1 fdb51000.avsd-plus: probing finish [ 17.430384] mpp_vdpu2 fdb50400.vdpu: Adding to iommu group 1 [ 17.430491] mpp_vdpu2 fdb50400.vdpu: probe device [ 17.430735] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0 [ 17.430765] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0 [ 17.430805] mpp_vdpu2 fdb50400.vdpu: probing finish [ 17.431113] mpp_vepu2 fdb50000.vepu: Adding to iommu group 1 [ 17.431216] mpp_vepu2 fdb50000.vepu: probing start [ 17.431487] mpp_vepu2 fdb50000.vepu: reset_group->rw_sem_on=0 [ 17.431517] mpp_vepu2 fdb50000.vepu: reset_group->rw_sem_on=0 [ 17.431585] mpp_vepu2 fdb50000.vepu: probing finish [ 17.431923] mpp_vepu2 fdba0000.jpege-core: Adding to iommu group 5 [ 17.432140] mpp_vepu2 fdba0000.jpege-core: probing start [ 17.432468] mpp_vepu2 fdba0000.jpege-core: attach ccu success [ 17.432541] mpp_vepu2 fdba0000.jpege-core: probing finish [ 17.432853] mpp_vepu2 fdba4000.jpege-core: Adding to iommu group 6 [ 17.433029] mpp_vepu2 fdba4000.jpege-core: probing start [ 17.433332] mpp_vepu2 fdba4000.jpege-core: attach ccu success [ 17.433403] mpp_vepu2 fdba4000.jpege-core: probing finish [ 17.433738] mpp_vepu2 fdba8000.jpege-core: Adding to iommu group 7 [ 17.433922] mpp_vepu2 fdba8000.jpege-core: probing start [ 17.434221] mpp_vepu2 fdba8000.jpege-core: attach ccu success [ 17.434292] mpp_vepu2 fdba8000.jpege-core: probing finish [ 17.434629] mpp_vepu2 fdbac000.jpege-core: Adding to iommu group 8 [ 17.434806] mpp_vepu2 fdbac000.jpege-core: probing start [ 17.435111] mpp_vepu2 fdbac000.jpege-core: attach ccu success [ 17.435182] mpp_vepu2 fdbac000.jpege-core: probing finish [ 17.435611] mpp-iep2 fdbb0000.iep: Adding to iommu group 9 [ 17.435804] mpp-iep2 fdbb0000.iep: probe device [ 17.436396] mpp-iep2 fdbb0000.iep: probing finish [ 17.436518] mpp_jpgdec fdb90000.jpegd: Adding to iommu group 4 [ 17.436635] mpp_jpgdec fdb90000.jpegd: probe device [ 17.436723] mpp_jpgdec fdb90000.jpegd: probing finish [ 17.436812] mpp_rkvdec2 fdc38100.rkvdec-core: Adding to iommu group 12 [ 17.436973] mpp_rkvdec2 fdc38100.rkvdec-core: rkvdec-core, probing start [ 17.437048] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found! [ 17.437054] rkvdec2_init:1198: No niu aclk reset resource define [ 17.437059] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found! [ 17.437063] rkvdec2_init:1201: No niu hclk reset resource define [ 17.437098] mpp_rkvdec2 fdc38100.rkvdec-core: no regulator, devfreq is disabled [ 17.437135] mpp_rkvdec2 fdc38100.rkvdec-core: core_mask=00010001 [ 17.437141] mpp_rkvdec2 fdc38100.rkvdec-core: attach ccu as core 0 [ 17.437256] mpp_rkvdec2 fdc38100.rkvdec-core: sram_start 0x00000000ff001000 [ 17.437262] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_iova 0x00000000fff00000 [ 17.437267] mpp_rkvdec2 fdc38100.rkvdec-core: sram_size 491520 [ 17.437271] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_size 1048576 [ 17.437277] mpp_rkvdec2 fdc38100.rkvdec-core: min_width 512 [ 17.437282] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_info_count 20 [ 17.437286] mpp_rkvdec2 fdc38100.rkvdec-core: [136, 24576] [ 17.437291] mpp_rkvdec2 