ValdasRK Posted June 8, 2015 Posted June 8, 2015 Hello, All I'm trying to compile the ftdi_sio module using suggestions from http://www.cyberciti.biz/tips/build-linux-kernel-module-against-installed-kernel-source-tree.html. I got the message: fatal error: asm/linkage.h: No such file or directory I added following lines to the standard Makefile from http://www.ftdichip.com/Drivers/VCP/Linux/ftdi_sio.tar.gz: CFLAGS += -I$(shell echo "/usr/src/linux-headers-`uname -r`/arch/arm/include") CFLAGS += -I$(shell echo "/usr/src/linux-headers-`uname -r`/arch/arm/include/generated") but now I got the message: fatal error: mach/irqs.h: No such file or directory when I trying to find the file missing find /usr/ -type f -name "irqs.h" I get to many results. My second approach is to follow http://stackoverflow.com/questions/21239505/compile-ftdi-kernel-module but when I type root@micro:/usr/src/linux# make menuconfig I get the message fatal error: curses.h: No such file or directory So I need instructions how to build ftdi_sio module on Linux micro 4.0.4-lime #10 SMP Fri May 22 06:53:33 CEST 2015 armv7l GNU/Linux Any help, please!
Igor Posted June 13, 2015 Posted June 13, 2015 Try this way: 1. Download latest kernel, you can use the one from Cubietruck: http://mirror.igorpecovnik.com/kernel/4.0.5-cubietruck-next.tar 2. Install image, headers and libc 3. Go to /usr/src/linux-headers-4.0.5-cubietruck 4. make headers_check; make headers_install ; make scripts Than try to compile again and try also to compile just some driver.
ValdasRK Posted June 17, 2015 Author Posted June 17, 2015 Stopped on step 4, with `make scripts` error: HOSTCC scripts/sortextable scripts/sortextable.c:31:32: fatal error: tools/be_byteshift.h: No such file or directory #include <tools/be_byteshift.h> ^ compilation terminated. scripts/Makefile.host:91: recipe for target 'scripts/sortextable' failed make[1]: *** [scripts/sortextable] Error 1 Makefile:557: recipe for target 'scripts' failed make: *** [scripts] Error 2 Then, I commented following lines in /usr/src/linux-headers-4.0.5-cubietruck/scripts/Makefile: # hostprogs-$(CONFIG_BUILDTIME_EXTABLE_SORT) += sortextable # HOSTCFLAGS_sortextable.o = -I$(srctree)/tools/include After that, `make scripts` finished without any error.But that result is zero worth, because original FTDI drivers ver 1.5.0 is not ready for new kernels, I think.At that point, I can to continue with compiling internal FTDI driver from full kernel sources, but I can't get sources for may kernel version 4.0.4: apt-cache show linux-source Package: linux-source Source: linux-latest (63) Version: 3.16+63 I tried to compile the kernel 4.0.5 sources from kernel.org. This took more than 3 hours, but finished successfully.
ValdasRK Posted June 18, 2015 Author Posted June 18, 2015 I can't to continue with 4.0.4 and 4.0.5, because grep USB_SERIAL config-4.0.4-lime # CONFIG_USB_SERIAL is not set grep USB_SERIAL config-4.0.5-cubietruck # CONFIG_USB_SERIAL is not set and after editing the ./config file, I got: /usr/src/linux-headers-4.0.5-cubietruck# make modules CHK include/config/kernel.release CHK include/generated/uapi/linux/version.h CHK include/generated/utsrelease.h make[1]: *** No rule to make target 'arch/arm/tools/gen-mach-types', needed by 'include/generated/mach-types.h'. Stop. arch/arm/Makefile:297: recipe for target 'archprepare' failed make: *** [archprepare] Error 2 Can I use kernel 4.0.5 from kernel.org with my Olimex micro? Because I can compile it on-board.I need CLI (headless), libboost and USB serial in my project.
ValdasRK Posted June 19, 2015 Author Posted June 19, 2015 I'm trying to answer my questions by myself.But I got wrong architecture after compiling sources from kernel.org: dpkg-deb: building package `linux-headers-4.0.5' in `../linux-headers-4.0.5_4.0.5-3_armel.deb'. dpkg-deb: building package `linux-libc-dev' in `../linux-libc-dev_4.0.5-3_armel.deb'. dpkg-deb: building package `linux-image-4.0.5' in `../linux-image-4.0.5_4.0.5-3_armel.deb'. dpkg -i linux-headers-4.0.5_4.0.5-3_armel.deb dpkg: error processing archive linux-headers-4.0.5_4.0.5-3_armel.deb (--install): package architecture (armel) does not match system (armhf) I still need help.
Igor Posted June 19, 2015 Posted June 19, 2015 Use this kernel. FTDI should work: http://mirror.igorpecovnik.com/kernel/4.0.5-lamobo-r1-next.tar But I got wrong architecture after compiling sources from kernel.org: Because you need to define this in the compilation process - make ARCH=arm or whatever target. Kernel compilation is / can be a nightmare ... I made a script to minimize risk, to simplify process, to save time but even if you fully stick to defaults, problems might occur. If you want do compile in any other but theoretically proper environment, native included, it might fail
ValdasRK Posted June 22, 2015 Author Posted June 22, 2015 I don't found the way to build modules on-board. I started to use the Emdebian tool-chain on Debian machine, like described in https://romanrm.net/a10/cross-compile-kernel. Now, I can run Your script. Thank You, Igor, very much for that!I can switch on/off internal modules with this script. I'm waiting now to include the Oduino XU3 and Cubieboard4 to the list of supported boards.
