mitu Posted March 15 Posted March 15 (edited) Hello, I have installed the minimal Trixie based image for Orange Pi5 (the image named Armbian_26.2.1_Orangepi5_trixie_current_6.18.8_minimal) and then attempted to build an out-of-tree kernel module. Having installed dkms and build-essentials, plus the kernel headers through armbian-config, I found the headers package hasn't been fully set-up, the build symlink in /lib/modules/<KVER> is missing and dkms complains that the kernel headers for the kernel are not installed. The kernel headers are installed though, but it looks like they're from a previous release (25.11.2 instead of 26.2.1). # dpkg -l | grep rockchip ii linux-dtb-current-rockchip64 26.2.1 arm64 Armbian Linux current DTBs in /boot/dtb-6.18.8-current-rockchip64 ii linux-headers-current-rockchip64 25.11.2 arm64 Armbian Linux current headers 6.12.58-current-rockchip64 ii linux-image-current-rockchip64 26.2.1 arm64 Armbian Linux current kernel image 6.18.8-current-rockchip64 It the headers package still pending packaging ? Shouldn't armbian-config provide an error in this case and not install the old kernel headers ? EDIT: armbianmonitor ouput - https://paste.armbian.com/oliyalebeq Edited March 15 by mitu 0 Quote
Solution Werner Posted March 15 Solution Posted March 15 Yes, they seem to be missing in repo. As a quick fix I'd suggest to use the build framework to create yourself a set of deb files containing all necessary packages ./compile.sh BOARD=orangepi5 BRANCH=current kernel copy the packages from output/debs to your board and use dpkg to install them. 0 Quote
mitu Posted March 15 Author Posted March 15 (edited) If I'm building the .deb file manually, is there a way to build with kernel 6.19 for the OrangePi5 ? Can I use the edge branch (instead of current) for this ? While I don't mind waiting for the package to build, if I can build the bsp/kernel/headers for 6.19 I can give it a try. EDITED for formatting. Edited March 15 by mitu 0 Quote
Werner Posted March 15 Posted March 15 No. edge will give you 7.0-rc3 since it was bumped recently. You can try to revert this commit to get 6.19. No guarantee it works, nor any support will be given. https://github.com/armbian/build/pull/9445 0 Quote
mitu Posted March 15 Author Posted March 15 Eh, I can try the 7.0 rc package and see how they behave, as long as it's 6.19 or later is fine. Thanks for the pointers. 0 Quote
mitu Posted March 15 Author Posted March 15 OK, so that went reasonably fast and produced the 4 kernel debs. The linux-libc-dev-edge-rockchip64 didn't install due to conflict with the (current/stable) linux-libc-dev package - I think this is expected - but the rest of the kernel packages have been succesfully installed and the dkms error seems resolved. 0 Quote