fdc38100.rkvdec-core: [137, 49152] [ 17.437295] mpp_rkvdec2 fdc38100.rkvdec-core: [141, 90112] [ 17.437300] mpp_rkvdec2 fdc38100.rkvdec-core: [140, 49152] [ 17.437304] mpp_rkvdec2 fdc38100.rkvdec-core: [139, 180224] [ 17.437309] mpp_rkvdec2 fdc38100.rkvdec-core: [133, 49152] [ 17.437313] mpp_rkvdec2 fdc38100.rkvdec-core: [134, 8192] [ 17.437318] mpp_rkvdec2 fdc38100.rkvdec-core: [135, 4352] [ 17.437322] mpp_rkvdec2 fdc38100.rkvdec-core: [138, 13056] [ 17.437326] mpp_rkvdec2 fdc38100.rkvdec-core: [142, 291584] [ 17.437345] mpp_rkvdec2 fdc38100.rkvdec-core: probing finish [ 17.437433] mpp_rkvdec2 fdc48100.rkvdec-core: Adding to iommu group 13 [ 17.437563] mpp_rkvdec2 fdc48100.rkvdec-core: rkvdec-core, probing start [ 17.437635] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found! [ 17.437641] rkvdec2_init:1198: No niu aclk reset resource define [ 17.437645] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found! [ 17.437650] rkvdec2_init:1201: No niu hclk reset resource define [ 17.437671] mpp_rkvdec2 fdc48100.rkvdec-core: no regulator, devfreq is disabled [ 17.437699] mpp_rkvdec2 fdc48100.rkvdec-core: core_mask=00020002 [ 17.437715] mpp_rkvdec2 fdc48100.rkvdec-core: attach ccu as core 1 [ 17.437823] mpp_rkvdec2 fdc48100.rkvdec-core: sram_start 0x00000000ff079000 [ 17.437828] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_iova 0x00000000ffe00000 [ 17.437833] mpp_rkvdec2 fdc48100.rkvdec-core: sram_size 487424 [ 17.437838] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_size 1048576 [ 17.437843] mpp_rkvdec2 fdc48100.rkvdec-core: min_width 512 [ 17.437848] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_info_count 20 [ 17.437852] mpp_rkvdec2 fdc48100.rkvdec-core: [136, 24576] [ 17.437857] mpp_rkvdec2 fdc48100.rkvdec-core: [137, 49152] [ 17.437861] mpp_rkvdec2 fdc48100.rkvdec-core: [141, 90112] [ 17.437866] mpp_rkvdec2 fdc48100.rkvdec-core: [140, 49152] [ 17.437870] mpp_rkvdec2 fdc48100.rkvdec-core: [139, 180224] [ 17.437875] mpp_rkvdec2 fdc48100.rkvdec-core: [133, 49152] [ 17.437879] mpp_rkvdec2 fdc48100.rkvdec-core: [134, 8192] [ 17.437884] mpp_rkvdec2 fdc48100.rkvdec-core: [135, 4352] [ 17.437888] mpp_rkvdec2 fdc48100.rkvdec-core: [138, 13056] [ 17.437893] mpp_rkvdec2 fdc48100.rkvdec-core: [142, 291584] [ 17.437913] mpp_rkvdec2 fdc48100.rkvdec-core: probing finish [ 17.437998] mpp_rkvenc2 fdbd0000.rkvenc-core: Adding to iommu group 10 [ 17.438091] mpp_rkvenc2 fdbd0000.rkvenc-core: probing start [ 17.438188] mpp_rkvenc2 fdbd0000.rkvenc-core: rockchip_init_read_margin: no regulator (venc) found: -19 [ 17.438195] mpp_rkvenc2 fdbd0000.rkvenc-core: bin=0 [ 17.438380] mpp_rkvenc2 fdbd0000.rkvenc-core: leakage=11 [ 17.438386] mpp_rkvenc2 fdbd0000.rkvenc-core: leakage-volt-sel=0 [ 17.438418] mpp_rkvenc2 fdbd0000.rkvenc-core: error -ENODEV: _opp_set_regulators: no regulator (venc) found [ 17.438436] mpp_rkvenc2 fdbd0000.rkvenc-core: failed to set opp config [ 17.438441] mpp_rkvenc2 fdbd0000.rkvenc-core: failed to init opp info [ 17.438445] mpp_rkvenc2 fdbd0000.rkvenc-core: failed to init_opp_table [ 17.438449] rkvenc_init:2147: failed to add venc devfreq [ 17.438469] mpp_rkvenc2 