BipBip1981 Posted yesterday at 07:08 PM Posted yesterday at 07:08 PM (edited) Hi everybody, I running Helios64 with kernel 6.12.58 since a long time and the prahal dtb file rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp and my helios64 work well. Today, Armbian upgrade to 6.18.10 kernel. Is this update use the same change or patch like in rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp ? Is rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp work with 6..18.10 kernel ? Is I must to downgrade to 6.12.58 kernel with rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp and freeze at this kernel version ? Thanks for answer. Edited yesterday at 07:35 PM by BipBip1981 0 Quote
BipBip1981 Posted yesterday at 07:26 PM Author Posted yesterday at 07:26 PM (edited) For information: First reboot and crash same that before use rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp. 😞 Back to 6.12.58, rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp and freeze to this setting Me and my brother have helios64 with 6.18.10 Kernel : RAID 10 / LVM / LUKS and crash always when "cryptsetup open..." start Crash when many I/O Crash when use Full CPUs With rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp and Kernel 6.12.58 or 6.12.(XX below): Me, never crash but I reboot often and power off often for personal choice. My brother have uptime upper than 100 or 200 days with problem, freeze or crash Bye Edited yesterday at 08:39 PM by BipBip1981 0 Quote
crosser Posted yesterday at 09:21 PM Posted yesterday at 09:21 PM FWIW, I am running -edge kernel from armbian with respective dtb (linux-dtb-edge-rockchip64 package), and it's quite stable. vmlinuz-6.18.0-rc6-edge-rockchip64 dtb-6.18.0-rc6-edge-rockchip64 🤞 0 Quote
BipBip1981 Posted 1 hour ago Author Posted 1 hour ago (edited) Hello, I hope you don't have any problem. Maybe me and my brother have defective or more unstable helios64 than you. Only thing I can say that Prahal share here the specifics files rk3399-kobol-helios64.dtb-6.XX.xx-L2-hs400-opp in this forum since two years ago my helios64 and my brother's helios64 work stable only with it. I back to 6.12.58 Kernel with rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp file and freeze firmware/kernel with armbian-config. Edited 1 hour ago by BipBip1981 0 Quote