fdbd0000.rkvenc-core: attach ccu as core 0 [ 17.438487] mpp_rkvenc2 fdbd0000.rkvenc-core: probing finish [ 17.438567] mpp_rkvenc2 fdbe0000.rkvenc-core: Adding to iommu group 11 [ 17.438667] mpp_rkvenc2 fdbe0000.rkvenc-core: probing start [ 17.438753] mpp_rkvenc2 fdbe0000.rkvenc-core: rockchip_init_read_margin: no regulator (venc) found: -19 [ 17.438759] mpp_rkvenc2 fdbe0000.rkvenc-core: bin=0 [ 17.438929] mpp_rkvenc2 fdbe0000.rkvenc-core: leakage=11 [ 17.438934] mpp_rkvenc2 fdbe0000.rkvenc-core: leakage-volt-sel=0 [ 17.438958] mpp_rkvenc2 fdbe0000.rkvenc-core: error -ENODEV: _opp_set_regulators: no regulator (venc) found [ 17.438970] mpp_rkvenc2 fdbe0000.rkvenc-core: failed to set opp config [ 17.438975] mpp_rkvenc2 fdbe0000.rkvenc-core: failed to init opp info [ 17.438979] mpp_rkvenc2 fdbe0000.rkvenc-core: failed to init_opp_table [ 17.438983] rkvenc_init:2147: failed to add venc devfreq [ 17.439020] mpp_rkvenc2 fdbe0000.rkvenc-core: attach ccu as core 1 [ 17.439036] mpp_rkvenc2 fdbe0000.rkvenc-core: probing finish [ 17.439120] mpp_av1dec fdc70000.av1d: Adding to iommu group 14 [ 17.439256] mpp_av1dec fdc70000.av1d: probing start [ 17.439352] mpp_av1dec fdc70000.av1d: probing finish [ 17.439820] rockchip-dmc dmc: bin=0 [ 17.439992] rockchip-dmc dmc: leakage=35 [ 17.439999] rockchip-dmc dmc: leakage-volt-sel=1 [ 17.440006] rockchip-dmc dmc: soc version=0, speed=1 [ 17.440182] mali fb000000.gpu: Kernel DDK version g25p0-00eac0 [ 17.440238] mali fb000000.gpu: GPU metrics tracepoint support enabled [ 17.444985] mali fb000000.gpu: bin=0 [ 17.445158] mali fb000000.gpu: leakage=14 [ 17.445178] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present! [ 17.445636] rockchip-dmc dmc: avs=0 [ 17.445651] rockchip-dmc dmc: current ATF version 0x100 [ 17.445812] rockchip-dmc dmc: normal_rate = 1560000000 [ 17.445819] rockchip-dmc dmc: reboot_rate = 2112000000 [ 17.445825] rockchip-dmc dmc: suspend_rate = 528000000 [ 17.445830] rockchip-dmc dmc: video_4k_rate = 1560000000 [ 17.445836] rockchip-dmc dmc: video_4k_10b_rate = 1560000000 [ 17.445841] rockchip-dmc dmc: video_svep_rate = 1560000000 [ 17.445847] rockchip-dmc dmc: boost_rate = 2112000000 [ 17.445852] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 2112000000 [ 17.445858] rockchip-dmc dmc: performance_rate = 2112000000 [ 17.445864] rockchip-dmc dmc: hdmirx_rate = 2112000000 [ 17.445870] rockchip-dmc dmc: deep_suspend_rate = 2112000000 [ 17.445877] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate [ 17.445883] rockchip-dmc dmc: failed to get vop pn to msch rl [ 17.446111] rockchip-dmc dmc: l=15000 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0 [ 17.446164] dwmmc_rockchip fe2c0000.mmc: Successfully tuned phase to 235 [ 17.446197] mmc1: new ultra high speed SDR104 SDHC card at address aaaa [ 17.446645] mmcblk1: mmc1:aaaa SC16G 14.8 GiB [ 17.450278] mali fb000000.gpu: pvtm=816 [ 17.452503] GPT:Primary header thinks Alt. header is not at the end of the disk. [ 17.452589] GPT:3235839 != 31116287 [ 17.452602] GPT:Alternate GPT header not at the end of the disk. [ 17.452616] GPT:3235839 != 31116287 [ 17.452627] GPT: Use GNU Parted to correct GPT errors. [ 17.452653] mmcblk1: p1 [ 17.456624] mali fb000000.gpu: pvtm-volt-sel=1 [ 17.456736] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present! [ 17.458413] mali fb000000.gpu: avs=0 [ 17.458521] mali fb000000.gpu: rockchip_pvtpll_set_volt_sel: error cfg clk_id=5 voltsel (-1) [ 17.458566] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 144; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available. [ 17.459429] WCN: marlin_init entry! [ 17.459488] mali fb000000.gpu: Register LUT 000a0800 initialized for GPU arch 0x000a0806 [ 17.459541] mali fb000000.gpu: r0p0 status 5 not found in HW issues table; [ 17.459562] mali fb000000.gpu: falling back to closest match: r0p0 status 0 [ 17.459580] mali fb000000.gpu: Execution proceeding normally with fallback match [ 17.459599] mali fb000000.gpu: GPU identified as 0x7 arch 10.8.6 r0p0 status 0 [ 17.459714] mali fb000000.gpu: CSF_GPU_RESET_TIMEOUT is capped from 20666ms to 4500ms [ 17.459739] mali fb000000.gpu: KBASE_PRFCNT_ACTIVE_TIMEOUT is capped from 40000ms to 4500ms [ 17.459760] mali fb000000.gpu: KBASE_AS_INACTIVE_TIMEOUT is capped from 40000ms to 4500ms [ 17.459780] mali fb000000.gpu: CSF_FIRMWARE_STOP_TIMEOUT is capped from 40000ms to 4500ms [ 17.459854] mali fb000000.gpu: No priority control manager is configured [ 17.459873] mali fb000000.gpu: Large page allocation set to false after hardware feature check [ 17.460184] mali fb000000.gpu: No memory group manager is configured [ 17.460228] mali fb000000.gpu: Protected memory allocator not available [ 17.460761] RKNPU fdab0000.npu: Adding to iommu group 0 [ 17.460982] RKNPU fdab0000.npu: RKNPU: rknpu iommu is enabled, using iommu mode [ 17.462436] mali fb000000.gpu: EM: created perf domain [ 17.462637] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff] [ 17.462672] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff] [ 17.462696] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff] [ 17.462789] mali fb000000.gpu: l=15000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0 [ 17.463410] [drm] Initialized rknpu 0.9.8 20240828 for fdab0000.npu on minor 1 [ 17.464159] mali fb000000.gpu: * MALI kbase_mmap_min_addr compiled to CONFIG_DEFAULT_MMAP_MIN_ADDR, no runtime update possible! * [ 17.464179] mali fb000000.gpu: Probed as mali0 [ 17.464915] hwmon hwmon8: temp1_input not attached to any thermal zone [ 17.465049] hwmon hwmon8: temp2_input not attached to any thermal zone [ 17.466216] RKNPU fdab0000.npu: RKNPU: bin=0 [ 17.466426] RKNPU fdab0000.npu: leakage=8 [ 17.466468] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present! [ 17.474051] RKNPU fdab0000.npu: pvtm=814 [ 17.475374] nvme nvme0: allocated 64 MiB host memory buffer. [ 17.479475] RKNPU fdab0000.npu: pvtm-volt-sel=0 [ 17.479591] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present! [ 17.482014] RKNPU fdab0000.npu: avs=0 [ 17.482107] RKNPU fdab0000.npu: rockchip_pvtpll_set_volt_sel: error cfg clk_id=6 voltsel (-1) [ 17.482283] RKNPU fdab0000.npu: l=15000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0 [ 17.489359] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.91 [ 17.489411] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 17.489441] usb 1-1: Product: USB2.1 Hub [ 17.489465] usb 1-1: Manufacturer: GenesysLogic [ 17.496617] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 17.518220] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 17.519182] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600' [ 17.520164] clk: Disabling unused clocks [ 17.521790] rockchip-pm rockchip-suspend: not set pwm-regulator-config [ 17.522587] rockchip-suspend not set sleep-mode-config for mem-lite [ 17.522615] rockchip-suspend not set wakeup-config for mem-lite [ 17.522644] rockchip-suspend not set sleep-mode-config for mem-ultra [ 17.522668] rockchip-suspend not set wakeup-config for mem-ultra [ 17.525353] ALSA device list: [ 17.525379] #0: rockchip-dp0 [ 17.525400] #1: rockchip-hdmi0 [ 17.525419] #2: rockchip-hdmi1 [ 17.525438] #3: rockchip-es8388 [ 17.534502] hub 1-1:1.0: USB hub found [ 17.534766] hub 1-1:1.0: 4 ports detected [ 17.596619] nvme nvme0: 8/0/0 default/read/poll queues [ 17.609378] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd [ 17.631903] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.91 [ 17.631965] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 17.632029] usb 2-1: Product: USB3.2 Hub [ 17.632054] usb 2-1: Manufacturer: GenesysLogic [ 17.660964] Freeing unused kernel memory: 8320K [ 17.661384] Run /init as init process [ 17.663401] hub 2-1:1.0: USB hub found [ 17.664091] hub 2-1:1.0: 4 ports detected [ 17.993319] input: adc-keys as /devices/platform/adc-keys/input/input9 [ 18.004482] rockchip-cpuinfo cpuinfo: SoC : 35881000 [ 18.004516] rockchip-cpuinfo cpuinfo: Serial : 9f77ef415554aece DDR V1.13 25cee80c4f cym 23/08/11-09:31:58 LPDDR4X, 2112MHz channel[0] BW=16 Col=10 Bk=8 CS0 Row=18 CS1 Row=18 CS=2 Die BW=8 Size=8192MB channel[1] BW=16 Col=10 Bk=8 CS0 Row=18 CS1 Row=18 CS=2 Die BW=8 Size=8192MB channel[2] BW=16 Col=10 Bk=8 CS0 Row=18 CS1 Row=18 CS=2 Die BW=8 Size=8192MB channel[3] BW=16 Col=10 Bk=8 CS0 Row=18 CS1 Row=18 CS=2 Die BW=8 Size=8192MB Manufacturer ID:0xff CH0 RX Vref:28.9%, TX Vref:22.8%,21.8% CH1 RX Vref:26.7%, TX Vref:21.8%,20.8% CH2 RX Vref:28.9%, TX Vref:20.8%,20.8% CH3 RX Vref:28.5%, TX Vref:20.8%,20.8% change to F1: 528MHz change to F2: 1068MHz change to F3: 1560MHz change to F0: 2112MHz out U-Boot SPL board init U-Boot SPL 2017.09-orangepi (Nov 15 2023 - 16:53:25) Trying to boot from MMC1 Trying fit image at 0x4000 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(7612223b82...) + OK ## Checking uboot 0x00200000 ... sha256(d41c62e80b...) + OK ## Checking fdt 0x00355940 ... sha256(7146109403...) + OK ## Checking atf-2 0xff100000 ... sha256(70505bb764...) + OK ## Checking atf-3 0x000f0000 ... sha256(b2af21b504...) + OK Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000) Total: 741.283 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-868-g040d2de11:derrick.huang, fwver: v1.48 NOTICE: BL31: Built : 15:02:44, Dec 19 2024 INFO: spec: 0x1 INFO: code: 0x88 INFO: ext 32k is valid INFO: ddr: stride-en 4CH INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0 INFO: l3 cache partition cfg-0 INFO: system boots from cpu-hwid-0 INFO: disable memory repair INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001 INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz INFO: BL31: Initialising Exception Handling Framework INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 usb dr_mode not found usb dr_mode not found U-Boot 2017.09_armbian-2017.09-S3f41-Pdfdd-H6539-Ve691-Bbf55-R448a (Nov 19 2025 - 17:07:00 +0000) Model: Orange Pi 5 Plus MPIDR: 0x0 PreSerial: 2, raw, 0xfeb50000 DRAM: 31.7 GiB Sysmem: init Relocation Offset: eda09000 Relocation fdt: eb9f7610 - eb9fecd0 CR: M/C/I usb dr_mode not found usb dr_mode not found Using default environment DM: v2 RESC: No bootdev Failed to load DTB, ret=-2 No valid DTB, ret=-22 Failed to get kernel dtb, ret=-22 Model: Orange Pi 5 Plus [Vendor ERROR]:Invalid boot device type(0) ## Error: Can't overwrite "ethaddr" ## Error inserting "ethaddr" variable, errno=1 ## Error: Can't overwrite "eth1addr" ## Error inserting "eth1addr" variable, errno=1 [Vendor ERROR]:Invalid boot device type(0) rockchip_set_ethaddr: vendor_storage_write failed -19 [Vendor ERROR]:Invalid boot device type(0) mmc@fe2c0000: 1, mmc@fe2e0000: 0 Card did not respond to voltage select! mmc_init: -95, time 13 switch to partitions #0, OK mmc1 is current device Boot from SDcard Bootdev(scan): mmc 1 No bootdev dev_desc is NULL! boot mode: None No bootdev CLK: (sync kernel. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A) b0pll 24000 KHz b1pll 24000 KHz lpll 24000 KHz v0pll 24000 KHz aupll 24000 KHz cpll 1500000 KHz gpll 1188000 KHz npll 24000 KHz ppll 1100000 KHz aclk_center_root 702000 KHz pclk_center_root 100000 KHz hclk_center_root 396000 KHz aclk_center_low_root 500000 KHz aclk_top_root 750000 KHz pclk_top_root 100000 KHz aclk_low_top_root 396000 KHz MMC1: Legacy, 52Mhz PartType: EFI No bootdev dev_desc is NULL! No bootdev Net: No ethernet found. Hit key to stop autoboot('CTRL+C'): 0 starting USB... Bus usb@fc000000: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus usb@fc800000: USB EHCI 1.00 Bus usb@fc840000: USB OHCI 1.0 Bus usb@fc880000: USB EHCI 1.00 Bus usb@fc8c0000: USB OHCI 1.0 Bus usb@fc400000: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fc000000 for devices... 1 USB Device(s) found scanning bus usb@fc800000 for devices... 1 USB Device(s) found scanning bus usb@fc840000 for devices... 1 USB Device(s) found scanning bus usb@fc880000 for devices... 1 USB Device(s) found scanning bus usb@fc8c0000 for devices... 1 USB Device(s) found scanning bus usb@fc400000 for devices... cannot reset port 1!? 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found ............. and so on 0 Quote
Werner Posted March 8 Posted March 8 Related to Again, you are using the wrong image. You cannot assume an image for the opi5+ works for the opi5b. Those are different boards. 0 Quote
Jean-Marc Posted March 12 Author Posted March 12 Thanks for your reply. Sorry for the bad identification of my SBC, (i have many ). The board is this one : https://www.armbian.com/orange-pi-5-plus/ Therefore, it seems that my bug report is relevant 0 Quote
